path: root/drivers/i2c
2011-05-26mfd: Use mfd cell platform_data for timberdale cells platform bitsSamuel Ortiz
With the addition of a device platform mfd_cell pointer, MFD drivers can go back to passing platform data back to their sub drivers. This allows for an mfd_cell->mfd_data removal and thus keep the sub drivers MFD agnostic. This is mostly needed for non MFD aware sub drivers. Acked-by: Richard Röjfors <richard.rojfors@pelagicore.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-05-24Merge branch 'for-linus/2640/i2c' of git://git.fluff.org/bjdooks/linuxLinus Torvalds
* 'for-linus/2640/i2c' of git://git.fluff.org/bjdooks/linux: (21 commits) mach-ux500: set proper I2C platform data from MOP500s i2c-nomadik: break out single messsage transmission i2c-nomadik: reset the hw after status check i2c-nomadik: remove the unnecessary delay i2c-nomadik: change the TX and RX threshold i2c-nomadik: add code to retry on timeout failure i2c-nomadik: use pm_runtime API i2c-nomadik: print abort cause only on abort tag i2c-nomadik: correct adapter timeout initialization i2c-nomadik: remove the redundant error message i2c-nomadik: corrrect returned error numbers i2c-nomadik: fix speed enumerator i2c-nomadik: make i2c timeout specific per i2c bus i2c-nomadik: add regulator support i2c: i2c-sh_mobile bus speed platform data V2 i2c: i2c-sh_mobile clock string removal i2c-eg20t: Support new device ML7223 IOH i2c: tegra: Add de-bounce cycles. i2c: tegra: fix repeated start handling i2c: tegra: recover from spurious interrupt storm ...
2011-05-25Merge branches 'for-2639/i2c-eg20t', 'for-2639/i2c-shmobile', ↵Ben Dooks
'for-2639/i2c-tegra' and 'for-2639/i2c-nomadik2' into for-linus/2640/i2c
2011-05-25i2c-nomadik: break out single messsage transmissionLinus Walleij
Reduce code size in the message transfer function by factoring out a single-message transfer function. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-05-25i2c-nomadik: reset the hw after status checkVirupax Sadashivpetimath
In case of I2C timeout, reset the HW only after the HW status is read, otherwise the staus will be lost. Signed-off-by: Virupax Sadashivpetimath <virupax.sadashivpetimath@stericsson.com> Reviewed-by: Jonas Aberg <jonas.aberg@stericsson.com> Reviewed-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-05-25i2c-nomadik: remove the unnecessary delayVirupax Sadashivpetimath
The delay in the driver seems to be not needed, so remove it. Signed-off-by: Virupax Sadashivpetimath <virupax.sadashivpetimath@stericsson.com> Reviewed-by: Markus Grape <markus.grape@stericsson.com> Tested-by: Per Persson <per.xb.persson@stericsson.com> Tested-by: Chethan Krishna N <chethan.krishna@stericsson.com> Reviewed-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-05-25i2c-nomadik: change the TX and RX thresholdVirupax Sadashivpetimath
1) Increase RX FIFO threshold so that there is a reduction in the number of interrupts handled to complete a transaction. 2) Fill TX FIFO in the write function. Signed-off-by: Virupax Sadashivpetimath <virupax.sadashivpetimath@stericsson.com> Reviewed-by: Jonas Aberg <jonas.aberg@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-05-25i2c-nomadik: add code to retry on timeout failureVirupax Sadashivpetimath
It is seen that i2c-nomadik controller randomly stops generating the interrupts leading to a i2c timeout. As a workaround to this problem, add retries to the on going transfer on failure. Signed-off-by: Virupax Sadashivpetimath <virupax.sadashivpetimath@stericsson.com> Reviewed-by: Jonas ABERG <jonas.aberg@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-05-25i2c-nomadik: use pm_runtime APIRabin Vincent
Use the pm_runtime API for pins control. Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Reviewed-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Reviewed-by: Jonas Aberg <jonas.aberg@stericsson.com> [deleted some surplus runtime PM code] Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-05-25i2c-nomadik: print abort cause only on abort tagVirupax Sadashivpetimath
Modify the code to: 1)Print the cause of i2c failure only if the status is set to ABORT. 2)Print slave address on send/receive fail, will help in which slave failed. Signed-off-by: Virupax Sadashivpetimath <virupax.sadashivpetimath@stericsson.com> Reviewed-by: Jonas Aberg <jonas.aberg@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-05-25i2c-nomadik: correct adapter timeout initializationVirupax Sadashivpetimath
Correct the incorrect initialization of adapter timeout not to be in milliseconds, as it needs to be done in jiffies. Signed-off-by: Virupax Sadashivpetimath <virupax.sadashivpetimath@stericsson.com> Reviewed-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-05-25i2c-nomadik: remove the redundant error messagesrinidhi kasagar
The abort cause string itself is an error, so remove the redundant explicit error message. Signed-off-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Reviewed-by: Jonas Aberg <jonas.aberg@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-05-25i2c-nomadik: corrrect returned error numbersVirupax Sadashivpetimath
The code was returning bad error numbers or just -1 in some cases. Signed-off-by: Virupax Sadashivpetimath <virupax.sadashivpetimath@stericsson.com> Reviewed-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-05-25i2c-nomadik: make i2c timeout specific per i2c busVirupax Sadashivpetimath
Add option to have different i2c timeout delay for different i2c buses specified in platform data. Default to the old value unless specified. Signed-off-by: Virupax Sadashivpetimath <virupax.sadashivpetimath@stericsson.com> Reviewed-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-05-25i2c-nomadik: add regulator supportJonas Aberg
This on-chip I2C controller needs to fetch the regulator representing its voltage domain so that it won't be switched off. Signed-off-by: Jonas Aberg <jonas.aberg@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-05-24i2c-parport: Various cleanupsJean Delvare
* Fix white space. * Rename labels to something meaningful. * Prefix defines with PORT_ to avoid collision with macros from <linux/parport.h>. * Add const markers where possible. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-05-24i2c-i801: Don't depend on other kernel driver config optionsJean Delvare
Don't let other driver config options influence us, as it makes the code more complex and fragile for a small benefit. There's nothing wrong with instantiating I2C devices even if they don't have a driver. And we're talking about 835 extra bytes in the binary on x86-64, that's hardly worth arguing about. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: David Woodhouse <david.woodhouse@intel.com> Cc: Hans de Goede <hdegoede@redhat.com>
2011-05-24i2c-i801: Check for vendor Fujitsu before probing for apanelJean Delvare
Scanning the BIOS memory for the apanel information is costly, so avoid doing it on non-Fujitsu machines. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-05-24i2c-i801: Don't probe for slaves on IDF channelsJean Delvare
I don't know if Fujitsu is ever going to produce Patsburg-based machines, but if they do, I'd rather not probe the secondary (IDF) SMBus channels. At least not until we have a good reason for doing so. On a side note, I'm not even sure if it is right to enable detection of HWMON and DDC devices on the IDF channels. Time will tell... Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Hans de Goede <hdegoede@redhat.com> Acked-by: David Woodhouse <David.Woodhouse@intel.com>
2011-05-24i2c-i801: SMBus patch for Intel Panther Point DeviceIDsSeth Heasley
This patch adds the SMBus controller DeviceID for the Intel Panther Point PCH. Signed-off-by: Seth Heasley <seth.heasley@intel.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-05-23Merge branch 'sh-latest' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6 * 'sh-latest' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (23 commits) sh: Ignore R_SH_NONE module relocations. SH: SE7751: Fix pcibios_map_platform_irq prototype. sh: remove warning and warning_symbol from struct stacktrace_ops sh: wire up sys_sendmmsg. clocksource: sh_tmu: Runtime PM support clocksource: sh_tmu: __clocksource_updatefreq_hz() update clocksource: sh_cmt: Runtime PM support clocksource: sh_cmt: __clocksource_updatefreq_hz() update dmaengine: shdma: synchronize RCU before freeing, simplify spinlock dmaengine: shdma: add runtime- and system-level power management dmaengine: shdma: fix locking sh: sh-sci: sh7377 and sh73a0 build fixes sh: cosmetic improvement: use an existing pointer serial: sh-sci: suspend/resume wakeup support V2 serial: sh-sci: Runtime PM support sh: select IRQ_FORCED_THREADING. sh: intc: Set virtual IRQs as nothread. sh: fixup fpu.o compile order i2c: add a module alias to the sh-mobile driver ALSA: add a module alias to the FSI driver ...
2011-05-23Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (27 commits) PCI: Don't use dmi_name_in_vendors in quirk PCI: remove unused AER functions PCI/sysfs: move bus cpuaffinity to class dev_attrs PCI: add rescan to /sys/.../pci_bus/.../ PCI: update bridge resources to get more big ranges when allocating space (again) KVM: Use pci_store/load_saved_state() around VM device usage PCI: Add interfaces to store and load the device saved state PCI: Track the size of each saved capability data area PCI/e1000e: Add and use pci_disable_link_state_locked() x86/PCI: derive pcibios_last_bus from ACPI MCFG PCI: add latency tolerance reporting enable/disable support PCI: add OBFF enable/disable support PCI: add ID-based ordering enable/disable support PCI hotplug: acpiphp: assume device is in state D0 after powering on a slot. PCI: Set PCIE maxpayload for card during hotplug insertion PCI/ACPI: Report _OSC control mask returned on failure to get control x86/PCI: irq and pci_ids patch for Intel Panther Point DeviceIDs PCI: handle positive error codes PCI: check pci_vpd_pci22_wait() return PCI: Use ICH6_GPIO_EN in ich6_lpc_acpi_gpio ... Fix up trivial conflicts in include/linux/pci_ids.h: commit a6e5e2be4461 moved the intel SMBUS ID definitons to the i2c-i801.c driver.
2011-05-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) b43: fix comment typo reqest -> request Haavard Skinnemoen has left Atmel cris: typo in mach-fs Makefile Kconfig: fix copy/paste-ism for dell-wmi-aio driver doc: timers-howto: fix a typo ("unsgined") perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course'). treewide: fix a few typos in comments regulator: change debug statement be consistent with the style of the rest Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations" audit: acquire creds selectively to reduce atomic op overhead rtlwifi: don't touch with treewide double semicolon removal treewide: cleanup continuations and remove logging message whitespace ath9k_hw: don't touch with treewide double semicolon removal include/linux/leds-regulator.h: fix syntax in example code tty: fix typo in descripton of tty_termios_encode_baud_rate xtensa: remove obsolete BKL kernel option from defconfig m68k: fix comment typo 'occcured' arch:Kconfig.locks Remove unused config option. treewide: remove extra semicolons ...
2011-05-23Merge branch 'master' of ↵Paul Mundt
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 into sh-latest
2011-05-18Haavard Skinnemoen has left AtmelJean Delvare
Haavard's e-mail address at Atmel is no longer valid. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Havard Skinnemoen <hskinnemoen@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-18drivercore: revert addition of of_match to struct deviceGrant Likely
Commit b826291c, "drivercore/dt: add a match table pointer to struct device" added an of_match pointer to struct device to cache the of_match_table entry discovered at driver match time. This was unsafe because matching is not an atomic operation with probing a driver. If two or more drivers are attempted to be matched to a driver at the same time, then the cached matching entry pointer could get overwritten. This patch reverts the of_match cache pointer and reworks all users to call of_match_device() directly instead. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-13i2c: pnx: Fix crash due to wrong init of timer->dataWolfram Sang
alg_data is already a pointer which must be passed directly. Reported-by: Dieter Ripp <ripp@systecnet.com> Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Cc: Russell King <linux@arm.linux.org.uk> Cc: Ben Dooks <ben-i2c@fluff.org> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-05-11i2c: i2c-sh_mobile bus speed platform data V2Magnus Damm
Add support to the i2c-sh_mobile driver for setting the I2C bus speed using platform data. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-05-11i2c: i2c-sh_mobile clock string removalMagnus Damm
Remove the clock string magic from the i2c-sh_mobile driver now when all platforms support clkdev properly. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-05-11i2c-eg20t: Support new device ML7223 IOHTomoya MORINAGA
Support new device OKI SEMICONDUCTOR ML7223 IOH(Input/Output Hub). The ML7223 IOH is for MP(Media Phone) use. The ML7223 is companion chip for Intel Atom E6xx series. The ML7223 is completely compatible for Intel EG20T PCH. Signed-off-by: Tomoya MORINAGA <tomoya-linux@dsn.okisemi.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-05-11i2c: tegra: Add de-bounce cycles.Jay Cheng
This enables debouncing of the I2C lines. The debounce period is 2 * the debounce register field value, in terms of the I2C block's main clock. The Tegra TRM indicates that a setting yielding >50nS is desirable. Hence, a setting of 2 => 4 clocks @ 72MHz => ~55nS. Signed-off-by: Ken Radtke <kradtke@nvidia.com> [swarren: Added commit description body, Fixed 80-column limit, Reverted file permission change] Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-05-11i2c: tegra: fix repeated start handlingErik Gilling
A repeated start should be used for all but the last msg in an xfer. The NOSTART flag is for skipping the START frame (addr/rw) Signed-off-by: Erik Gilling <konkers@android.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-05-11i2c: tegra: recover from spurious interrupt stormTodd Poynor
Re-init the I2C controller when an IRQ arrives with no I2C_INT_STATUS bits set to indicate why the interrupt was sent. Storms of such mystery interrupts are infrequently seen. Dump some more status when these interrupts arrive. Set an error for the current request and wake up the requester (rather than timing out the request or possibly silently ignoring the interrupts). If the I2C block is inside the DVC, also ACK the DVC I2C transfer done interrupt in the ISR error return path, as is done for the normal return path. Signed-off-by: Todd Poynor <toddpoynor@google.com> [swarren: Fix minor checkpatch whitespace issue, commit tag] Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-05-11i2c: tegra: Enable new slave mode.Kenneth Waters
For Tegra i2c controller to function properly new slave mode must be enabled. swarren notes: In particular, I found this was needed when working on enabling the Tegra audio driver on the Seaboard board. There are two different PCB layouts for this board; a "clamshell" version, which works just fine without this change, and the original non-clamshell version, which needs this change in order for I2C to operate correctly. Without it, I2C probing fails for some devices, e.g. with: wm8903 0-001a: Device with ID register 0 is not a WM8903 wm8903 0-001a: asoc: failed to probe CODEC wm8903.0-001a: -19 asoc: failed to instantiate card tegra-wm8903: -19 ALSA device list: No soundcards found. Signed-off-by: Rakesh Iyer <riyer@nvidia.com> Cc: stable <stable@kernel.org> Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-05-01i2c-parport: Fix adapter list handlingJean Delvare
Use a standard list with proper locking to handle the list of adapters. Thankfully it only matters on systems with more than one parallel port, which are very rare. Thanks to Lukasz Kapiec for reporting the problem to me. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: stable@kernel.org
2011-05-01i2c-i801: Move device ID definitions to driverJean Delvare
Move the SMBus device ID definitions of recent devices from pci_ids.h to the i2c-i801.c driver file. They don't have to be shared, as they are clearly identified and only used in this driver. In the future, such IDs will go to i2c-i801 directly. This will make adding support for new devices much faster and easier, as it will avoid cross- subsystem patch sets and merge conflicts. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Seth Heasley <seth.heasley@intel.com> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-04-18i2c: add a module alias to the sh-mobile driverGuennadi Liakhovetski
This patch enables I2C driver autoloading on sh-mobile systems. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Reviewed-by: Simon Horman <horms@verge.net.au> Cc: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-04-17i2c-algo-bit: Call pre/post_xfer for bit_testAlex Deucher
Apparently some distros set i2c-algo-bit.bit_test to 1 by default. In some cases this causes i2c_bit_add_bus to fail and prevents the i2c bus from being added. In the radeon case, we fail to add the ddc i2c buses which prevents the driver from being able to detect attached monitors. The i2c bus works fine even if bit_test fails. This is likely due to gpio switching that is required and handled in the pre/post_xfer hooks, so call the pre/post_xfer hooks in the bit test as well. Fixes: https://bugs.freedesktop.org/show_bug.cgi?id=36221 Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: stable@kernel.org [.38 down to .34]
2011-04-17i2c: Improve deprecation warningsJean Delvare
When warning on the use of deprecated i2c_driver methods attach_adapter and detach_adapter, mention the name of the driver which needs to be updated. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-03-23mfd: mfd_cell is now implicitly available to timberdale driversAndres Salomon
The cell's platform_data is now accessed with a helper function; change clients to use that, and remove the now-unused data_size. Note that the mfd's platform_data is marked __devinitdata. This is still correct in all cases except for the timbgpio driver, whose remove hook has been changed to no longer reference the pdata. Signed-off-by: Andres Salomon <dilinger@queued.net> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-03-22Merge branch 'for-linus/2639/i2c-2' of git://git.fluff.org/bjdooks/linuxLinus Torvalds
* 'for-linus/2639/i2c-2' of git://git.fluff.org/bjdooks/linux: i2c-pxa2xx: Don't clear isr bits too early i2c-pxa2xx: Fix register offsets i2c-pxa2xx: pass of_node from platform driver to adapter and publish i2c-pxa2xx: check timeout correctly i2c-pxa2xx: add support for shared IRQ handler i2c-pxa2xx: Add PCI support for PXA I2C controller ARM: pxa2xx: reorganize I2C files i2c-pxa2xx: use dynamic register layout i2c-mxs: set controller to pio queue mode after reset i2c-eg20t: support new device OKI SEMICONDUCTOR ML7213 IOH i2c/busses: Add support for Diolan U2C-12 USB-I2C adapter
2011-03-21i2c-pxa2xx: Don't clear isr bits too earlyVasily Khoruzhick
isr is passed later into i2c_pxa_irq_txempty and i2c_pxa_irq_rxfull and they may use some other bits than irq sources. Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-03-21Merge branches 'for-2639/i2c/i2c-ce4100-v6', 'for-2639/i2c/i2c-eg20t-v3' and ↵Ben Dooks
'for-2639/i2c/i2c-imx' into for-linus/2639/i2c-2
2011-03-21i2c-pxa2xx: Fix register offsetsVasily Khoruzhick
Fix regression that was introduced by dynamic register layout. Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-03-21i2c-pxa2xx: pass of_node from platform driver to adapter and publishSebastian Andrzej Siewior
the of_node will auto-publish devices which are added to the device tree. Commit 925bb9c6 aka ("of/i2c: Fix module load order issue caused by of_i2c.c) moved the of_i2c_register_devices() function from the i2c core back to the drivers. This patch does the same thing for the pxa driver. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-03-21i2c-pxa2xx: check timeout correctlySebastian Andrzej Siewior
timeout here maybe 0 if the event occured and a task with a higher priority stole the cpu and we were sleeping longer than the timeout value we specified. In case of a real timeout I changed the error code to I2C_RETRY so we retry the transfer. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-03-21i2c-pxa2xx: add support for shared IRQ handlerSebastian Andrzej Siewior
Sodaville has three of them on a single IRQ. IRQF_DISABLED is removed because it is a NOP allready and scheduled for removal. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-03-21i2c-pxa2xx: Add PCI support for PXA I2C controllerSebastian Andrzej Siewior
The Sodaville I2C controller is almost the same as found on PXA2xx. The difference: - the register are at a different offset - no slave support The PCI probe code adds three platform devices which are probed then by the platform code. The X86 part also adds dummy clock defines because we don't have HW clock support. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-03-21ARM: pxa2xx: reorganize I2C filesSebastian Andrzej Siewior
This patch moves the platform data definition from arch/arm/plat-pxa/include/plat/i2c.h to include/linux/i2c/pxa-i2c.h so it can be accessed from x86 the same way as on ARM. This change should make no functional change to the PXA code. The move is verified by building the following defconfigs: cm_x2xx_defconfig corgi_defconfig em_x270_defconfig ezx_defconfig imote2_defconfig pxa3xx_defconfig spitz_defconfig zeus_defconfig raumfeld_defconfig magician_defconfig mmp2_defconfig pxa168_defconfig pxa910_defconfig Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
