path: root/drivers/hid/hid-ezkey.c
2013-01-03HID: Use module_hid_driver macroH Hartley Sweeten
Use the new module_hid_driver macro in all HID drivers that have a simple register/unregister init/exit. This also converts the hid drivers that test for a failure of hid_register_driver() and report the failure. Using module_hid_driver in those drivers removes the failure message. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-09-05HID: remove Paul Walmsley's copyright from places where it shouldn't beJiri Kosina
Paul Walmsley has implemented dynamic quirk handling back in 2007 through commits: 2eb5dc30eb ("USB HID: encapsulate quirk handling into hid-quirks.c") 8222fbe67c ("USB HID: clarify static quirk handling as squirks") 8cef908235 ("USB HID: add support for dynamically-created quirks") 876b9276b9 ("USB HID: add 'quirks' module parameter") and as such, his copyright rightly belongs to drivers/hid/usbhid/hid-quirks.c file. However when generic HID code has been converted to bus and individual quirks separated out to individual drivers on the bus, the copyright has been blindly transfered into all the tiny drivers, which actually don't contain any of Pauls' copyrighted code. Remove the copyright from those sub-drivers. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Acked-by: Paul Walmsley <paul@pwsan.com>
2009-07-23HID: adding __init/__exit macros to module init/exit functionsPeter Huewe
Trivial patch which adds the __init and __exit macros to the module_init / module_exit functions of several HID drivers from drivers/hid/ Signed-off-by: Peter Huewe <peterhuewe@gmx.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-03-30HID: remove compat stuffJiri Slaby
This removal was scheduled and there is no problem with later distros to adapt for the new bus, thanks to aliases. module-init-tools map files are deprecated nowadays, so that the patch which introduced hid ones into the m-i-t won't be accepted and hence there is no reason for leaving compat stuff in. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-10-14HID: move ezkey quirksJiri Slaby
Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
