path: root/drivers/i2c/busses/i2c-at91.c
2012-01-12i2c/busses: Use module_platform_driver()Axel Lin
Convert the drivers in drivers/i2c/busses/* to use the module_platform_driver() macro which makes the code smaller and a bit simpler. Cc: Ben Dooks <ben-linux@fluff.org> Acked-by: Jochen Friedrich <jochen@scram.de> Acked-by: Peter Korsgaard <jacmet@sunsite.dk> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Cc: Manuel Lauss <manuel.lauss@googlemail.com> Cc: Barry Song <21cnbao@gmail.com> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Yong Zhang <yong.zhang0@gmail.com> Cc: Lucas De Marchi <lucas.demarchi@profusion.mobi> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-05-21i2c: Use <linux/io.h> instead of <asm/io.h>H Hartley Sweeten
As warned by checkpatch.pl, <linux/io.h> should be used instead of <asm/io.h>. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-06-16i2c: Use resource_size macroLinus Walleij
This replace all instances in the i2c busses tree of res->end - res->start + 1 with the handy macro resource_size(res) from ioport.h (coming in from platform_device.h). This was created with a simple sed -i -e 's/\([a-z]*\)->end *- *[a-z]*->start *+ *1/resource_size(\1)/g' Then manually replacing the PXA redefiniton of the same kind of macro manually. Recompiled some ARM defconfigs I could find to make a rough test so it shouldn't break anything, though I couldn't see exactly which configs you need for all the drivers. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2009-01-07i2c: Use snprintf to set adapter namesJean Delvare
Use snprintf instead of sprintf to set adapter names, it's safer. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-08-23removed unused #include <linux/version.h>'sAdrian Bunk
This patch lets the files using linux/version.h match the files that #include it. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-22i2c: Fix platform driver hotplug/coldplugKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable I2C platform drivers, to allow module auto loading. [ db: add some more drivers ] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-01-14i2c: Spelling fixesJoe Perches
[JD: One more fix in i2c-dev.] Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-05-10i2c-at91: compile fix (IS_ERR)Alexey Dobriyan
CC drivers/i2c/busses/i2c-at91.o drivers/i2c/busses/i2c-at91.c: In function 'at91_i2c_probe': drivers/i2c/busses/i2c-at91.c:213: warning: implicit declaration of function 'IS_ERR' Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: David Brownell <david-b@pacbell.net> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-10i2c-at91 supports new-style i2c driversDavid Brownell
Make i2c-at91 register as i2c adapter zero (none of these chips seem to have more than one TWI controllers) to let it kick in any board-specific device declarations; also make it hotplug/coldplug. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Jean Delvare <khali@linux-fr.org> Cc: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-02PCI: Cleanup the includes of <linux/pci.h>Jean Delvare
I noticed that many source files include <linux/pci.h> while they do not appear to need it. Here is an attempt to clean it all up. In order to find all possibly affected files, I searched for all files including <linux/pci.h> but without any other occurence of "pci" or "PCI". I removed the include statement from all of these, then I compiled an allmodconfig kernel on both i386 and x86_64 and fixed the false positives manually. My tests covered 66% of the affected files, so there could be false positives remaining. Untested files are: arch/alpha/kernel/err_common.c arch/alpha/kernel/err_ev6.c arch/alpha/kernel/err_ev7.c arch/ia64/sn/kernel/huberror.c arch/ia64/sn/kernel/xpnet.c arch/m68knommu/kernel/dma.c arch/mips/lib/iomap.c arch/powerpc/platforms/pseries/ras.c arch/ppc/8260_io/enet.c arch/ppc/8260_io/fcc_enet.c arch/ppc/8xx_io/enet.c arch/ppc/syslib/ppc4xx_sgdma.c arch/sh64/mach-cayman/iomap.c arch/xtensa/kernel/xtensa_ksyms.c arch/xtensa/platform-iss/setup.c drivers/i2c/busses/i2c-at91.c drivers/i2c/busses/i2c-mpc.c drivers/media/video/saa711x.c drivers/misc/hdpuftrs/hdpu_cpustate.c drivers/misc/hdpuftrs/hdpu_nexus.c drivers/net/au1000_eth.c drivers/net/fec_8xx/fec_main.c drivers/net/fec_8xx/fec_mii.c drivers/net/fs_enet/fs_enet-main.c drivers/net/fs_enet/mac-fcc.c drivers/net/fs_enet/mac-fec.c drivers/net/fs_enet/mac-scc.c drivers/net/fs_enet/mii-bitbang.c drivers/net/fs_enet/mii-fec.c drivers/net/ibm_emac/ibm_emac_core.c drivers/net/lasi_82596.c drivers/parisc/hppb.c drivers/sbus/sbus.c drivers/video/g364fb.c drivers/video/platinumfb.c drivers/video/stifb.c drivers/video/valkyriefb.c include/asm-arm/arch-ixp4xx/dma.h sound/oss/au1550_ac97.c I would welcome test reports for these files. I am fine with removing the untested files from the patch if the general opinion is that these changes aren't safe. The tested part would still be nice to have. Note that this patch depends on another header fixup patch I submitted to LKML yesterday: [PATCH] scatterlist.h needs types.h http://lkml.org/lkml/2007/3/01/141 Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-10i2c: New Atmel AT91 bus driverAndrew Victor
Add support for the I2C (Two-wire interface) controller integrated in the Atmel AT91RM9200 processor. This driver should also be usable on the Atmel AT91SAM9261 and AT91SAM9260 processors. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
