path: root/drivers/hwmon/ibmaem.c
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-06-15hwmon: (ibmaem) Automatically load on HC10 bladeDarrick J. Wong
Enable auto-probing for the HC10 blade and amend the supported system list. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-11-12Fix platform drivers that crash on suspend/resumeDarrick J. Wong
It turns out that if one registers a struct platform_device, the platform device code expects that platform_device.device->driver points to a struct driver inside a struct platform_driver. This is not the case with the ipmi-si, ipmi-msghandler and ibmaem drivers, which causes the suspend/resume hook functions to jump off into nowhere, causing a crash. Make this assumption hold true for these three drivers. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Acked-by: Corey Minyard <cminyard@mvista.com> Cc: Jean Delvare <khali@linux-fr.org> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Greg KH <greg@kroah.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-17hwmon: (ibmaem) Automatically load on IBM systems via DMIDarrick J. Wong
2008-08-15ibmaem: don't query the entire sensor repository when reading energy meterDarrick J. Wong
Currently, all sensors are read when the energy meter is queried via sysfs. This introduces a considerable amount of delay and variation in the sysfs reading, which is not desirable when trying to profile energy use. Therefore, read only the energy meters when a sysfs query comes in for them, and don't cache the results so that we always get the latest reading. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-15ibmaem: prevent infinite probing loop on x3650 M2 systemsDarrick J. Wong
On older machines, probing for a nonexistent AEM interface returned an IPMI error; when we saw this, we'd stop probing. On the x3650 M2 and (presumably) later, we are returned a value indicating success and a buffer full of garbage or zeroes. This causes the probe function to run in an infinite loop. To fix this, we add one last check--if the interface number we're looking for is higher than the number of interfaces that AEM claims to have, stop probing. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-15ibmaem: update the documentation to reflect the current nameDarrick J. Wong
Minor documentation update to reflect the current full name of the power management hardware interface and reflows the text a bit. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-04ibmaem endianness annotationsAl Viro
2008-05-24ibmaem: new driver for power/energy/temp meters in IBM System X hardwareDarrick J. Wong
This driver reads IBM Active Energy Manager energy/temperature/power sensors on IBM System X hardware. [akpm@linux-foundation.org: fix printk warnings] Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Cc: "Mark M. Hoffman" <mhoffman@lightlink.com> Cc: Corey Minyard <minyard@acm.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
