path: root/drivers/hid/hid-holtek-kbd.c
2019-08-25HID: holtek: test for sanity of intfdataOliver Neukum
commit 01ec0a5f19c8c82960a07f6c7410fc9e01d7fb51 upstream. The ioctl handler uses the intfdata of a second interface, which may not be present in a broken or malicious device, hence the intfdata needs to be checked for NULL. [jkosina@suse.cz: fix newly added spurious space] Reported-by: syzbot+965152643a75a56737be@syzkaller.appspotmail.com Signed-off-by: Oliver Neukum <oneukum@suse.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-03HID: Use module_hid_driver macroH Hartley Sweeten
Use the new module_hid_driver macro in all HID drivers that have a simple register/unregister init/exit. This also converts the hid drivers that test for a failure of hid_register_driver() and report the failure. Using module_hid_driver in those drivers removes the failure message. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-07-12HID: Add driver for Holtek based keyboards with broken HIDTom Harwood
Corrects two HID descriptor issues, which prevent some Holtek based (USB ID 04d9:a055) keyboards from working. The error when not using the driver is: generic-usb: probe ... failed with error -22 . Signed-off-by: Tom Harwood <tomharwood@fastmail.fm> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
