path: root/drivers/hid/hid-gyration.c
2011-02-15HID: Add teletext/color keys - gyration remote - EU version (GYAR3101CKDE)Steffen Barszus
This patch adds support for 5 keys which can be found only on the EU version of the gyration remote, which has been not mapped before. Signed-off-by: Steffen Barszus <steffenbpunkt[AT]googlemail[DOT]com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-05-24HID: Add the GYR4101US USB ID to hid-gyrationCory Maccarrone
This change adds in the USB product ID for the Gyration GYR4101US USB media center remote control. This remote is similar enough to the other two devices that this driver can be used without any other changes to get full support for the remote. Signed-off-by: Cory Maccarrone <darkstar6262@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-03-23HID: fix oops in gyration_event()Jiri Kosina
Fix oops caused by dereferencing field->hidinput in cases where the device hasn't been claimed by hid-input. Reported-by: Andreas Demmer <mail@andreas-demmer.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-07-23HID: adding __init/__exit macros to module init/exit functionsPeter Huewe
Trivial patch which adds the __init and __exit macros to the module_init / module_exit functions of several HID drivers from drivers/hid/ Signed-off-by: Peter Huewe <peterhuewe@gmx.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-03-30HID: remove compat stuffJiri Slaby
This removal was scheduled and there is no problem with later distros to adapt for the new bus, thanks to aliases. module-init-tools map files are deprecated nowadays, so that the patch which introduced hid ones into the m-i-t won't be accepted and hence there is no reason for leaving compat stuff in. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-10-17HID: add support for another Gyration remote controlJiri Kosina
There is a slightly different Gyration remote control, which requires the quirks we already have in place for the 0x0002 PID, plus KEY_MEDIA mapping is different. Reported-by: Marc Randolph <mrand@pobox.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-10-14HID: move gyration quirksJiri Slaby
Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
