in OF device ID table
[ Upstream commit f422449b58548a41e98fc97b259a283718e527db ]
Correct a typo in OF device ID table
The last one should be 'ti,tmp442'
Signed-off-by: Cheng-Min Ao <tony_ao@wiwynn.com>
Signed-off-by: Yu-Hsiang Chen <matt_chen@wiwynn.com>
The driver doesn't have a struct of_device_id table but supported devices
are registered via Device Trees. This is working on the assumption that a
I2C device registered via OF will always match a legacy I2C device ID and
that the MODALIAS reported will always be of the form i2c:<device>.
But this could change in the future so the correct approach is to have an
OF device ID table if the devices are registered via OF.
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
Simplify code and reduce code size by using the new hwmon
registration API.
The FSF mailing address can and will change over time,
so drop it.
Reviewed-by: Jean Delvare <jdelvare@suse.de>
TMP441 and TMP442 are compatible to TMP421 and TMP422.
Not all supported chips support the entire I2C address range.
Only accept specific chips at the addresses supported by that chip.
Check for invalid values in conversion rate and status registers.
Use devm_hwmon_device_register_with_groups API to attach attributes
to hwmon device, simplify code, and reduce code size.
Propagate return value obtained from i2c_smbus_read_byte_data()
instead of hardcoding.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Cc: Andre Prendel <andre.prendel@gmx.de>
Cc: Corentin Labbe <corentin.labbe@geomatys.fr>
Cc: Mark M. Hoffman <mhoffman@lightlink.com>
Cc: Juerg Haefliger <juergh@gmail.com>
Cc: Andreas Herrmann <herrmann.der.user@googlemail.com>
Cc: Rudolf Marek <r.marek@assembler.cz>
Cc: Jim Cromie <jim.cromie@gmail.com>
Cc: Roger Lucas <vt8231@hiddenengine.co.uk>
Cc: Marc Hulsman <m.hulsman@tudelft.nl>
Convert to use devm_ functions to reduce code size and simplify the code.
Acked-by: Jean Delvare <khali@linux-fr.org>
This patch converts the drivers in drivers/hwmon/* to use the
module_i2c_driver() macro which makes the code smaller and a bit simpler.
Cc: Dirk Eibach <eibach@gdsys.de>
Cc: "Mark M. Hoffman" <mhoffman@lightlink.com>
Cc: Steve Glendinning <steve.glendinning@smsc.com>
Cc: Riku Voipio <riku.voipio@iki.fi>
Cc: Guillaume Ligneul <guillaume.ligneul@gmail.com>
Cc: David George <david.george@ska.ac.za>
Cc: "Hans J. Koch" <hjk@hansjkoch.de>
Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
We can mark normal_i2c const. Almost all drivers do that already, so
fix the 3 remaining ones before they are used as (bad) examples for
new drivers.
Cc: George Joseph <george.joseph@fairview5.com>
Reviewed-by: Guenter Roeck <guenter.roeck@ericsson.com>
I2C drivers can use the clientdata-pointer to point to private data. As I2C
devices are not really unregistered, but merely detached from their driver, it
used to be the drivers obligation to clear this pointer during remove() or a
failed probe(). As a couple of drivers forgot to do this, it was agreed that it
was cleaner if the i2c-core does this clearance when appropriate, as there is
no guarantee for the lifetime of the clientdata-pointer after remove() anyhow.
This feature was added to the core with commit
e4a7b9b04de15f6b63da5ccdd373ffa3057a3681 to fix the faulty drivers.
As there is no need anymore to clear the clientdata-pointer, remove all current
occurrences in the drivers to simplify the code and prevent confusion.
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Acked-by: Richard Purdie <rpurdie@linux.intel.com>
Acked-by: Dmitry Torokhov <dtor@mail.ru>
Recent changes on the I2C front have left off-by-one array indexes in
3 hwmon drivers. Fix them.
Faulty commit:
e5e9f44c2 i2c: Drop I2C_CLIENT_INSMOD_2 to 8
Reported-by: Dan Carpenter <error27@gmail.com>
Cc: Hans de Goede <hdegoede@redhat.com>
Cc: stable@kernel.org
The low bits of temperature registers are status bits, they must be
masked out before converting the register values to temperatures.
Tested-by: Andre Prendel <andre.prendel@gmx.de>
An off-by-one error caused some inputs to not be created by the driver
when they should. TMP421 gets only one input instead of two, TMP422
gets two instead of three, etc. Fix the bug by listing explicitly the
number of inputs each device has.
These macros simply declare an enum, so drivers might as well declare
it themselves. This puts an end to the arbitrary limit of 8 chip types
per i2c driver.
Tested-by: Wolfram Sang <w.sang@pengutronix.de>
Struct i2c_client_address_data only contains one field at this point,
which makes its usefulness questionable. Get rid of it and pass simple
address lists around instead.
The "kind" parameter always has value -1, and nobody is using it any
longer, so we can remove it.
As kind is now hard-coded to -1, there is room for code clean-ups.
Acked-by: Andre Prendel <andre.prendel@gmx.de>
Add support for Texas Instruments TMP421/422/423 temperature sensor IC.
TI's TMP421/422/423 are I2C temperature sensor chips. These chips are
similar to TI's TMP401/411 chips, but with reduced functionality (only
temperature measurement). The chips have one local sensor and up to
three (TMP423) remote sensors.
Signed-off-by: Andre Prendel <andre.prendel@gmx.de>
Acked-by: Hans de Goede <hdegoede@redhat.com>
