path: root/drivers/gpu
2013-06-07drm/radeon: fix card_posted check for newer asicsAlex Deucher
commit 09fb8bd1a63b0f9f15e655c4fe8d047e5d2bf67a upstream. Newer asics have variable numbers of crtcs. Use that rather than the asic family to determine which crtcs to check. This avoids checking non-existent crtcs or missing crtcs on certain asics. Reviewed-by: Michel Dänzer <michel.daenzer@amd.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-24drm/radeon: Fix VRAM size calculation for VRAM >= 4GBNiels Ole Salscheider
commit fc986034540102cd090237bf3f70262e1ae80d9c upstream. Add ULL prefix to avoid overflow. Signed-off-by: Niels Ole Salscheider <niels_ole@salscheider-online.de> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19drm/radeon: check incoming cliprects pointerKees Cook
commit fefaedcfb82d2e57c2320acf60604ab03b750cc0 upstream. The "boxes" parameter points into userspace memory. It should be verified like any other operation against user memory. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19drm/mm: fix dump table BUGDaniel Vetter
commit 3a359f0b21ab218c1bf7a6a1b638b6fd143d0b99 upstream. In commit 9e8944ab564f2e3dde90a518cd32048c58918608 Author: Chris Wilson <chris@chris-wilson.co.uk> Date: Thu Nov 15 11:32:17 2012 +0000 drm: Introduce an iterator over holes in the drm_mm range manager helpers and iterators for hole handling have been introduced with some debug BUG_ONs sprinkled over. Unfortunately this broke the mm dumper which unconditionally tried to compute the size of the very first hole. While at it unify the code a bit with the hole dumping in the loop. v2: Extract a hole dump helper. Reported-by: Christopher Harvey <charvey@matrox.com> Cc: Christopher Harvey <charvey@matrox.com> Cc: Dave Airlie <airlied@redhat.com> Cc: Chris Wilson <chris@chris-wilson.co.uk> Acked-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/radeon: fix handling of v6 power tablesAlex Deucher
commit 441e76ca83ac604eaf0f046def96d8e3a27eea28 upstream. The code was mis-handling variable sized arrays. Reported-by: Sylvain BERTRAND <sylware@legeek.net> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/radeon: add new richland pci idsAlex Deucher
commit 62d1f92e06aef9665d71ca7e986b3047ecf0b3c7 upstream. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/radeon: fix possible segfault when parsing pm tablesAlex Deucher
commit f8e6bfc2ce162855fa4f9822a45659f4b542c960 upstream. If we have a empty power table, bail early and allocate the default power state. Should fix: https://bugs.freedesktop.org/show_bug.cgi?id=63865 Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/radeon: fix endian bugs in atom_allocate_fb_scratch()Alex Deucher
commit beb71fc61c2cad64e347f164991b8ef476529e64 upstream. Reviwed-by: Michel Dänzer <michel.daenzer@amd.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/radeon/evergreen+: don't enable HPD interrupts on eDP/LVDSAlex Deucher
commit 2e97be73e5f74a317232740ae82eb8f95326a660 upstream. Avoids potential interrupt storms when the display is disabled. May fix: https://bugzilla.kernel.org/show_bug.cgi?id=56041 Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/radeon: disable the crtcs in mc_stop (evergreen+) (v2)Alex Deucher
commit abf1457bbbe4c62066bd03c6d31837dea28644dc upstream. Just disabling the mem requests should be enough, but that doesn't seem to work correctly on efi systems. May fix: https://bugs.freedesktop.org/show_bug.cgi?id=57567 https://bugs.freedesktop.org/show_bug.cgi?id=43655 https://bugzilla.kernel.org/show_bug.cgi?id=56441 v2: blank displays first, then disable. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/radeon: properly lock disp in mc_stop/resume for evergreen+Alex Deucher
commit 968c01664ccbe0e46c19a1af662c4c266a904203 upstream. Need to wait for the new addresses to take affect before re-enabling the MC. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/radeon/dce6: add missing display reg for tiling setupAlex Deucher
commit 7c1c7c18fc752b2a1d07597286467ef186312463 upstream. A new tiling config register for the display blocks was added on DCE6. May fix: https://bugs.freedesktop.org/show_bug.cgi?id=62889 https://bugs.freedesktop.org/show_bug.cgi?id=57919 Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/radeon: don't use get_engine_clock() on APUsAlex Deucher
commit bf05d9985111f85ed6922c134567b96eb789283b upstream. It doesn't work reliably. Just report back the currently selected engine clock. Partially fixes: https://bugs.freedesktop.org/show_bug.cgi?id=62493 Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/i915: Fall back to bit banging mode for DVO transmitter detectionDavid Müller
commit e4bfff54ed3f5de88f5358504c78c2cb037813aa upstream. As discussed in this thread http://lists.freedesktop.org/archives/dri-devel/2013-April/037411.html GMBUS based DVO transmitter detection seems to be unreliable which could result in an unusable DVO port. The attached patch fixes this by falling back to bit banging mode for the time DVO transmitter detection is in progress. Signed-off-by: David Müller <d.mueller@elsoft.ch> Tested-by: David Müller <d.mueller@elsoft.ch> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/i915: Add no-lvds quirk for Fujitsu Esprimo Q900Christian Lamparter
commit 9e9dd0e889c76c786e8f2e164c825c3c06dea30c upstream. The "Mobile Sandy Bridge CPUs" in the Fujitsu Esprimo Q900 mini desktop PCs are probably misleading the LVDS detection code in intel_lvds_supported. Nothing is connected to the LVDS ports in these systems. Signed-off-by: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-25fbcon: fix locking harderDave Airlie
commit 054430e773c9a1e26f38e30156eff02dedfffc17 upstream. Okay so Alan's patch handled the case where there was no registered fbcon, however the other path entered in set_con2fb_map pit. In there we called fbcon_takeover, but we also took the console lock in a couple of places. So push the console lock out to the callers of set_con2fb_map, this means fbmem and switcheroo needed to take the lock around the fb notifier entry points that lead to this. This should fix the efifb regression seen by Maarten. Tested-by: Maarten Lankhorst <maarten.lankhorst@canonical.com> Tested-by: Lu Hua <huax.lu@intel.com> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-16udl: handle EDID failure properly.Dave Airlie
commit 1baee58638fc58248625255f5c5fcdb987f11b1f upstream. Don't oops seems proper. Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-16drm/i915: Use the correct size of the GTT for placing the per-process entriesChris Wilson
commit 9a0f938bde74bf9e50bd75c8de9e38c1787398cd upstream. The current layout is to place the per-process tables at the end of the GTT. However, this is currently using a hardcoded maximum size for the GTT and not taking in account limitations imposed by the BIOS. Use the value for the total number of entries allocated in the table as provided by the configuration registers. Reported-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: Daniel Vetter <daniel.vetter@ffwll.ch> Cc: Ben Widawsky <ben@bwidawsk.net> Cc: Matthew Garret <mjg@redhat.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Cc: Jonathan Nieder <jrnieder@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-05drm/i915: Don't clobber crtc->fb when queue_flip failsVille Syrjälä
commit 4a35f83b2b7c6aae3fc0d1c4554fdc99dc33ad07 upstream. Restore crtc->fb to the old framebuffer if queue_flip fails. While at it, kill the pointless intel_fb temp variable. v2: Update crtc->fb before queue_flip and restore it back after a failure. Backported for 3.4-stable. Adjusted context only. Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Reported-and-Tested-by: Mika Kuoppala <mika.kuoppala@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Lingzhu Xiang <lxiang@redhat.com> Reviewed-by: CAI Qian <caiqian@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-28i915: initialize CADL in opregionLekensteyn
commit d627b62ff8d4d36761adbcd90ff143d79c94ab22 upstream. This is rather a hack to fix brightness hotkeys on a Clevo laptop. CADL is not used anywhere in the driver code at the moment, but it could be used in BIOS as is the case with the Clevo laptop. The Clevo B7130 requires the CADL field to contain at least the ID of the LCD device. If this field is empty, the ACPI methods that are called on pressing brightness / display switching hotkeys will not trigger a notification. As a result, it appears as no hotkey has been pressed. Reference: https://bugs.freedesktop.org/show_bug.cgi?id=45452 Tested-by: Peter Wu <lekensteyn@gmail.com> Signed-off-by: Peter Wu <lekensteyn@gmail.com> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Cc: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-28drm/radeon/benchmark: make sure bo blit copy exists before using itAlex Deucher
commit fa8d387dc3f62062a6b4afbbb2a3438094fd8584 upstream. Fixes a segfault on asics without a blit callback. Fixes: https://bugs.freedesktop.org/show_bug.cgi?id=62239 Reviewed-by: Michel Dänzer <michel.daenzer@amd.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-28drm/radeon: add support for Richland APUsAlex Deucher
commit e4d170633fde379f39a90f8a5e7eb619b5d1144d upstream. Richland APUs are a new version of the Trinity APUs with performance and power management improvements. Reviewed-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-28KMS: fix EDID detailed timing frame rateTorsten Duwe
commit c19b3b0f6eed552952845e4ad908dba2113d67b4 upstream. When KMS has parsed an EDID "detailed timing", it leaves the frame rate zeroed. Consecutive (debug-) output of that mode thus yields 0 for vsync. This simple fix also speeds up future invocations of drm_mode_vrefresh(). While it is debatable whether this qualifies as a -stable fix I'd apply it for consistency's sake; drm_helper_probe_single_connector_modes() does the same thing already for all probed modes. Signed-off-by: Torsten Duwe <duwe@lst.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-28KMS: fix EDID detailed timing vsync parsingTorsten Duwe
commit 16dad1d743d31a104a849c8944e6b9eb479f6cd7 upstream. EDID spreads some values across multiple bytes; bit-fiddling is needed to retrieve these. The current code to parse "detailed timings" has a cut&paste error that results in a vsync offset of at most 15 lines instead of 63. See http://en.wikipedia.org/wiki/EDID and in the "EDID Detailed Timing Descriptor" see bytes 10+11 show why that needs to be a left shift. Signed-off-by: Torsten Duwe <duwe@lst.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-28drm/i915: bounds check execbuffer relocation countKees Cook
commit 3118a4f652c7b12c752f3222af0447008f9b2368 upstream. It is possible to wrap the counter used to allocate the buffer for relocation copies. This could lead to heap writing overflows. CVE-2013-0913 v3: collapse test, improve comment v2: move check into validate_exec_list Signed-off-by: Kees Cook <keescook@chromium.org> Reported-by: Pinkie Pie Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-28drm/i915: restrict kernel address leak in debugfsKees Cook
commit 2563a4524febe8f4a98e717e02436d1aaf672aa2 upstream. Masks kernel address info-leak in object dumps with the %pK suffix, so they cannot be used to target kernel memory corruption attacks if the kptr_restrict sysctl is set. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-20drm/i915: Increase the RC6p threshold.Stéphane Marchesin
commit 0920a48719f1ceefc909387a64f97563848c7854 upstream. This increases GEN6_RC6p_THRESHOLD from 100000 to 150000. For some reason this avoids the gen6_gt_check_fifodbg.isra warnings and associated GPU lockups, which makes my ivy bridge machine stable. Signed-off-by: Stéphane Marchesin <marcheu@chromium.org> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-20drm/i915: EBUSY status handling added to i915_gem_fault().Dmitry Rogozhkin
commit e79e0fe380847493266fba557217e2773c61bd1b upstream. Subsequent threads returning EBUSY from vm_insert_pfn() was not handled correctly. As a result concurrent access from new threads to mmapped data caused SIGBUS. Note that this fixes i-g-t/tests/gem_threaded_tiled_access. Tested-by: Mika Kuoppala <mika.kuoppala@intel.com> Signed-off-by: Dmitry Rogozhkin <dmitry.v.rogozhkin@intel.com> Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-14drm/radeon: add primary dac adj quirk for R200 boardAlex Deucher
commit e8fc41377f5037ff7a661ea06adc05f1daec1548 upstream. vbios values are wrong leading to colors that are too bright. Use the default values instead. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28drm/i915: Set i9xx sdvo clock limits according to specificationsPatrik Jakobsson
commit 4f7dfb6788dd022446847fbbfbe45e13bedb5be2 upstream. The Intel PRM says the M1 and M2 divisors must be in the range of 10-20 and 5-9. Since we do all calculations based on them being register values (which are subtracted by 2) we need to specify them accordingly. Signed-off-by: Patrik Jakobsson <patrik.r.jakobsson@gmail.com> Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=56359 Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28drm/i915: disable shared panel fitter for pipeMika Kuoppala
commit 24a1f16de97c4cf0029d9acd04be06db32208726 upstream. If encoder is switched off by BIOS, but the panel fitter is left on, we never try to turn off the panel fitter and leave it still attached to the pipe - which can cause blurry output elsewhere. Based on work by Chris Wilson <chris@chris-wilson.co.uk> Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=58867 Signed-off-by: Mika Kuoppala <mika.kuoppala@intel.com> Tested-by: Andreas Sturmlechner <andreas.sturmlechner@gmail.com> [danvet: Remove the redundant HAS_PCH_SPLIT check and add a tiny comment.] Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28drm/usb: bind driver to correct deviceDave Airlie
commit 9f23de52b64f7fb801fd76f3dd8651a0dc89187b upstream. While looking at plymouth on udl I noticed that plymouth was trying to use its fb plugin not its drm one, it was trying to drmOpen a driver called usb not udl, noticed that we actually had out driver pointing at the wrong device. Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28drm: Use C8 instead of RGB332 when determining the format from depth/bppVille Syrjälä
commit d84f031bd230fdf9c3b7734940c859bf28b90219 upstream. Support for real RGB332 is a rarity, most hardware only really support C8. So use C8 instead of RGB332 when determining the format based on depth/bpp. This fixes 8bpp fbcon on i915, since i915 will only accept C8 and not RGB332. Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=59572 Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Acked-by: Dave Airlie <airlied@gmail.com> Tested-by: mlsemon35@gmail.com Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28drm: Fill depth/bits_per_pixel for C8 formatVille Syrjälä
commit c51a6bc5f6d328926a9a4a1247c5030faf190a80 upstream. Set depth/bits_per_pixel to 8 for C8 format. Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Acked-by: Dave Airlie <airlied@gmail.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28drm: don't add inferred modes for monitors that don't support themPaulo Zanoni
commit 196e077dc165a307efbd9e7569f81bbdbcf18f65 upstream. If bit 0 of the features byte (0x18) is set to 0, then, according to the EDID spec, "the display is non-continuous frequency (multi-mode) and is only specified to accept the video timing formats that are listed in Base EDID and certain Extension Blocks". For more information, please see the EDID spec, check the notes of the table that explains the "Feature Support" byte (18h) and also the notes on the tables of the section that explains "Display Range Limits & Additional Timing Description Definition (tag #FDh)". Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=45729 Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Reviewed-by: Adam Jackson <ajax@redhat.com> Signed-off-by: Paulo Zanoni <paulo.r.zanoni@intel.com> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28drm/udl: disable fb_defio by defaultDave Airlie
commit 677d23b70bf949f75746c80cbae92c233c6b5e2a upstream. There seems to be a bad interaction between gem/shmem and defio on top, I get list corruption on the page lru in the shmem code. Turn it off for now until we get some more digging done. Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28drm/udl: make usage as a console saferDave Airlie
commit bcb39af4486be07e896fc374a2336bad3104ae0a upstream. Okay you don't really want to use udl devices as your console, but if you are unlucky enough to do so, you run into a lot of schedule while atomic due to printk being called from all sorts of funky places. So check if we are in an atomic context, and queue the damage for later, the next printk should cause it to appear. This isn't ideal, but it is simple, and seems to work okay in my testing here. (dirty area idea came from xenfb) fixes a bunch of sleeping while atomic issues running fbcon on udl devices. Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28drm/radeon/dce6: fix display powergatingAlex Deucher
commit 0e3d50bfcbd338254795a700dcff429a96cba1a6 upstream. Only enable it when we disable the display rather than at DPMS time since enabling it requires a full modeset to restore the display state. Fixes blank screens in certain cases. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14efi: Make 'efi_enabled' a function to query EFI facilitiesMatt Fleming
commit 83e68189745ad931c2afd45d8ee3303929233e7f upstream. Originally 'efi_enabled' indicated whether a kernel was booted from EFI firmware. Over time its semantics have changed, and it now indicates whether or not we are booted on an EFI machine with bit-native firmware, e.g. 64-bit kernel with 64-bit firmware. The immediate motivation for this patch is the bug report at, https://bugs.launchpad.net/ubuntu-cdimage/+bug/1040557 which details how running a platform driver on an EFI machine that is designed to run under BIOS can cause the machine to become bricked. Also, the following report, https://bugzilla.kernel.org/show_bug.cgi?id=47121 details how running said driver can also cause Machine Check Exceptions. Drivers need a new means of detecting whether they're running on an EFI machine, as sadly the expression, if (!efi_enabled) hasn't been a sufficient condition for quite some time. Users actually want to query 'efi_enabled' for different reasons - what they really want access to is the list of available EFI facilities. For instance, the x86 reboot code needs to know whether it can invoke the ResetSystem() function provided by the EFI runtime services, while the ACPI OSL code wants to know whether the EFI config tables were mapped successfully. There are also checks in some of the platform driver code to simply see if they're running on an EFI machine (which would make it a bad idea to do BIOS-y things). This patch is a prereq for the samsung-laptop fix patch. Signed-off-by: Matt Fleming <matt.fleming@intel.com> Cc: David Airlie <airlied@linux.ie> Cc: Corentin Chary <corentincj@iksaif.net> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Cc: Dave Jiang <dave.jiang@intel.com> Cc: Olof Johansson <olof@lixom.net> Cc: Peter Jones <pjones@redhat.com> Cc: Colin Ian King <colin.king@canonical.com> Cc: Steve Langasek <steve.langasek@canonical.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Konrad Rzeszutek Wilk <konrad@kernel.org> Cc: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11drm/radeon: Calling object_unrefer() when creating fb failureliu chuansheng
commit f2d68cf4daa4de97d400d94836b907e35228e54f upstream. When kzalloc() failed in radeon_user_framebuffer_create(), need to call object_unreference() to match the object_reference(). Signed-off-by: liu chuansheng <chuansheng.liu@intel.com> Signed-off-by: xueminsu <xuemin.su@intel.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11drm/radeon: prevent crash in the ring space allocationAlex Deucher
commit fd5d93a0015ce1a7db881382022b2fcdfdc61760 upstream. If the requested number of DWs on the ring is larger than the size of the ring itself, return an error. In testing with large VM updates, we've seen crashes when we try and allocate more space on the ring than the total size of the ring without checking. This prevents the crash but for large VM updates or bo moves of very large buffers, we will need to break the transaction down into multiple batches. I have patches to use IBs for the next kernel. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11drm/radeon: fix MC blackout on evergreen+Christopher Staite
commit bb588820ef421c6098dca1fec29c3b347f1c8c19 upstream. Force the crtc mem requests on/off immediately rather than waiting for the double buffered updates to kick in. Seems we miss the update in certain conditions. Also handle the DCE6 case. Signed-off-by: Christopher Staite <chris@yourdreamnet.co.uk> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11drm/radeon: add quirk for RV100 boardAlex Deucher
commit 9200ee4941a6e5d1ec5df88982243686882dff3f upstream. vbios says external TMDS while the board is actually internal TMDS. fixes: https://bugs.freedesktop.org/show_bug.cgi?id=60037 Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11drm/radeon: add WAIT_UNTIL to the non-VM safe regs list for cayman/TNAlex Deucher
commit 674a16f2b4724880d07389abbb95abf320b924aa upstream. Newer versions of mesa emit this. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11drm/radeon/evergreen+: wait for the MC to settle after MC blackoutAlex Deucher
commit ed39fadd6df01095378e499fac3674883f16b853 upstream. Some chips seem to need a little delay after blacking out the MC before the requests actually stop. May fix: https://bugs.freedesktop.org/show_bug.cgi?id=56139 https://bugs.freedesktop.org/show_bug.cgi?id=57567 Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-03radeon_display: Use pointer return error codesxueminsu
commit b2f4b03f8a378cd626d2ea67d19e7470c050a098 upstream. drm_mode_addfb() expects fb_create return error code instead of NULL. Signed-off-by: xueminsu <xuemin.su@intel.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-03drm/radeon: fix cursor corruption on DCE6 and newerJerome Glisse
commit e521a29014794d139cca46396d1af8faf1295a26 upstream. Aruba and newer gpu does not need the avivo cursor work around, quite the opposite this work around lead to corruption. agd5f: check DCE6 rather than ARUBA since the issue is DCE version specific rather than family specific. Signed-off-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-27drm/i915: Implement WaDisableHiZPlanesWhenMSAAEnabledDaniel Vetter
commit 4283908ef7f11a72c3b80dd4cf026f1a86429f82 upstream. Quoting from Bspec, 3D_CHICKEN1, bit 10 This bit needs to be set always to "1", Project: DevSNB " Reviewed-by: Rodrigo Vivi <rodrigo.vivi@gmail.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Abdallah Chatila <abdallah.chatila@ericsson.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-27drm/i915: Invalidate the relocation presumed_offsets along the slow pathChris Wilson
commit 262b6d363fcff16359c93bd58c297f961f6e6273 upstream. In the slow path, we are forced to copy the relocations prior to acquiring the struct mutex in order to handle pagefaults. We forgo copying the new offsets back into the relocation entries in order to prevent a recursive locking bug should we trigger a pagefault whilst holding the mutex for the reservations of the execbuffer. Therefore, we need to reset the presumed_offsets just in case the objects are rebound back into their old locations after relocating for this exexbuffer - if that were to happen we would assume the relocations were valid and leave the actual pointers to the kernels dangling, instant hang. Fixes regression from commit bcf50e2775bbc3101932d8e4ab8c7902aa4163b4 Author: Chris Wilson <chris@chris-wilson.co.uk> Date: Sun Nov 21 22:07:12 2010 +0000 drm/i915: Handle pagefaults in execbuffer user relocations Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=55984 Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: Daniel Vetter <daniel.vetter@fwll.ch> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2013-01-17Revert "drm/i915: no lvds quirk for Zotac ZDBOX SD ID12/ID13"Daniel Vetter
commit 48e858340dae43189a4e55647f6eac736766f828 upstream. This reverts commit 9756fe38d10b2bf90c81dc4d2f17d5632e135364. The bogus lvds output is actually a lvds->hdmi bridge, which we don't really support. But unconditionally disabling it breaks some existing setups. Reported-by: John Tapsell <johnflux@gmail.com> References: http://permalink.gmane.org/gmane.comp.freedesktop.xorg.drivers.intel/17237 Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Cc: Luis Henriques <luis.henriques@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
