path: root/drivers/i2c/busses/i2c-isch.c
2010-03-07i2c: convert i2c-isch to platform_deviceDenis Turischev
Convert i2c-isch to platform_device for the lpc mfd core to add it at probe time. Signed-off-by: Denis Turischev <denis@compulab.co.il> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-03-02i2c: Make PCI device ids constantMárton Németh
The id_table field of the struct pci_driver is constant in <linux/pci.h> so it is worth to make initialization data also constant. The semantic match that finds this kind of pattern is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r@ disable decl_init,const_decl_init; identifier I1, I2, x; @@ struct I1 { ... const struct I2 *x; ... }; @s@ identifier r.I1, y; identifier r.x, E; @@ struct I1 y = { .x = E, }; @c@ identifier r.I2; identifier s.E; @@ const struct I2 E[] = ... ; @depends on !c@ identifier r.I2; identifier s.E; @@ + const struct I2 E[] = ...; // </smpl> Signed-off-by: Márton Németh <nm127@freemail.hu> Cc: Julia Lawall <julia@diku.dk> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-10-04i2c: Hide probe errors caused by ACPI resource conflictsJean Delvare
When an ACPI resource conflict is detected, error messages are already printed by ACPI. There's no point in causing the driver core to print more error messages, so return one of the error codes for which no message is printed. This fixes bug #14293: http://bugzilla.kernel.org/show_bug.cgi?id=14293 Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-05-05i2c: Timeouts off by 1Roel Kluin
with while (timeout++ < MAX_TIMEOUT); timeout reaches MAX_TIMEOUT + 1 after the loop, so the tests below are off by one. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-07-14i2c: Check for ACPI resource conflictsJean Delvare
Check for ACPI resource conflicts in i2c bus drivers. I've included all recent SMBus master drivers for PC hardware. I've voluntarily left out: * Drivers that don't run on PCs: they can't conflict with ACPI. * Bit-banged bus device drivers: it's very unlikely that ACPI would deal with such buses. Signed-off-by: Jean Delvare <jdelvare@suse.de>
2008-07-14i2c: Let bus drivers add SPD to their classJean Delvare
Let general purpose I2C/SMBus bus drivers add SPD to their class. Once this is done, we will be able to tell the eeprom driver to only probe for SPD EEPROMs and similar on these buses. Note that I took a conservative approach here, adding I2C_CLASS_SPD to many drivers that have no idea whether they can host SPD EEPROMs or not. This is to make sure that the eeprom driver doesn't stop probing buses where SPD EEPROMs or equivalent live. So, bus driver maintainers and users should feel free to remove the SPD class from drivers those buses never have SPD EEPROMs or they don't want the eeprom driver to bind to them. Likewise, feel free to add the SPD class to any bus driver I might have missed. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-07-14i2c: Add Intel SCH SMBus supportAlek Du
New i2c bus driver for the Intel SCH chipsets (AF82US15W, AF82US15L, AF82UL11L). Signed-off-by: Alek Du <alek.du@intel.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
