path: root/drivers/hwmon/max1111.c
2017-01-02hwmon: (max1111) use permission-specific DEVICE_ATTR variantsJulia Lawall
Use DEVICE_ATTR_RO for read-only attributes. This simplifies the source code, improves readbility, and reduces the chance of inconsistencies. The conversion was done automatically using coccinelle. It was validated by compiling both the old and the new source code and comparing its text, data, and bss size. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> [groeck: Updated description] Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2016-03-27hwmon: (max1111) Return -ENODEV from max1111_read_channel if not instantiatedGuenter Roeck
arm:pxa_defconfig can result in the following crash if the max1111 driver is not instantiated. Unhandled fault: page domain fault (0x01b) at 0x00000000 pgd = c0004000 [00000000] *pgd=00000000 Internal error: : 1b [#1] PREEMPT ARM Modules linked in: CPU: 0 PID: 300 Comm: kworker/0:1 Not tainted 4.5.0-01301-g1701f680407c #10 Hardware name: SHARP Akita Workqueue: events sharpsl_charge_toggle task: c390a000 ti: c391e000 task.ti: c391e000 PC is at max1111_read_channel+0x20/0x30 LR is at sharpsl_pm_pxa_read_max1111+0x2c/0x3c pc : [<c03aaab0>] lr : [<c0024b50>] psr: 20000013 ... [<c03aaab0>] (max1111_read_channel) from [<c0024b50>] (sharpsl_pm_pxa_read_max1111+0x2c/0x3c) [<c0024b50>] (sharpsl_pm_pxa_read_max1111) from [<c00262e0>] (spitzpm_read_devdata+0x5c/0xc4) [<c00262e0>] (spitzpm_read_devdata) from [<c0024094>] (sharpsl_check_battery_temp+0x78/0x110) [<c0024094>] (sharpsl_check_battery_temp) from [<c0024f9c>] (sharpsl_charge_toggle+0x48/0x110) [<c0024f9c>] (sharpsl_charge_toggle) from [<c004429c>] (process_one_work+0x14c/0x48c) [<c004429c>] (process_one_work) from [<c0044618>] (worker_thread+0x3c/0x5d4) [<c0044618>] (worker_thread) from [<c004a238>] (kthread+0xd0/0xec) [<c004a238>] (kthread) from [<c000a670>] (ret_from_fork+0x14/0x24) This can occur because the SPI controller driver (SPI_PXA2XX) is built as module and thus not necessarily loaded. While building SPI_PXA2XX into the kernel would make the problem disappear, it appears prudent to ensure that the driver is instantiated before accessing its data structures. Cc: Arnd Bergmann <arnd@arndb.de> Cc: stable@vger.kernel.org Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2015-10-28spi: Drop owner assignment from spi_driversAndrew F. Davis
An spi_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Andrew F. Davis <afd@ti.com> Acked-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-05-21hwmon: (max1111) remove unnecessary OOM messagesJingoo Han
The site-specific OOM messages are unnecessary, because they duplicate the MM subsystem generic OOM message. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2012-11-28hwmon: remove use of __devexitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Hans de Goede <hdegoede@redhat.com> Cc: Jean Delvare <khali@linux-fr.org> Cc: Alistair John Strachan <alistair@devzero.co.uk> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Juerg Haefliger <juergh@gmail.com> Cc: Andreas Herrmann <herrmann.der.user@googlemail.com> Cc: Clemens Ladisch <clemens@ladisch.de> Cc: Rudolf Marek <r.marek@assembler.cz> Cc: Jim Cromie <jim.cromie@gmail.com> Cc: "Mark M. Hoffman" <mhoffman@lightlink.com> Cc: Roger Lucas <vt8231@hiddenengine.co.uk> Acked-by: Guenter Roeck <linux@roeck-us.net> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28hwmon: remove use of __devinitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Hans de Goede <hdegoede@redhat.com> Cc: Jean Delvare <khali@linux-fr.org> Cc: Alistair John Strachan <alistair@devzero.co.uk> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Juerg Haefliger <juergh@gmail.com> Cc: Andreas Herrmann <herrmann.der.user@googlemail.com> Cc: Clemens Ladisch <clemens@ladisch.de> Cc: Rudolf Marek <r.marek@assembler.cz> Cc: Jim Cromie <jim.cromie@gmail.com> Cc: "Mark M. Hoffman" <mhoffman@lightlink.com> Cc: Roger Lucas <vt8231@hiddenengine.co.uk> Acked-by: Guenter Roeck <linux@roeck-us.net> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28hwmon: remove use of __devexit_pBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Hans de Goede <hdegoede@redhat.com> Cc: Jean Delvare <khali@linux-fr.org> Cc: Alistair John Strachan <alistair@devzero.co.uk> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Juerg Haefliger <juergh@gmail.com> Cc: Andreas Herrmann <herrmann.der.user@googlemail.com> Cc: Clemens Ladisch <clemens@ladisch.de> Cc: Rudolf Marek <r.marek@assembler.cz> Cc: Jim Cromie <jim.cromie@gmail.com> Cc: "Mark M. Hoffman" <mhoffman@lightlink.com> Cc: Roger Lucas <vt8231@hiddenengine.co.uk> Acked-by: Guenter Roeck <linux@roeck-us.net> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-23hwmon: (max1111) Add support for MAX1110, MAX1112, and MAX1113Guenter Roeck
MAX1110 is similar to MAX1111, with 8 instead of 4 channels. MAX1112 and MAX1113 are similar to MAX1110 and MAX1111, with 4.096V reference voltage instead of 2.048V. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Acked-by: Jean Delvare <khali@linux-fr.org>
2012-07-21hwmon: (max1111) Convert to use devm_ functionsGuenter Roeck
Convert to use devm_ functions to reduce code size and simplify the code. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Acked-by: Jean Delvare <khali@linux-fr.org>
2012-03-18hwmon: (max1111) Fix multi-line commentsGuenter Roeck
2012-03-18hwmon: convert drivers/hwmon/* to use module_spi_driver()Axel Lin
This patch converts the drivers in drivers/hwmon/* to use the module_spi_driver() macro which makes the code smaller and a bit simpler. Signed-off-by: Axel Lin <axel.lin@gmail.com> Cc: Sonic Zhang <sonic.zhang@analog.com> Cc: Marc Pignat <marc.pignat@hevs.ch> Cc: Paul Thomas <pthomas8589@gmail.com> Cc: Eric Miao <eric.y.miao@gmail.com> Acked-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2012-01-16hwmon: (max1111) Change sysfs interface to in[0-3]_input in millivoltsEric Miao
This patch fixed the inconsistent max1111 sysfs interface as pointed out by Jean Delvare: It was pointed to me that the max1111 driver doesn't implement the standard sysfs interface for hwmon drivers (as described in Documentation/hwmon/sysfs-interface). It exports files adc[0-3]_in, which aren't part of the standard interface. Presumably these should be renamed to in[0-3]_input. Renaming them is probably not sufficient though, as I see no scaling done in the driver. As the MAX1111 chip has a documented full scale of 2.048V, I take it that the LSB of the ADC has a weight of 8 mV. Exporting raw register values to user-space is not OK. Reported-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Eric Miao <eric.y.miao@gmail.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2012-01-05max1111.c: fix checkpatch warningFrans Meulenbroeks
Signed-off-by: Frans Meulenbroeks <fransmeulenbroeks@gmail.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-07-25hwmon: (max1111) Avoid extra memory allocationsJean Delvare
We can allocate the tx and rx buffers as part of our data structure. Doing so is faster and spares memory. Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Stanislav Brabec <utx@penguin.cz>
2011-07-17hwmon: (max1111) Fix race condition causing NULL pointer exceptionPavel Herrmann
spi_sync call uses its spi_message parameter to keep completion information, using a drvdata structure is not thread-safe. Use a mutex to prevent multiple access to shared driver data. Signed-off-by: Pavel Herrmann <morpheus.ibis@gmail.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Pavel Machek <pavel@ucw.cz> Acked-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Cyril Hrubis <metan@ucw.cz> Tested-by: Stanislav Brabec <utx@penguin.cz> Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: stable@kernel.org
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-09-23spi: prefix modalias with "spi:"Anton Vorontsov
This makes it consistent with other buses (platform, i2c, vio, ...). I'm not sure why we use the prefixes, but there must be a reason. This was easy enough to do it, and I did it. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Jean Delvare <khali@linux-fr.org> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Samuel Ortiz <sameo@openedhand.com> Cc: "John W. Linville" <linville@tuxdriver.com> Acked-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-23hwmon: add max1111_read_channel() for use by sharpsl_pmEric Miao
This is not generic, and is added here for backward compatibility. It is made an individual commit here to make it easier for revert once the sharpsl_pm gets generic enough. Signed-off-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-23hwmon: add max1111 Low-power Multichannel Serial 8-bit ADCsEric Miao
Driver based on corgi_ssp.c and sharpsl_pm.c, previously done by Richard Purdie and many others. Now changed to generic HWMON device and expose all the ADC input value through sysfs. Signed-off-by: Eric Miao <eric.miao@marvell.com> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
