path: root/drivers/hwmon/pcf8591.c
2014-01-29Update Jean Delvare's e-mail addressJean Delvare
2012-07-21hwmon: (pcf8591) Convert to use devm_ functionsGuenter Roeck
Convert to use devm_ functions to reduce code size and simplify the code. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Acked-by: Jean Delvare <khali@linux-fr.org>
2012-03-18hwmon: (pcf8591) Fix checkpatch issuesGuenter Roeck
Fixed: ERROR: do not use assignment in if condition ERROR: spaces required around that ':' (ctx:VxV) ERROR: spaces required around that '?' (ctx:VxV) WARNING: line over 80 characters WARNING: simple_strtoul is obsolete, use kstrtoul instead Modify multi-line comments to follow Documentation/CodingStyle. Cc: Aurelien Jarno <aurelien@aurel32.net> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2012-03-18hwmon: remove () used with returnFrans Meulenbroeks
fix checkpatch ERROR: return is not a function, parentheses are not required Signed-off-by: Frans Meulenbroeks <fransmeulenbroeks@gmail.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-01-08hwmon: (pcf8591) Use pr_fmt and pr_<level>Joe Perches
Added #define pr_fmt KBUILD_MODNAME ": " fmt Converted printks to pr_<level> Coalesced any long formats Removed prefixes from formats Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2010-10-28hwmon: (pcf8591) Don't attempt to detect devicesJean Delvare
The PCF8591 can't be detected, don't even try. There are plenty of other means to instantiate i2c devices these days. Signed-off-by: Jean Delvare <khali@linux-fr.org> Reviewed-by: Guenter Roeck <guenter.roeck@ericsson.com> Cc: Aurelien Jarno <aurelien@aurel32.net>
2010-10-28hwmon: (pcf8591) Register as a hwmon deviceJean Delvare
Register PCF8591 devices as hwmon devices. There's little point in implementing the standard sysfs interface if we don't register it in a way libsensors will pick it. Signed-off-by: Jean Delvare <khali@linux-fr.org> Reviewed-by: Guenter Roeck <guenter.roeck@ericsson.com> Cc: Aurelien Jarno <aurelien@aurel32.net>
2009-12-14i2c: Drop I2C_CLIENT_INSMOD_1Jean Delvare
This macro simply declares an enum, so drivers might as well declare it themselves. Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Wolfram Sang <w.sang@pengutronix.de>
2009-12-14i2c: Get rid of struct i2c_client_address_dataJean Delvare
Struct i2c_client_address_data only contains one field at this point, which makes its usefulness questionable. Get rid of it and pass simple address lists around instead. Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Wolfram Sang <w.sang@pengutronix.de>
2009-12-14i2c: Drop the kind parameter from detect callbacksJean Delvare
The "kind" parameter always has value -1, and nobody is using it any longer, so we can remove it. Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Wolfram Sang <w.sang@pengutronix.de>
2009-03-30Move the pcf8591 driver to hwmonJean Delvare
Directory drivers/i2c/chips is going away, so drivers there must find new homes. For the pcf8591 driver, the best choice seems to be the hwmon subsystem. While the Philips PCF8591 device isn't a typical hardware monitoring chip, its DAC interface is compatible with the hwmon one, so it fits somewhat. If a better subsystem is ever created for ADC/DAC chips, the driver could be moved there. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Aurelien Jarno <aurelien@aurel32.net>
