commit 3f9aec7610b39521c7c69d754de7265f6994c194 upstream.
When the core number exceeds 9, the size of the buffer storing the
alarm attribute name is insufficient and the attribute name is
truncated. This causes libsensors to skip these attributes as the
truncated name is not recognized.
Reported-by: Andreas Hollmann <hollmann@in.tum.de>
Cc: Corentin Labbe <corentin.labbe@geomatys.fr>
Cc: Mark M. Hoffman <mhoffman@lightlink.com>
Cc: Juerg Haefliger <juergh@gmail.com>
Cc: Andreas Herrmann <herrmann.der.user@googlemail.com>
Cc: Rudolf Marek <r.marek@assembler.cz>
Cc: Jim Cromie <jim.cromie@gmail.com>
Cc: Roger Lucas <vt8231@hiddenengine.co.uk>
Cc: Marc Hulsman <m.hulsman@tudelft.nl>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core updates from Greg Kroah-Hartman:
"Here's the large driver core updates for 3.8-rc1.
The biggest thing here is the various __dev* marking removals. This
is going to be a pain for the merge with different subsystem trees, I
know, but all of the patches included here have been ACKed by their
various subsystem maintainers, as they wanted them to go through here.
If this is too much of a pain, I can pull all of them out of this tree
and just send you one with the other fixes/updates and then, after
3.8-rc1 is out, do the rest of the removals to ensure we catch them
all, it's up to you. The merges should all be trivial, and Stephen
has been doing them all in linux-next for a few weeks now quite
easily.
Other than the __dev* marking removals, there's nothing major here,
some firmware loading updates and other minor things in the driver
core.
All of these have (much to Stephen's annoyance), been in linux-next
for a while.
Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>"
Fixed up trivial conflicts in drivers/gpio/gpio-{em,stmpe}.c due to gpio
update.
* tag 'driver-core-3.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (93 commits)
modpost.c: Stop checking __dev* section mismatches
init.h: Remove __dev* sections from the kernel
acpi: remove use of __devinit
PCI: Remove __dev* markings
PCI: Always build setup-bus when PCI is enabled
PCI: Move pci_uevent into pci-driver.c
PCI: Remove CONFIG_HOTPLUG ifdefs
unicore32/PCI: Remove CONFIG_HOTPLUG ifdefs
sh/PCI: Remove CONFIG_HOTPLUG ifdefs
powerpc/PCI: Remove CONFIG_HOTPLUG ifdefs
mips/PCI: Remove CONFIG_HOTPLUG ifdefs
microblaze/PCI: Remove CONFIG_HOTPLUG ifdefs
dma: remove use of __devinit
dma: remove use of __devexit_p
firewire: remove use of __devinitdata
leds: remove use of __devexit
leds: remove use of __devinit
leds: remove use of __devexit_p
mmc: remove use of __devexit
Since N4xx, N5xx, D4xx, and D5xx are now reliably detected using the model ID
and the stepping/mask, drop the respective entries from tjmax_table.
Acked-by: Jean Delvare <khali@linux-fr.org>
Make the code easier to extend and easier to adjust by using a model table
listing CPU models, stepping/mask, and associated TjMax.
So far, we use the NM10 Express Chipset PCI chip ID to detect TjMax for
Atom CPUs with model 0x1c. As it turns out, we can use the CPU stepping
(x86_mask) for the same purpose; stepping is 10 for all model 0x1c CPUs
with TjMax of 100 degrees C. This was verified by checking the output of
/proc/cpuinfo for the respective CPUs (D4xx, D5xx, N4xx, N5xx).
Other CPUs currently covered by the same code (Exx, Z6xx, Z2460) are not
supported by the NM10 Express Chipset. Most of those CPUs have TjMax of 90
degrees C, except for E6xxT models which have a TjMax of 110 degrees C.
E6xxT CPUs can however not be detected by software.
Calculate TjMax for Atom CPUs as follows. Note that the listed values are not
correct in some cases (230, 330). tjmax_table is used for those to override
the default values.
ID Stepping TjMax Models
0x1c 10 100 D4xx, N4xx, D5xx, N5xx
0x1c not 10 90 Z5xx, N2xx, 230, 330, others
0x26 - 90 Atom Tunnel Creek (Exx),
Lincroft (Z6xx)
0x27 - 90 Atom Medfield (Z2460)
0x36 - 100 Atom Cedar Trail (N2xxx, D2xxx)
Also drop the module dependency on PCI.
CONFIG_HOTPLUG is going away as an option so __devexit is no
longer needed.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Cc: Hans de Goede <hdegoede@redhat.com>
Cc: Jean Delvare <khali@linux-fr.org>
Cc: Alistair John Strachan <alistair@devzero.co.uk>
Cc: Clemens Ladisch <clemens@ladisch.de>
Cc: "Mark M. Hoffman" <mhoffman@lightlink.com>
Acked-by: Guenter Roeck <linux@roeck-us.net>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
CONFIG_HOTPLUG is going away as an option so __devinit is no longer
needed.
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer
needed.
TjMax for the CE4100 series of Atom CPUs was previously reported to be
110 degrees C.
cpuinfo logs on the web show existing CPU types CE4110, CE4150, and CE4170,
reported as "model name : Intel(R) Atom(TM) CPU CE41{1|5|7}0 @ 1.{2|6}0GHz"
with model 28 (0x1c) and stepping 10 (0x0a). Add the three known variants
to the tjmax table.
cc: stable@vger.kernel.org
coretemp_init loops with for_each_online_cpu, adding platform_devices
and sysfs interfaces, then calls register_hotcpu_notifier. There is a
race if a CPU is offlined or onlined after the loop, but before
register_hotcpu_notifier. The race might result in the absence of a
platform_device+sysfs interface for an online CPU, or the presence of
a platform_device+sysfs interface for an offline CPU. A similar race
occurs during coretemp_exit, after the module calls
unregister_hotcpu_notifier, but before it unregisters all devices, a
CPU might offline and a device for an offline CPU will exist for a
short while.
This fix surrounds for_each_online_cpu and register_hotcpu_notifier
with get_online_cpus+put_online_cpus; and surrounds
unregister_hotcpu_notifier and device unregistering with
get_online_cpus+put_online_cpus.
Build tested.
Signed-off-by: Silas Boyd-Wickizer <sbw@mit.edu>
... as being referenced from __init code only.
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Pull x86 fixes from Ingo Molnar.
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, cpufeature: Remove stray %s, add -w to mkcapflags.pl
x86, cpufeature: Catch duplicate CPU feature strings
x86, cpufeature: Rename X86_FEATURE_DTS to X86_FEATURE_DTHERM
x86: Fix kernel-doc warnings
x86, compat: Use test_thread_flag(TIF_IA32) in compat signal delivery
It makes sense to label "Digital Thermal Sensor" as "DTS", but
unfortunately the string "dts" was already used for "Debug Store", and
/proc/cpuinfo is a user space ABI.
Therefore, rename this to "dtherm".
This conflict went into mainline via the hwmon tree without any x86
maintainer ack, and without any kind of hint in the subject.
a4659053 x86/hwmon: fix initialization of coretemp
Reported-by: Jean Delvare <khali@linux-fr.org>
Link: http://lkml.kernel.org/r/4FE34BCB.5050305@linux.intel.com
Cc: Jan Beulich <JBeulich@suse.com>
Cc: <stable@vger.kernel.org> v2.6.36..v3.4
The value is overridden a few lines later.
Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
Atom CPUs don't have a register to retrieve TjMax. Detection so far was
incomplete. Use the X86 model ID to improve it.
Document the Atom series D2000 and N2000 (Cedar Trail) as being supported.
List and set TjMax for those series.
Cc: "R, Durgadoss" <durgadoss.r@intel.com>
Document the new Atom series (Tunnel Creek and Medfield) as being
supported, and list TjMax for the Atom E600 series.
Also enable the Atom tjmax heuristic for these Atom CPU models.
Reviewed-by: Guenter Roeck <guenter.roeck@ericsson.com>
Cc: Alexander Stein <alexander.stein@systec-electronic.com>
CPU core ID is used to index the core_data[] array. The core ID is, however, not
sequential; 10-core CPUS can have a core ID as high as 25. Increase the limit to
32 to be able to deal with current CPUs.
Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
Cc: stable@vger.kernel.org # 3.0+
Acked-by: Durgadoss R <durgadoss.r@intel.com>
coretemp tries to access core_data array beyond bounds on cpu unplug if
core id of the cpu if more than NUM_REAL_CORES-1.
BUG: unable to handle kernel NULL pointer dereference at 000000000000013c
IP: [<ffffffffa00159af>] coretemp_cpu_callback+0x93/0x1ba [coretemp]
PGD 673e5a067 PUD 66e9b3067 PMD 0
Oops: 0000 [#1] SMP
CPU 79
Modules linked in: sunrpc cpufreq_ondemand acpi_cpufreq freq_table mperf bnep bluetooth rfkill ip6t_REJECT nf_conntrack_ipv6 nf_defrag_ipv6 ip6table_filter nf_conntrack_ipv4 nf_defrag_ipv4 ip6_tables xt_state nf_conntrack coretemp crc32c_intel asix tpm_tis pcspkr usbnet iTCO_wdt i2c_i801 microcode mii joydev tpm i2c_core iTCO_vendor_support tpm_bios i7core_edac igb ioatdma edac_core dca megaraid_sas [last unloaded: oprofile]
Pid: 3315, comm: set-cpus Tainted: G W 3.4.0-rc5+ #2 QCI QSSC-S4R/QSSC-S4R
RIP: 0010:[<ffffffffa00159af>] [<ffffffffa00159af>] coretemp_cpu_callback+0x93/0x1ba [coretemp]
RSP: 0018:ffff880472fb3d48 EFLAGS: 00010246
RAX: 0000000000000124 RBX: 0000000000000034 RCX: 00000000ffffffff
RDX: 0000000000000000 RSI: 0000000000000046 RDI: 0000000000000246
RBP: ffff880472fb3d88 R08: ffff88077fcd36c0 R09: 0000000000000001
R10: ffffffff8184bc48 R11: 0000000000000000 R12: ffff880273095800
R13: 0000000000000013 R14: ffff8802730a1810 R15: 0000000000000000
FS: 00007f694a20f720(0000) GS:ffff88077fcc0000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 000000000000013c CR3: 000000067209b000 CR4: 00000000000007e0
Process set-cpus (pid: 3315, threadinfo ffff880472fb2000, task ffff880471fa0000)
Stack:
ffff880277b4c308 0000000000000003 ffff880472fb3d88 0000000000000005
0000000000000034 00000000ffffffd1 ffffffff81cadc70 ffff880472fb3e14
ffff880472fb3dc8 ffffffff8161f48d ffff880471fa0000 0000000000000034
Call Trace:
[<ffffffff8161f48d>] notifier_call_chain+0x4d/0x70
[<ffffffff8107f1be>] __raw_notifier_call_chain+0xe/0x10
[<ffffffff81059d30>] __cpu_notify+0x20/0x40
[<ffffffff815fa251>] _cpu_down+0x81/0x270
[<ffffffff815fa477>] cpu_down+0x37/0x50
[<ffffffff815fd6a3>] store_online+0x63/0xc0
[<ffffffff813c7078>] dev_attr_store+0x18/0x30
[<ffffffff811f02cf>] sysfs_write_file+0xef/0x170
[<ffffffff81180443>] vfs_write+0xb3/0x180
[<ffffffff8118076a>] sys_write+0x4a/0x90
[<ffffffff816236a9>] system_call_fastpath+0x16/0x1b
Code: 48 c7 c7 94 60 01 a0 44 0f b7 ac 10 ac 00 00 00 31 c0 e8 41 b7 5f e1 41 83 c5 02 49 63 c5 49 8b 44 c4 10 48 85 c0 74 56 45 31 ff <39> 58 18 75 4e eb 1f 49 63 d7 4c 89 f7 48 89 45 c8 48 6b d2 28
RIP [<ffffffffa00159af>] coretemp_cpu_callback+0x93/0x1ba [coretemp]
RSP <ffff880472fb3d48>
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging
Pull hwmon changes for v3.4 from Guenter Roeck:
"Mostly cleanup. No new drivers this time around, but support for
several chips added to existing drivers: TPS40400, TPS40422, MTD040,
MAX34446, ZL9101M, ZL9117M, and LM96080. Also, added watchdog support
for SCH56xx, and additional attributes for a couple of drivers."
* tag 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging: (137 commits)
hwmon: (sch56xx) Add support for the integrated watchdog (v2)
hwmon: (w83627ehf) Add support for temperature offset registers
hwmon: (jc42) Remove unnecessary device IDs
hwmon: (zl6100) Add support for ZL9101M and ZL9117M
hwmon: (adm1275) Add support for ADM1075
hwmon: (max34440) Add support for MAX34446
hwmon: (pmbus) Add more virtual registers
hwmon: (pmbus) Add support for Lineage Power MDT040
hwmon: (pmbus) Add support for TI TPS40400 and TPS40422
hwmon: (max34440) Add support for 'lowest' output voltage attribute
hwmon: (jc42) Convert to use devm_kzalloc
hwmon: (max16065) Convert to use devm_kzalloc
hwmon: (smm665) Convert to use devm_kzalloc
hwmon: (ltc4261) Convert to use devm_kzalloc
hwmon: (pmbus) Simplify remove functions
hwmon: (pmbus) Convert pmbus drivers to use devm_kzalloc
hwmon: (lineage-pem) Convert to use devm_kzalloc
hwmon: (hwmon-vid) Fix checkpatch issues
hwmon: (hwmon-vid) Add new entries to VRM model table
hwmon: (lm80) Add detection of NatSemi/TI LM96080
Fix:
ERROR: Macros with complex values should be enclosed in parenthesis
Acked-By: Durgadoss R <durgadoss.r@intel.com>
Use the new x86 cpuid autoprobe interface for the Intel coretemp
driver.
Cc: Guenter Roeck <guenter.roeck@ericsson.com>
Signed-off-by: Thomas Renninger <trenn@suse.de>
Acked-by: H. Peter Anvin <hpa@zytor.com>
Many functions in the coretemp driver lack a proper section
annotation. Add them to let the kernel free the memory after
initialization when possible.
Cc: Durgadoss R <durgadoss.r@intel.com>
Several fields in struct cpuinfo_x86 were not defined for the
!SMP case, likely to save space. However, those fields still
have some meaning for UP, and keeping them allows some #ifdef
removal from other files. The additional size of the UP kernel
from this change is not significant enough to worry about
keeping up the distinction:
4737168 506459 972040 6215667 5ed7f3 vmlinux.o.before
4737444 506459 972040 6215943 5ed907 vmlinux.o.after
for a difference of 276 bytes for an example UP config.
If someone wants those 276 bytes back badly then it should
be implemented in a cleaner way.
Signed-off-by: Kevin Winchester <kjwinchester@gmail.com>
Cc: Steffen Persvold <sp@numascale.com>
Link: http://lkml.kernel.org/r/1324428742-12498-1-git-send-email-kjwinchester@gmail.com
The definition of TO_ATTR_NO in the non-SMP case is wrong. As the SMP
definition resolves to the correct value, just use this for both
cases.
Without this fix the temperature attributes are named temp0_* instead
of temp2_*, so libsensors won't pick them. Broken since kernel 3.0.
Tested-by: Phil Sutter <phil@nwl.cc>
Cc: stable@kernel.org
Acked-by: Durgadoss R <Durgadoss.r@intel.com>
Now that the ucode revision is available in cpu_data remove
the existing code in coretemp.c to query it manually. Read the
ucode revision from cpu_data instead
Cc: jbeulich@novell.com
Cc: fenghua.yu@intel.com
Cc: khali@linux-fr.org
Link: http://lkml.kernel.org/r/1318466795-7393-3-git-send-email-andi@firstfloor.org
Storing the struct temp_data pointer allocated from create_core_data()
when returning an error has the potential of leaving around a pointer
to freed memory. Reset it to NULL for error returns.
Reported-by: Jan Beulich <jbeulich@suse.com>
With recent change "hwmon: (coretemp) don't use kernel assigned CPU
number as platform device ID", the microcode check is now running on
random CPU. Fix that by checking the microcode before creating the
platform device rather than at probe time.
Also avoid calling TO_PHYS_ID(cpu) twice in the same function, it's
expensive.
Cc: Jan Beulich <jbeulich@suse.com>
create_core_data()
The only caller of the function obtained the pointer solely for the
purpose of passing it to this function, while it can be easily
determined from the struct platform_device * parameter also passed.
These arrays won't ever be written to, so protect them from
unintentional modification.
... as that has the potential to conflict with (particularly soft) CPU
hot removal and re-adding.
[guenter.roeck@ericsson.com: use platform device ID as physical CPU id]
With commit c814a4c7c4aad795835583344353963a0a673eb0, the meaning of tempX_max
was changed. It no longer returns the value of bits 8:15 of
MSR_IA32_TEMPERATURE_TARGET, but instead returns the value of CPU threshold
register T1. tempX_max_hyst was added to reflect the value of temperature
threshold register T0.
As it turns out, T0 and T1 are used on some systems, presumably by the BIOS.
Also, T0 and T1 don't have a well defined meaning. The thresholds may be used
as upper or lower limits, and it is not guaranteed that T0 <= T1. Thus, the new
attribute mapping does not reflect the actual usage of the threshold registers.
Also, register contents are changed during runtime by an entity other than the
hwmon driver, meaning the values cached by the driver do not reflect actual
register contents.
Revert most of c814a4c7c4aad795835583344353963a0a673eb0 to address the problem.
Support for T0 and T1 will be added back in with a separate commit, using new
attribute names.
On old CPUs (and even some recent Atom CPUs) TjMax can't be read from
the CPU registers, so it is guessed by the driver using a complex
heuristic which isn't reliable. So let users who know their CPU's
TjMax pass it as a module parameter.
Acked-by: Fenghua Yu <fenghua.yu@intel.com>
Function get_pkg_tjmax is a simplified copy of get_tjmax. Drop it and
always use get_tjmax, result is the same and this avoids code
duplication.
Also make get_tjmax less verbose: don't warn about MSR read failure
when failure was expected, and don't report TjMax in the logs unless
debugging is enabled.
ttarget is initialized when the driver is loaded, but tmin is not.
As a result, tempX_max_hyst attributes read 0. Fix this.
Also use THERM_*_THRESHOLD* constants in these initializations instead
of hard-coding the constants.
This patch adds the core and pkg support to coretemp.
These thresholds can be configured via the sysfs interfaces tempX_max
and tempX_max_hyst. An interrupt is generated when CPU temperature reaches
or crosses above tempX_max OR drops below tempX_max_hyst.
This patch is based on the documentation in IA Manual vol 3A, that can be
downloaded from here:
http://download.intel.com/design/processor/manuals/253668.pdf
Signed-off-by: Durgadoss R <durgadoss.r@intel.com>
pdev_entry.cpu and pdev_entry.cpu_core_id aren't used anywhere in the
driver code so we can drop these struct members.
Further relax temperature range checks after reading the IA32_TEMPERATURE_TARGET
register. If the register returns a value other than 0 in bits 16..32, assume
that the returned value is correct.
This change applies to both packet and core temperature limits.
Cc: Carsten Emde <C.Emde@osadl.org>
Commit a321cedb12904114e2ba5041a3673ca24deb09c9 excludes CPU models 0xe, 0xf,
0x16, and 0x1a from TjMax temperature adjustment, even though several of those
CPUs are known to have TiMax other than 100 degrees C, and even though the code
in adjust_tjmax() explicitly handles those CPUs and points to a Web document
listing several of the affected CPU IDs.
Reinstate original TjMax adjustment if TjMax can not be determined using the
IA32_TEMPERATURE_TARGET register.
https://bugzilla.kernel.org/show_bug.cgi?id=32582
Cc: Huaxu Wan <huaxu.wan@linux.intel.com>
Cc: Valdis Kletnieks <valdis.kletnieks@vt.edu>
Cc: Henrique de Moraes Holschuh <hmh@hmh.eng.br>
Cc: Yong Wang <yong.y.wang@linux.intel.com>
Tested-by: Jean Delvare <khali@linux-fr.org>
Cc: <stable@kernel.org> # .35.x .36.x .37.x .38.x .39.x
The current temperature range check of MSR_IA32_TEMPERATURE_TARGET
seems too strict to me, some TjMax values documented in
Documentation/hwmon/coretemp wouldn't pass. Relax the check so that
all the documented values pass.
chk_ucode_version() is only called from coretemp_probe() which is
__devinit, so it can be marked __devinit too.
Update comments describing the handling of HT CPUs based on review feedback.
Initialize sysfs attrs before device_create_file() call to suppress lockdep_init_map()
warning:
[ 3.653628] WARNING: at kernel/lockdep.c:2885 lockdep_init_map+0xea/0x43c()
[ 3.653698] Modules linked in:
[ 3.654835] Pid: 1, comm: swapper Not tainted 2.6.39-dbg-git8-05624-g46187f8 #576
[ 3.656014] Call Trace:
[ 3.657139] [<ffffffff8103e4b4>] warn_slowpath_common+0x7e/0x96
[ 3.658298] [<ffffffff8103e4e1>] warn_slowpath_null+0x15/0x17
[ 3.659460] [<ffffffff8106d7b9>] lockdep_init_map+0xea/0x43c
[ 3.660616] [<ffffffff81163c1a>] sysfs_add_file_mode+0x5d/0xa8
[ 3.661785] [<ffffffff81163c71>] sysfs_add_file+0xc/0xe
[ 3.662929] [<ffffffff81163d26>] sysfs_create_file+0x23/0x25
[ 3.664045] [<ffffffff813724d1>] device_create_file+0x14/0x16
[ 3.665172] [<ffffffff81460ed4>] coretemp_probe+0xf9/0x185
[ 3.666306] [<ffffffff8137638e>] platform_drv_probe+0x12/0x14
[ 3.667420] [<ffffffff81375321>] driver_probe_device+0xb0/0x14b
[ 3.668542] [<ffffffff8137546d>] __device_attach+0x35/0x3a
[ 3.669710] [<ffffffff81375438>] ? __driver_attach+0x7c/0x7c
[ 3.670816] [<ffffffff8137426b>] bus_for_each_drv+0x54/0x88
[ 3.671921] [<ffffffff81375231>] device_attach+0x77/0x9b
[ 3.673027] [<ffffffff81374aef>] bus_probe_device+0x22/0x39
[ 3.674137] [<ffffffff81373235>] device_add+0x3c1/0x550
[ 3.675249] [<ffffffff81371ed9>] ? dev_set_name+0x3c/0x3e
[ 3.676371] [<ffffffff813769f3>] platform_device_add+0x10c/0x156
[ 3.677491] [<ffffffff8146af9c>] get_core_online+0xab/0x16e
[ 3.678608] [<ffffffff81ad8070>] coretemp_init+0x4b/0x80
[ 3.679724] [<ffffffff81ad8025>] ? hwmon_init+0xee/0xee
[ 3.680853] [<ffffffff8100020a>] do_one_initcall+0x7a/0x13c
[ 3.681975] [<ffffffff81aaac74>] kernel_init+0xe1/0x15b
[ 3.683081] [<ffffffff8147e4e4>] kernel_thread_helper+0x4/0x10
[ 3.684174] [<ffffffff8102d48c>] ? finish_task_switch+0x76/0xf0
[ 3.685266] [<ffffffff81477918>] ? retint_restore_args+0x13/0x13
[ 3.686356] [<ffffffff81aaab93>] ? start_kernel+0x3ee/0x3ee
[ 3.687425] [<ffffffff8147e4e0>] ? gs_change+0x13/0x13
[ 3.688489] ---[ end trace 7392ad3e6a92ae39 ]---
Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
The coretemp driver provides a single set of device attributes for each
physical core of a HT CPU to avoid duplicate sensors. This
functionality was introduced with commit d883b9f09772 ("hwmon:
(coretemp) Skip duplicate CPU entries").
Commit e40cc4bdfd4b ("x86/hwmon: register alternate sibling upon CPU
removal") extends this functionality to register the HT sibling of a CPU
which is taken offline, to ensure that sensor attributes are provided if
at least one HT sibling of a core is online.
Add comments into the code describing the functionality in some more
detail.
cpu_sibling_mask() is not defined unless CONFIG_SMP is defined, so it
must not be used directly in the code without ifdef protection.
To solve the problem and avoid ifdefs in the code, define
for_each_sibling() and use it instead.
Fix remaining checkpatch errors in the coretemp driver.
This patch merges the pkgtemp with coretemp driver.
The sysfs interfaces for all cores in the same pkg
are shown under one directory, in hwmon. It also
supports CONFIG_HOTPLUG_CPU. So, the sysfs interfaces
are created when each core comes online and are
removed when it goes offline.
[guenter.roeck@ericsson.com: Fixed section reference errors]
