Using a single list for all userspace devices leads to a dead lock
on multiplexed buses in some circumstances (mux chip instantiated
from userspace). This is solved by using a separate list for each
bus segment.
Acked-by: Michael Lawnick <ml.lawnick@gmx.de>
Some FSC hardware monitoring chips (Syleus at least) doesn't like
quick writes we typically use to probe for I2C chips. Use a regular
byte read instead for the address they live at (0x73). These are the
only known chips living at this address on PC systems.
For clarity, this fix should not be needed for kernels 2.6.30 and
later, as we started instantiating the hwmon devices explicitly based
on DMI data. Still, this fix is valuable in the following two cases:
* Support for recent FSC chips on older kernels. The DMI-based device
instantiation is more difficult to backport than the device support
itself.
* Case where the DMI-based device instantiation fails, whatever the
reason. We fall back to probing in that case, so it should work.
This fixes kernel bug #15634:
https://bugzilla.kernel.org/show_bug.cgi?id=15634
Acked-by: Hans de Goede <hdegoede@redhat.com>
Cc: stable@kernel.org
After discovering that a lot of i2c-drivers leave the pointer to their
clientdata dangling, it was decided to let the core handle this issue.
It is assumed that the core may access the private data after remove()
as there are no guarantees for the lifetime of such pointers anyhow (see
thread starting at http://lkml.org/lkml/2010/3/21/68)
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
Signed-off-by: David Daney <ddaney@caviumnetworks.com>
To: linux-i2c@vger.kernel.org
To: ben-linux@fluff.org
To: khali@linux-fr.org
Cc: linux-mips@linux-mips.org
Cc: rade.bozic.ext@nsn.com
Patchwork: http://patchwork.linux-mips.org/patch/1037/
The struct device_node *of_node pointer is moving out of dev->archdata
and into the struct device proper. of_i2c.c needs to set the of_node
pointer before the device is registered. Since the i2c subsystem
doesn't allow 2 stage allocation and registration of i2c devices, the
of_node pointer needs to be passed via the i2c_board_info structure
so that it is set prior to registration.
This patch adds of_node to struct i2c_board_info (conditional on
CONFIG_OF), sets of_node in i2c_new_device(), and modifies of_i2c.c
to use the new parameter. The calling of dev_archdata_set_node()
from of_i2c will be removed in a subsequent patch when of_node is
removed from archdata and all users are converted over.
If we don't find the correct rate, we want to end the loop with "i"
pointing to the last element in the array.
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
Add a stop condition bit flag to the last byte in the transfer.
This will generate an extra clock to handle the stop condition
and prevent devices from staying in an ACK'd state.
Signed-off-by: Kevin Wells <wellsk40@gmail.com>
Limit maximum divider to 0x3ff to divider computations. On high I2C
parent clock rates, the divider can exceed 0x3ff. This will help
prevent some very odd clock rates.
Commit d84d3ea317ce0db89ce0903b4037f800c5d4c477 added register shift to allow
also 16-bit register access. However, omap_i2c_unidle() is called before these
are set which causes the following OOPS:
Unhandled fault: alignment exception (0x801) at 0xfa070009
Internal error: : 801 [#1]
last sysfs file:
Modules linked in:
CPU: 0 Not tainted (2.6.34-rc2-00052-gae6be51 #3)
PC is at omap_i2c_unidle+0x44/0x138
LR is at trace_hardirqs_on_caller+0x158/0x18c
pc : [<c01cd2c4>] lr : [<c00743f8>] psr: 20000013
sp : cfc2bf10 ip : 00000009 fp : 00000000
r10: 00000000 r9 : 00000000 r8 : c0378560
r7 : c0378b88 r6 : c0378558 r5 : cfcadc00 r4 : cfcadc00
r3 : 00000009 r2 : fa070000 r1 : 00000000 r0 : 00000000
Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
Control: 10c5387f Table: 80004019 DAC: 00000017
Process swapper (pid: 1, stack limit = 0xcfc2a2e8)
Stack: (0xcfc2bf10 to 0xcfc2c000)
bf00: c0372cf8 c027225c 00000000 c0a69678
bf20: cfc3e508 c0500898 c0378560 c0378560 c0500898 cfcac8c0 c04fc280 c017d4f4
bf40: c0378560 c017c63c c0378560 c0378594 c0500898 cfcac8c0 c04fc280 c017c754
bf60: 00000000 c017c6f4 c0500898 c017beac cfc16a5c cfc3fd94 c0023448 c0500898
bf80: c0500898 c017b7d4 c032dc7f 00000093 cfc28d40 c0023448 00000000 c0500898
bfa0: 00000000 00000000 00000000 c017ca48 c0023448 00000000 c001d274 00000000
bfc0: 00000000 c002b344 00000031 00000000 00000000 00000192 00000000 c0023448
bfe0: 00000000 00000000 00000000 c0008578 00000000 c002c304 ffdfffff ffffffff
[<c01cd2c4>] (omap_i2c_unidle+0x44/0x138) from [<c027225c>] (omap_i2c_probe+0x1a4/0x398)
[<c027225c>] (omap_i2c_probe+0x1a4/0x398) from [<c017d4f4>] (platform_drv_probe+0x18/0x1c)
[<c017d4f4>] (platform_drv_probe+0x18/0x1c) from [<c017c63c>] (driver_probe_device+0xc0/0x178)
[<c017c63c>] (driver_probe_device+0xc0/0x178) from [<c017c754>] (__driver_attach+0x60/0x84)
[<c017c754>] (__driver_attach+0x60/0x84) from [<c017beac>] (bus_for_each_dev+0x44/0x74)
[<c017beac>] (bus_for_each_dev+0x44/0x74) from [<c017b7d4>] (bus_add_driver+0x9c/0x218)
[<c017b7d4>] (bus_add_driver+0x9c/0x218) from [<c017ca48>] (driver_register+0xa8/0x130)
[<c017ca48>] (driver_register+0xa8/0x130) from [<c002b344>] (do_one_initcall+0x5c/0x1b8)
[<c002b344>] (do_one_initcall+0x5c/0x1b8) from [<c0008578>] (kernel_init+0x90/0x144)
[<c0008578>] (kernel_init+0x90/0x144) from [<c002c304>] (kernel_thread_exit+0x0/0x8)
Code: e5942004 e3a0c009 e1a0331c e3a01000 (e18210b3)
---[ end trace 1b75b31a2719ed1c ]---
This patch moves register shift setting before any register accesses are done.
Signed-off-by: Mika Westerberg <ext-mika.1.westerberg@nokia.com>
Cc: Cory Maccarrone <darkstar6262@gmail.com>
- Return -ETIMEDOUT on bus busy error
- Fix timeout test "time_after(jiffies, orig_jiffies + HZ / 1000)" :
By default, HZ=100 on arm. This means that this test has no chances to
work and may result in a dead loop. Set timeout to 500ms.
- Don't try to send a new message if we failed to transmit
previous one. This was preventing to recover from error on my system
Signed-off-by: Arnaud Patard <apatard@mandriva.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Provide module aliases for automatic loading.
Signed-off-by: Darrick J. Wong <djwong@us.ibm.com>
*) add a new HID for IBM SMBus CMI devices
*) add methods for IBM SMBus CMI devices
*) hook different HID with different control methods set
*) minor tweaks as suggested by Jean Delvare
Slightly modified by Darrick to use #define'd IBM SMBUS HID from Darrick's ACPI
scan quirk patch.
Signed-off-by: Crane Cai <crane.cai@amd.com>
drivers/i2c/busses/i2c-xiic.c:493: error: implicit declaration of function 'mdelay'
Cc: "Richard Röjfors" <richard.rojfors@pelagicore.com>
Cc: "Ben Dooks (embedded platforms)" <ben-linux@fluff.org>
Cc: linux-i2c@vger.kernel.org
Drivers might have to do random things before and/or after I2C
transfers. Add hooks to the i2c-algo-bit implementation to let them do
so.
Cc: Alex Deucher <alexdeucher@gmail.com>
Now that directory drivers/i2c/chips is gone, configuration option
I2C_DEBUG_CHIP no longer has any effect, so we can drop it.
Move the last remaining driver from i2c/chips to misc. Good ridance!
Acked-by: Jonathan Cameron <jic23@cam.ac.uk>
Experience has shown that the block buffer can only be used for SMBus
(not I2C) block transactions, even though the datasheet doesn't
mention this limitation.
Reported-by: Felix Rubinstein <felixru@gmail.com>
Cc: Oleg Ryjkov <oryjkov@gmail.com>
Be less verbose in the absence of real errors. We don't have to report
failed probes to the users, it's only confusing them.
Tested-by: Andrey Gusev <ronne@list.ru>
Use the new device locking/unlocking API.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (56 commits)
doc: fix typo in comment explaining rb_tree usage
Remove fs/ntfs/ChangeLog
doc: fix console doc typo
doc: cpuset: Update the cpuset flag file
Fix of spelling in arch/sparc/kernel/leon_kernel.c no longer needed
Remove drivers/parport/ChangeLog
Remove drivers/char/ChangeLog
doc: typo - Table 1-2 should refer to "status", not "statm"
tree-wide: fix typos "ass?o[sc]iac?te" -> "associate" in comments
No need to patch AMD-provided drivers/gpu/drm/radeon/atombios.h
devres/irq: Fix devm_irq_match comment
Remove reference to kthread_create_on_cpu
tree-wide: Assorted spelling fixes
tree-wide: fix 'lenght' typo in comments and code
drm/kms: fix spelling in error message
doc: capitalization and other minor fixes in pnp doc
devres: typo fix s/dev/devm/
Remove redundant trailing semicolons from macros
fix typo "definetly" -> "definitely" in comment
tree-wide: s/widht/width/g typo in comments
Fix trivial conflict in Documentation/laptops/00-INDEX
Documentation/filesystems/proc.txt
arch/arm/mach-u300/include/mach/debug-macro.S
drivers/net/qlge/qlge_ethtool.c
drivers/net/qlge/qlge_main.c
drivers/net/typhoon.c
A pointer to omap_i2c_probe is passed to the core via
platform_driver_register and so the function must not disappear when the
.init sections are discarded. Otherwise (if also having HOTPLUG=y)
unbinding and binding a device to the driver via sysfs will result in an
oops as does a device being registered late.
An alternative to this patch is using platform_driver_probe instead of
platform_driver_register plus removing the pointer to the probe function
from the struct platform_driver.
Cc: Kalle Jokiniemi <ext-kalle.jokiniemi@nokia.com>
Cc: Tony Lindgren <tony@atomide.com>
Cc: Paul Walmsley <paul@pwsan.com>
Cc: Richard Woodruff <r-woodruff2@ti.com>
Cc: chandra shekhar <x0044955@ti.com>
Cc: Jason P Marini <jason.marini@gmail.com>
Cc: Syed Mohammed Khasim <x0khasim@ti.com>
Cc: Jarkko Nikula <jarkko.nikula@nokia.com>
Cc: Juha Yrjola <juha.yrjola@solidboot.com>
* 'for-linus/i2c' of git://git.fluff.org/bjdooks/linux:
i2c: Add support for Xilinx XPS IIC Bus Interface
i2c: omap: Add support for 16-bit registers
i2c-pnx: fix setting start/stop condition
powerpc: doc/dts-bindings: update doc of FSL I2C bindings
i2c-mpc: add support for the MPC512x processors from Freescale
i2c-mpc: rename "setclock" initialization functions to "setup"
i2c-mpc: use __devinit[data] for initialization functions and data
i2c/imx: don't add probe function to the driver struct
i2c: Add support for Ux500/Nomadik I2C controller
This patch adds support for the Xilinx XPS IIC Bus Interface.
The driver uses the dynamic mode, supporting to put several
I2C messages in the FIFO to reduce the number of interrupts.
It has the same feature as ocores, it can be passed a list
of devices that will be added when the bus is probed.
Signed-off-by: Richard Röjfors <richard.rojfors@pelagicore.com>
The current i2c-omap driver is set up for 32-bit registers, which
corresponds to most OMAP devices. However, OMAP730/850 based
devices use a 16-bit register size.
This change modifies the driver to perform a runtime CPU type check
to determine the register sizes, and uses a bit shift of either 1
or 2 bits to compute the proper register sizes for all registers.
Signed-off-by: Cory Maccarrone <darkstar6262@gmail.com>
The start/stop condtions are set in different places repetedly in the i2c-pnx
driver. Beside in i2c_pnx_start and i2c_pnx_stop the start/stop bit are also
set during the transfer of a i2c message in the master_xmit/rcv calls. This is
wrong since we can't set the start/stop condition during the transaction of a
single message any way. As a matter of fact, the driver will sometimes set both
the start and the stop bits at one time. This can be easily reproduced by
sending a simple read request like e.g
struct i2c_msg msgs[] = {
{ addr, 0, 1, buf },
{ addr, I2C_M_RD, offset, buf }
While processing the first message the i2c_pnx_master_xmit will set both the
start_bit and the stop_bit, which will eventually confuse the slave.
Fixed by remove setting start/stop condition from the transmit routines.
Signed-off-by: Luotao Fu <l.fu@pengutronix.de>
As I2C interrupts must be enabled for the MPC512x by the setup function
as well, "fsl,preserve-clocking" is handled in a slighly different way.
Also, the old settings are now reported calling dev_dbg(). For the
MPC512x the clock setup function of the MPC52xx can be re-used.
Furthermore, the Kconfig help has been updated and corrected.
Signed-off-by: Wolfgang Grandegger <wg@denx.de>
Reviewed-by: Wolfram Sang <w.sang@pengutronix.de>
To prepare support for the MPC512x processors from Freescale the
"setclock" initialization functions have been renamed to "setup"
because I2C interrupts must be enabled for the MPC512x by this
function as well.
"__devinit[data]" has not yet been used for all initialization functions
and data. To avoid truncating lines, the struct "mpc_i2c_match_data" has
been renamed to "mpc_i2c_data", which is even the better name.
Tested-by: Wolfram Sang <w.sang@pengutronix.de>
Having a pointer to the probe function is unnecessary when using
platform_driver_probe and yields a section mismatch warning after
removing the white list entry "*driver" for
{ .data$, .data.rel$ } -> { .init.* } mismatches in modpost.
This adds support for ST-Ericsson's I2C block found
in Ux500 and Nomadik 8815 platforms.
Signed-off-by: srinidhi kasagar <srinidhi.kasagar@stericsson.com>
Acked-by: Andrea Gallo <andrea.gallo@stericsson.com>
Acked-by: Linus Walleij <linus.walleij@stericsson.com>
Reviewed-by: Linus Walleij <linus.walleij@stericsson.com>
LPC_SCH is selected by GPI_SCH and I2C_ISCH, even when PCI is not
enabled, but LPC_SCH depends on PCI, so make GPI_SCH and I2C_ISCH
also depend on PCI.
Those 2 selects also need to select what LPC_SCH selects,
since kconfig does not follow selects.
Cc: Denis Turischev <denis@compulab.co.il>
Convert i2c-isch to platform_device for the lpc mfd core to add it at probe
time.
Signed-off-by: Denis Turischev <denis@compulab.co.il>
Rename for_each_bit to for_each_set_bit in the kernel source tree. To
permit for_each_clear_bit(), should that ever be added.
The patch includes a macro to map the old for_each_bit() onto the new
for_each_set_bit(). This is a (very) temporary thing to ease the migration.
[akpm@linux-foundation.org: add temporary for_each_bit()]
Suggested-by: Alexey Dobriyan <adobriyan@gmail.com>
Suggested-by: Andrew Morton <akpm@linux-foundation.org>
Cc: Artem Bityutskiy <dedekind@infradead.org>
i2c_master_send & i2c_master_recv do not support more than 64 kb
transfer, since msg.len is u16.
Signed-off-by: Zhangfei Gao <zgao6@marvell.com>
Thanks to -Wshadow.
Allow I2C drivers to make use of the runtime PM framework by adding
bus implementations of the runtime PM operations. These simply
immediately suspend when the device is idle. The runtime PM framework
provides drivers with off the shelf refcounts for enables and sysfs
control for managing runtime suspend from userspace so is useful even
without meaningful input from the bus.
Add support for the SMBus alert mechanism to the i2c-parport-light
driver. The ADM1032 evaluation board at least is properly wired for
this.
Cc: David Brownell <dbrownell@users.sourceforge.net>
Cc: Trent Piepho <tpiepho@freescale.com>
Add support for the SMBus alert mechanism to the i2c-parport driver.
The ADM1032 evaluation board at least is properly wired for this.
Having a separate Kconfig option for i2c-smbus makes it possible to
build that support as a module even when i2c-core itself is built-in.
Bus drivers which implement SMBus alert should select this option, so
in most cases this option is hidden and the user doesn't have to care
about it.
SMBus alert support. The SMBus alert protocol allows several SMBus
slave devices to share a single interrupt pin on the SMBus master,
while still allowing the master to know which slave triggered the
interrupt.
This is based on preliminary work by David Brownell. The key
difference between David's implementation and mine is that his was
part of i2c-core, while mine is split into a separate, standalone
module named i2c-smbus. The i2c-smbus module is meant to include
support for all SMBus extensions to the I2C protocol in the future.
The benefit of this approach is a zero cost for I2C bus segments which
do not need SMBus alert support. Where David's implementation
increased the size of struct i2c_adapter by 7% (40 bytes on i386),
mine doesn't touch it. Where David's implementation added over 150
lines of code to i2c-core (+10%), mine doesn't touch it. The only
change that touches all the users of the i2c subsystem is a new
callback in struct i2c_driver (common to both implementations.) I seem
to remember Trent was worried about the footprint of David'd
implementation, hopefully mine addresses the issue.
When the i2c-parport adapter is reponsible for powering devices, it
would seem reasonable to give them some time to settle before trying
to access them.
The description of the delay parameter is incomplete, it suggests that
there is a direct relation between the delay value and the bus
frequency. In fact, due to additional delays in the i2c bitbanging
code, the i2c clock is always much slower.
Cc: Till Harbaum <Till@Harbaum.org>
Add the Intel Cougar Point (PCH) SMBus controller device IDs.
Signed-off-by: Seth Heasley <seth.heasley@intel.com>
The id_table field of the struct pci_driver is constant in <linux/pci.h>
so it is worth to make initialization data also constant.
The semantic match that finds this kind of pattern is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@r@
disable decl_init,const_decl_init;
identifier I1, I2, x;
struct I1 {
const struct I2 *x;
@s@
identifier r.I1, y;
identifier r.x, E;
struct I1 y = {
.x = E,
@c@
identifier r.I2;
identifier s.E;
const struct I2 E[] = ... ;
@depends on !c@
identifier r.I2;
identifier s.E;
+ const
struct I2 E[] = ...;
// </smpl>
Signed-off-by: Márton Németh <nm127@freemail.hu>
Cc: Julia Lawall <julia@diku.dk>
