path: root/drivers/hid/hid-waltop.c
2016-09-19HID: Remove broken links to tablet descriptionsNikolai Kondrashov
Remove comments with broken links to tablet descriptions from hid-kye/uclogic/waltop drivers. They pointed to now dead DIGImend project wiki at sf.net. Even though the DIGImend project still hosts descriptions, now at digimend.github.io, it's better to avoid them going stale again, and let anyone interested search the web instead. Signed-off-by: Nikolai Kondrashov <spbnick@gmail.com> Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-01-03HID: Use module_hid_driver macroH Hartley Sweeten
Use the new module_hid_driver macro in all HID drivers that have a simple register/unregister init/exit. This also converts the hid drivers that test for a failure of hid_register_driver() and report the failure. Using module_hid_driver in those drivers removes the failure message. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-09-07HID: waltop: Remove waltop_probe() and waltop_remove() functionsAxel Lin
The waltop_probe() and waltop_remove() functions do not have any special initialization and cleanup. Remove them and let HID core handle the default probe/remove actions. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Nikolai Kondrashov <spbnick@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-05-21HID: waltop: Extend barrel button fixNikolai Kondrashov
Extend Waltop barrel button fix to all models: ignore reported pressure when a barrel button is pressed, because it is rarely correct. Report zero pressure in such cases instead. Signed-off-by: Nikolai Kondrashov <spbnick@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-03-28HID: waltop: Add support for Sirius tabletNikolai Kondrashov
Add support for Waltop Sirius Battery Free Tablet. VisTablet Muse and Princeton PTB-S1BK are other possible names of this tablet. Signed-off-by: Nikolai Kondrashov <spbnick@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-03-06HID: waltop: Add support for tablet with PID 0038Nikolai Kondrashov
Add support for unknown Waltop tablet with product ID 0x0038. This tablet is sold as Genius G-Pen F509. Signed-off-by: Nikolai Kondrashov <spbnick@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-03-06HID: waltop: Replace original rdescs with linksNikolai Kondrashov
Replace original report descriptor dumps in the comments with links to tablet descriptions in a wiki, to make code clearer. Signed-off-by: Nikolai Kondrashov <spbnick@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-02-07HID: waltop: Add support for Waltop Q PadNikolai Kondrashov
Add support for Waltop Q Pad by fixing its report descriptor. This tablet is also sold as Aiptek HyperPen Mini. Other possible names include: NGS Flexi Style, VisTablet PenPad, iVistaTablet Q Flex Pad, Bravod Q-PD65-S. Signed-off-by: Nikolai Kondrashov <spbnick@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-01HID: waltop: add support for Waltop Slim Tablet 12.1 inchNikolai Kondrashov
Add support for Waltop Slim Tablet 12.1 inch by fixing its report descriptor. This mainly fixes button reporting. This tablet is also sold as Genius G-Pen F610. Other possible names of this tablet: VisTablet Original 12", Adesso CyberTablet Z12, Adesso CT-Z12A, PenPower Tooya Pro, Aiptek Slim 12.1 Inch Signed-off-by: Nikolai Kondrashov <spbnick@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-09-01HID: waltop: comment on tablet modesNikolai Kondrashov
Add a comment on modes supported by Waltop tablets - a knowledge extracted from the outdated official driver, but not yet used by this driver. Signed-off-by: Nikolai Kondrashov <spbnick@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-09-01HID: waltop: fix Media Tablet 10.6 inch zoomingNikolai Kondrashov
Fix zoom controls of older version of Waltop Media Tablet 10.6 inch, aka Genius G-Pen M609. This should make it supported on par with the newer version, aka Genius G-Pen M609X. The fix is extrapolated from the behavior of the newer version (Genius G-Pen M609X) and both older and newer versions of Media Tablet 14.1 inch (Genius G-Pen M712/M712X) and should work with high probability. Signed-off-by: Nikolai Kondrashov <spbnick@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-09-01HID: waltop: add Media Tablet 14.1 inch supportNikolai Kondrashov
Add support for Waltop Media Tablet 14.1 inch by fixing report descriptor. This tablet is also sold as Genius G-Pen M712 (older version) and M712X (newer version). Both are supported. Trust Wide Screen Design Tablet (TB-7300, item no 15358) seems to be the older version of this tablet (similar to Genius G-Pen M712), and could be supported as well. Signed-off-by: Nikolai Kondrashov <spbnick@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-09-01HID: waltop: fix Media Tablet 10.6 inch scrollingNikolai Kondrashov
Add support for horizontal scrolling with Waltop Media Tablet 10.6 inch by updating the fixed HID report descriptor. The horizontal/vertical scrolling is toggled by pressing the wheels' center buttons while in scroll mode, which wasn't discovered at the time the support for this tablet was added. Signed-off-by: Nikolai Kondrashov <spbnick@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-08-23HID: add support for two Waltop tabletsNikolai Kondrashov
Add support for Waltop Slim Tablet 5.8 inch and Media Tablet 10.6 inch. These (and other Waltop) tablets are usually sold by different companies (such as Genius and Trust) and with different names, but with the same USB vendor/product IDs. Slim Tablet 5.8 inch is known to also be sold as Genius G-Pen F350 and Trust Widescreen Mini Tablet (item no 16485). Media Tablet 10.6 inch is known to also be sold as Genius G-Pen M609 and M609X. Of these only the latter is known to be supported. Signed-off-by: Nikolai Kondrashov <spbnick@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
