path: root/drivers/hid/hid-chicony.c
2009-07-23HID: adding __init/__exit macros to module init/exit functionsPeter Huewe
Trivial patch which adds the __init and __exit macros to the module_init / module_exit functions of several HID drivers from drivers/hid/ Signed-off-by: Peter Huewe <peterhuewe@gmx.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-03-30HID: remove compat stuffJiri Slaby
This removal was scheduled and there is no problem with later distros to adapt for the new bus, thanks to aliases. module-init-tools map files are deprecated nowadays, so that the patch which introduced hid ones into the m-i-t won't be accepted and hence there is no reason for leaving compat stuff in. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-10-14HID: move chicony quirksJiri Slaby
Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
