path: root/drivers/hwmon/asus_atk0110.c
2011-07-17hwmon: (asus_atk0110) Fix memory leakLuca Tettamanti
The object returned by atk_gitm is dynamically allocated and must be freed. Signed-off-by: Luca Tettamanti <kronos.it@gmail.com> Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: stable@kernel.org
2011-06-17hwmon: (asus_atk0110) Consolidate sysfs attribute initializationGuenter Roeck
Call sysfs_attr_init() from atk_init_attribute() to handle sysfs attribute initialization in a single function. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Cc: Luca Tettamanti <kronos.it@gmail.com> Acked-by: Jean Delvare <khali@linux-fr.org>
2011-01-23hwmon: (asus_atk0110) Override interface detection on Sabertooth X58Luca Tettamanti
ASUS Sabertooth X58 has a bug in ACPI that prevents the reading of MCH temperature when the "old" ATK0110 interface is used. Add a DMI entry to override the detection heuristic and force the use of the "new" interface on this board. Signed-off-by: Luca Tettamanti <kronos.it@gmail.com> Tested-by: Joris Creyghton <jorisctn@gmail.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-01-08hwmon: (asus_atk0110) Use pr_fmt and pr_<level>Joe Perches
Added #define pr_fmt KBUILD_MODNAME ": " fmt Converted printks to pr_<level> Coalesced any long formats Removed prefixes from formats Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-05-27hwmon: (asus_atk0110) Don't load if ACPI resources aren't enforcedJean Delvare
When the user passes the kernel parameter acpi_enforce_resources=lax, the ACPI resources are no longer protected, so a native driver can make use of them. In that case, we do not want the asus_atk0110 to be loaded. Unfortunately, this driver loads automatically due to its MODULE_DEVICE_TABLE, so the user ends up with two drivers loaded for the same device - this is bad. So I suggest that we prevent the asus_atk0110 driver from loading if acpi_enforce_resources=lax. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Luca Tettamanti <kronos.it@gmail.com> Cc: Len Brown <lenb@kernel.org>
2010-04-22sysfs: use sysfs_attr_init in ASUS atk0110 driverJiri Kosina
Annotate dynamic sysfs attribute in atk_create_files(). This gets rid of the following lockdep warning: BUG: key ffff8800379ca670 not in .data! ------------[ cut here ]------------ WARNING: at kernel/lockdep.c:2696 lockdep_init_map+0xd2/0x108() Hardware name: P5K PRO Modules linked in: asus_atk0110(+) pata_acpi firewire_ohci ata_generic dm_multipath firewire_core crc_itu_t pata_marvell floppy Pid: 599, comm: modprobe Not tainted 2.6.34-rc4 #27 Call Trace: [<ffffffff8104cdb0>] warn_slowpath_common+0x7c/0x94 [<ffffffff8104cddc>] warn_slowpath_null+0x14/0x16 [<ffffffff81077c4d>] lockdep_init_map+0xd2/0x108 [<ffffffff81165873>] sysfs_add_file_mode+0x66/0xa2 [<ffffffff811658c0>] sysfs_add_file+0x11/0x13 [<ffffffff8116594b>] sysfs_create_file+0x2a/0x2c [<ffffffff812c1f9c>] device_create_file+0x19/0x1b [<ffffffffa005b4fd>] atk_add+0x58b/0x72e [asus_atk0110] [<ffffffff812572a1>] acpi_device_probe+0x50/0x122 [<ffffffff812c46af>] driver_probe_device+0xa2/0x127 [<ffffffff812c4783>] __driver_attach+0x4f/0x6b [<ffffffff812c4734>] ? __driver_attach+0x0/0x6b [<ffffffff812c3c94>] bus_for_each_dev+0x59/0x8e [<ffffffff812c4519>] driver_attach+0x1e/0x20 [<ffffffff812c4152>] bus_add_driver+0xb9/0x207 [<ffffffff812c4a5f>] driver_register+0x9d/0x10e [<ffffffffa005f000>] ? atk0110_init+0x0/0x31 [asus_atk0110] [<ffffffff81257c7c>] acpi_bus_register_driver+0x43/0x45 [<ffffffffa005f015>] atk0110_init+0x15/0x31 [asus_atk0110] [<ffffffffa005f000>] ? atk0110_init+0x0/0x31 [asus_atk0110] [<ffffffff81002069>] do_one_initcall+0x5e/0x15e [<ffffffff81085075>] sys_init_module+0xd8/0x239 [<ffffffff81009cf2>] system_call_fastpath+0x16/0x1b ---[ end trace 4d0c84007055efb9 ]--- BUG: key ffff8800379ca638 not in .data! BUG: key ffff8800379ca6a8 not in .data! BUG: key ffff8800379ca6e0 not in .data! BUG: key ffff880036f73670 not in .data! BUG: key ffff880036f73638 not in .data! BUG: key ffff880036f736a8 not in .data! BUG: key ffff880036f736e0 not in .data! BUG: key ffff880036f76c70 not in .data! BUG: key ffff880036f76c38 not in .data! BUG: key ffff880036f76ca8 not in .data! BUG: key ffff880036f76ce0 not in .data! BUG: key ffff8800368e7670 not in .data! BUG: key ffff8800368e7638 not in .data! BUG: key ffff8800368e76a8 not in .data! BUG: key ffff8800368e76e0 not in .data! BUG: key ffff880036ef7670 not in .data! BUG: key ffff880036ef7638 not in .data! BUG: key ffff880036ef76a8 not in .data! BUG: key ffff880036ef76e0 not in .data! BUG: key ffff8800373ccc70 not in .data! BUG: key ffff8800373ccc38 not in .data! BUG: key ffff8800373ccca8 not in .data! BUG: key ffff8800373ccce0 not in .data! BUG: key ffff880037a60870 not in .data! BUG: key ffff880037a60838 not in .data! BUG: key ffff880037a608a8 not in .data! BUG: key ffff880037a608e0 not in .data! BUG: key ffff880037355070 not in .data! BUG: key ffff880037355038 not in .data! BUG: key ffff8800373550a8 not in .data! BUG: key ffff8800373550e0 not in .data! BUG: key ffff8800378c2670 not in .data! BUG: key ffff8800378c2638 not in .data! BUG: key ffff8800378c26a8 not in .data! BUG: key ffff8800378c26e0 not in .data! BUG: key ffff880036ef7e70 not in .data! BUG: key ffff880036ef7e38 not in .data! BUG: key ffff880036ef7ea8 not in .data! BUG: key ffff880036ef7ee0 not in .data! Cc: Eric W. Biederman <ebiederm@xmission.com> Reported-by: Dhaval Giani <dhaval.giani@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Tested-by: Dhaval Giani <dhaval.giani@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-01-25hwmon: (asus_atk0110) Do not fail if MBIF is missingLuca Tettamanti
MBIF (motherboard identification) is only used to print the name of the board, it's not essential for the driver; do not fail if it's missing. Based on Juan's patch. Signed-off-by: Luca Tettamanti <kronos.it@gmail.com> Acked-by: Juan RP <xtraeme@gmail.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-01-10hwmon: (asus_atk0110) Add debugfs interfaceLuca Tettamanti
Expose the raw GGRP/GITM interface via debugfs. The hwmon interface is reverse engineered and the driver tends to break on newer boards... Using this interface it's possible to poke directly at the ACPI methods without the need to recompile, reducing the guesswork and the round trips needed to support a new revision of the interface. Signed-off-by: Luca Tettamanti <kronos.it@gmail.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-01-10hwmon: (asus_atk0110) Refactor interface probe codeLuca Tettamanti
The behaviour is unmodified, this makes easier to override the heuristic (which is probably needed for some boards). Signed-off-by: Luca Tettamanti <kronos.it@gmail.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-10-09hwmon: (asus_atk0110) Enable the ECLuca Tettamanti
On newer ASUS boards (e.g. P7P55D) the EC (that - among other things - is responsible for updating the readings from the hwmon sensors) is disabled by default since ASUS detected conflict with some tools under Windows. The following patch checks the state of the EC and enable it if needed; under Linux, native drivers are locked out from ACPI owned resources so there's no risk of conflict. Signed-off-by: Luca Tettamanti <kronos.it@gmail.com> Tested-by: Robert Hancock <hancockrwd@gmail.com> Tested-by: Thomas Backlund <tmb@mandriva.org> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-10-09hwmon: (asus_atk0110) Refactor the codeLuca Tettamanti
Refactor the code of the new style interface around GGRP (enumeration) and GITM (read) helpers to mimic ASL code. Also switch the read path to use dynamic buffers (handled by ACPI core) since ASUS expanded the return buffer (ASBF) in newer boards (e.g. P7P55D). Signed-off-by: Luca Tettamanti <kronos.it@gmail.com> Tested-by: Robert Hancock <hancockrwd@gmail.com> Tested-by: Thomas Backlund <tmb@mandriva.org> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-07-28hwmon: (asus_atk0110) Fix upper limit readingsLuca Tettamanti
On newer Asus boards the "upper" limit of a sensor is encoded as delta from the "lower" limit. Fix the driver to correctly handle this case. Signed-off-by: Luca Tettamanti <kronos.it@gmail.com> Tested-by: Alex Macfarlane Smith <nospam@archifishal.co.uk> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-05-08hwmon: (asus_atk0110) Fix compiler warningLuca Tettamanti
atk_sensor_type is only used when DEBUG is defined. Signed-off-by: Luca Tettamanti <kronos.it@gmail.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-04-07hwmon: Add Asus ATK0110 supportLuca Tettamanti
Asus boards have an ACPI interface for interacting with the hwmon (fan, temperatures, voltages) subsystem; this driver exposes the relevant information via the standard sysfs interface. There are two different ACPI interfaces: - an old one (based on RVLT/RFAN/RTMP) - a new one (GGRP/GITM) Both may be present but there a few cases (my board, sigh) where the new interface is just an empty stub; the driver defaults to the old one when both are present. The old interface has received a considerable testing, but I'm still awaiting confirmation from my tester that the new one is working as expected (hence the debug code is still enabled). Currently all the attributes are read-only, though a (partial) control should be possible with a bit more work. Signed-off-by: Luca Tettamanti <kronos.it@gmail.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
