on tegra3, the i2c communication start immediately
after writing the tx fifo. And hence there is possibility
to complete the transfer and generates done interrupt before
actually sw updates their local pointers/count.
This patch will make sure that pointers/count can
get updated before data written into the fifo.
Reviewed-on: http://git-master/r/89510
(cherry picked from commit 999c09f0ed32f271e767a319dd094947e63fdb8c)
Change-Id: I8e974b83b5306ec3363d4ca31ce1b539a498ca08
Signed-off-by: Johnny Qiu <joqiu@nvidia.com>
Reviewed-on: http://git-master/r/99997
Reviewed-by: Simone Willett <swillett@nvidia.com>
writes to modules on APB bus may complete out-of-order. need
to guarantee that the write is completed by reading it back.
read I2C_INT_STATUS back right after writing the current int status
in the isr to make sure the clear operation of I2C_INT_STATUS is
done before the interrupt is re-enabled.
the same also done for DVC_STATUS.
bug 980763
Change-Id: I34f18804d530ccadf561fe1736552b6a4dd6e4ce
Signed-off-by: Ken Chang <kenc@nvidia.com>
Reviewed-on: http://git-master/r/101925
Adding support for protocol mangling I2C_M_NOSTART.
Change-Id: I6cc0c96b3c374d452ea886a0f983dc5d31c4575c
Reviewed-on: http://git-master/r/92573
Add support for protocol mangling "I2C_M_REV_DIR_ADDR"
Change-Id: Icdef16885f1cf6ed1ce9c4003a94c2c2e917ced2
Reviewed-on: http://git-master/r/92572
Because of race condition between isr and tx fifo fill,
duplicate data is being written. So added locking to make
Tx fifo fill as atomic.
Change-Id: Ia99466adadfb6d86a6f238ec4cd0aa13bd36e434
Signed-off-by: Chaitanya Bandi <bandik@nvidia.com>
Reviewed-on: http://git-master/r/90870
Dvc I2C_DONE_INTR_EN interrupt bit is always enable into dvc
control register3. During normal transaction on dvc i2c bus
sometimes one transaction written two times in TX fifo buffer
because of triggered dvc interrupt. This is causing to corrupt
the next transaction header and send wrong address over dvc
i2c bus. To solve this issue dvc i2c interrupt has to disable
during filling of Tx fifo and enable after that.
Updated the following things in code:
(1) Add the code to mask/unmask I2C_DONE_INTR_EN into dvc control reg3
writing into Tx Fifo register.
(2) Put delay before resetting the controller
Hand-picked this change from: http://git-master/r/#change,39997
Change-Id: I16b5821e1d0d0cf8419ce9d239e794de9d5b47be
Reviewed-on: http://git-master/r/89456
The slave address of device to be configured in packet
header as follows:
7 bit address: PacketHeader3[7:1]
10 bit address: PacketHeader3[9:0]
Fixing the code to make packet header3 properly.
Change-Id: I1797066d23ada5d4d7b14710201a1fb17566b78b
Reviewed-on: http://git-master/r/92556
Reviewed-by: Andy Carman <acarman@nvidia.com>
Removed unnecessary synchronization between init and isr
because clock driver is making sure that any operations
will be completed before disabling the driver clock.
Change-Id: I545e48be73697e023fedb8c663402c15e2a472df
Reviewed-on: http://git-master/r/91779
I2c controller requires the clock for fast clock as a second clock
source. This clock should be on during normal function of i2c controller.
Making sure that i2c driver get this clock and hold the clock enable
during data transfer.
bug 933653
Change-Id: I676eee1f8a0e1dff81b17259abcd9644bcb0b394
Reviewed-on: http://git-master/r/78996
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
Adding the connection name of clock as "i2c-div" when i2c driver
calls clk_get_sys() for getting clock data pointers.
Change-Id: I3e7fa79ce6d51be189f1d93cb54af0d1b3425de8
Reviewed-on: http://git-master/r/84694
Bug 915417
Signed-off-by: Alexandre Courbot <acourbot@nvidia.com>
Reviewed-on: http://git-master/r/74134
(cherry picked from commit 37018b3493d2d3006e38eb7a2f81cf47b111e5ea)
Change-Id: I1f8bda8be92f3861fabc51c362e677497e1cb44f
Signed-off-by: Pritesh Raithatha <praithatha@nvidia.com>
Reviewed-on: http://git-master/r/79993
Added i2c high speed support.
Bug 873879
Reviewed-on: http://git-master/r/71997
Change-Id: I5a2c5f272485e6f7c8bb6c11d7c3b6850fdcd768
Signed-off-by: Alok Chauhan <alokc@nvidia.com>
Reviewed-on: http://git-master/r/77741
Before making a transfer, is_suspended is checked to make sure the
device is alive. However this check is done without holding the lock
that the suspend and resume functions hold to change the suspend state,
creating the possibility of a race condition.
Bug 916336
Reviewed-on: http://git-master/r/70488
Change-Id: I7b4e52f686b0b372f3fc8ba7c7a4e4fdcdb6ba10
Reviewed-on: http://git-master/r/77740
put busses array as last struct member to avoid overwritting
arb_recovery function pointer.
Bug:889581
Reviewed-on: http://git-master/r/58347
(cherry picked from commit 223b2794fb0d3e94ccfb28549b74941a492415dd)
Change-Id: I4e8792a0cb42255724c8e45baea4f273181a8e2f
Signed-off-by: Linqiang Pu <dpu@nvidia.com>
Reviewed-on: http://git-master/r/58942
Fixed i2c_add_slave_adapter routine because id attribute has been
dropped from adapter.
Change-Id: I84a8d3a8fb3a16b772107a5d265cfadfb70dbaec
Change-Id: I3181507404e929b48ba2f1f7290e423d1a07f559
Reviewed-on: http://git-master/r/70944
This reverts commit fc56d07f59a3cafa33c31bf90a50af04a0235cf8.
Convert tegra i2c driver to use PM runtime framework.
changes since last version:
fix hang when using resume_noirq
Change-Id: I1cce314ef4c06dbc7f1b3ddbdd1ad50255aa8b02
Signed-off-by: Peter De Schrijver <pdeschrijver@nvidia.com>
Reviewed-on: http://git-master/r/71192
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
arch/arm/Kconfig
Change-Id: If8aaaf3efcbbf6c9017b38efb6d76ef933f147fa
commit cc6bcf7d2ec2234e7b41770185e4dc826390185e upstream.
The wrong bits were put on the wire, fix that.
This fixes kernel bug #42562.
Signed-off-by: Sheng-Hui J. Chu <jeffchu@broadcom.com>
Corrected the slave address configuration routine.
Reviewed-on: http://git-master/r/66805
(cherry picked from commit 18e9409c1db3e3880435e4435f30ad5725e54cdb)
Change-Id: Ia6b314e513a8bc33ca7782604c80d6686dfa260f
Reviewed-on: http://git-master/r/67604
Rebase-Id: Rbc628711479b187a90437bea94776066c7a58b54
These changes have no effect if CONFIG_GCOV_KERNEL is not set in
defconfig. It is easier to trigger GCOV for kernel if this patch
is in by only setting the before mentioned flag.
Change-Id: I8aade309da2da62c4b3889bd84e4123ba8f182da
Signed-off-by: Juha Tukkinen <jtukkinen@nvidia.com>
Reviewed-on: http://git-master/r/62999
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Rebase-Id: R4c238f707f1db600f188ae83426336753992b7be
Add runtime PM support for i2c slave.
Bug: 886802
Change-Id: I6649ab7e7b2e528d755e0a7167247a5a4440ef2f
Reviewed-on: http://git-master/r/59928
Tested-by: Bandi Krishna Chaitanya <bandik@nvidia.com>
Reviewed-by: Venu Byravarasu <vbyravarasu@nvidia.com>
Reviewed-by: Peter De Schrijver <pdeschrijver@nvidia.com>
Rebase-Id: R3db59ff198a0d124c3f8fe60b592630207e7ef80
Fixed the following issues in i2c slave driver:
1) Driver was failing to receive large data
2) Driver was receiving only eight bytes in a loop
3) Incorrect arguments while calling readl
Change-Id: I5ffe76b800a24270845aced0df30a69d9625f557
Reviewed-on: http://git-master/r/57218
Reviewed-by: Bandi Krishna Chaitanya <bandik@nvidia.com>
Rebase-Id: Rc262503e24baad814f7175c88f9fa8a6671c34b9
Calling regulator_disable causes system to crash when there
is no regualtor. It calls regulator_disable only when regulators
exist.
Bug 871860
Reviewed-on: http://git-master/r/55603
(cherry picked from commit 042e786e9766c891b44b8e00aa05f4c42b724440)
Reviewed-on: http://git-master/r/56237
(cherry picked from commit 9607d33bfcb84f764935ea911b93e716018ab818)
Change-Id: I06cfaeedcbdf276c3a17a759d410c7b46de8e9b1
Reviewed-on: http://git-master/r/57416
Reviewed-by: Jihoon Bang <jbang@nvidia.com>
Tested-by: Jihoon Bang <jbang@nvidia.com>
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
Rebase-Id: Rb146536a30b5e0c1f06a1622e77248aa539617a8
Add regulators to PCA954x in case PCA954x is controlled
by programmable PMIC. Add two Vcc. One is for PCA954x itself
and the other is for I2C bus.
Bug 871860
Reviewed-on: http://git-master/r/54745
(cherry picked from commit 7beddf4e72024e6f140ed306e80a7e1d19d7f36b)
Reviewed-on: http://git-master/r/55800
(cherry picked from commit 57138283d20301658ffe904577a72e9ea95b053e)
Change-Id: Ic98f33d2b8b324b7539d9b5b000a5591c5f7f742
Reviewed-on: http://git-master/r/57415
Rebase-Id: R9ece556f76ca88bfb74ceae1e6d520956c1b7d0a
Updated arbitration lost recovery to accumulate i2c multiplexing.
bug 854305
Original-Change-Id: I3f669c507980df78fa443c84b304d337bbe6a6da
Reviewed-on: http://git-master/r/46630
Reviewed-by: Alok Chauhan <alokc@nvidia.com>
Rebase-Id: R987d84dcf51a3d8e366f2e4b2d0d278304e2db76
Added the arbitration lost error recovery code into
i2c driver.
bug 854305
Original-Change-Id: Ib855f3541d139c01ea34fd9070feef7969eed395
Reviewed-on: http://git-master/r/43201
Rebase-Id: R7cda6214579416b3b0a4eafe412a18293260e669
This reverts commit 738c1a66079ee7db8e4365aa85819ccdef2592a8.
This fixed the video recording system hang bug
Bug 842901
Reviewed-on: http://git-master/r/39912
Rebase-Id: R183a5a9202ec65099503ddad913a25b139bd6d91
Remove the handling of synchronisation between isr and caller.
This change has become obsolete because now clock driver will make
sure that any write operations will be completed before disabling the
driver clock.
Original-Change-Id: I95957351fd1f291a59182fddbb619ffd02a0db63
Reviewed-on: http://git-master/r/33099
Reviewed-by: Bo Yan <byan@nvidia.com>
Tested-by: Alok Chauhan <alokc@nvidia.com>
Rebase-Id: Rec9671e9283870630fda6ceb977b99b92c3a99a9
Following are the changes:
- Added a mechanism to handle synchronization between caller thread
and isr so that isr should not get called when clock is disable or
controller is in reset state.
- Handling tx fifo overflow error.
- Added delay before resetting the controller which is required if
there is any error in previous transaction so proper stop signal
will be generated.
Original-Change-Id: I7ac121e056193cd4601f032cdabab59e7e0946ea
Reviewed-on: http://git-master/r/30457
Tested-by: Laxman Dewangan <ldewangan@nvidia.com>
Reviewed-by: Danielle Sun <dsun@nvidia.com>
Tested-by: Danielle Sun <dsun@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Rebase-Id: R0e7b428de2b0b1567a23bcac3c53aa5cc9d8d4a9
Added some more debug message to print during i2c transfer
failure to get more information from log.
This help to understand/analyse the issue quickly.
Original-Change-Id: Ie957b9f2ad737da210722f2ea6f18da9a7b76813
Reviewed-on: http://git-master/r/30011
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Rebase-Id: Rc40314cf7d257db51d98fba2dc94c8398fb2b8a9
The clock table have two different entry for a given i2c controller.
The second entry is not required and hence removing from table.
Also removing the reference of this entry from driver.
Original-Change-Id: Iab5f79bf5d1fea9363ef524258fb3ec262547691
Reviewed-on: http://git-master/r/29629
Reviewed-by: Daniel Willemsen <dwillemsen@nvidia.com>
Reviewed-by: Narendra Damahe <ndamahe@nvidia.com>
Rebase-Id: R0265f605ec00f464eb9ec8d5ffe840a642592fab
Original-Change-Id: I2ffeaf6f8dfeb279b40ca6f69f6c9157401a746a
Rebase-Id: R84f13e4b66ba9711fcb92850fd5e800ef3248a3f
Following are changes:
- Using the sysinit_call to initialize the driver.
- Using device from master adapter for slave adpter.
Original-Change-Id: I4dd0725694008a6aaee9a1d3a92d370a5c46de31
Reviewed-on: http://git-master/r/19249
Reviewed-by: Krishna Thota <kthota@nvidia.com>
Tested-by: Krishna Thota <kthota@nvidia.com>
Original-Change-Id: I62ba2e474d15764eccb2174444b194502e771307
Rebase-Id: Re845b3bac0f08ac25d0aa330acf0ee267ea8fcd4
To make the response fast from i2c, providing the option to enable
clock of i2c always through platform data.
Original-Change-Id: I89c9156fc97f92a45ce72626ccd77920e02ca356
Reviewed-on: http://git-master/r/19880
Tested-by: Pradeep Goudagunta <pgoudagunta@nvidia.com>
Reviewed-by: Ramachandrudu Kandhala <rkandhala@nvidia.com>
Original-Change-Id: Ifaab9d7e052fb377abe27afdeb5c9cb4d19a6320
Rebase-Id: R15e2cfa9080024d9e2bbc8d966f5145766ee9e1a
Implementing i2c slave driver in the linux i2c framework.
This driver will support the slave functionality on tegra i2c
controller.
Original-Change-Id: Ia56e3299605ab8705f2f82bf512195e7736214b3
Reviewed-on: http://git-master/r/14208
Original-Change-Id: I01b742f2c9477f0df476330e49163eda43a8d14f
Rebase-Id: R0127682848aa0cf230cc63b29e8c2c712c4e28f3
To support the i2c slave functionality in the kernel, adding the
framework so that chip specific slave driver can be plugged in.
Adding slave adapter and alogithms in framework so that slave bus driver
can register chip specific driver.
Original-Change-Id: Ie002dbd3b021f70814b455471e66a5da378ab3e9
Reviewed-on: http://git-master/r/14206
Original-Change-Id: I92b6bc4f3953a9edc7f9414a65b69005d2bbf8db
Rebase-Id: R13abe740fa88a76747dcbcd42ffc9f74a504f7c5
Removing the unnecessarily write in the interrupt status register
to avoid controller status misbehave.
bug 773262
Original-Change-Id: I15e2f3d5b377f44df5aae0fce9b55b2f3e7232b9
Reviewed-on: http://git-master/r/14223
Original-Change-Id: I17d9b90b91d54248bb23f7426faececd856403ea
Rebase-Id: R604a43169dbe3363cb9cb6d11c381aeeb502ea01
New i2c slave should be configured with a non-zero i2c address.
Configure i2c slave with an i2c address assigned by platform
data for an i2c dev.
BUG 788286
Reviewed-on: http://git-master/r/25100
(cherry picked from commit e6e0610c72ffce3b734e079faf88fad3f0468d07)
Original-Change-Id: I440aa2cc72007d2835b2027c0b26089d0aad9263
Reviewed-on: http://git-master/r/25223
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
Rebase-Id: Rfac0b98a3aad6f7df4badd5554a63856212a580d
Use new cam_i2c slave (i2c2) instead of the legacy one.
With old i2c slave controller, occasionally it generates
spurious slave interrupts causing disruptions in i2c transfers.
BUG 790315
Reviewed-on: http://git-master/r/24287
(cherry picked from commit 001805e9036b647e9a1220f2b50e8973ec28e917)
Original-Change-Id: Icd5310286de0338a4458c26a8d491bcded032b03
Reviewed-on: http://git-master/r/24294
Tested-by: Nitin Kumbhar <nkumbhar@nvidia.com>
Rebase-Id: R547c7338528aacebfb6b5258449dba31897552fc
tegra2 has an improved new i2c slave controller. This should be
used instead of the old i2c slave controller. With old i2c slave
controller, occasionally it generates spurious slave interrupts
causing disruptions in master i2c transfers.
BUG 788286
BUG 804545
Reviewed-on: http://git-master/r/24107
(cherry picked from commit 64a6e1d5a555be1c330de80cfb477563ae061452)
Original-Change-Id: Id5d5bd809df4a583a743d84a91aecbb78889a3c6
Reviewed-on: http://git-master/r/24246
Rebase-Id: Re4b74bb7df316c939cb619da87d2f6fd1ccb35dc
I2C driver needs to be suspended late and resumed early than other drivers.
So, I2C driver uses the suspend_noirq/resume_noirq callbacks of struct dev_pm_ops
for early/late power management system.
Original-Change-Id: Ie2f453b96fb9ab9b16cafec79644fe5d3b982dd3
Reviewed-on: http://git-master/r/23347
Tested-by: Jubeom Kim <jubeomk@nvidia.com>
Reviewed-by: Jinyoung Park <jinyoungp@nvidia.com>
Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Rebase-Id: R1126fb1683ac4f9138763e7981a0e36769f14738
Sometimes unexpected status like I2C busy status, Tx FIFO interrupted
and wait on Rx data etc is seen. Add a code to detect such conditions
and return -EAGAIN from driver. This will cause the i2c-core to retry
the transmission as per the retry count and time-out specified by the
platform data of the adapter.
Bug ID: 777455
Original-Change-Id: Iac5971bca4d760d93cd2ed147f78fc2807315b4e
Signed-off-by: Jin Park <jinyoungp@nvidia.com>
Reviewed-on: http://git-master/r/16212
Rebase-Id: R7c56bb575b1e7be19d1916124cdd86618c2f9c42
Original-Change-Id: I4ce92b4f7784b01fc68f454a1768ff7dc5b1b51a
Reviewed-on: http://git-master/r/11338
Tested-by: Pritesh Raithatha <praithatha@nvidia.com>
Reviewed-by: Peter Zu <pzu@nvidia.com>
Original-Rebase-Id: Rbae98a74cc8aad60cb8424f91ee4d6147c5d3587
This was partially upstreamed, now it's just adding dev_warn'ings.
Change-Id: I504d3d8833406db68cc0045d1dc37278d9ee8708
Signed-off-by: Colin Cross <ccross@android.com>
Change-Id: I558577e86654bc9a5a2cbfeeeb8055454ab8f328
this adds support for dynamically reprogramming the I2C controller's
pin mux on transaction boundaries to enable one controller to be
registered as multiple I2C bus adapters with the kernel. this allows
platform designers an additional tool to resolve clock rate, I/O
voltage and electrical loading restrictions between the platform's
peripherals.
the i2c-tegra platform data is extended to support this; platforms
which use this feature should pass in the number of busses which
should be created for each controller, the starting adapter number
to use and the clock rate and pin mux for each virtual bus.
Change-Id: I57a96deb7b7b793222ec3f8cc3a941917a023609
Signed-off-by: Gary King <gking@nvidia.com>
In tegra_i2c_fill_tx_fifo, once we have finished pushing all the bytes
to the I2C hardware controller, the interrupt might happen before we
have updated i2c_dev->msg_buf_remaining at the end of the function.
Then, in tegra_i2c_isr, we will call again tegra_i2c_fill_tx_fifo
triggering weird behaviour. This has been shown to happen under real
conditions.
Signed-off-by: Doug Anderson <dianders@chromium.org>
Tested-by: Vincent Palatin <vpalatin@chromium.org>
Acked-by: Rhyland Klein <rklein@nvidia.com>
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
Signed-off-by: Mike Rapoport <mike@compulab.co.il>
