[ Upstream commit 8c0826756744c0ac1df600a5e4cca1a341b13101 ]
Super-IO accesses may fail on a system with no or unmapped LPC bus.
Also, other drivers may attempt to access the LPC bus at the same time,
resulting in undefined behavior.
Use request_muxed_region() to ensure that IO access on the requested
address space is supported, and to ensure that access by multiple drivers
is synchronized.
Fixes: 8d5d45fb1468 ("I2C: Move hwmon drivers (2/3)")
Reported-by: Kefeng Wang <wangkefeng.wang@huawei.com>
Reported-by: John Garry <john.garry@huawei.com>
Cc: John Garry <john.garry@huawei.com>
Acked-by: John Garry <john.garry@huawei.com>
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Use ATTRIBUTE_GROUPS macro and devm_hwmon_device_register_with_groups() to
simplify the code a bit.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
Tested-by: Jean Delvare <jdelvare@suse.de>
CONFIG_HOTPLUG is going away as an option so __devexit is no
longer needed.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Cc: Hans de Goede <hdegoede@redhat.com>
Cc: Jean Delvare <khali@linux-fr.org>
Cc: Alistair John Strachan <alistair@devzero.co.uk>
Cc: Juerg Haefliger <juergh@gmail.com>
Cc: Andreas Herrmann <herrmann.der.user@googlemail.com>
Cc: Clemens Ladisch <clemens@ladisch.de>
Cc: Rudolf Marek <r.marek@assembler.cz>
Cc: Jim Cromie <jim.cromie@gmail.com>
Cc: "Mark M. Hoffman" <mhoffman@lightlink.com>
Cc: Roger Lucas <vt8231@hiddenengine.co.uk>
Acked-by: Guenter Roeck <linux@roeck-us.net>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
CONFIG_HOTPLUG is going away as an option so __devinit is no longer
needed.
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer
needed.
Convert to use devm_ functions to reduce code size and simplify the code.
Cc: Mark M. Hoffman <mhoffman@lightlink.com>
Acked-by: Jean Delvare <khali@linux-fr.org>
Some configurations produce the following compiler warning:
drivers/hwmon/smsc47b397.c: In function 'smsc47b397_init':
drivers/hwmon/smsc47b397.c:385: warning: 'address' may be used uninitialized in this function
While this is a false positive, it can easily be fixed by overloading the return
value from smsc47b397_find with both address and error return code (the address
is an unsigned short and thus never negative). This also reduces module size by
a few bytes (64 bytes for x86_64).
Reviewed-by: Robert Coulson <robert.coulson@ericsson.com>
Cc: Mark M Hoffman <mhoffman@lightlink.com>
Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
Added #define pr_fmt KBUILD_MODNAME ": " fmt
Converted printks to pr_<level>
Coalesced any long formats
Removed prefixes from formats
Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
Drivers should be including <linux/io.h> instead of <asm/io.h>.
Cc: Nicolas Boichat <nicolas@boichat.ch>
Cc: Frank Seidel <frank@f-seidel.de>
Acked-by: Jim Cromie <jim.cromie@gmail.com>
Check for ACPI resource conflicts in hwmon drivers. I've included
all Super-I/O and PCI drivers.
I've voluntarily left out:
* Vendor-specific drivers: if they conflicted on any system, this would
pretty much mean that they conflict on all systems, and we would know
by now.
* Legacy ISA drivers (lm78 and w83781d): they only support chips found
on old designs were ACPI either wasn't supported or didn't deal with
thermal management.
* Drivers accessing the I/O resources indirectly (e.g. through SMBus):
the checks are already done where they belong, i.e. in the bus drivers.
Signed-off-by: Jean Delvare <jdelvare@suse.de>
Acked-by: David Hubbard <david.c.hubbard@gmail.com>
Added a new ID (0x8c) for the smsc47b397 hardware monitor driver.
This ID is used by HP in, at least, their dc7700 line.
Signed-off-by: Craig Kelley <namonai@gmail.com>
Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
While it is possible to force SMBus-based hardware monitoring chip
drivers to drive a not officially supported device, we do not have this
possibility for Super-I/O-based drivers. That's unfortunate because
sometimes newer chips are fully compatible and just forcing the driver
to load would work. Instead of that we have to tell the users to
recompile the kernel driver, which isn't an easy task for everyone.
So, I propose that we add a module parameter to all Super-I/O based
hardware monitoring drivers, letting advanced users force the driver
to load on their machine. The user has to provide the device ID of a
supposedly compatible device. This requires looking at the source code or
a datasheet, so I am confident that users can't randomly force a driver
without knowing what they are doing. Thus this should be relatively safe.
As you can see from the code, the implementation is pretty simple and
unintrusive.
Acked-by: Hans de Goede <j.w.r.degoede@hhs.nl>
Convert from class_device to device for hwmon_device_register/unregister
Signed-off-by: Tony Jones <tonyj@suse.de>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Also protects ourselves against a possible division by zero.
This patch adds the SMSC SCH5317 chip (device ID 0x85) as a supported
device to the smsc47b397 driver.
Signed-off-by: Juerg Haefliger <juergh at gmail.com>
This lets us get rid of macro-generated functions and shrinks the
driver size by a small amount.
Convert the smsc47b397 driver from the nonsensical i2c-isa hack to a
regular platform driver.
hwmon: Fix unchecked return status, batch 1
Fix up some hwmon drivers so that they no longer ignore return status
from device_create_file().
i2c-isa: Restore driver owner
Commit 2b48716d1d2f2edb1e7cbc5ecf1cb2cb39373e33 back in January
2006 was a bit overzealous. It removed .owner from all i2c drivers,
including i2c-isa ones, while they still need it.
convert drivers/hwmon/*.c semaphore use to mutexes.
the conversion was generated via scripts, and the result was validated
automatically via a script as well.
all affected hwmon drivers were build-tested.
Now that i2c_add_driver() doesn't need the module owner to be set by
hand, we can delete it from the drivers. This patch catches all of the
drivers that I found in the current tree (if a driver sets the .owner by
hand, it's not a problem, just not needed.)
We should use the i2c_driver.driver's .name and .owner fields
instead of the i2c_driver's ones.
This patch updates the hwmon drivers.
Signed-off-by: Laurent Riffard <laurent.riffard@free.fr>
Use kzalloc instead of kmalloc+memset in all hardware monitoring
drivers.
Signed-off-by: Deepak Saxena <dsaxena@plexity.net>
This patch adds a new ID to the SMSC LPC47B397-NC hardware
monitoring driver - for a chip that is claimed to be 100%
compatible otherwise.
Signed-off-by: Bryan Young (Utilitek Systems, Inc.)
We could refactor the error message 34 different i2c drivers print if
i2c_detach_client() fails in this function itself. Saves quite a few
lines of code. Documentation is updated to reflect that change.
Note that this patch should be applied after Rudolf Marek's w83792d
patches.
Call the ISA chip drivers detection function directly instead of relying
on i2c_detect. The net effect is that address lists won't be handled
anymore, but they were mostly useless in the ISA case anyway (pc87360,
smsc47m1, smsc47b397 had already dropped them).
We don't need to handle multiple devices, all we may need is a way to
force a given address instead of the original one (some drivers already
do: sis5595, via686a, w83627hf), and, for drivers supporting multiple
chips, a way to force one given kind. All this may be added later on
demand, but I actually don't think there will be much demand.
Convert the 10 ISA hardware monitoring drivers (it87, lm78, pc87360,
sis5595, smsc47b397, smsc47m1, via686a, w83627hf, w83627ehf, w83781d) to
explicitely register with i2c-isa. For hybrid drivers (it87, lm78,
w83781d), we now have two separate instances of i2c_driver, one for the
I2C interface of the chip, and one for ISA interface. In the long run,
the one for ISA will be replaced with a different driver type.
At this point, all drivers are working again, except for missing
dependencies in Kconfig.
This patch modifies sensors chip drivers to make use of the new
sysfs class "hwmon".
The adm9240 driver, in adm9240_detect(), allocates a structure. The
error path attempts to kfree() ->client field of it (second one),
resulting in an oops (or slab corruption) if the hardware is not present.
->client field in adm1026, adm1031, smsc47b397 and smsc47m1 is the first in
${HWMON}_data structure, but fix them too.
Signed-off-by: Jonathan Corbet <corbet@lwn.net
Part 2: Move the driver files themselves.
Note that the patch "adds trailing whitespace", because it does move the
files as-is, and some files happen to have trailing whitespace.
