commit 412f30105ec6735224535791eed5cdc02888ecb4 upstream.
A HID device could send a malicious output report that would cause the
pantherlord HID driver to write beyond the output report allocation
during initialization, causing a heap overflow:
[ 310.939483] usb 1-1: New USB device found, idVendor=0e8f, idProduct=0003
[ 315.980774] BUG kmalloc-192 (Tainted: G W ): Redzone overwritten
CVE-2013-2892
This allows the hid drivers to be independent from the transport layer.
The patch was constructed by replacing all occurences of
usbhid_submit_report() by its hid_hw_request() counterpart.
Then, drivers not requiring USB_HID anymore have their USB_HID
dependency cleaned in the Kconfig file.
Finally, few drivers still depends on USB_HID. Many of them
are requiring the io wait callback. They are found in the next patch.
Signed-off-by: Benjamin Tissoires <benjamin.tissoires@gmail.com>
Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com>
For the sensor-hub part:
Tested-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Add support for another gamepad to the hid-pl driver. The "color rumble pad
P580" marketed using the "Saitek" brand in Germany, and using a USB Vendor ID
attributed to "Jess" seems to be electronically identical to the 4-field
variant of the "Green Asia" gamepad.
The pad has been tested to support rumble strengths up to 255, not just 127.
Signed-off-by: Michael Karcher <kernel@mkarcher.dialup.fu-berlin.de>
Use the new module_hid_driver macro in all HID drivers that have
a simple register/unregister init/exit.
This also converts the hid drivers that test for a failure of
hid_register_driver() and report the failure. Using module_hid_driver
in those drivers removes the failure message.
A pending cleanup will mean that module.h won't be implicitly
everywhere anymore. Make sure the modular drivers in clocksource
are actually calling out for <module.h> explicitly in advance.
Neaten current uses of dev_<level> by adding and using
hid specific hid_<level> macros.
Convert existing uses of dev_<level> uses to hid_<level>.
Convert hid-pidff printk uses to hid_<level>.
Remove err_hid and use hid_err instead.
Add missing newlines to logging messages where necessary.
Coalesce format strings.
Add and use pr_fmt(fmt) KBUILD_MODNAME ": " fmt
Other miscellaneous changes:
Add const struct hid_device * argument to hid-core functions
extract() and implement() so hid_<level> can be used by them.
Fix bad indentation in hid-core hid_input_field function
that calls extract() function above.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Trivial patch which adds the __init and __exit macros to the module_init /
module_exit functions of several HID drivers from drivers/hid/
Signed-off-by: Peter Huewe <peterhuewe@gmx.de>
This removal was scheduled and there is no problem with later
distros to adapt for the new bus, thanks to aliases.
module-init-tools map files are deprecated nowadays, so that
the patch which introduced hid ones into the m-i-t won't be
accepted and hence there is no reason for leaving compat stuff in.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Cc: Jiri Kosina <jkosina@suse.cz>
Add support for another version of 0e8f:0003 device into hid-pl driver.
This device has the values in separate fields and resembles devices
handled by hid-zpff.
Signed-off-by: Anssi Hannula <anssi.hannula@gmail.com>
Tested-by: Pantelis Koukousoulas <pktoss@gmail.com>
0x0810/0x0002 needs the very same handling as 0x0001.
Reported-by: Steve Conklin <sconklin@canonical.com>
Since we have a real device bound to a driver, we may use struct
device for printing. Use dev_* functions instead of printks in
4 drivers.
Move the force feedback processing into a separate module.
[jkosina@suse.cz: fix Kconfig texts a little bit]
