path: root/drivers/hwmon/lm85.c
2015-04-17hwmon: (lm85) use find_closest() in x_TO_REG() functionsBartosz Golaszewski
Replace RANGE_TO_REG() and FREQ_TO_REG() implementations with calls to find_closest(). Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com> Cc: Guenter Roeck <linux@roeck-us.net> Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-04hwmon: (lm85) Convert to devm_hwmon_device_register_with_groupsAxel Lin
Use devm_hwmon_device_register_with_groups() to simplify the code a bit. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2014-08-04hwmon: (lm85) Avoid forward declarationAxel Lin
Reorder functions to avoid forward declaration. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2014-07-30hwmon: (lm85) Fix various errors on attribute writesGuenter Roeck
Temperature limit register writes did not account for negative numbers. As a result, writing -127000 resulted in -126000 written into the temperature limit register. This problem affected temp[1-3]_min, temp[1-3]_max, temp[1-3]_auto_temp_crit, and temp[1-3]_auto_temp_min. When writing pwm[1-3]_freq, a long variable was auto-converted into an int without range check. Wiring values larger than MAXINT resulted in unexpected register values. When writing temp[1-3]_auto_temp_max, an unsigned long variable was auto-converted into an int without range check. Writing values larger than MAXINT resulted in unexpected register values. vrm is an u8, so the written value needs to be limited to [0, 255]. Cc: Axel Lin <axel.lin@ingics.com> Cc: stable@vger.kernel.org Reviewed-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2014-06-12hwmon: (lm85) Drop generic detectionJean Delvare
Generic detection leads to too many false positives, so drop it. FWIW sensors-detect does not have such generic detection. If the user wants to force the driver to bind to a not yet supported chip, he/she can still do so using sysfs attribute new_device. Signed-off-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2014-01-29Update Jean Delvare's e-mail addressJean Delvare
2013-04-07hwmon: Fix checkpatch warning 'quoted string split across lines'Guenter Roeck
Cc: Corentin Labbe <corentin.labbe@geomatys.fr> Cc: Mark M. Hoffman <mhoffman@lightlink.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Juerg Haefliger <juergh@gmail.com> Cc: Andreas Herrmann <herrmann.der.user@googlemail.com> Cc: Rudolf Marek <r.marek@assembler.cz> Cc: Jim Cromie <jim.cromie@gmail.com> Cc: Roger Lucas <vt8231@hiddenengine.co.uk> Cc: Marc Hulsman <m.hulsman@tudelft.nl> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2013-01-25hwmon: Replace SENSORS_LIMIT with clamp_valGuenter Roeck
SENSORS_LIMIT and the generic clamp_val have the same functionality, and clamp_val is more efficient. This patch reduces text size by 9052 bytes and bss size by 11624 bytes for x86_64 builds. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Acked-by: George Joseph <george.joseph@fairview5.com> Acked-by: Jean Delvare <khali@linux-fr.org>
2012-07-21hwmon: (lm85) Convert to use devm_ functionsGuenter Roeck
Convert to use devm_ functions to reduce code size and simplify the code. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Acked-by: Jean Delvare <khali@linux-fr.org>
2012-03-18hwmon: (lm85) Fix checkpatch issuesGuenter Roeck
Fixed: ERROR: code indent should use tabs where possible ERROR: do not use assignment in if condition WARNING: simple_strtol is obsolete, use kstrtol instead WARNING: simple_strtoul is obsolete, use kstrtoul instead Modify multi-line comments to follow Documentation/CodingStyle. Also: s/#define^I/#define / Not fixed (false positive): ERROR: Macros with multiple statements should be enclosed in a do - while loop Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2012-03-18hwmon: convert drivers/hwmon/* to use module_i2c_driver()Axel Lin
This patch converts the drivers in drivers/hwmon/* to use the module_i2c_driver() macro which makes the code smaller and a bit simpler. Signed-off-by: Axel Lin <axel.lin@gmail.com> Cc: Corentin Labbe <corentin.labbe@geomatys.fr> Cc: Dirk Eibach <eibach@gdsys.de> Cc: "Mark M. Hoffman" <mhoffman@lightlink.com> Cc: Steve Glendinning <steve.glendinning@smsc.com> Cc: Riku Voipio <riku.voipio@iki.fi> Cc: Guillaume Ligneul <guillaume.ligneul@gmail.com> Cc: David George <david.george@ska.ac.za> Cc: "Hans J. Koch" <hjk@hansjkoch.de> Cc: Marc Hulsman <m.hulsman@tudelft.nl> Cc: Rudolf Marek <r.marek@assembler.cz> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-04-29hwmon: (lm85) Fix error paths in probe functionJean Delvare
We must remove all files we created, even in error cases. Fixes second part of kernel bug #34072: https://bugzilla.kernel.org/show_bug.cgi?id=34072 Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-04-29hwmon: (lm85) Add missing list terminatorsJean Delvare
Fixes kernel bug #34072: https://bugzilla.kernel.org/show_bug.cgi?id=34072 Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-03-14hwmon: (lm85) Add support for EMC6D103SGuenter Roeck
EMC6D103S is similar to EMC6D103, only it does not support registers 62[5:7], 6D[0:7], and 6E[0:7]. Register respective sysfs attributes and update affected registers for all other chips only. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Acked-by: Jean Delvare <khali@linux-fr.org>
2011-03-14hwmon: (lm85) Do not update hysteresis and temp_auto_off if auto_temp_min is ↵Guenter Roeck
changed So far, the driver updates temp_auto_hyst and temp_auto_off if temp_auto_min changes. This may cause problems if temp_auto_off was not configured before configuring temp_auto_min, because one of the variables used (off_desired) is not initialized in this case. To simplify the code, and for consistency with other drivers, no longer update the delta between "min" and "off" until the user sets the "off" value again. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Acked-by: Jean Delvare <khali@linux-fr.org>
2011-03-14hwmon: (lm85) Use function to remove sysfs attribute filesGuenter Roeck
2011-03-14hwmon: (lm85) Use boolean to determine if VID5 is configuredGuenter Roeck
ADT7463 and ADT7468 optionally support VID5 instead of the standard +12V measurement input. Use a boolean to identify the chip configuration instead of hardcoding it several times. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Acked-by: Jean Delvare <khali@linux-fr.org>
2011-02-18hwmon: (lm85) extend to support EMC6D103 chipsJan Beulich
The interface is identical EMC6D102, so all that needs to be added are some definitions and their uses. Registers apparently missing in EMC6D103S/EMC6D103:A2 compared to EMC6D103:A0, EMC6D103:A1, and EMC6D102 (according to the data sheets), but used unconditionally in the driver: 62[5:7], 6D[0:7], and 6E[0:7]. For that reason, EMC6D103S chips don't get enabled for the time being. Signed-off-by: Jan Beulich <jbeulich@novell.com> (Guenter Roeck: Replaced EMC6D103_A2 with EMC6D103S per EMC6D103S datasheet) Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Cc: stable@kernel.org
2010-10-28hwmon: (lm85) Add support for ADT7468 high-frequency PWM modeJean Delvare
The ADT7468 supports a high-frequency PWM output mode where all PWM outputs are driven by a 22.5 kHz clock. Add support for this mode, and document it, as it may surprise the user that setting one PWM output frequency also affects the other PWM outputs. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Darrick J. Wong <djwong@us.ibm.com> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
2010-10-28hwmon: (lm85) Fix ADT7468 frequency tableJean Delvare
The ADT7468 uses the same frequency table as the ADT7463. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: stable@kernel.org Cc: Darrick J. Wong <djwong@us.ibm.com> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
2009-12-14i2c: Drop I2C_CLIENT_INSMOD_2 to 8Jean Delvare
These macros simply declare an enum, so drivers might as well declare it themselves. This puts an end to the arbitrary limit of 8 chip types per i2c driver. Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Wolfram Sang <w.sang@pengutronix.de>
2009-12-14i2c: Get rid of struct i2c_client_address_dataJean Delvare
Struct i2c_client_address_data only contains one field at this point, which makes its usefulness questionable. Get rid of it and pass simple address lists around instead. Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Wolfram Sang <w.sang@pengutronix.de>
2009-12-14i2c: Drop the kind parameter from detect callbacksJean Delvare
The "kind" parameter always has value -1, and nobody is using it any longer, so we can remove it. Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Wolfram Sang <w.sang@pengutronix.de>
2009-12-09hwmon: (lm85) Clean up detect functionJean Delvare
As kind is now hard-coded to -1, there is room for code clean-ups. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-09-15hwmon: (lm85) Don't bind to Winbond/Nuvoton WPCD377IJean Delvare
The Winbond/Nuvoton WPCD377I is the reduced version of a Super-I/O which emulates the National Semiconductor LM96000 hardware monitoring chips, but without the hardware monitoring part. Instead of plain disabling the emulation, the vendor left the emulated chip visible, but all monitored values are always zero. This is rather confusing for the users. So detect this case and refuse to bind to such fake chips. This fixes lm-sensors ticket #2182: http://www.lm-sensors.org/ticket/2182 Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-03-10lm85: add VRM10 support for adt7468 chipDarrick J. Wong
The adt7468 chip supports VRM10 sensors just like the adt7463; add a missing check for it. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-10lm85: fix the version check that broke adt7468 probingDarrick J. Wong
The verstep check in the lm85 driver fails because the upper nibble of the version register is 0x7, not 0x6, on the adt7468 chip. Probing of all adt7468s was broken by 69fc1feba2d5856ff74dedb6ae9d8c490210825c ("hwmon: (lm85) Rework the device detection"), and this patch fixes that. Also add in a missing i2c_device_id that accidentally got dropped from the original patch. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-12lm85: support adt7468 chipsDarrick J. Wong
The adt7468 is a follow-on to the adt7463, so plumb in adt7468 support along the same code paths. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-17hwmon: (lm85) Better label namesJean Delvare
Label names ERROR1 and ERROR3 aren't exactly explicit. Change them for better names that indicate what we are up to. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Herbert Poetzl <herbert@13thfloor.at>
2008-10-17hwmon: (lm85) Simplify RANGE_TO_REGJean Delvare
Function RANGE_TO_REG can easily be simplified. Credits go to Herbert Poetzl for indirectly suggesting this to me. I tested that the new implementation returns the same result as the original implementation for all input values. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Herbert Poetzl <herbert@13thfloor.at>
2008-10-17hwmon: (lm85) Convert to a new-style i2c driverJean Delvare
The new-style lm85 driver implements the optional detect() callback to cover the use cases of the legacy driver. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Herbert Poetzl <herbert@13thfloor.at>
2008-10-17hwmon: (lm85) Support different PWM frequency tablesJean Delvare
The Analog Devices and SMSC devices supported by the lm85 driver do not have the same PWM frequency table as the National Semiconductor devices. Add support for per-device frequency tables. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Herbert Poetzl <herbert@13thfloor.at>
2008-10-17hwmon: (lm85) Select the closest PWM frequencyJean Delvare
The LM85 and compatible chips only support 8 arbitrary PWM frequencies. The algorithm to pick one of them based on the user input is not optimum. Improve it to always pick the closest supported frequency. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Herbert Poetzl <herbert@13thfloor.at>
2008-10-17hwmon: (lm85) Implement the standard PWM frequency interfaceJean Delvare
Implement the standard PWM frequency interface: pwm[1-*]_freq in units of 1 Hz, instead of the non-standard pwm[1-*]_auto_pwm_freq in units of 0.1 Hz. The old naming was not only non-standard, it was also confusing, because it suggested that the frequency value only applied in automatic fan speed mode, which isn't true. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Herbert Poetzl <herbert@13thfloor.at>
2008-10-17hwmon: (lm85) Rework the device detectionJean Delvare
Rework the device detection to make it clearer and faster in the general case (when a known device is found.) Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Herbert Poetzl <herbert@13thfloor.at>
2008-07-31hwmon: (lm85) Simplify device initialization functionJean Delvare
Clean up and simplify the device initialization function: * Degrade error messages to warnings - what they really are. * Stop warning about VxI mode, we don't really care. * Drop comment about lack of limit initialization - that's the standard way, all hardware monitoring drivers do that. * Only read the configuration register once. * Only write back to the configuration register if needed. * Don't attempt to clear the lock bit, it locks itself to 1. * Move the function to before it's called, so that we no longer need to forware declare it. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2008-07-31hwmon: (lm85) Misc cleanupsJean Delvare
Misc cleanups to the lm85 hardware monitoring driver: * Mark constant arrays as const. * Remove useless masks. * Have lm85_write_value return void - nobody is checking the returned value anyway and in some cases it was plain wrong. * Remove useless initializations. * Rename new_client to client in lm85_detect. * Replace cascaded if/else with a switch/case in lm85_detect. * Group similar loops in lm85_update_device. * Remove legacy comments. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Juerg Haefliger <juergh at gmail.com> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2008-07-31hwmon: (lm85) Don't write back cached valuesJean Delvare
In set_pwm_auto_pwm_minctl, we write cached register bits back to the chip. This is a bad idea as we have no guarantee that the cache is up-to-date. Better read a fresh register value from the chip, it's safer and in fact it is also more simple. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Juerg Haefliger <juergh at gmail.com> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2008-07-31hwmon: (lm85) Drop dead codeJean Delvare
Drop a lot of useless register defines, conversion macros, data structure members and update code. All these register values were read from the device but nothing is done out of them, so this is all dead code in practice. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Juerg Haefliger <juergh at gmail.com> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2008-07-31hwmon: (lm85) Coding-style cleanupsJean Delvare
Fix most style issues reported by checkpatch, including: * Trailing, missing and extra whitespace * Extra parentheses, curly braces and semi-colons * Broken indentation * Lines too long I verified that the generated code is the same before and after these changes. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Juerg Haefliger <juergh at gmail.com> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2008-06-19hwmon: (lm85) Fix function RANGE_TO_REG()Jean Delvare
Function RANGE_TO_REG() is broken. For a requested range of 2000 (2 degrees C), it will return an index value of 15, i.e. 80.0 degrees C, instead of the expected index value of 0. All other values are handled properly, just 2000 isn't. The bug was introduced back in November 2004 by this patch: http://git.kernel.org/?p=linux/kernel/git/tglx/history.git;a=commit;h=1c28d80f1992240373099d863e4996cdd5d646d0 While this can be fixed easily with the current code, I'd rather rewrite the whole function in a way which is more obviously correct. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Justin Thiessen <jthiessen@penguincomputing.com> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2008-02-18hwmon: normal_i2c arrays should be constMark M. Hoffman
2008-02-07hwmon: VRM is not written to registersJean Delvare
What was true of reading the VRM value is also true of writing it: not being a register value, it doesn't need hardware access, so we don't need a reference to the i2c client. This allows for a minor code cleanup. As gcc appears to be smart enough to simplify the generated code by itself, this cleanup only affects the source code, the generated binaries are unchanged. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2008-02-07hwmon: Discard useless I2C driver IDsJean Delvare
Many I2C hwmon drivers define a driver ID but no other code references these, meaning that they are useless. Discard them, along with a few IDs which are defined but never used at all. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2008-02-07hwmon: (lm85) Make the pwmN_enable files writableJean Delvare
Make the pwmN_enable files writable. This makes it possible to use standard fan speed control tools (pwmconfig, fancontrol) with the lm85 driver. I left the non-standard pwmN_auto_channels files in place, as they give additional control for the automatic mode, and some users might be used to them by now. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2008-02-07hwmon: (lm85) Return standard values in pwmN_enableJean Delvare
The values returned by the lm85 driver in pwmN_enable sysfs files do not match the standard. Fix that. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-10-09hwmon: VRM is not read from registersJean Delvare
The VRM value is not read from chip registers, so there's no need to update the device data cache before exporting the VRM value to user-space. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Hans de Goede <j.w.r.degoede@hhs.nl> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-10-09hwmon: (lm85) Let the user set the fan min limit to 0Jean Delvare
Trying to set the fan min limit to 0 currently writes 0 to the register, which is an invalid value. It's read back as -1 and the alarm flag is raised. Instead we should write 0xffff (maximum value), which reads back as 0 and no alarm flag is raised. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Juerg Haefliger <juergh at gmail.com> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-10-09hwmon: (lm85) Clean up the handling of additional resolution bitsJean Delvare
The way the lm85 driver currently handles the additional resolution bits some chips have for the voltage and temperature measurements is quite complex. This is my attempt to make it simpler. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Juerg Haefliger <juergh at gmail.com> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
