commit 6e6c18bcb78c0dc0601ebe216bed12c844492d0c upstream.
This adds support for the Trace Hub in Tiger Lake CPU.
Signed-off-by: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Cc: stable@vger.kernel.org
Link: https://lore.kernel.org/r/20191120130806.44028-4-alexander.shishkin@linux.intel.com
commit 6a1743422a7c0fda26764a544136cac13e5ae486 upstream.
This adds support for the Trace Hub in Ice Lake CPU.
Link: https://lore.kernel.org/r/20191120130806.44028-3-alexander.shishkin@linux.intel.com
commit 512592779a337feb5905d8fcf9498dbf33672d4a upstream.
Commit a753bfcfdb1f ("intel_th: Make the switch allocate its subdevices")
factored out intel_th_subdevice_alloc() from intel_th_populate(), but got
the error path wrong, resulting in two instances of a double put_device()
on a freshly initialized, but not 'added' device.
Fix this by only doing one put_device() in the error path.
Fixes: a753bfcfdb1f ("intel_th: Make the switch allocate its subdevices")
Reported-by: Wen Yang <wenyang@linux.alibaba.com>
Cc: stable@vger.kernel.org # v4.14+
Link: https://lore.kernel.org/r/20191120130806.44028-2-alexander.shishkin@linux.intel.com
commit 2fe6899e36aa174abefd017887f9cfe0cb60c43a upstream.
A number of issues are fixed relating to sysfs input validation:-
1) bb_ctrl_store() - incorrect compare of bit select field to absolute
value. Reworked per ETMv4 specification.
2) seq_event_store() - incorrect mask value - register has two
event values.
3) cyc_threshold_store() - must mask with max before checking min
otherwise wrapped values can set illegal value below min.
4) res_ctrl_store() - update to mask off all res0 bits.
Reviewed-by: Leo Yan <leo.yan@linaro.org>
Reviewed-by: Mathieu Poirier <mathieu.poirier@linaro.org>
Signed-off-by: Mike Leach <mike.leach@linaro.org>
Fixes: a77de2637c9eb ("coresight: etm4x: moving sysFS entries to a dedicated file")
Cc: stable <stable@vger.kernel.org> # 4.9+
Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org>
Link: https://lore.kernel.org/r/20191104181251.26732-6-mathieu.poirier@linaro.org
[ Upstream commit e7753f3937610633a540f2be81be87531f96ff04 ]
>From the comment in the code, it claims the requirement for byte-address
alignment for RRP register: 'for 32-bit, 64-bit and 128-bit wide trace
memory, the four LSBs must be 0s. For 256-bit wide trace memory, the
five LSBs must be 0s'. This isn't consistent with the program, the
program sets five LSBs as zeros for 32/64/128-bit wide trace memory and
set six LSBs zeros for 256-bit wide trace memory.
After checking with the CoreSight Trace Memory Controller technical
reference manual (ARM DDI 0461B, section 3.3.4 RAM Read Pointer
Register), it proves the comment is right and the program does wrong
setting.
This patch fixes byte-address alignment for RRP by following correct
definition in the technical reference manual.
Cc: Mathieu Poirier <mathieu.poirier@linaro.org>
Cc: Mike Leach <mike.leach@linaro.org>
Signed-off-by: Leo Yan <leo.yan@linaro.org>
[ Upstream commit b860801e3237ec4c74cf8de0be4816996757ae5c ]
For non-VHE systems host kernel runs at EL1 and jumps to EL2 whenever
hypervisor code should be executed. In this case ETM4x driver must
restrict configuration to EL1 when it setups kernel tracing.
However, there is no separate hypervisor privilege level when VHE
is enabled, the host kernel runs at EL2.
This patch fixes configuration of TRCACATRn register for VHE systems
so that ETM_EXLEVEL_NS_HYP bit is used instead of ETM_EXLEVEL_NS_OS
to on/off kernel tracing. At the same time, it moves common code
to new helper.
Signed-off-by: Tomasz Nowicki <tnowicki@caviumnetworks.com>
[ Upstream commit 4f8ef21007531c3d7cb5b826e7b2c8999b65ecae ]
We enable the trace path, before activating the source.
If we fail to enable the source, we must disable the path
to make sure it is available for another session.
Signed-off-by: Suzuki K Poulose <suzuki.poulose@arm.com>
[ Upstream commit 5ecabe4a76e8cdb61fa3e24862d9ca240a1c4ddf ]
We create a coresight trace path for each online CPU when
we start the event. We rely on the number of online CPUs
and then go on to allocate an array matching the "number of
online CPUs" for holding the path and then uses normal
CPU id as the index to the array. This is problematic as
we could have some offline CPUs causing us to access beyond
the actual array size (e.g, on a dual SMP system, if CPU0 is
offline, CPU1 could be really accessing beyond the array).
The solution is to switch to per-cpu array for holding the path.
[ Upstream commit c71369de02b285d9da526a526d8f2affc7b17c59 ]
The coresight components could be operated either in sysfs mode or in perf
mode. For some of the components, the mode of operation doesn't matter as
they simply relay the data to the next component in the trace path. But for
sinks, they need to be able to provide the trace data back to the user.
Thus we need to make sure that "mode" is handled appropriately. e.g,
the sysfs mode could have multiple sources driving the trace data, while
perf mode doesn't allow sharing the sink.
The coresight_enable_sink() however doesn't really allow this check to
trigger as it skips the "enable_sink" callback if the component is
already enabled, irrespective of the mode. This could cause mixing
of data from different modes or even same mode (in perf), if the
sources are different. Also, if we fail to enable the sink while
enabling a path (where sink is the first component enabled),
we could end up in disabling the components in the "entire"
path which were not enabled in this trial, causing disruptions
in the existing trace paths.
commit 9d55499d8da49e9261e95a490f3fda41d955f505 upstream.
This adds support for Intel TH on Jasper Lake PCH.
Link: https://lore.kernel.org/r/20191028070651.9770-8-alexander.shishkin@linux.intel.com
commit 3adbb5718dd5264666ddbc2b9b43799d292e9cb6 upstream.
This adds support for Intel TH on Comet Lake PCH.
Link: https://lore.kernel.org/r/20191028070651.9770-7-alexander.shishkin@linux.intel.com
commit 1004ce4c255fc3eb3ad9145ddd53547d1b7ce327 upstream.
Synchronization is recommended before disabling the trace registers
to prevent any start or stop points being speculative at the point
of disabling the unit (section 7.3.77 of ARM IHI 0064D).
Synchronization is also recommended after programming the trace
registers to ensure all updates are committed prior to normal code
resuming (section 4.3.7 of ARM IHI 0064D).
Let's ensure these syncronization points are present in the code
and clearly commented.
Note that we could rely on the barriers in CS_LOCK and
coresight_disclaim_device_unlocked or the context switch to user
space - however coresight may be of use in the kernel.
On armv8 the mb macro is defined as dsb(sy) - Given that the etm4x is
only used on armv8 let's directly use dsb(sy) instead of mb(). This
removes some ambiguity and makes it easier to correlate the code with
the TRM.
Signed-off-by: Andrew Murray <andrew.murray@arm.com>
Reviewed-by: Suzuki K Poulose <suzuki.poulose@arm.com>
[Fixed capital letter for "use" in title]
Link: https://lore.kernel.org/r/20190829202842.580-11-mathieu.poirier@linaro.org
Cc: stable@vger.kernel.org # 4.9+
commit 9c78255fdde45c6b9a1ee30f652f7b34c727f5c7 upstream.
This adds support for the Trace Hub in Tiger Lake PCH.
Link: https://lore.kernel.org/r/20190821074955.3925-5-alexander.shishkin@linux.intel.com
commit 164eb56e3b64f3a816238d410c9efec7567a82ef upstream.
Add support for the Trace Hub in another Lewisburg PCH.
Link: https://lore.kernel.org/r/20190821074955.3925-4-alexander.shishkin@linux.intel.com
commit 961b6ffe0e2c403b09a8efe4a2e986b3c415391a upstream.
In the error path of stm_source_register_device(), the kfree is
unnecessary, as the put_device() before it ends up calling
stm_source_device_release() to free stm_source_device, leading to
a double free at the outer kfree() call. Remove it.
Signed-off-by: Ding Xiang <dingxiang@cmss.chinamobile.com>
Fixes: 7bd1d4093c2fa ("stm class: Introduce an abstraction for System Trace Module devices")
Link: https://lore.kernel.org/linux-arm-kernel/1563354988-23826-1-git-send-email-dingxiang@cmss.chinamobile.com/
Cc: stable@vger.kernel.org # v4.4+
Link: https://lore.kernel.org/r/20190821074955.3925-2-alexander.shishkin@linux.intel.com
commit 918b8646497b5dba6ae82d4a7325f01b258972b9 upstream.
Commit 4e0eaf239fb3 ("intel_th: msu: Fix single mode with IOMMU") switched
the single mode code to use dma mapping pages obtained from the page
allocator, but with IOMMU disabled, that may lead to using SWIOTLB bounce
buffers and without additional sync'ing, produces empty trace buffers.
Fix this by using a DMA32 GFP flag to the page allocation in single mode,
as the device supports full 32-bit DMA addressing.
Fixes: 4e0eaf239fb3 ("intel_th: msu: Fix single mode with IOMMU")
Reported-by: Ammy Yi <ammy.yi@intel.com>
Link: https://lore.kernel.org/r/20190621161930.60785-4-alexander.shishkin@linux.intel.com
commit 4aa5aed2b6f267592705a526f57518a5d715b769 upstream.
This adds Ice Lake NNPI support to the Intel(R) Trace Hub.
Link: https://lore.kernel.org/r/20190621161930.60785-5-alexander.shishkin@linux.intel.com
commit 4e0eaf239fb33ebc671303e2b736fa043462e2f4 upstream.
Currently, the pages that are allocated for the single mode of MSC are not
mapped into the device's dma space and the code is incorrectly using
*_to_phys() in place of a dma address. This fails with IOMMU enabled and
is otherwise bad practice.
Fix the single mode buffer allocation to map the pages into the device's
DMA space.
Fixes: ba82664c134e ("intel_th: Add Memory Storage Unit driver")
commit ee496da4c3915de3232b5f5cd20e21ae3e46fe8d upstream.
Number of free masters is not set correctly in stm
free path. Fix this by properly adding the number
of output channels before setting them to 0 in
stm_output_disclaim().
Currently it is equivalent to doing nothing since
master->nr_free is incremented by 0.
Fixes: 7bd1d4093c2f ("stm class: Introduce an abstraction for System Trace Module devices")
Signed-off-by: Tingwei Zhang <tingwei@codeaurora.org>
Signed-off-by: Sai Prakash Ranjan <saiprakash.ranjan@codeaurora.org>
commit e60e9a4b231a20a199d7a61caadc48693c30d695 upstream.
This adds support for Intel TH on Comet Lake.
commit 91d3f8a629849968dc91d6ce54f2d46abf4feb7f upstream.
Commit 9ed3f22223c3 ("intel_th: Don't reference unassigned outputs")
fixes a NULL dereference for all masters except the last one ("256+"),
which keeps the stale pointer after the output driver had been unassigned.
Fix the off-by-one.
Fixes: 9ed3f22223c3 ("intel_th: Don't reference unassigned outputs")
[ Upstream commit a0f890aba2be33377f4eb24e13633c4a76a68f38 ]
This patch is to add the AMBA device ID for CA73 CPU, so that CPU debug
module can be initialized successfully when a SoC contain CA73 CPUs.
This patch has been verified on 96boards Hikey960.
[ Upstream commit 5666dfd1d8a45a167f0d8b4ef47ea7f780b1f24a ]
SDM845 has ETMv4.2 and can use the existing etm4x driver.
But the current etm driver checks only for ETMv4.0 and
errors out for other etm4x versions. This patch adds this
missing support to enable SoC's with ETMv4x to use same
driver by checking only the ETM architecture major version
number.
Without this change, we get below error during etm probe:
/ # dmesg | grep etm
[ 6.660093] coresight-etm4x: probe of 7040000.etm failed with error -22
[ 6.666902] coresight-etm4x: probe of 7140000.etm failed with error -22
[ 6.673708] coresight-etm4x: probe of 7240000.etm failed with error -22
[ 6.680511] coresight-etm4x: probe of 7340000.etm failed with error -22
[ 6.687313] coresight-etm4x: probe of 7440000.etm failed with error -22
[ 6.694113] coresight-etm4x: probe of 7540000.etm failed with error -22
[ 6.700914] coresight-etm4x: probe of 7640000.etm failed with error -22
[ 6.707717] coresight-etm4x: probe of 7740000.etm failed with error -22
With this change, etm probe is successful:
[ 6.659198] coresight-etm4x 7040000.etm: CPU0: ETM v4.2 initialized
[ 6.665848] coresight-etm4x 7140000.etm: CPU1: ETM v4.2 initialized
[ 6.672493] coresight-etm4x 7240000.etm: CPU2: ETM v4.2 initialized
[ 6.679129] coresight-etm4x 7340000.etm: CPU3: ETM v4.2 initialized
[ 6.685770] coresight-etm4x 7440000.etm: CPU4: ETM v4.2 initialized
[ 6.692403] coresight-etm4x 7540000.etm: CPU5: ETM v4.2 initialized
[ 6.699024] coresight-etm4x 7640000.etm: CPU6: ETM v4.2 initialized
[ 6.705646] coresight-etm4x 7740000.etm: CPU7: ETM v4.2 initialized
commit 9ed3f22223c33347ed963e7c7019cf2956dd4e37 upstream.
When an output port driver is removed, also remove references to it from
any masters. Failing to do this causes a NULL ptr dereference when
configuring another output port:
> BUG: unable to handle kernel NULL pointer dereference at 000000000000000d
> RIP: 0010:master_attr_store+0x9d/0x160 [intel_th_gth]
> Call Trace:
> dev_attr_store+0x1b/0x30
> sysfs_kf_write+0x3c/0x50
> kernfs_fop_write+0x125/0x1a0
> __vfs_write+0x3a/0x190
> ? __vfs_write+0x5/0x190
> ? _cond_resched+0x1a/0x50
> ? rcu_all_qs+0x5/0xb0
> vfs_write+0xb8/0x1b0
> ksys_write+0x55/0xc0
> __x64_sys_write+0x1a/0x20
> do_syscall_64+0x5a/0x140
> entry_SYSCALL_64_after_hwframe+0x44/0xa9
Fixes: b27a6a3f97b9 ("intel_th: Add Global Trace Hub driver")
CC: stable@vger.kernel.org # v4.4+
commit bf7cbaae0831252b416f375ca9b1027ecd4642dd upstream.
Using STP_POLICY_ID_SET ioctl command with dummy_stm device, or any STM
device that supplies zero mmio channel size, will trigger a division by
zero bug in the kernel.
Prevent this by disallowing channel widths other than 1 for such devices.
commit a1d75dad3a2c689e70a1c4e0214cca9de741d0aa upstream.
There is a bug in the channel allocation logic that leads to an endless
loop when looking for a contiguous range of channels in a range with a
mixture of free and occupied channels. For example, opening three
consequtive channels, closing the first two and requesting 4 channels in
a row will trigger this soft lockup. The bug is that the search loop
forgets to skip over the range once it detects that one channel in that
range is occupied.
Restore the original intent to the logic by fixing the omission.
Signed-off-by: Zhi Jin <zhi.jin@intel.com>
commit ec5b5ad6e272d8d6b92d1007f79574919862a2d2 upstream.
The 'nr_pages' attribute of the 'msc' subdevices parses a comma-separated
list of window sizes, passed from userspace. However, there is a bug in
the string parsing logic wherein it doesn't exclude the comma character
from the range of characters as it consumes them. This leads to an
out-of-bounds access given a sufficiently long list. For example:
> # echo 8,8,8,8 > /sys/bus/intel_th/devices/0-msc0/nr_pages
> BUG: KASAN: slab-out-of-bounds in memchr+0x1e/0x40
> Read of size 1 at addr ffff8803ffcebcd1 by task sh/825
> CPU: 3 PID: 825 Comm: npktest.sh Tainted: G W 4.20.0-rc1+
> Call Trace:
> dump_stack+0x7c/0xc0
> print_address_description+0x6c/0x23c
> ? memchr+0x1e/0x40
> kasan_report.cold.5+0x241/0x308
> memchr+0x1e/0x40
> nr_pages_store+0x203/0xd00 [intel_th_msu]
Fix this by accounting for the comma character.
Fixes: ba82664c134ef ("intel_th: Add Memory Storage Unit driver")
[ Upstream commit 987d1e8dcd370d96029a3d76a0031b043c4a69ae ]
If the ETB is already enabled in sysfs mode, the ETB reports
success even if a perf mode is requested. Fix this by checking
the requested mode.
[ Upstream commit 59d08d00d43c644ee2011d7ff1807bdd69f31fe0 ]
This adds Intel(R) Trace Hub PCI ID for Ice Lake PCH.
commit 8801922cd94c918e4dc3a108ecaa500c4d40583f upstream.
brings in new subdevice addition/removal logic that's broken for "host
mode": the SWITCH device has no children to begin with, which is not
handled in the code. This results in a null dereference bug later down
the path.
This patch fixes the subdevice removal code to handle host mode correctly.
CC: stable@vger.kernel.org # v4.14+
[ Upstream commit 5cedd22370a0a460b663c06de1fc10b4ba3c5d0b ]
Add ETM PIDs of the Arm cortex-A CPUs to the white list of ETMs.
While at it add a helper macro to make it easier to add the new
entries.
[ Upstream commit ccff2dfaceaca4517432f5c149594215fe9098cc ]
Probing the TPIU driver under UBSan triggers an out-of-bounds shift
warning in coresight_timeout():
[ 5.677530] UBSAN: Undefined behaviour in drivers/hwtracing/coresight/coresight.c:929:16
[ 5.685542] shift exponent 64 is too large for 64-bit type 'long unsigned int'
On closer inspection things are exponentially out of whack because we're
passing a bitmask where a bit number should be. Amusingly, it seems that
both calls will find their expected values by sheer luck and appear to
succeed: 1 << FFCR_FON_MAN ends up at bit 64 which whilst undefined
evaluates as zero in practice, while 1 << FFSR_FT_STOPPED finds bit 2
(TCPresent) which apparently is usually tied high.
Following the examples of other drivers, define separate FOO and FOO_BIT
macros for masks vs. indices, and put things right.
CC: Robert Walker <robert.walker@arm.com>
CC: Mike Leach <mike.leach@linaro.org>
CC: Mathieu Poirier <mathieu.poirier@linaro.org>
Fixes: 11595db8e17f ("coresight: Fix disabling of CoreSight TPIU")
Signed-off-by: Robin Murphy <robin.murphy@arm.com>
[ Upstream commit fe470f5f7f684ed15bc49b6183a64237547910ff ]
If we fail to find the input / output port for a LINK component
while enabling a path, we should fail gracefully rather than
assuming port "0".
commit 0ed2424b911f3a058dfea01b78817abed767433d upstream.
Commit d5c435df4a890 ("intel_th: msu: Use the real device in case of IOMMU
domain allocation") changes dma buffer allocation to use the actual
underlying device, but forgets to change the deallocation path, which leads
to (if you've got CAP_SYS_RAWIO):
> # echo 0,0 > /sys/bus/intel_th/devices/0-msc0/nr_pages
> ------------[ cut here ]------------
> kernel BUG at ../linux/drivers/iommu/intel-iommu.c:3670!
> CPU: 3 PID: 231 Comm: sh Not tainted 4.17.0-rc1+ #2729
> RIP: 0010:intel_unmap+0x11e/0x130
> Call Trace:
> intel_free_coherent+0x3e/0x60
> msc_buffer_win_free+0x100/0x160 [intel_th_msu]
This patch fixes the buffer deallocation code to use the correct device.
Fixes: d5c435df4a890 ("intel_th: msu: Use the real device in case of IOMMU domain allocation")
Reported-by: Baofeng Tian <baofeng.tian@intel.com>
commit 806e30873f0e74d9d41b0ef761bd4d3e55c7d510 upstream.
Commit b5e2ced9bf81 ("stm class: Use vmalloc for the master map") caused
a build error on some arches as vmalloc.h was not explicitly included.
Fix that by adding it to the list of includes.
Fixes: b5e2ced9bf81 ("stm class: Use vmalloc for the master map")
Reported-by: kbuild test robot <lkp@intel.com>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
commit b5e2ced9bf81393034072dd4d372f6b430bc1f0a upstream.
Fengguang is running into a warning from the buddy allocator:
> swapper/0: page allocation failure: order:9, mode:0x14040c0(GFP_KERNEL|__GFP_COMP), nodemask=(null)
> CPU: 1 PID: 1 Comm: swapper/0 Not tainted 4.17.0-rc1 #262
> Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-1 04/01/2014
> Call Trace:
> __kmalloc+0x14b/0x180: ____cache_alloc at mm/slab.c:3127
> stm_register_device+0xf3/0x5c0: stm_register_device at drivers/hwtracing/stm/core.c:695
Which is basically a result of the stm class trying to allocate ~512kB
for the dummy_stm with its default parameters. There's no reason, however,
for it not to be vmalloc()ed instead, which is what this patch does.
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
[ Upstream commit 831c326fcd0e8e2a6ece952f898a1ec9b1dc1004 ]
Commit ad67b74d2469 ("printk: hash addresses printed with %p") lets
printk specifier %p to hash all addresses before printing, this was
resulting in the high 32 bits of pcsr can only output zeros. So
module cannot completely print pc value and it's pointless for debugging
purpose.
This patch fixes this by using %px to print pcsr instead.
[ Upstream commit 9ad577087165478c9d9be82b15ed9bf2db5835f5 ]
Since commit 8edc514b01e9 ("intel_th: Make SOURCE devices children of the
root device") the hub is not the parent of SOURCE devices any more, so the
new helper function should be used for that instead of always using the
parent. The intel_th_set_output() path, however, still uses the old
logic, leading to the hub driver structure being aliased with something
else, like struct pci_driver or struct acpi_driver, and an incorrect call
to an address inferred from that, potentially resulting in a crash.
Fixes: 8edc514b01e9 ("intel_th: Make SOURCE devices children of the root device")
[ Upstream commit 11595db8e17faaa05fadc25746c870e31276962f ]
The CoreSight TPIU should be disabled when tracing to other sinks to allow
them to operate at full bandwidth.
This patch fixes tpiu_disable_hw() to correctly disable the TPIU by
configuring the TPIU to stop on flush, initiating a manual flush, waiting
for the flush to complete and then waits for the TPIU to indicate it has
stopped.
Signed-off-by: Robert Walker <robert.walker@arm.com>
Tested-by: Mike Leach <mike.leach@linaro.org>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
This adds Intel(R) Trace Hub PCI ID for Lewisburg PCH.
This adds Intel(R) Trace Hub PCI ID for Cedar Fork PCH.
For reasons unknown, the stm_source removal path uses device_destroy()
to kill the underlying device object. Because device_destroy() uses
devt to look for the device to destroy and the fact that stm_source
devices don't have one (or all have the same one), it just picks the
first device in the class, which may well be the wrong one.
That is, loading stm_console and stm_heartbeat and then removing both
will die in dereferencing a freed object.
Since this should have been device_unregister() in the first place,
use it instead of device_destroy().
Fixes: 7bd1d4093c2 ("stm class: Introduce an abstraction for System Trace Module devices")
git://git.kernel.org/pub/scm/linux/kernel/git/ash/stm into char-misc-next
Alexander writes:
stm class / intel_th: Updates for 4.14
Intel TH:
* Updated subdevice management code to better fit host mode
* Added support for Low Power Path (LPP) output type
* Fixed memory allocation with IOMMU enabled (DMAR tables)
* Added Cannon Lake PCH PCI IDs
* Added a quirk to force time sync on devices that need it
STM:
* Fixed potential read overflow in ioctl()
* Documented stm_ftrace source.
amba_id are not supposed to change at runtime. All functions
working with const amba_id. So mark the non-const structs as const.
Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com>
