Add LM82 temperature sensor support (similar to the LM83,
but less featureful).
Signed-off-by: Jordan Crouse <jordan.crouse@amd.com>
Now that i2c_add_driver() doesn't need the module owner to be set by
hand, we can delete it from the drivers. This patch catches all of the
drivers that I found in the current tree (if a driver sets the .owner by
hand, it's not a problem, just not needed.)
Cc: Jean Delvare <khali@linux-fr.org>
We should use the i2c_driver.driver's .name and .owner fields
instead of the i2c_driver's ones.
This patch updates the hwmon drivers.
Signed-off-by: Laurent Riffard <laurent.riffard@free.fr>
Just about every i2c chip driver sets the I2C_DF_NOTIFY flag, so we
can simply make it the default and drop the flag. If any driver really
doesn't want to be notified when i2c adapters are added, that driver
can simply omit to set .attach_adapter. This approach is also more
robust as it prevents accidental NULL pointer dereferences.
Use kzalloc instead of kmalloc+memset in all hardware monitoring
drivers.
Signed-off-by: Deepak Saxena <dsaxena@plexity.net>
The only thing left in i2c-sensor.h are module parameter definition
macros. It's only an extension of what i2c.h offers, and this extension
is not sensors-specific. As a matter of fact, a few non-sensors drivers
use them. So we better merge them in i2c.h, and get rid of i2c-sensor.h
altogether.
Signed-off-by: Jean Delvare <khali@linux-fr>
i2c_probe and i2c_detect now do the exact same thing and operate on
the same data structure, so we can have everyone call i2c_probe.
We could refactor the error message 34 different i2c drivers print if
i2c_detach_client() fails in this function itself. Saves quite a few
lines of code. Documentation is updated to reflect that change.
Note that this patch should be applied after Rudolf Marek's w83792d
patches.
Kill normal_isa in header files, documentation and all chip drivers, as
it is no more used.
normal_i2c could be renamed to normal, but I decided not to do so at the
moment, so as to limit the number of changes. This might be done later
as part of the i2c_probe/i2c_detect merge.
This patch modifies sensors chip drivers to make use of the new
sysfs class "hwmon".
Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
Part 2: Move the driver files themselves.
Note that the patch "adds trailing whitespace", because it does move the
files as-is, and some files happen to have trailing whitespace.
