This patch fixes a number of cases where things were not properly
cleaned up when acpi_check_resource_conflict() returned an error,
causing oopses such as the one reported here:
https://bugzilla.redhat.com/show_bug.cgi?id=483208
If the F71882FG chip is at address 0x4e, then the probe at 0x2e will
fail with the following message in the logs:
f71882fg: Not a Fintek device
This is misleading because there is a Fintek device, just at a
different address. So I propose to degrade this message to a debug
message.
Acked-by: Hans de Goede <hdegoede@redhat.com>
Add support for the HP laptops of model 6710x for having correctly setup
axes.
Signed-off-by: Martin Kebert <gkmarty@gmail.com>
Signed-off-by: Eric Piel <eric.piel@tremplin-utc.net>
Acked-by: Pavel Machek <pavel@suse.cz>
Add support for the HP laptops of model 6730x for having correctly setup
axes.
Signed-off-by: Pavel Herrmann <morpheus.ibis@gmail.com>
Add support for the HP laptops of model 6530x for having correctly setup
axes.
Reported-by: Jerome Poulin <jeromepoulin@gmail.com>
According to dmesg my laptop model HP 6510b is not being recognized by this
driver. After I have modified "lis3lv02d.c" axes in Neverball are OK.
Signed-off-by: Jiri Tersel <tersel@mail.muni.cz>
MacPro 3 have more temperature sensors than the previous MacPro's also the
sensor THTG has been removed. This patch add supports for the newer
temperature sensors in the MacPro3.
Signed-off-by: Bharath Ramesh <bramesh@vt.edu>
Signed-off-by: Henrik Rydberg <rydberg@euromail.se>
* 'hwmon-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6:
hwmon: (abituguru3) Fix CONFIG_DMI=n fallback to probe
hwmon: (abituguru3) Enable DMI probing feature on IN9 32X MAX
hwmon: (abituguru3) Match partial DMI board name strings
hwmon: Add a driver for the ADT7475 hardware monitoring chip
hwmon: (k8temp) Fix temperature reporting for (most) K8 RevG CPUs
hwmon: (k8temp) Fix wrong sensor selection for AMD K8 RevF/RevG CPUs
hwmon: (k8temp) Warn about fam F rev F errata
The LED on HP notebooks is connected through ACPI. That unfortunately
means that it needs to be delayed by using schedule_work() to avoid
calling the ACPI interpreter from an invalid context.
[akpm@linux-foundation.org: use flush_work() rather than sort-of reimplementing it]
Signed-off-by: Pavel Machek <pavel@suse.cz>
Cc: Éric Piel <eric.piel@tremplin-utc.net>
Cc: Len Brown <lenb@kernel.org>
Move the second part of the HP laptop disk protection functionality (a red
led) to the same driver. From a purely Linux developer's point of view,
the led and the accelerometer have nothing related. However, they
correspond to the same ACPI functionality, and so will always be used
together, moreover as they share the same ACPI PNP alias, there is no
other simple to allow to have same loaded at the same time if they are not
in the same module. Also make it requires the led class to compile and
update the Kconfig text.
The light sensors ALV0 and ALV1 on newer MacBooks (early 2008 and later)
changed to report 10 bytes instead the earlier 6, and the sensor encoding
subsequently changed. As a result, the reported light sensors readings
are much too low.
Via experiments leading up to this patch, it seems only the ALV0 is
reporting data, and the most useful value therein is a 10-bit big-endian
value at offset 6. This suggests that a new protocol was added as a
backward-compatible replacement on top of the old one.
This patch makes applesmc report the improved light sensor reading for the
new machines, on a scale in conformance with earlier ones.
Signed-off-by: Alex Murray <murray.alex@gmail.com>
Cc: Nicolas Boichat <nicolas@boichat.ch>
When CONFIG_DMI is not enabled, dmi detection should flag that no board
could be detected (err=1) rather than another error condition (err<0).
This fixes the fallback to manual probing for all motherboards, even
those without DMI strings, when CONFIG_DMI=n.
Signed-off-by: Alistair John Strachan <alistair@devzero.co.uk>
Cc: Hans de Goede <hdegoede@redhat.com>
Switch the IN9 32X MAX over from port probing to the preferred DMI
probe method.
Tested-by: Paul Hartman <paul.hartman+gentoo@gmail.com>
The switch-over to using DMI board strings to identify abituguru3 compatible
mainboards works most of the time, but sometimes the vendor has substantially
modified the board string between BIOS revisions.
We have found that the vendor chipset identification string (provided in
brackets) changes frequently and is of no use to us. The rest of the board
string sometimes changes in subtle ways, e.g. whitespace or variations in
capitalization.
The new comparison code checks only a part of the supplied DMI board string,
trimming the bracketed content, whitespace, and ignoring case as necessary.
This fixes a bug where an IP35 Pro running an early BIOS would not be
detected without the force=1 module parameter, and also speculatively
fixes other similiar issues.
Reported-by: Nick Pasich <NewsLetters@nickandbarb.net>
Hwmon driver for the ADT7475 chip.
Signed-off-by: Jordan Crouse <jordan.crouse@amd.com>
Current Temperature for K8 RevG desktop CPUs is a "normalized value"
which can be below ambient temperature.
As a consequence lots of RevG systems report temperatures like:
$ sensors
k8temp-pci-00c3
Adapter: PCI adapter
Core0 Temp: +17 C
Core0 Temp: +3 C
Core1 Temp: +21 C
Core1 Temp: +5 C
being quite below ambient temperature.
There are even reports of negative temperature values.
This patch corrects the temperature reporting of k8temp for
RevG desktop CPUs.
Cc: Rudolf Marek <r.marek@assembler.cz>
Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com>
Meaning of ThermSenseCoreSel bit was inverted beginning with K8 RevF.
That means with current driver temp1/temp2 belong to core 1 and
temp3/temp4 belong to core 0 on a K8 RevF/RevG CPU.
This patch ensures that temp1/temp2 always belong to core 0 and
temp3/temp4 to core 1 for all K8 revisions.
Add warning about wrong CPU temperature readouts on all fam F rev F.
The allowed combinations of processors ensure that all processors
in a multisocket system have similar characteristics, e.g.
(1) provide temperature sensor interface (>=RevC && <RevF)
(2) are affected by erratum #141 (>=RevF)
Thus it is sufficient to check the revision of the boot CPU.
For "mixed silicon support" refer to
"Revision Guide for AMD Athlon 64 and AMD Opteron Processors" (RevA-E) and
"Revision Guide for AMD NPT Family 0Fh Processors" (RefF-G).
The sensor can be accessed via various buses. In particular, SPI, I²C
and, on HP laptops, via a specific ACPI API (the only one currently
supported). Separate this latest platform from the core of the sensor
driver to allow support for the other bus type. The second, and more
direct goal is actually to be able to merge this part with the
hp-disk-leds driver, which has the same ACPI PNP number.
* 'hwmon-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6: (29 commits)
hwmon: Fix various typos
hwmon: Check for ACPI resource conflicts
hwmon: (lm70) Add TI TMP121 support
hwmon: (lm70) Code streamlining and cleanup
hwmon: Deprecate the fscher and fscpos drivers
hwmon: (fschmd) Add watchdog support
hwmon: (fschmd) Cleanups for watchdog support
hwmon: (i5k_amb) Load automatically on all 5000/5400 chipsets
hwmon: (it87) Add support for the ITE IT8720F
hwmon: Don't overuse I2C_CLIENT_MODULE_PARM
hwmon: Add LTC4245 driver
hwmon: (f71882fg) Fix fan_to/from_reg prototypes
hwmon: (f71882fg) Printout fan modes
hwmon: (f71882fg) Add documentation
hwmon: (f71882fg) Fix auto_channels_temp temp numbering with f8000
hwmon: (f71882fg) Add missing pwm3 attr for f71862fg
hwmon: (f71882fg) Add F8000 support
hwmon: (f71882fg) Remove the fan_mode module option
hwmon: (f71882fg) Separate max and crit alarm and beep
hwmon: (f71882fg) Check for hwmon powerdown state
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (24 commits)
trivial: chack -> check typo fix in main Makefile
trivial: Add a space (and a comma) to a printk in 8250 driver
trivial: Fix misspelling of "firmware" in docs for ncr53c8xx/sym53c8xx
trivial: Fix misspelling of "firmware" in powerpc Makefile
trivial: Fix misspelling of "firmware" in usb.c
trivial: Fix misspelling of "firmware" in qla1280.c
trivial: Fix misspelling of "firmware" in a100u2w.c
trivial: Fix misspelling of "firmware" in megaraid.c
trivial: Fix misspelling of "firmware" in ql4_mbx.c
trivial: Fix misspelling of "firmware" in acpi_memhotplug.c
trivial: Fix misspelling of "firmware" in ipw2100.c
trivial: Fix misspelling of "firmware" in atmel.c
trivial: Fix misspelled firmware in Kconfig
trivial: fix an -> a typos in documentation and comments
trivial: fix then -> than typos in comments and documentation
trivial: update Jesper Juhl CREDITS entry with new email
trivial: fix singal -> signal typo
trivial: Fix incorrect use of "loose" in event.c
trivial: printk: fix indentation of new_text_line declaration
trivial: rtc-stk17ta8: fix sparse warning
Acked-by: David Hubbard <david.c.hubbard@gmail.com>
Check for ACPI resource conflicts in hwmon drivers. I've included
all Super-I/O and PCI drivers.
I've voluntarily left out:
* Vendor-specific drivers: if they conflicted on any system, this would
pretty much mean that they conflict on all systems, and we would know
by now.
* Legacy ISA drivers (lm78 and w83781d): they only support chips found
on old designs were ACPI either wasn't supported or didn't deal with
thermal management.
* Drivers accessing the I/O resources indirectly (e.g. through SMBus):
the checks are already done where they belong, i.e. in the bus drivers.
Signed-off-by: Jean Delvare <jdelvare@suse.de>
The Texas Instruments TMP121 is a SPI temperature sensor very similar
to the LM70, with slightly higher resolution. This patch extends the
LM70 driver to support the TMP121. The TMP123 differs in pin assign-
ment.
Signed-off-by: Manuel Lauss <mano@roarinelk.homelinux.net>
This fixes a byteswap bug in the LM70 temperature sensor driver,
which was previously covered up by a converse bug in the driver
for the LM70EVAL-LLP board (which is also fixed).
Other fixes: doc updates, remove an annoying msleep(), and improve
three-wire protocol handling.
Signed-off-by: Kaiwan N Billimoria <kaiwan@designergraphix.com>
[ dbrownell@users.sourceforge.net: doc and whitespace tweaks ]
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Now that the new merged fschmd driver has gained support for the watchdog
integrated into these IC's, there is no more reason to keep the old fscher
and fscpos drivers around, so mark them as deprecated.
This patch adds support for the watchdog part found in _all_ supported FSC
sensor chips.
Various small cleanups in preparation of adding watchdog support,
mostly removing _MASK postfix from defines which are not masks.
It turns out that we cannot create a pci_driver in this driver because PCI will
not call this module's probe function if the i5000-edac driver is already
loaded. That said, we only want one value (AMBASE) from the PCI config space.
Neither driver alters this value, so it's safe to read it. However, we still
want the module aliases, so provide that.
Signed-off-by: Darrick J. Wong <djwong@us.ibm.com>
Allow it87.c to handle IT8720 chipset like IT8718 in order to
retrieve voltage, temperatures and fans speed from sensors
tools. Also updating the related documentation.
Signed-off-by: Jean-Marc Spaggiari <jean-marc@spaggiari.org>
I2C_CLIENT_MODULE_PARM is overkill for force_subclients. We really
only use 4 out of the 48 slots, so we're better defining a custom
variable instead. This change saves 92 bytes of data for each of the
five drivers affected.
Cc: Wolfgang Grandegger <wg@grandegger.com>
Acked-by: Marc Hulsman <m.hulsman@tudelft.nl>
Cc: Mark M. Hoffman <mhoffman@lightlink.com>
Add Linux support for the Linear Technology LTC4245 Multiple Supply Hot
Swap controller I2C monitoring interface.
Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu>
The RPM after conversion from / before conversion to a register value can be
much more than 65535 (up to 1500000), so putting this into an u16 can cause
overflows. This changes the functions to use an int to store / get RPM instead.
Print the mode (duty-cycle or RPM) of each fan on driver load.
Add some documentation about the f71882fg driver, and update the Kconfig
documentation to report the new supported models.
Adjust auto_channels_temp show and store functions for different numbering of
temps between f8000 and other supported models.
For some reason the fan_attr array for the f71862fg was missing the attr for
the 3th pwm output. This patch fixes this.
And (finally) the patch actually adding f8000 support.
Remove the fan_mode module option it was a monstrosity to begin with, and
when adding support for the F8000 it becomes a real pain!
While studying the datasheets for adding F8000 support, I noticed that the
F718x2 has separate alarms (and beep control) for its max and crit limits.
We keep the temp#_alarm attributes as they are, even though it would be more
logical to rename them to temp#_max_alarm. Because lm_sensors v2 depends
on them.
More F8000 prep work. Take over the checking if the hwmon part is not
powered down from the standalone f8000 driver.
This check is valid for all supported models.
Simplify fan and temp hyst. handling by treating the registers as an array of
nibbles instead of using switch cases. Also unify the way hysts are handled
between temp and fans, the temp code was storing the actual per temp hyst
values in 4 u8's, where as the fan code was storing actual register values.
While working on adding F8000 support I noticed that various of the
store sysfs functions (and a few of the show also) had issues.
This patch fixes the following issues in these functions:
* store: storing the result of strto[u]l in an int, resulting in a possible
overflow before boundary checking
* store: use of f71882fg_update_device(), we don't want to read the whole
device in store functions, just the registers we need
* store: use of cached register values instead of reading the needed regs
in the store function, including cases where f71882fg_update_device() was
not used, this could cause real isues
* show: shown value is a calculation of 2 or more cached register reads,
without locking the data struct.
This patch is a preparation patch for adding F8000 support to the f71882fg
driver. If you look at the register addresses and esp, the bits used for
the temperature channels, then you will notice that it appears that they
start at 1 in a system meant to start at 0. As the F8000 actually uses the 0
addresses and bits, this patch changes the f71882fg driver to take 4
temperatures numbered 0-3 in to account, using 1-3 in this new scheme for
the temperatures actually present in the F718x2FG.
The f71882fg driver did some io to ioports it hadn't reserved yet in its
find (detect) function, this patches moves this io to the probe function
where these ports are reserved and this io belongs.
This patch adds support for the Fintek f71862fg superio monitoring
functions to the f71882fg driver.
This support has been tested without problems on a Jetway J9F2 by
Tony McConnell.
Various small cleanups as preparation for adding f71862fg support to the
f71882fg driver.
Add PWM (fan speed control) support to the f71882fg driver. Both
manual control and automatic (temperature-based) modes are supported.
Additionally, each mode has a PWM-based and an RPM-based variant. By
default we use the mode set by the BIOS.
Cc: Mark van Doesburg <mark.vandoesburg@hetnet.nl>
A few cleanups that were originally part of a larger patch but are
better submitted separately.
Convert f71882fg driver from SENSOR_ATTR to SENSOR_ATTR2 use, this is a
preparation patch for adding pwm support, which is broken out to make what
changes really in the pwm support patch clear.
