path: root/drivers/hwmon/w83792d.c
2011-01-12hwmon: (w83792d) Implement the standard intrusion detection interfaceJean Delvare
We have a standard intrusion detection interface now, drivers should implement it. I've left the old interface in place for the time being, with a deprecation warning, it will be removed later. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
2009-12-14i2c: Drop I2C_CLIENT_INSMOD_1Jean Delvare
This macro simply declares an enum, so drivers might as well declare it themselves. Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Wolfram Sang <w.sang@pengutronix.de>
2009-12-14i2c: Get rid of struct i2c_client_address_dataJean Delvare
Struct i2c_client_address_data only contains one field at this point, which makes its usefulness questionable. Get rid of it and pass simple address lists around instead. Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Wolfram Sang <w.sang@pengutronix.de>
2009-12-14i2c: Drop the kind parameter from detect callbacksJean Delvare
The "kind" parameter always has value -1, and nobody is using it any longer, so we can remove it. Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Wolfram Sang <w.sang@pengutronix.de>
2009-12-09hwmon: (w83792d) Clean up detect functionJean Delvare
As kind is now hard-coded to -1, there is room for code clean-ups. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-01-07hwmon: Don't overuse I2C_CLIENT_MODULE_PARMJean Delvare
I2C_CLIENT_MODULE_PARM is overkill for force_subclients. We really only use 4 out of the 48 slots, so we're better defining a custom variable instead. This change saves 92 bytes of data for each of the five drivers affected. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Wolfgang Grandegger <wg@grandegger.com> Acked-by: Marc Hulsman <m.hulsman@tudelft.nl> Cc: Mark M. Hoffman <mhoffman@lightlink.com>
2008-07-16hwmon: (w83792d) Convert to a new-style i2c driverJean Delvare
The new-style w83792d driver implements the optional detect() callback to cover the use cases of the legacy driver. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-02-18hwmon: normal_i2c arrays should be constMark M. Hoffman
Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-10-18Add missing newlines to some uses of dev_<level> messagesJoe Perches
Found these while looking at printk uses. Add missing newlines to dev_<level> uses Add missing KERN_<level> prefixes to multiline dev_<level>s Fixed a wierd->weird spelling typo Added a newline to a printk Signed-off-by: Joe Perches <joe@perches.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Mark M. Hoffman <mhoffman@lightlink.com> Cc: Roland Dreier <rolandd@cisco.com> Cc: Tilman Schmidt <tilman@imap.cc> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: Stephen Hemminger <shemminger@linux-foundation.org> Cc: Greg KH <greg@kroah.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Cc: James Smart <James.Smart@Emulex.Com> Cc: Andrew Vasquez <andrew.vasquez@qlogic.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-09hwmon: Convert from class_device to deviceTony Jones
Convert from class_device to device for hwmon_device_register/unregister Signed-off-by: Tony Jones <tonyj@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-10-09hwmon: (w83792d) Add individual alarm filesGong Jun
w83792d: add individual alarm files for the new libsensors. Signed-off-by: Gong Jun <jgong@winbond.com> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2006-12-12hwmon: Update Rudolf Marek's e-mail addressJean Delvare
The Silicon Hill club is not what it used to be. Signed-off-by: Rudolf Marek <r.marek@assembler.cz> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2006-09-28w83792d: Fix unchecked return statusRudolf Marek
w83792d: Fix unchecked return status Fix the w83792d driver. Add error checking to device_create_file and also care to destroy the files upon exit. Signed-off-by: Rudolf Marek <r.marek@assembler.cz> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26spelling fixesAndreas Mohr
acquired (aquired) contiguous (contigious) successful (succesful, succesfull) surprise (suprise) whether (weather) some other misspellings Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-06-22[PATCH] w83792d: Add missing data access locksYuan Mu
Add missing data lock in w83792d driver to avoid unexpected data change. Signed-off-by: Yuan Mu <ymu@winbond.com.tw> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-22[PATCH] w83792d: Fix setting the PWM valueYuan Mu
W83792D use pwm register low 4 bits to store PWM/DC value, bit 7 is used to store fan PWM/DC mode. The store_pwm function did not convert the pwm input correctly, so it may change the fan mode when new value is set. This fix the problem. Change the "index" value of pwm*_mode and pwm* SENSOR_ATTR to simplify code. Signed-off-by: Yuan Mu <ymu@winbond.com.tw> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-14[PATCH] w83792d: Be quiet on misdetectionJean Delvare
Make the w83792d driver keep quiet when misdetecting a chip. This can happen, and the user doesn't need to know. Also renumber the messages, and add one, for consistency. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-23[PATCH] hwmon: Semaphore to mutex conversionsIngo Molnar
convert drivers/hwmon/*.c semaphore use to mutexes. the conversion was generated via scripts, and the result was validated automatically via a script as well. all affected hwmon drivers were build-tested. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-23[PATCH] hwmon: w83792d drop useless macrosJean Delvare
Drop 3 useless macros in the w83792d hardware monitoring driver. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-23[PATCH] hwmon: w83792d use arrays of attributesYuan Mu
Use arrays of attributes in the w83792d driver. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Yuan Mu <ymu@winbond.com.tw> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-02-06[PATCH] hwmon: Inline w83792d register access functionsJean Delvare
Inline w83792d_{read,write}_value for better performance. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Yuan Mu <Ymu@winbond.com.tw> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-05[PATCH] hwmon: w83792d simplify in low bits handlingJean Delvare
Simplify the way the w83792d driver handles the extra resolution bits of voltage input channels. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Yuan Mu <Ymu@winbond.com.tw> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-05[PATCH] hwmon: w83792d misc cleanupsJean Delvare
Cleanup the w83792d driver a bit: * Discard unused lock and irrelevant comments inherited from the w83781d driver. * Simplify w83792d_{read,write}_value functions. * Drop useless address test during detection. * Drop useless bitmasking. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Yuan Mu <Ymu@winbond.com.tw> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-05[PATCH] I2C: Remove .owner setting from i2c_driver as it's no longer neededGreg Kroah-Hartman
Now that i2c_add_driver() doesn't need the module owner to be set by hand, we can delete it from the drivers. This patch catches all of the drivers that I found in the current tree (if a driver sets the .owner by hand, it's not a problem, just not needed.) Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Cc: Jean Delvare <khali@linux-fr.org>
2006-01-05[PATCH] i2c: Drop i2c_driver.{owner,name}, 3 of 11Laurent Riffard
We should use the i2c_driver.driver's .name and .owner fields instead of the i2c_driver's ones. This patch updates the hwmon drivers. Signed-off-by: Laurent Riffard <laurent.riffard@free.fr> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-05[PATCH] i2c: Drop i2c_driver.flags, 2 of 3Jean Delvare
Just about every i2c chip driver sets the I2C_DF_NOTIFY flag, so we can simply make it the default and drop the flag. If any driver really doesn't want to be notified when i2c adapters are added, that driver can simply omit to set .attach_adapter. This approach is also more robust as it prevents accidental NULL pointer dereferences. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-29[PATCH] hwmon: w83792d fix unused fan pinsJean Delvare
1. This patch add check for fan4,5,6,7 and do not create device file if their pins are not configured as fan. 2. Fix the issue that can not set fan divisor to 128. 3. Fix the index out of bounds bug in w83792d_detect function. Signed-off-by: Yuan Mu <ymu@winbond.com.tw> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] hwmon: kzalloc conversionDeepak Saxena
Use kzalloc instead of kmalloc+memset in all hardware monitoring drivers. Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] hwmon: Discard bogus comment about init setting limitsJean Delvare
Discard a common out-of-date comment in 5 hardware monitoring drivers. The hardware monitoring chip drivers are no more setting sensor limits at initialization time, for quite some time already. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> drivers/hwmon/lm78.c | 1 - drivers/hwmon/via686a.c | 1 - drivers/hwmon/w83627hf.c | 1 - drivers/hwmon/w83781d.c | 1 - drivers/hwmon/w83792d.c | 1 - 5 files changed, 5 deletions(-)
2005-09-05[PATCH] hwmon: hwmon vs i2c, second round (07/11)Jean Delvare
The only part left in i2c-sensor is the VRM/VRD/VID handling code. This is in no way related to i2c, so it doesn't belong there. Move the code to hwmon, where it belongs. Note that not all hardware monitoring drivers do VRM/VRD/VID operations, so less drivers depend on hwmon-vid than there were depending on i2c-sensor. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] hwmon: hwmon vs i2c, second round (06/11)Jean Delvare
The only thing left in i2c-sensor.h are module parameter definition macros. It's only an extension of what i2c.h offers, and this extension is not sensors-specific. As a matter of fact, a few non-sensors drivers use them. So we better merge them in i2c.h, and get rid of i2c-sensor.h altogether. Signed-off-by: Jean Delvare <khali@linux-fr> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] hwmon: hwmon vs i2c, second round (04/11)Jean Delvare
i2c_probe and i2c_detect now do the exact same thing and operate on the same data structure, so we can have everyone call i2c_probe. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] I2C: refactor message in i2c_detach_clientJean Delvare
We could refactor the error message 34 different i2c drivers print if i2c_detach_client() fails in this function itself. Saves quite a few lines of code. Documentation is updated to reflect that change. Note that this patch should be applied after Rudolf Marek's w83792d patches. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] I2C: W83792D add hwmon class register 2/3R.Marek@sh.cvut.cz
This patch adds registration of hwmon class. Tested with help of i2c-stub. Signed-off-by: Rudolf Marek <r.marek@sh.cvut.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] I2C: W83792D driver 1/3R.Marek@sh.cvut.cz
I would like to announce support for W83792D chip. This driver was developed by Winbond Electronics Corp. I added sysfs attributes callbacks infrastructure plus various code fixes and codingstyle cleanups. I would like to thank Winbond for supporting free software. This patch is against 2.6.13rc3 plus hwmon-class and hwmon-split. Separate patch for documantation and hwmon class register will follow. Signed-off-by: Rudolf Marek <r.marek@sh.cvut.cz> Signed-off-by: Chunhao Huang <DZShen@Winbond.com.tw> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
