set PS3 controller first LED, when connected over bluetooth.
Bug 847075
Change-Id: Ia32c692cbd5d7e041625d8bccfcb935ae669e82a
Signed-off-by: Nagarjuna Kristam <nkristam@nvidia.com>
Reviewed-on: http://git-master/r/95804
The accelerometers/gyro on the Sixaxis are reported in the wrong
endianness (ie. not compatible with HID), so this patch intercepts
the report and swaps the appropriate bytes over.
Accelerometers are scaled with a nominal value of +/-4000 = 1G,
maximum value would be around +/-32768 = 8G.
Gyro on my device always reports -32768, might need some calibration
set within the controller.
Fix extracted from previous patch submission:
https://patchwork.kernel.org/patch/95212/
Signed-off-by: Marcin Tolysz <tolysz@gmail.com>
Signed-off-by: Simon Wood <simon@mungewell.org>
Signed-off-by: Antonio Ospite <ospite@studenti.unina.it>
Modify the HID descriptor of the Sixaxis controller to allow the
reporting of the accelerometers and gyro via a joystick axis.
Rewrite section from offset 83:
0x75, 0x08, /* Report Size (8), */
/* all the other data lumped together */
0x95, 0x27, /* Report Count (39), */
0x09, 0x01, /* Usage (Pointer), */
0x81, 0x02, /* Input (Variable), */
0x95, 0x30, /* Report Count (48), */
/* Note Output */
0x91, 0x02, /* Output (Variable), */
/* Note Feature */
0xB1, 0x02, /* Feature (Variable), */
with
/* last 2 not used... */
0x95, 0x13, /* Report Count (19), */
/* Padding */
0x95, 0x0C, /* Report Count (12), */
0x81, 0x01, /* Input (Constant), */
0x75, 0x10, /* Report Size (16), */
0x95, 0x04, /* Report Count (4), */
0x26, 0xFF, 0x03, /* Logical Maximum (1023), */
0x46, 0xFF, 0x03, /* Physical Maximum (1023), */
Sony Navigation Controller needs a special report to be sent to it
before it is able to operate, the same way as other Sony controllers
do.
Tested-by: Jacek Lukas Wotka <jlw@team-fatal.com>
The Sixaxis does not want the report_id as part of the data packet in
Output reports, so we have to discard buf[0] when sending the actual
control message.
Add also some documentation about that and about why
hdev->hid_output_raw_report needs to be overridden.
Neaten current uses of dev_<level> by adding and using
hid specific hid_<level> macros.
Convert existing uses of dev_<level> uses to hid_<level>.
Convert hid-pidff printk uses to hid_<level>.
Remove err_hid and use hid_err instead.
Add missing newlines to logging messages where necessary.
Coalesce format strings.
Add and use pr_fmt(fmt) KBUILD_MODNAME ": " fmt
Other miscellaneous changes:
Add const struct hid_device * argument to hid-core functions
extract() and implement() so hid_<level> can be used by them.
Fix bad indentation in hid-core hid_input_field function
that calls extract() function above.
drivers/hid/hid-ids.h
drivers/hid/hid-lg.c
drivers/hid/usbhid/hid-quirks.c
Override usbhid_output_raw_report in order to force output reports (sent
via hidraw_write, for instance) on the control endpoint.
The Sony Sixaxis (PS3 Controller) accepts output reports only on the
control endpoint, it silently discards them when they arrive over the
interrupt endpoint where usbhid would normally deliver them.
Be more explicit and avoid calling sony_set_operational_usb() when we
have USB_DEVICE_ID_SONY_VAIO_VGX_MOUSE.
While at it, rename the sony_set_operational routines to
sixaxis_set_operational as they are sixaxis specific.
This is also in preparation for the sysfs interface to set and get bdaddr
over usb and for some other Sixaxis report fixup.
Signed-off-by: Bastien Nocera <hadess@hadess.net>
Update hid_driver's report_fixup prototype to allow changing report
descriptor size and/or returning completely different report descriptor.
Update existing usage accordingly.
This is to give more freedom in descriptor fixup and to allow having a whole
fixed descriptor in the code for the sake of readability.
Signed-off-by: Nikolai Kondrashov <spbnick@gmail.com>
Don't send the report type as part of the data, this prevents the
controller from going into the operational state at all.
This is completely equivalent to what the code originally meant to accomplish:
as per in net/bluetooth/hidp/core.c::hidp_output_raw_report(), by using
HID_FEATURE_REPORT here, what will be actually sent is
(HIDP_TRANS_SET_REPORT | HIDP_DATA_RTYPE_FEATURE) which is exactly 0x53.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
'apple_magic_mouse' into for-linus
drivers/hid/Kconfig
Now that hid_output_raw_report works, port the PS3 Sixaxis
Bluetooth quirk from user-space, into kernel-space.
Acked-by: Marcel Holtmann <marcel@holtmann.org>
Trivial patch which adds the __init and __exit macros to the module_init /
module_exit functions of several HID drivers from drivers/hid/
Signed-off-by: Peter Huewe <peterhuewe@gmx.de>
This removal was scheduled and there is no problem with later
distros to adapt for the new bus, thanks to aliases.
module-init-tools map files are deprecated nowadays, so that
the patch which introduced hid ones into the m-i-t won't be
accepted and hence there is no reason for leaving compat stuff in.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Cc: Jiri Kosina <jkosina@suse.cz>
sony_set_operational() only propagates return value from
usb_control_msg(), which returns negative on error and number
of transferred bytes otherwise.
Reported-by: Marcin Tolysz <tolysz@gmail.com>
The Sony Vaio VGX-TP1E multimedia PC has a wireless keyboard with
a touchpad.
The mouse pointer is wrongly declared as constant non-data variable, which make
HID code to completely ignore all the "Pointer" usages.
Fix the report descriptor before it enters the parser to contain touchpad
pointer description that is correctly parsable (declaring data rather than
constant).
Reported-by: Stefan Hundhammer <sh@suse.de>
Move connecting from usbhid to the hid layer and fix also hidp in
that manner.
This removes all the ignore/force hidinput/hiddev connecting quirks.
