path: root/drivers/hwmon/ltc4261.c
2013-10-18hwmon: (ltc4261) fix coccinelle warningsFengguang Wu
drivers/hwmon/ltc4261.c:243:1-3: WARNING: PTR_RET can be used Use PTR_ERR_OR_ZERO rather than if(IS_ERR(...)) + PTR_ERR Generated by: coccinelle/api/ptr_ret.cocci CC: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2013-10-18hwmon: (ltc4261) Convert to use devm_hwmon_device_register_with_groupsGuenter Roeck
Also use new macro ATTRIBUTE_GROUPS to declare attribute groups. Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2013-04-07hwmon: (ltc4261) Fix 'Macros with complex values' checkpatch errorGuenter Roeck
Fix: ERROR: Macros with complex values should be enclosed in parenthesis by unwinding the problematic macros. Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2012-10-10hwmon: Add missing inclusions of <linux/jiffies.h>Jean Delvare
Many hwmon drivers use jiffies but omit the inclusion of the header file. Fix that, and also fix one driver which was including the header file but didn't need it. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Guenter Roeck <linux@roeck-us.net> Acked-by: Luca Tettamanti <kronos.it@gmail.com> Cc: Marc Hulsman <m.hulsman@tudelft.nl> Cc: Rudolf Marek <r.marek@assembler.cz>
2012-06-25hwmon: Update my e-mail addressGuenter Roeck
My old e-mail address won't be valid for much longer. Time to update it. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Acked-by: Jean Delvare <khali@linux-fr.org>
2012-03-18hwmon: (ltc4261) Convert to use devm_kzallocGuenter Roeck
Marginally less code and eliminate the possibility of memory leaks. Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2012-03-18hwmon: convert drivers/hwmon/* to use module_i2c_driver()Axel Lin
This patch converts the drivers in drivers/hwmon/* to use the module_i2c_driver() macro which makes the code smaller and a bit simpler. Signed-off-by: Axel Lin <axel.lin@gmail.com> Cc: Corentin Labbe <corentin.labbe@geomatys.fr> Cc: Dirk Eibach <eibach@gdsys.de> Cc: "Mark M. Hoffman" <mhoffman@lightlink.com> Cc: Steve Glendinning <steve.glendinning@smsc.com> Cc: Riku Voipio <riku.voipio@iki.fi> Cc: Guillaume Ligneul <guillaume.ligneul@gmail.com> Cc: David George <david.george@ska.ac.za> Cc: "Hans J. Koch" <hjk@hansjkoch.de> Cc: Marc Hulsman <m.hulsman@tudelft.nl> Cc: Rudolf Marek <r.marek@assembler.cz> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2012-01-05hwmon: (ltc4261) set data->valid to 0 if errorFrans Meulenbroeks
If there is an error it is better to set data->valid to 0 so the next call to ltc4261_update_device will always be executed. Signed-off-by: Frans Meulenbroeks <fransmeulenbroeks@gmail.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2010-11-05hwmon: (ltc4261) Fix error message formatJean Delvare
adapter->id is deprecated and not set by any adapter driver, so this was certainly not what the author wanted to use. adapter->nr maybe, but as dev_err() already includes this value, as well as the client's address, there's no point repeating them. Better print a simple error message in plain English words. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2010-11-05hwmon: (ltc4261) Add missing newline in debug messageGuenter Roeck
Reported-by: Joe Perches <joe@perches.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Acked-by: Jean Delvare <khali@linux-fr.org>
2010-10-25hwmon: LTC4261 Hardware monitoring driverGuenter Roeck
This driver adds support for Linear Technology LTC4261 I2C Negative Voltage Hot Swap Controller. Reviewed-by: Ira W. Snyder <iws@ovro.caltech.edu> Reviewed-by: Tom Grennan <tom.grennan@ericsson.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
