Neaten current uses of dev_<level> by adding and using
hid specific hid_<level> macros.
Convert existing uses of dev_<level> uses to hid_<level>.
Convert hid-pidff printk uses to hid_<level>.
Remove err_hid and use hid_err instead.
Add missing newlines to logging messages where necessary.
Coalesce format strings.
Add and use pr_fmt(fmt) KBUILD_MODNAME ": " fmt
Other miscellaneous changes:
Add const struct hid_device * argument to hid-core functions
extract() and implement() so hid_<level> can be used by them.
Fix bad indentation in hid-core hid_input_field function
that calls extract() function above.
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (59 commits)
HID: fix up 'EMBEDDED' mess in Kconfig
HID: roccat: cleanup preprocessor macros
HID: roccat: refactor special event handling
HID: roccat: fix special button support
HID: roccat: Correctly mark init and exit functions
HID: hidraw: Use Interrupt Endpoint for OUT Transfers if Available
HID: hid-samsung: remove redundant key mappings
HID: add omitted hid-zydacron.c file
HID: hid-samsung: add support for Creative Desktop Wireless 6000
HID: picolcd: Eliminate use after free
HID: Zydacron Remote Control driver
HID: Use kmemdup
HID: magicmouse: fix input registration
HID: make Prodikeys driver standalone config option
HID: Prodikeys PC-MIDI HID Driver
HID: hidraw: fix indentation
HID: ntrig: add filtering module parameters
HID: ntrig: add sysfs access to filter parameters
HID: ntrig: add sensitivity and responsiveness support
HID: add multi-input quirk for eGalax Touchcontroller
For more clearance what the functions actually do,
usb_buffer_alloc() is renamed to usb_alloc_coherent()
usb_buffer_free() is renamed to usb_free_coherent()
They should only be used in code which really needs DMA coherency.
All call sites have been changed accordingly, except for staging
drivers.
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Pedro Ribeiro <pedrib@gmail.com>
This patch (as1350) removes all usages of coherent buffers for USB
control-request setup-packet buffers. There's no good reason to
reserve coherent memory for these things; control requests are hardly
ever used in large quantity (the major exception is firmware
transfers, and they aren't time-critical). Furthermore, only seven
drivers used it. We might as well always use streaming DMA mappings
for setup-packet buffers, and remove some extra complexity from
usbcore.
The DMA-mapping portion of hcd.c is currently in flux. A separate
patch will be submitted to remove support for URB_NO_SETUP_DMA_MAP
after everything else settles down. The removal should go smoothly,
as by then nobody will be using it.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
This patch (as1365) enables remote wakeup by default for USB keyboard
devices. Keyboards in general are supposed to be wakeup devices, but
the correct place to enable it depends on the device's bus; no single
approach will work for all keyboard devices. In particular, this
covers only USB keyboards (and then only those supporting the boot
protocol).
Use strlcat() to append a string to the previously created first part.
Signed-off-by: Márton Németh <nm127@freemail.hu>
Acked-by: Jiri Kosina <jkosina@suse.cz>
USB should not be having it's own printk macros, so remove warn() and
use the system-wide standard of dev_warn() wherever possible. In the
few places that will not work out, use a basic printk().
USB should not be having it's own printk macros, so remove info() and
use the system-wide standard of dev_info() wherever possible.
This patch completely removes the dependency of usbkbd and usbmouse drivers
on usbhid code.
usbkbd/usbmouse drivers are not needed in the vast majority of cases anyway,
and they shouldn't be loaded in standard configurations at all. They are supposed
to be as trivial as possible, and searching for HID_QUIRK_IGNORE can even be
bad in some cases.
When usbmouse/kbd is set to build, USB_HID is never defined due to
the USB_HID!=y Kconfig rule. Test CONFIG_USB_HID_MODULE in both
drivers instead.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
mark it as const because it is read only
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
This patch removes CVS keywords that weren't updated for a long time
from comments.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
We can use the blacklist only if usbhid code is compiled.
Reported-by: jurriaan <thunder7@xs4all.nl>
Cc: Pascal Terjan <pterjan@mandriva.com>
This fixes wacom tablets not working if usbmouse is loaded.
Signed-off-by: Pascal Terjan <pterjan@mandriva.com>
get rid of input BIT* duplicate defines
use newly global defined macros for input layer. Also remove includes of
input.h from non-input sources only for BIT macro definiton. Define the
macro temporarily in local manner, all those local definitons will be
removed further in this patchset (to not break bisecting).
BIT macro will be globally defined (1<<x)
Cc: <dtor@mail.ru>
Cc: <lenb@kernel.org>
Acked-by: Marcel Holtmann <marcel@holtmann.org>
Cc: <perex@suse.cz>
Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Cc: <vernux@us.ibm.com>
Cc: <malattia@linux.it>
There have been many reports recently about broken HID devices, the
diagnosis of which required users to recompile their kernels in order
to be able to provide debugging output needed for coding a quirk for
a particular device.
This patch makes CONFIG_HID_DEBUG default y if !EMBEDDED and makes it
possible to control debugging output produced by HID code by supplying
'debug=1' module parameter.
In preparation for struct class_device -> struct device input
core conversion switch to using input_dev->dev.parent when
specifying device position in sysfs tree.
usb_buffer_free() now handles NULLs so remove unneeded checks
form callers.
Handle errors when registering input devices in usbkbd/usbmouse.
Separate usbhid code into dedicated drivers/hid/usbhid directory as
discussed previously with Greg, so that it eases maintaineance process.
