Convert the drivers in drivers/i2c/busses/* to use the
module_platform_driver() macro which makes the code smaller and a bit
simpler.
Cc: Ben Dooks <ben-linux@fluff.org>
Acked-by: Jochen Friedrich <jochen@scram.de>
Acked-by: Peter Korsgaard <jacmet@sunsite.dk>
Cc: Manuel Lauss <manuel.lauss@googlemail.com>
Cc: Barry Song <21cnbao@gmail.com>
Cc: Linus Walleij <linus.walleij@linaro.org>
Cc: Yong Zhang <yong.zhang0@gmail.com>
Cc: Lucas De Marchi <lucas.demarchi@profusion.mobi>
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: Samuel Ortiz <sameo@linux.intel.com>
i2c->adap.name shouldn't be used in request_irq.
Instead the driver name "i2c-pca-platform" should be used.
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
Cc: stable@kernel.org
ret is still -1, if during the polling read_byte() returns at once
with I2C_PCA_CON_SI set. So ret > 0 would lead *_waitforcompletion()
to return 0, in spite of the proper behavior.
The routine was rewritten, so that ret has always a proper value,
before returning.
Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com>
Reviewed-by: Wolfram Sang <w.sang@pengutronix.de>
As warned by checkpatch.pl, <linux/io.h> should be used instead of
<asm/io.h>.
Unexpected signals can disturb the bus-handling and lock it up. Don't use
interruptible in 'wait_event_*' and 'wake_*' as in commits
dc1972d02747d2170fb1d78d114801f5ecb27506 (for cpm),
1ab082d7cbd0f34e39a5396cc6340c00bc5d66ef (for mpc),
b7af349b175af45f9d87b3bf3f0a221e1831ed39 (for omap).
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
This replace all instances in the i2c busses tree of
res->end - res->start + 1 with the handy macro resource_size(res)
from ioport.h (coming in from platform_device.h).
This was created with a simple
sed -i -e 's/\([a-z]*\)->end *- *[a-z]*->start *+ *1/resource_size(\1)/g'
Then manually replacing the PXA redefiniton of the same kind
of macro manually. Recompiled some ARM defconfigs I could find to
make a rough test so it shouldn't break anything, though I
couldn't see exactly which configs you need for all the drivers.
Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
We now timeout also if the state machine does not change within the
given time. For that, the driver-specific completion-functions are
extended to return true or false depending on the timeout. This then
gets checked in the algorithm.
Add support for the PCA9665 I2C controller.
Fix errorcode to be more descriptive when ioremap fails.
Tested on a blackfin.
