path: root/drivers/i2c/busses/i2c-sis5595.c
2010-05-21i2c: Use <linux/io.h> instead of <asm/io.h>H Hartley Sweeten
As warned by checkpatch.pl, <linux/io.h> should be used instead of <asm/io.h>. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-03-02i2c: Make PCI device ids constantMárton Németh
The id_table field of the struct pci_driver is constant in <linux/pci.h> so it is worth to make initialization data also constant. The semantic match that finds this kind of pattern is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r@ disable decl_init,const_decl_init; identifier I1, I2, x; @@ struct I1 { ... const struct I2 *x; ... }; @s@ identifier r.I1, y; identifier r.x, E; @@ struct I1 y = { .x = E, }; @c@ identifier r.I2; identifier s.E; @@ const struct I2 E[] = ... ; @depends on !c@ identifier r.I2; identifier s.E; @@ + const struct I2 E[] = ...; // </smpl> Signed-off-by: Márton Németh <nm127@freemail.hu> Cc: Julia Lawall <julia@diku.dk> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-12-06i2c: Add missing __devinit markers to old i2c adapter driversJean Delvare
These _setup functions are called from _probe so they can be marked __devinit. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-05-05i2c: Timeouts off by 1Roel Kluin
with while (timeout++ < MAX_TIMEOUT); timeout reaches MAX_TIMEOUT + 1 after the loop, so the tests below are off by one. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-01-26i2c: Delete many unused adapter IDsJean Delvare
2009-01-07i2c: Use snprintf to set adapter namesJean Delvare
Use snprintf instead of sprintf to set adapter names, it's safer. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-07-14i2c: Drop stray references to lm_sensorsJean Delvare
2008-07-14i2c: Check for ACPI resource conflictsJean Delvare
Check for ACPI resource conflicts in i2c bus drivers. I've included all recent SMBus master drivers for PC hardware. I've voluntarily left out: * Drivers that don't run on PCs: they can't conflict with ACPI. * Bit-banged bus device drivers: it's very unlikely that ACPI would deal with such buses. Signed-off-by: Jean Delvare <jdelvare@suse.de>
2008-07-14i2c: Let bus drivers add SPD to their classJean Delvare
Let general purpose I2C/SMBus bus drivers add SPD to their class. Once this is done, we will be able to tell the eeprom driver to only probe for SPD EEPROMs and similar on these buses. Note that I took a conservative approach here, adding I2C_CLASS_SPD to many drivers that have no idea whether they can host SPD EEPROMs or not. This is to make sure that the eeprom driver doesn't stop probing buses where SPD EEPROMs or equivalent live. So, bus driver maintainers and users should feel free to remove the SPD class from drivers those buses never have SPD EEPROMs or they don't want the eeprom driver to bind to them. Likewise, feel free to add the SPD class to any bus driver I might have missed. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-07-14i2c: Bus drivers return -Errno not -1David Brownell
Tighten error paths used by various i2c adapters (mostly x86) so they return real fault/errno codes instead of a "-1" (which is most often interpreted as "-EPERM"). Build tested, with eyeball review. One minor initial goal is to have adapters consistently return the code "-ENXIO" when addressing a device doesn't get an ACK response, at least in the probe paths where they are already good at stifling related logspam. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-04-29i2c-sis5595: Minor cleanups in sis5595_accessJean Delvare
* Remove commented-out code. * Use dev_warn instead of printk. * Remove a legacy comment. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-04-29i2c: Spelling fix (successful)Jean Delvare
2007-07-12i2c-sis5595: Resolve resource conflict with sis5595Jean Delvare
Let the i2c-sis5595 driver release its PCI device after registering. This is to allow the sis5595 hardware monitoring driver to also access this PCI device. The same trick is already used in the i2c-viapro and via686a drivers to let them both load. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-02-17Replace remaining references to "driverfs" with "sysfs".Robert P. J. Day
Globally, s/driverfs/sysfs/g. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-13i2c: Add IDs to adaptersStephen Hemminger
IDs have been defined but not used by most of the I2C adapters. By having a unique ID, clients can check for correct connection during probe. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2006-09-26i2c: Constify i2c_algorithm declarations, part 2Jean Delvare
i2c: Constify i2c_algorithm declarations, part 2 Make struct i2c_algorithm declarations const in all i2c bus drivers where it is possible. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-10[PATCH] PCI: removed unneeded .owner field from struct pci_driverGreg Kroah-Hartman
2005-10-28[PATCH] Owner field additions to many i2c drivers, 1 of 5Laurent Riffard
This patch updates .owner field for various struct pci_driver variables. Signed-off-by: Laurent Riffard <laurent.riffard@free.fr> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] i2c: Reuse name strings in i2c bus driversJean Delvare
Clean up name string usage in 12 i2c bus drivers: * Use the i2c_adapter name for requesting the I/O region rather than redefining a new string. * Do not initialize the i2c_adapter name to "unset". This should save a few data bytes here and there. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> drivers/i2c/busses/i2c-ali1535.c | 6 +++--- drivers/i2c/busses/i2c-ali1563.c | 6 ++++-- drivers/i2c/busses/i2c-ali15x3.c | 5 +++-- drivers/i2c/busses/i2c-amd756.c | 5 ++--- drivers/i2c/busses/i2c-amd8111.c | 4 +++- drivers/i2c/busses/i2c-i801.c | 4 ++-- drivers/i2c/busses/i2c-nforce2.c | 4 ++-- drivers/i2c/busses/i2c-piix4.c | 4 ++-- drivers/i2c/busses/i2c-sis5595.c | 5 +++-- drivers/i2c/busses/i2c-sis630.c | 6 ++++-- drivers/i2c/busses/i2c-sis96x.c | 5 +++-- drivers/i2c/busses/i2c-via.c | 4 ++-- 12 files changed, 33 insertions(+), 25 deletions(-)
2005-10-28[PATCH] i2c: Discard explicit static initializations to 0Jean Delvare
Kill explicit static initializations to 0 in 10 i2c drivers. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> drivers/i2c/algos/i2c-algo-pca.c | 2 +- drivers/i2c/algos/i2c-algo-sibyte.c | 2 +- drivers/i2c/busses/i2c-ali15x3.c | 4 ++-- drivers/i2c/busses/i2c-amd756.c | 2 +- drivers/i2c/busses/i2c-iop3xx.c | 2 +- drivers/i2c/busses/i2c-piix4.c | 8 ++++---- drivers/i2c/busses/i2c-sis5595.c | 4 ++-- drivers/i2c/busses/i2c-sis630.c | 2 +- drivers/i2c/busses/i2c-sis96x.c | 2 +- drivers/i2c/busses/i2c-via.c | 2 +- 10 files changed, 15 insertions(+), 15 deletions(-)
2005-09-05[PATCH] I2C: Kill i2c_algorithm.id (4/7)Jean Delvare
There are no more users of i2c_algorithm.id, so we can finally drop this structure member. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] I2C: Kill i2c_algorithm.name (1/7)Jean Delvare
The name member of the i2c_algorithm is never used, although all drivers conscientiously fill it. We can drop it completely, this structure doesn't need to have a name. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-07-11[PATCH] I2C: Strip trailing whitespace from stringsJean Delvare
Here is a simple patch originally from Denis Vlasenko, which strips a useless trailing whitespace from 8 strings in 4 i2c drivers. Please apply, thanks. From: Denis Vlasenko <vda@ilport.com.ua> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-21[PATCH] I2C: drivers/i2c/*: #include <linux/config.h> cleanupAlexey Dobriyan
Files that don't use CONFIG_* stuff shouldn't include config.h Files that use CONFIG_* stuff should include config.h It's that simple. ;-) Signed-off-by: Alexey Dobriyan <adobriyan@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
