Current calculation is completely wrong. Add missing brackets to fix it.
Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
Acked-by: Jean Delvare <khali@linux-fr.org>
Cc: stable@kernel.org # 3.0+
Function i5k_channel_pci_id looks like it can fail, while a better
code design would make it more obvious that it can't. We can even get
rid of the function.
Acked-by: Darrick J. Wong <djwong@us.ibm.com>
Replace unnecessary if with else statement.
This fixes the following (false) compile warning reported with some combinations
of C compiler version and configuration.
drivers/hwmon/ntc_thermistor.c: In function 'ntc_show_temp':
drivers/hwmon/ntc_thermistor.c:225: warning: 'low' may be used uninitialized in
this function
drivers/hwmon/ntc_thermistor.c:225: note: 'low' was declared here
drivers/hwmon/ntc_thermistor.c:225: warning: 'high' may be used uninitialized in
this function
drivers/hwmon/ntc_thermistor.c:225: note: 'high' was declared here
drivers/hwmon/ntc_thermistor.c:294: warning: 'temp' may be used uninitialized in
this function
rs_resp is dynamically allocated in aem_read_sensor(), so it should be freed
before exiting in every case. This collects the kfree and the return at
the end of the function.
Cc: stable@kernel.org # 2.6.27+
pmbus_clear_faults() attempts to clear faults on non-existing real pages.
As a result, the command error bit in the status register is set, and faults
are not really cleared.
All byte writes to non-zero pages are requests to clear the status register
on that page. Since non-zero pages are virtual and do not exist on the chip,
there is nothing to do, and such requests have to be ignored. This fixes
above problem.
Reviewed-by: Robert Coulson <robert.coulson@ericsson.com>
With virtual pages and to be able to handle more chips, it is necessary to
virtualise pmbus_write_byte().
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging
* 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging: (24 commits)
hwmon: (lm90) Refactor reading of config2 register
hwmon: (lm90) Make SA56004 detection more robust
hwmon: (lm90) Simplify handling of extended local temp register
hwmon: (pmbus) Add client driver for LM25066, LM5064, and LM5066
hwmon: (max34440) Add support for peak attributes
hwmon: (max8688) Add support for peak attributes
hwmon: (max16064) Add support for peak attributes
hwmon: (adm1275) Add support for peak attributes
hwmon: (pmbus) Add support for peak attributes
hwmon: Add new attributes to sysfs ABI
hwmon: (pmbus) Strengthen check for status register existence
hwmon: (pmbus) Add support for virtual pages
hwmon: (pmbus) Support reading and writing of word registers in device specific code
hwmon: (pmbus) Increase attribute name size
hwmon: (pmbus) Add ADP4000, NCP4200 and NCP4208 to list of supported devices
hwmon: (pmbus) Add support for VID output voltage mode
hwmon: (pmbus) Move PMBus drivers to drivers/hwmon/pmbus
hwmon: (coretemp) Add core/pkg threshold support to Coretemp
hwmon: (lm95241) Add support for LM95231
hwmon: LM95245 driver
Several vendors implement a second configuration register, which we
check during device detection. Refactor the code to avoid duplication.
Cc: Stijn Devriendt <sdevrien@cisco.com>
Cc: Guenter Roeck <guenter.roeck@ericsson.com>
With a device ID register value of 0, the SA56004 detection is rather
weak. Check several other register too to confirm the detection, as we
do for other supported devices.
Acked-by: Stijn Devriendt <sdevrien@cisco.com>
The optional extended local temperature register can never have
address 0, as this address is already used by another register. Thus
we can get rid of flag LM90_HAVE_LOCAL_EXT and simply rely on
reg_local_ext being non-zero to determine if a given chip has this
extension or not. This makes the code more simple.
PMBus client driver supporting National Semiconductor LM25066, LM5064, and LM5066.
Add support for voltage, current, and temperature peak (historic maximum)
attributes.
attributes.
Add support for voltage and temperature peak (historic maximum) attributes.
Add support for voltage and current peak (historic maximum) attributes.
Most PMBus devices provide manufacturer specific commands to read low and/or
high peak values for some or all of its sensors.
To support providing those values as lowest/highest attributes to the user,
introduce virtual PMBus commands. Those commands reside outside the normal
command set and have to be implemented in device specific code, which map the
virtual commands to device specific commands.
With virtual register page support, it is now possible that the status register
on virtual pages does not exist or is itself virtual. To take this into account
when creating alarm attributes, generate those attributes only if the status
register on the respective page is known to exist.
Some PMBus chips have non-standard sensor registers. An easy way to
support such sensors is to introduce virtual pages and map the non-standard
registers into standard registers on an extra page.
For this to work, the code verifying if the configured number of pages exists
has to be removed. Since a wrong number of pages can only be configured in a
front-end driver, this should not have a practical impact since the resulting
errors should be found during development and testing.
Also, functions to read the chip status while checking if a command register
exists must be modified to no longer set the page register before reading the
status, since the physical page associated with the checked register may not
exist. This does not make a functional difference since the page was already set
when the attempt to read the register was made.
specific code
Some PMBus devices use non-standard registers for some of the sensors and/or
limits. To support such devices, add code to support reading and writing of word
size registers in device specific code.
Some hwmon sysfs attributes have a length of 20 bytes (plus terminating 0).
I2C_NAME_SIZE is defined as 20 and thus can not be used to define the length
of hwmon sysfs attributes. Replace it with PMBUS_NAME_SIZE, set to 24.
Add ADP4000, NCP4200 and NCP4208 to the list of devices supported by the generic
PMBus driver, and add device IDs to enable explicit instantiation.
In VID mode, output voltages are measured and reported as VID values, and
have to be converted to voltages using VID conversion tables or functions.
Support is added for VR11 only at this time.
This patch enables support for PMBus devices supporting VID VR11 based output
voltage selection such as NCP4200 and NCP4208.
Since the number of PMBus drivers is getting large, move them into
directory drivers/hwmon/pmbus to improve readability and scalability.
This patch adds the core and pkg support to coretemp.
These thresholds can be configured via the sysfs interfaces tempX_max
and tempX_max_hyst. An interrupt is generated when CPU temperature reaches
or crosses above tempX_max OR drops below tempX_max_hyst.
This patch is based on the documentation in IA Manual vol 3A, that can be
downloaded from here:
http://download.intel.com/design/processor/manuals/253668.pdf
Signed-off-by: Durgadoss R <durgadoss.r@intel.com>
LM95231 is fully compatible to LM95241; only necessary change is to add
chip detection.
A hwmon driver for the National Semiconductor LM95245 dual temperature
sensors chip.
Signed-off-by: Alexander Stein <alexander.stein@systec-electronic.com>
Add support for Philips SA56004, an LM86 compatible temperature sensor.
Signed-off-by: Stijn Devriendt <sdevrien@cisco.com>
Add support for NTC Thermistor series. In this release, the
following thermistors are supported: NCP15WB473, NCP18WB473, NCP03WB473,
and NCP15WL333. This driver is based on the datasheet of MURATA.
The driver in the patch does conversion from the raw ADC value
(either voltage or resistence) to temperature. In order to use
voltage values as input, the circuit schematics should be provided
with the platform data. A compensation table for each type of thermistor
is provided for the conversion.
Signed-off-by: Donggeun Kim <dg77.kim@samsung.com>
Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com>
Signed-off-by: KyungMin Park <kyungmin.park@samsung.com>
Reviewed-by: Shubhrajyoti D <shubhrajyoti@ti.com>
MAX1668 and compatibles have several external temperature sensors, but only a
single FAULT status bit. If a fault occurs, the temperature reported on the
affected sensors is 127 degrees C. Use this knowledge to report fault on
external sensors.
This patch adds support for MAX1668 and compatible temperature sensors.
Signed-off-by: David George <david.george@ska.ac.za>
[guenter.roeck@ericsson.com: minor cleanup of probe error path]
This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
Signed-off-by: Arun Sharma <asharma@fb.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging
* 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging:
hwmon: (lm78) Become the maintainer
hwmon: (lm78) Make ISA interface depend on CONFIG_ISA
hwmon: (lm78) Avoid forward declarations
hwmon: (sht15) Correct a comment mistake
hwmon: (max1111) Avoid extra memory allocations
hwmon: (it87) Add chassis intrusion detection support
hwmon: (via-cputemp) Add VID reporting support
hwmon-vid: Add support for VIA family 6 model D CPU
hwmon: New driver sch5636
hwmon: (sch5627) Factor out some code shared with sch5636 driver
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
fs: Merge split strings
treewide: fix potentially dangerous trailing ';' in #defined values/expressions
uwb: Fix misspelling of neighbourhood in comment
net, netfilter: Remove redundant goto in ebt_ulog_packet
trivial: don't touch files that are removed in the staging tree
lib/vsprintf: replace link to Draft by final RFC number
doc: Kconfig: `to be' -> `be'
doc: Kconfig: Typo: square -> squared
doc: Konfig: Documentation/power/{pm => apm-acpi}.txt
drivers/net: static should be at beginning of declaration
drivers/media: static should be at beginning of declaration
drivers/i2c: static should be at beginning of declaration
XTENSA: static should be at beginning of declaration
SH: static should be at beginning of declaration
MIPS: static should be at beginning of declaration
ARM: static should be at beginning of declaration
rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check
Update my e-mail address
PCIe ASPM: forcedly -> forcibly
gma500: push through device driver tree
Fix up trivial conflicts:
- arch/arm/mach-ep93xx/dma-m2p.c (deleted)
- drivers/gpio/gpio-ep93xx.c (renamed and context nearby)
- drivers/net/r8169.c (just context changes)
Declare myself the maintainer of the lm78 driver. I still have a
running system with one of these chips.
Also count myself as a co-author of the driver. With 34 commits over
6 years, it seems fair.
We should only include support for the ISA interface of the LM78/LM79
if CONFIG_ISA is set. Not only this makes the driver somewhat smaller
on most architectures, but this also avoids poking at random I/O
ports on these architectures.
This is very similiar to what was done for the w83781d driver in
October 2008.
Cc: Dean Nelson <dnelson@redhat.com>
Move code around to avoid several forward declarations. Also group
ISA-related functions together, to make future changes easier.
sht15_store_heater() is called on _write_ access to heater_enable.
Signed-off-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com>
We can allocate the tx and rx buffers as part of our data structure.
Doing so is faster and spares memory.
Tested-by: Stanislav Brabec <utx@penguin.cz>
Add chassis intrusion detection support for all supported devices,
using the standard interface.
At least VIA family 6 model D CPU report the VID settings in a MSR,
so expose the value to user-space. Not sure about model A.
Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
Tested-by: Jeff Rickman <jrickman@myamigos.us>
The VIA family 6 model D CPU (C7-D, Eden 90 nm) can use two different
VID tables, we have to check the value of a MSR to decide which one to
use.
This patch adds a new driver for SMSC SCH5636 Super I/O chips.
The chips include an embedded microcontroller for hardware monitoring
solutions, allowing motherboard manufacturers to create their own
custom hwmon solution based upon the SCH5636.
Currently the sch5636 driver only supports the Fujitsu Theseus SCH5636
based hwmon solution. The sch5636 driver runs a sanity check on
loading to ensure it is dealing with a Fujitsu Theseus and not with
another custom SCH5636 based hwmon solution.
This patch adds a new sch56xx-common.ko which contains code which will also
be used in the new sch5636 driver.
All these are instances of
#define NAME value;
or
#define NAME(params_opt) value;
These of course fail to build when used in contexts like
if(foo $OP NAME)
while(bar $OP NAME)
and may silently generate the wrong code in contexts such as
foo = NAME + 1; /* foo = value; + 1; */
bar = NAME - 1; /* bar = value; - 1; */
baz = NAME & quux; /* baz = value; & quux; */
Reported on comp.lang.c,
Message-ID: <ab0d55fe-25e5-482b-811e-c475aa6065c3@c29g2000yqd.googlegroups.com>
Initial analysis of the dangers provided by Keith Thompson in that thread.
There are many more instances of more complicated macros having unnecessary
trailing semicolons, but this pile seems to be all of the cases of simple
values suffering from the problem. (Thus things that are likely to be found
in one of the contexts above, more complicated ones aren't.)
Signed-off-by: Phil Carmody <ext-phil.2.carmody@nokia.com>
spi_sync call uses its spi_message parameter to keep completion information,
using a drvdata structure is not thread-safe. Use a mutex to prevent
multiple access to shared driver data.
Signed-off-by: Pavel Herrmann <morpheus.ibis@gmail.com>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Acked-by: Pavel Machek <pavel@ucw.cz>
Acked-by: Marek Vasut <marek.vasut@gmail.com>
Acked-by: Cyril Hrubis <metan@ucw.cz>
A copy-and-paste error caused it87_attributes_vid to be referenced
where it87_attributes_label should be. Thankfully the group is only
used for attribute removal, not attribute creation, so the effects of
this bug are limited, but let's fix it still.
The object returned by atk_gitm is dynamically allocated and must be
freed.
Signed-off-by: Luca Tettamanti <kronos.it@gmail.com>
Coefficients to convert chip register values to voltage/current have been
slightly changed in revision B of the chip datasheet. Update driver coefficients
to match the coefficients in the datasheet.
Using integer variable types for register to data conversions can cause
overflows especially for power calculations, which are in microwatt.
Use long variables instead.
Cc: stable@kernel.org # 2.6.39+
It is possible that a PMBus device supports the READ_TEMPERATURE2 and/or
READ_TEMPERATURE3 registers but does not support READ_TEMPERATURE1.
Improve temperature status register detection to address this condition.
Reported-by: Jean Delvare <khali@linux-fr.org>
