commit 1b15d2e5b8077670b1e6a33250a0d9577efff4a5 upstream.
Some drivers use the first HID report in the list instead of using an
index. In these cases, validation uses ID 0, which was supposed to mean
"first known report". This fixes the problem, which was causing at least
the lgff family of devices to stop working since hid_validate_values
was being called with ID 0, but the devices used single numbered IDs
for their reports:
0x05, 0x01, /* Usage Page (Desktop), */
0x09, 0x05, /* Usage (Gamepad), */
0xA1, 0x01, /* Collection (Application), */
0xA1, 0x02, /* Collection (Logical), */
0x85, 0x01, /* Report ID (1), */
Reported-by: Simon Wood <simon@mungewell.org>
Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
commit 2f433083e854ec72c19dc9b0e1cebcc8e230fd75 upstream.
This touchpad seriously dislikes init reports, not only timeing out, but
also refusing to work after this.
Reported-and-tested-by: Vincent Fortier <th0ma7@gmail.com>
commit e24d0d399b2fce71b627043e900ef28283850482 upstream.
The Microsoft Surface Type/Touch Cover 2 is a fancy device which advertised
itself as a multitouch device but with constant input reports.
This way, hid_scan_report() gives the group MULTITOUCH to it, but
hid-multitouch can not handle it due to the constant collection ignored
by hid-input.
To prevent such crap in the future, and while we do not fix this particular
device, make the scan_report coherent with hid-input.c, and ignore constant
input reports.
Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
commit f3b0cbce01cd5c242b420d986b208d306bdc5083 upstream.
This reverts commit 117309c51dca42121f70cacec801511b76acf75c.
The MS Surface Pro 2 has an USB composite device with 3 interfaces
- interface 0 - sensor hub
- interface 1 - wacom digitizer
- interface 2 - the keyboard cover, if one is attached
This USB composite device changes it product id dependent on if and which
keyboard cover is attached. Adding the covers to hid_have_special_driver
prevents loading the right hid drivers for the other two interfaces, all 3
get loaded with hid-microsoft. We don't even need hid-microsoft for the
keyboards. We have to revert this to load the right hid modules for each
interface.
Signed-off-by: Derya <derya.kiran@yahoo.de>
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid
Pull HID fixes from Jiri Kosina:
- fix for ordering of device removal actions in hidraw, by Fernando
Luis Vázquez Cao
- fix for uninitialized workqueue usage in hid-sony, by Frank Praznik
- device ID addition for new variant of Logitech G27, from Simon Wood
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid:
HID: hid-lg4ff: Support new version of G27
HID: hidraw: fix warning destroying hidraw device files after parent
HID: sony: Fix work queue issues.
It has been reported that there is a new hardware version of the G27
in the 'wild'. This patch add's this new revision so that it can be
sent the command to switch to native mode.
Reported-by: "Ivan Baldo" <ibaldo@adinet.com.uy>
Tested-by: "evilcow" <evilcow93@yahoo.com>
Signed-off-by: Simon Wood <simon@mungewell.org>
I noticed that after hot unplugging a Logitech unifying receiver
(drivers/hid/hid-logitech-dj.c) the kernel would occasionally spew a
stack trace similar to this:
usb 1-1.1.2: USB disconnect, device number 7
WARNING: CPU: 0 PID: 2865 at fs/sysfs/group.c:216 device_del+0x40/0x1b0()
sysfs group ffffffff8187fa20 not found for kobject 'hidraw0'
CPU: 0 PID: 2865 Comm: upowerd Tainted: G W 3.14.0-rc4 #7
Hardware name: LENOVO 7783PN4/ , BIOS 9HKT43AUS 07/11/2011
0000000000000009 ffffffff814cd684 ffff880427ccfdf8 ffffffff810616e7
ffff88041ec61800 ffff880427ccfe48 ffff88041e444d80 ffff880426fab8e8
ffff880429359960 ffffffff8106174c ffffffff81714b98 0000000000000028
Call Trace:
[<ffffffff814cd684>] ? dump_stack+0x41/0x51
[<ffffffff810616e7>] ? warn_slowpath_common+0x77/0x90
[<ffffffff8106174c>] ? warn_slowpath_fmt+0x4c/0x50
[<ffffffff81374fd0>] ? device_del+0x40/0x1b0
[<ffffffff8137516f>] ? device_unregister+0x2f/0x50
[<ffffffff813751fa>] ? device_destroy+0x3a/0x40
[<ffffffffa03ca245>] ? drop_ref+0x55/0x120 [hid]
[<ffffffffa03ca3e6>] ? hidraw_release+0x96/0xb0 [hid]
[<ffffffff811929da>] ? __fput+0xca/0x210
[<ffffffff8107fe17>] ? task_work_run+0x97/0xd0
[<ffffffff810139a9>] ? do_notify_resume+0x69/0xa0
[<ffffffff814dbd22>] ? int_signal+0x12/0x17
---[ end trace 63f4a46f6566d737 ]---
During device removal hid_disconnect() is called via hid_hw_stop() to
stop the device and free all its resources, including the sysfs
files. The problem is that if a user space process, such as upowerd,
holds a reference to a hidraw file the corresponding sysfs files will
be kept around (drop_ref() does not call device_destroy() if the open
counter is not 0) and it will be usb_disconnect() who, by calling
device_del() for the USB device, will indirectly remove the sysfs
files of the hidraw device (sysfs_remove_dir() is recursive these
days). Because of this, by the time user space releases the last
reference to the hidraw file and drop_ref() tries to destroy the
device the sysfs files are already gone and the kernel will print
the warning above.
Fix this by calling device_destroy() at USB disconnect time.
Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp>
Reviewed-by: David Herrmann <dh.herrmann@gmail.com>
Cc: stable@vger.kernel.org # 3.13
Don't initialize force-feedback for devices that don't support it to avoid calls
to schedule_work() with an uninitialized work_struct.
Move the cancel_work_sync() call out of sony_destroy_ff() since the state worker
is used for the LEDs even when force-feedback is disabled.
Remove sony_destroy_ff() to avoid a compiler warning since it is no longer used.
Signed-off-by: Frank Praznik <frank.praznik@oh.rr.com>
Pull HID update from Jiri Kosina:
- fixes for several bugs in incorrect allocations of buffers by David
Herrmann and Benjamin Tissoires.
- support for a few new device IDs by Archana Patni, Benjamin
Tissoires, Huei-Horng Yo, Reyad Attiyat and Yufeng Shen
HID: hyperv: make sure input buffer is big enough
HID: Bluetooth: hidp: make sure input buffers are big enough
HID: hid-sensor-hub: quirk for STM Sensor hub
HID: apple: add Apple wireless keyboard 2011 JIS model support
HID: fix buffer allocations
HID: multitouch: add FocalTech FTxxxx support
HID: microsoft: Add ID's for Surface Type/Touch Cover 2
HID: usbhid: quirk for CY-TM75 75 inch Touch Overlay
We need at least HID_MAX_BUFFER_SIZE (4096) bytes as input buffer. HID
core depends on this as it requires every input report to be at least as
big as advertised.
Signed-off-by: David Herrmann <dh.herrmann@gmail.com>
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
Added STM sensor hub vendor id in HID_SENSOR_HUB_ENUM_QUIRK to
fix report descriptors. These devices uses old FW which uses
logical 0 as minimum. In these, HID reports are not using proper
collection classes. So we need to fix report descriptors,for
such devices. This will not have any impact, if the FW uses
logical 1 as minimum.
We look for usage id for "power and report state", and modify
logical minimum value to 1.
This is a follow-up patch to commit id 875e36f8.
Signed-off-by: Archana Patni <archana.patni@linux.intel.com>
Reviewed-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
Add Apple wireless keyboard 2011 JIS model (05ac:0257).
Signed-off-by: Huei-Horng Yo <hiroshi@ghostsinthelab.org>
When using hid_output_report(), the buffer should be allocated by hid_alloc_report_buf(),
not a custom malloc.
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media updates from Mauro Carvalho Chehab:
- a new jpeg codec driver for Samsung Exynos (jpeg-hw-exynos4)
- a new dvb frontend for ds2103 chipset (m88ds2103)
- a new sensor driver for Samsung S5K5BAF UXGA (s5k5baf)
- new drivers for R-Car VSP1
- a new radio driver: radio-raremono
- a new tuner driver for ts2022 chipset (m88ts2022)
- the analog part of em28xx is now a separate module that only
load/runs if the device is not a pure digital TV device
- added a staging driver for bcm2048 radio devices
- the omap 2 video driver (omap24xx) was moved to staging. This driver
is for an old hardware and uses a deprecated Kernel internal API. If
nobody cares enough to fix it, it would be removed on a couple Kernel
releases
- the sn9c102 driver was moved to staging. This driver was replaced by
gspca, and disabled on some distros, as almost all devices are known
to work properly with gspca. It should be removed from kernel on a
couple Kernel releases
- lots of driver fixes, improvements and cleanups
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (421 commits)
[media] media: v4l2-dev: fix video device index assignment
[media] rc-core: reuse device numbers
[media] em28xx-cards: properly initialize the device bitmap
[media] Staging: media: Fix line length exceeding 80 characters in as102_drv.c
[media] Staging: media: Fix line length exceeding 80 characters in as102_fe.c
[media] Staging: media: Fix quoted string split across line in as102_fe.c
[media] media: st-rc: Add reset support
[media] m2m-deinterlace: fix allocated struct type
[media] radio-usb-si4713: fix sparse non static symbol warnings
[media] em28xx-audio: remove needless check before usb_free_coherent()
[media] au0828: Fix sparse non static symbol warning
Revert "[media] go7007-usb: only use go->dev after allocated"
[media] em28xx-audio: provide an error code when URB submit fails
[media] em28xx: fix check for audio only usb interfaces when changing the usb alternate setting
[media] em28xx: fix usb alternate setting for analog and digital video endpoints > 0
[media] em28xx: make 'em28xx_ctrl_ops' static
em28xx-alsa: Fix error patch for init/fini
[media] em28xx-audio: flush work at .fini
[media] drxk: remove the option to load firmware asynchronously
[media] em28xx: adjust period size at runtime
This is a Win7 device which does not work correctly with the default
settings (not the previous default BT).
However, the quirk ALWAYS_TRUE makes it working like a charm.
The Microsoft Surface Type/Touch cover 2 devices have the flag HID_DG_CONTACTID
in their reports.This causes the device to bind to the hid-multitouch driver,
which doesn't handle generic keyboard/mouse input events. The patch adds
the hardware id's of the device to hid-microsoft and to the HID special
driver array, which makes the device get handled by hid-generic/hid-input
properly.
Fixes: https://bugzilla.kernel.org/show_bug.cgi?id=64811
Singed-off-by: Reyad Attiyat <reyad.attiyat@gmail.com>
Reviewed-by: Benjamin Tissoires<benjamin.tissoires@redhat.com>
There is timeout error during initialization:
kernel: [ 11.733104] hid-multitouch 0003:1870:0110.0001: usb_submit_urb(ctrl) failed: -1
kernel: [ 11.734093] hid-multitouch 0003:1870:0110.0001: timeout initializing reports
Adding quirk HID_QUIRK_NO_INIT_REPORTS can solve the problem.
Signed-off-by: Yufeng Shen <miletus@chromium.org>
Pull ACPI and power management updates from Rafael Wysocki:
"As far as the number of commits goes, the top spot belongs to ACPI
this time with cpufreq in the second position and a handful of PM
core, PNP and cpuidle updates. They are fixes and cleanups mostly, as
usual, with a couple of new features in the mix.
The most visible change is probably that we will create struct
acpi_device objects (visible in sysfs) for all devices represented in
the ACPI tables regardless of their status and there will be a new
sysfs attribute under those objects allowing user space to check that
status via _STA.
Consequently, ACPI device eject or generally hot-removal will not
delete those objects, unless the table containing the corresponding
namespace nodes is unloaded, which is extremely rare. Also ACPI
container hotplug will be handled quite a bit differently and cpufreq
will support CPU boost ("turbo") generically and not only in the
acpi-cpufreq driver.
Specifics:
- ACPI core changes to make it create a struct acpi_device object for
every device represented in the ACPI tables during all namespace
scans regardless of the current status of that device. In
accordance with this, ACPI hotplug operations will not delete those
objects, unless the underlying ACPI tables go away.
- On top of the above, new sysfs attribute for ACPI device objects
allowing user space to check device status by triggering the
execution of _STA for its ACPI object. From Srinivas Pandruvada.
- ACPI core hotplug changes reducing code duplication, integrating
the PCI root hotplug with the core and reworking container hotplug.
- ACPI core simplifications making it use ACPI_COMPANION() in the
code "glueing" ACPI device objects to "physical" devices.
- ACPICA update to upstream version 20131218. This adds support for
the DBG2 and PCCT tables to ACPICA, fixes some bugs and improves
debug facilities. From Bob Moore, Lv Zheng and Betty Dall.
- Init code change to carry out the early ACPI initialization
earlier. That should allow us to use ACPI during the timekeeping
initialization and possibly to simplify the EFI initialization too.
From Chun-Yi Lee.
- Clenups of the inclusions of ACPI headers in many places all over
from Lv Zheng and Rashika Kheria (work in progress).
- New helper for ACPI _DSM execution and rework of the code in
drivers that uses _DSM to execute it via the new helper. From
Jiang Liu.
- New Win8 OSI blacklist entries from Takashi Iwai.
- Assorted ACPI fixes and cleanups from Al Stone, Emil Goode, Hanjun
Guo, Lan Tianyu, Masanari Iida, Oliver Neukum, Prarit Bhargava,
Rashika Kheria, Tang Chen, Zhang Rui.
- intel_pstate driver updates, including proper Baytrail support,
from Dirk Brandewie and intel_pstate documentation from Ramkumar
Ramachandra.
- Generic CPU boost ("turbo") support for cpufreq from Lukasz
Majewski.
- powernow-k6 cpufreq driver fixes from Mikulas Patocka.
- cpufreq core fixes and cleanups from Viresh Kumar, Jane Li, Mark
Brown.
- Assorted cpufreq drivers fixes and cleanups from Anson Huang, John
Tobias, Paul Bolle, Paul Walmsley, Sachin Kamat, Shawn Guo, Viresh
Kumar.
- cpuidle cleanups from Bartlomiej Zolnierkiewicz.
- Support for hibernation APM events from Bin Shi.
- Hibernation fix to avoid bringing up nonboot CPUs with ACPI EC
disabled during thaw transitions from Bjørn Mork.
- PM core fixes and cleanups from Ben Dooks, Leonardo Potenza, Ulf
Hansson.
- PNP subsystem fixes and cleanups from Dmitry Torokhov, Levente
Kurusa, Rashika Kheria.
- New tool for profiling system suspend from Todd E Brandt and a
cpupower tool cleanup from One Thousand Gnomes"
* tag 'pm+acpi-3.14-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (153 commits)
thermal: exynos: boost: Automatic enable/disable of BOOST feature (at Exynos4412)
cpufreq: exynos4x12: Change L0 driver data to CPUFREQ_BOOST_FREQ
Documentation: cpufreq / boost: Update BOOST documentation
cpufreq: exynos: Extend Exynos cpufreq driver to support boost
cpufreq / boost: Kconfig: Support for software-managed BOOST
acpi-cpufreq: Adjust the code to use the common boost attribute
cpufreq: Add boost frequency support in core
intel_pstate: Add trace point to report internal state.
cpufreq: introduce cpufreq_generic_get() routine
ARM: SA1100: Create dummy clk_get_rate() to avoid build failures
cpufreq: stats: create sysfs entries when cpufreq_stats is a module
cpufreq: stats: free table and remove sysfs entry in a single routine
cpufreq: stats: remove hotplug notifiers
cpufreq: stats: handle cpufreq_unregister_driver() and suspend/resume properly
cpufreq: speedstep: remove unused speedstep_get_state
platform: introduce OF style 'modalias' support for platform bus
PM / tools: new tool for suspend/resume performance optimization
ACPI: fix module autoloading for ACPI enumerated devices
ACPI: add module autoloading support for ACPI enumerated devices
ACPI: fix create_modalias() return value handling
'for-3.14/sensor-hub', 'for-3.14/sony' and 'for-3.14/upstream' into for-linus
Use the naming scheme 'devicename:colour' for the Dualshock 4
LED lightbar controls as specified in Documentation/leds/leds-class.txt
Add annotated HID descriptor for the Dualshock 4.
Retrieve and cache the output report for the Dualshock 4 in sony_probe()
instead of repeatedly walking the report list in the worker function.
Use a modified HID descriptor for the Dualshock 4 to assign the gyroscope
sensors and accelerometers to axes.
Fix cosmetic spacing in the device definitions.
to the Dualshock 4.
Use regular HID output reports instead of raw reports in the
dualshock4_state_worker function. (Thanks Simon Mungewell)
Dualshock 4 controllers.
Use separate identifiers for Dualshock 4 controllers connected via USB and
Bluetooth.
Added support of RITMIX ROM-316 mouse to hid-holtek-mouse workaround module
Signed-off-by: Alexey Kharlamov <derlafff@ya.ru>
This addresses regression caused by commit id "751d17e23a9f7"
iio: hid-sensors: Fix power and report state.
This commit removed a quirk, to change the enumeration base
to 1 from 0 based on an CONFIG paramter. There was objection to
add more changes under this quirk, instead suggested to add an
HID quirk. But there is no easy way to add HID qurik as the
reports are not properly using collection class.
The solution was to use logical minimum, which is a correct way.
There were changes done in firmware to address this.
Unfortunately some devices, still use old FW and can't be upgraded
to newer version on Linux devices as there is no FW upgrade tool
available for Linux devices. So we need to fix report descriptors,
for such devices. This will not have any impact, if the FW uses
In this patch we look for usage id for "power and report state", and
modify logical minimum value to 1.
Background on enum:
In the original HID sensor hub firmwares all Named array enums were
to 0-based. But the most recent hub implemented as 1-based,
because of the implementation by one of the major OS vendor.
Using logical minimum for the field as the base of enum. So we add
logical minimum to the selector values before setting those fields.
Some sensor hub FWs already changed logical minimum from 0 to 1
to reflect this and hope every other vendor will follow.
There is no easy way to add a common HID quirk for NAry elements,
even if the standard specifies these field as NAry, the collection
used to describe selectors is still just "logical".
Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
This fix (not very clean though) should fix the long time USB3
issue that was spotted last year. The rational has been given by
Hans de Goede:
I think the most likely cause for this is a firmware bug
in the unifying receiver, likely a race condition.
The most prominent difference between having a USB-2 device
plugged into an EHCI (so USB-2 only) port versus an XHCI
port will be inter packet timing. Specifically if you
send packets (ie hid reports) one at a time, then with
the EHCI controller their will be a significant pause
between them, where with XHCI they will be very close
together in time.
The reason for this is the difference in EHCI / XHCI
controller OS <-> driver interfaces.
For non periodic endpoints (control, bulk) the EHCI uses a
circular linked-list of commands in dma-memory, which it
follows to execute commands, if the list is empty, it
will go into an idle state and re-check periodically.
The XHCI uses a ring of commands per endpoint, and if the OS
places anything new on the ring it will do an ioport write,
waking up the XHCI making it send the new packet immediately.
For periodic transfers (isoc, interrupt) the delay between
packets when sending one at a time (rather then queuing them
up) will be even larger, because they need to be inserted into
the EHCI schedule 2 ms in the future so the OS driver can be
sure that the EHCI driver does not try to start executing the
time slot in question before the insertion has completed.
So a possible fix may be to insert a delay between packets
being send to the receiver.
I tested this on a buggy Haswell USB 3.0 motherboard, and I always
get the notification after adding the msleep.
Rename sony_state_worker to sixaxis_state_worker since the function is now
sixaxis specific.
Add LED lightbar controls for the Dualshock 4.
The Dualshock 4 light bar has 3 separate RGB LEDs that can range in
brightness from 0 to 255 so a full byte is now needed to store each LED's
state
Changed the module to support an arbitrary number of LEDs instead of being
hardcoded to 4.
Adds the Dualshock 4 to the HID device list and enables force-feedback.
Adds a Dualshock 4 specific worker function since the Dualshock 4 needs a
different report than the Sixaxis.
The right motor in the Dualshock 4 is variable so the full rumble value
is now passed to the worker function and clamped there if necessary.
Reformat and reword some of the comments to make them more understandable.
Use helper functions to simplify _DSM related code in i2c-hid driver.
Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com>
Currently the return variable ret is always 0. Set it to other values in
error cases, as used in the direct return.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
if@p1 (\(ret < 0\|ret != 0\))
{ ... return ret; }
ret@p1 = 0
... when != ret = e1
when != &ret
*if(...)
... when != ret = e2
when forall
return ret;
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
we used to set the parent of the input device as the parent of
the hid bus. This was introduced when we created hid as a real bus, and
to keep backward compatibility. Now, it's time to proper set the parent
so that sysfs has an idea of which input device is attached to
which hid device.
The Si4713 development board contains a Si4713 FM transmitter chip
and is handled by the radio-usb-si4713 driver.
The board reports itself as (10c4:8244) Cygnal Integrated Products, Inc.
and misidentifies itself as a HID device in its USB interface descriptor.
This patch ignores this device as an HID device and hence loads the custom driver.
Signed-off-by: Dinesh Ram <dinesh.ram@cern.ch>
Acked-by: Jiri Kosina <jkosina@suse.cz>
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Tested-by: Eduardo Valentin <edubezval@gmail.com>
Acked-by: Eduardo Valentin <edubezval@gmail.com>
Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
Add labels for BTN_DPAD_UP, BTN_DPAD_DOWN, BTN_DPAD_LEFT, BTN_DPAD_RIGHT and
BTN_TOOL_QUADTAP.
[jkosina@suse.cz: make changelog more verbose]
Signed-off-by: Antonio Ospite <ospite@studenti.unina.it>
The entries are not needed, as hid-multitouch gets bound correctly
automatically by contact ID.
For 0xff05 usage in MS ergonomy keyboard quirk, we are falling through
and returning 0 instread of properly (because we've performed new mapping)
returning 1. Fix that.
Reported-by: Joe Perches <joe@perches.com>
- Genius Gx Imperator Keyboard regression fix (missing break in case),
by Ben Hutchings
- duplicate sysfs entry error fix for hid-sensor-hub driver, by
Srinivas Pandruvada
HID: hid-sensor-hub: fix duplicate sysfs entry error
HID: kye: Fix missing break in kye_report_fixup()
[jkosina@suse.cz: refresh to apply after SIS quirk merging]
Signed-off-by: Emanuel Krenz <emanuelkrenz@web.de>
Fix kernel warning and failure to register sensor hub devices with MFD. Now
many devices has in-built sensor hubs. So by default this HID hub, is properly
parsed and register individual sensors as platform device using MFD framework.
But if a second sensor hub is attached via USB, which has same sensors, it will
result in kernel warning and failure to register MFD cell as the platform
device sysfs file name will be same as created by in-built sensor hubs. This
patch sets MFD cell id to PLATFORM_DEVID_AUTO. In this way there will never be
duplicate sysfs file names.
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-linus
Jonathan writes:
Second round of IIO fixes for the 3.13 cycle.
2 fixes here.
* The gp2ap020a00f is a simple missing kconfig dependency.
* The hid sensors hub fix is a work around for an issue introduced by hardware
changes due to a certain large software vendor having an 'interesting'
interpretation of the specification and hence indexing some arrays from 1
rather than 0. The fix takes advantage of the logical min and max reading
facilities introduced by the precursor patch to figure out whether we have
a 0 indexed or 1 indexed device and to adjust appropriately. It also
drops a previous kconfig option that allowed this issue to be worked around
at build time.
hid-logitech-dj.c driver needs hidraw to work correctly. Without
hidraw, hid-logitech-dj.c fails during probe() and Logitech
Unifying devices HID reports aren't recognized.
The unifying receiver has 3 usb interfaces. When hid-logitech-dj driver is
loaded, interfaces 0 and 1 are discarded.
Interface 2 consists of a hid class interface with 3 collections, each of
which sports the 'vendor' usage, thus, there is no reason for hid_input to
claim any of them. On the other hand, hidraw has no issue in claiming the
collections, even if they are 'vendor'. As of today, hid-logitech-dj uses
hidraw api to send configuration/control reports to interface 2 of the
Unifying receiver.
Without the hid-logitech-dj driver, interfaces 0 and 1 are claimed by
hid-input, as they correspond to a keyboard and a mouse. But that is not
relevant to the discussion.
[jkosina@suse.cz: make the changelog more verbose, thanks to Nestor]
Signed-off-by: Olivier Gay <ogay@logitech.com>
Signed-off-by: Nestor Lopez Casado <nlopezcasad@logitech.com>
Signed-off-by: Mathieu Meisser <mmeisser@logitech.com>
I have two Logitech Dual Action gamepads, both have same Vendor/Device id pair.
Newest gamepad (A) can switch between old mode (HID) and XBox gamepad emulation
mode. Old gamepad (B) can only work in HID mode. In HID mode gamepad A sends
many EPIPE errors during initialization and was disconnected immediately after
connect to usb port. It works fine in Win and Mac. After adding NOGET quirk in
driver, it was working properly. Gamepad B works fine before and after
changes. I tested both gamepads with 3.8.0 and 3.11.6 kernels with modified
driver. Follow patch can apply for current git kernel version. I can send pcap
log from usb bus with both gamepads or any other additional information if it
is needed
Signed-off-by: Vitaly Katraew <zawullon@gmail.com>
Exporting logical minimum and maximum of HID fields as part of the
hid sensor attribute info. This can be used for range checking and
to calculate enumeration base for NAry fields of HID sensor hub.
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
Since commit 765e5fbd merged the sis quirk,
then USB_VENDOR_ID_SIS2_TOUCH remains undefined.
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Signed-off-by: Wanlong Gao <gaowanlong@cn.fujitsu.com>
The change to support Genius Manticore Keyboard also changed behaviour
for Genius Gx Imperator Keyboard, as there is no break between the
cases. This is presumably a mistake.
Reported by Coverity as CID 1134029.
Fixes: 4a2c94c9b6c0 ('HID: kye: Add report fixup for Genius Manticore Keyboard')
Add Synaptics HD touchscreen(06cb:1ac3) to no init report quirk
Signed-off-by: AceLan Kao <acelan.kao@canonical.com>
