path: root/drivers/hid/hid-roccat-pyra.c
2011-06-13HID: roccat: fix NULL pointer dereference, add range checksStefan Achatz
On rare occassions raw events can be triggered before drvdata gets set up which leads to NULL pointer dereferences. This was only observed with pyra on 2.6.39, but is fixed for all devices now to play it save. kovaplus returned wrong actual values when profile change was initiated from host. Added range checks for setting actual profile on all devices. Signed-off-by: Stefan Achatz <erazor_de@users.sourceforge.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-06-13HID: roccat: correction and cleanup of HID feature reportsStefan Achatz
Removed analog feature report enums and modified code in roccat_common to reflect this. Non standard conform Kone got its own copy of the old code. That helps extracting more generalizations for newer devices. Signed-off-by: Stefan Achatz <erazor_de@users.sourceforge.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-03-24HID: roccat: Add support for wireless variant of PyraStefan Achatz
Wireless variant of Roccat Pyra finally has been tested with existing driver. Signed-off-by: Stefan Achatz <erazor_de@users.sourceforge.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-02-03HID: roccat: Rename header roccat.h -> hid-roccat.hStefan Achatz
It was desired that the header roccat.h should be named hid-roccat.h Signed-off-by: Stefan Achatz <erazor_de@users.sourceforge.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-02-03HID: roccat: Fix NULL pointer dereference when unloading moduleStefan Achatz
Class was destroyed before starting the unregistering driver chain. Disconnecting a device from roccat chardev in this process then raised a NULL pointer dereference. Fixed this by destroying class after unregistering driver. Signed-off-by: Stefan Achatz <erazor_de@users.sourceforge.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-02-03HID: roccat: Add ioctl command to retreive report size from chardevStefan Achatz
Roccat chardev was reworked to support only a defined report size per device and this can be retreived by an ioctl now to enable future changes in report definitions. Header was moved/renamed from drivers/hid to include/linux for accessibility. Signed-off-by: Stefan Achatz <erazor_de@users.sourceforge.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-02-03HID: roccat: Introduce module hid-roccat-commonStefan Achatz
Module hid-roccat-common contains functions used by roccat device driver modules to reduce code duplication. At the moment it contains just two wrapper methods for usb_control_msg that ensure that the buffer used for transfer is dma capable which wasn't the case before. The kconfig option is not visible to the user but will be selected by the device specific drivers. Signed-off-by: Stefan Achatz <erazor_de@users.sourceforge.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-01-08HID: roccat: reduce number of functions in kone and pyra driversStefan Achatz
The profile number is now passed via bin_attribute->private instead of function parameter to reduce number of functions. Signed-off-by: Stefan Achatz <erazor_de@users.sourceforge.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-01-08HID: roccat: use class for char device for sysfs attribute creationStefan Achatz
Adding sysfs attributes to an already created device raises no userland notification. Now the device drivers associate the devices attributes with a class and use this for roccat event char device creation. Signed-off-by: Stefan Achatz <erazor_de@users.sourceforge.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-12-10HID: Add and use hid_<level>: dev_<level> equivalentsJoe Perches
Neaten current uses of dev_<level> by adding and using hid specific hid_<level> macros. Convert existing uses of dev_<level> uses to hid_<level>. Convert hid-pidff printk uses to hid_<level>. Remove err_hid and use hid_err instead. Add missing newlines to logging messages where necessary. Coalesce format strings. Add and use pr_fmt(fmt) KBUILD_MODNAME ": " fmt Other miscellaneous changes: Add const struct hid_device * argument to hid-core functions extract() and implement() so hid_<level> can be used by them. Fix bad indentation in hid-core hid_input_field function that calls extract() function above. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-09-01HID: roccat: Normalized reported profile number for pyra button events.Stefan Achatz
Pyra uses profile numbers in range 0-4 for everything except button events. Using range 1-5 consistent now. Signed-off-by: Stefan Achatz <erazor_de@users.sourceforge.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-09-01HID: roccat: add driver for Roccat Pyra mouseStefan Achatz
This patch add support for Pyra mobile gaming mouse from Roccat. It provides access to profiles, settings, actual settings etc. through sysfs attributes. This driver is conceptual similar to the existing Kone driver. Userland tools can soon be found at http://sourceforge.net/projects/roccat Signed-off-by: Stefan Achatz <erazor_de@users.sourceforge.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
