path: root/drivers/ide/Kconfig
2011-10-13ide: Fix file references in drivers/ide/Johann Felix Soden
Fix file references in drivers/ide/ There are a lot of file references to now moved or deleted files in the whole tree, especially in documentation and Kconfig files. This patch fixes the references in drivers/ide/. Signed-off-by: Johann Felix Soden <johfel@users.sourceforge.net> Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-20kconfig: rename CONFIG_EMBEDDED to CONFIG_EXPERTDavid Rientjes
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option is used to configure any non-standard kernel with a much larger scope than only small devices. This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes references to the option throughout the kernel. A new CONFIG_EMBEDDED option is added that automatically selects CONFIG_EXPERT when enabled and can be used in the future to isolate options that should only be considered for embedded systems (RISC architectures, SLOB, etc). Calling the option "EXPERT" more accurately represents its intention: only expert users who understand the impact of the configuration changes they are making should enable it. Reviewed-by: Ingo Molnar <mingo@elte.hu> Acked-by: David Woodhouse <david.woodhouse@intel.com> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Greg KH <gregkh@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jens Axboe <axboe@kernel.dk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Robin Holt <holt@sgi.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29ide: update Kconfig text to mark as deprecatedRobert Hancock
The current Kconfig text for CONFIG_IDE doesn't give a hint to users that this subsystem is currently in maintenance mode and isn't actively developed. Let's correct this by marking it as deprecated, and also get rid of a bunch of unnecessary text that doesn't really have anything to do with what the option is for. Signed-off-by: Robert Hancock <hancockrwd@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-12trivial: Kconfig: .ko is normally not included in module namesPavel Machek
.ko is normally not included in Kconfig help, make it consistent. Signed-off-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-03-31ide: be able to build pmac driver without IDE built-inGilles Espinasse
No reason to need IDE built-in to be able to compile pmac driver. Tested to work on 2.6.29-rc8 and 2.6.28.8 with ide and pmac as modules inside an initramfs. Signed-off-by: Gilles Espinasse <g.esp@free.fr> Cc: sam@ravnborg.org Cc: benh@kernel.crashing.org [bart: remove now superfluous IDE check] Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide: remove CONFIG_BLK_DEV_IDEDOUBLER config optionBartlomiej Zolnierkiewicz
Nowadays it is not worth having a separate config option for Amiga IDE Doubler support so always include it (it still needs to be explicitly enabled by module parameter). Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide: merge ide_arm and ide_generic host driversBartlomiej Zolnierkiewicz
There is no need for a separate ide_arm host driver nowadays so merge it into ide_generic one. While at it: - return -EBUSY from ide_generic_init() if I/O resources are busy - scale down ide_generic_check_pci_legacy_iobases() for CONFIG_PCI=n Cc: Russell King <rmk@arm.linux.org.uk> Cc: Alexander Schulz <alex@shark-linux.de> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-24ide: move xfer mode tuning code to ide-xfer-mode.cBartlomiej Zolnierkiewicz
* Move xfer mode tuning code to ide-xfer-mode.c. * Add CONFIG_IDE_XFER_MODE config option to be selected by host drivers that support xfer mode tuning. * Add CONFIG_IDE_XFER_MODE=n static inline versions of ide_set_pio() and ide_set_xfer_rate(). * Make IDE_TIMINGS and BLK_DEV_IDEDMA config options select IDE_XFER_MODE, also add explicit selects for few host drivers that need it. * Build/link ide-xfer-mode.o and ide-pio-blacklist.o (it is needed only by ide-xfer-mode.o) only if CONFIG_IDE_XFER_MODE=y. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-05ide: add at91_ide driverStanislaw Gruszka
This is IDE host driver for AT91 (SAM9, CAP9, AT572D940HF) Static Memory Controller with Compact Flash True IDE Mode logic. Driver have to switch 8/16 bit bus width when accessing Task Tile or Data Register. Moreover some extra things need to be done when setting PIO mode. Only PIO mode is used, hardware have no DMA support. If interrupt line is connected through GPIO extra quirk is needed to cope with fake interrupts. Signed-off-by: Stanislaw Gruszka <stf_xl@wp.pl> Cc: Andrew Victor <avictor.za@gmail.com> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-02-25ide: ide.c 'clear' fix, update "ide=nodma" documentationDavid Fries
Documentation/kernel-parameters.txt - ide=nodma is no longer valid. drivers/ide/Kconfig - The module is ide-core.ko not ide. drivers/ide/ide.c - It took me a while to figure out what the arguments %d.%d:%d to nodma module parameter ment, so I added a comment to each. - Added a comment to each of the sscanf lines. - There is a bug, if j is 0 it would previously clear all the other bits except the current device, changed in three different places. mask &= (1 << i) should be mask &= ~(1 << i). Signed-off-by: David Fries <david@fries.net> [bart: s/disk/device/ in ide.c, beautify patch description] Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-02-02ide: add CS5536 host driver (v3)Bartlomiej Zolnierkiewicz
This is a port of libata's pata_cs5536.c (written by Martin K. Petersen) to IDE subsystem. Changes done while at it: * Reprogram PIO/MWDMA timings if needed before and after DMA transfer (chipset uses shared PIO/MWDMA timings). * Fix cable detection to report 80-wires cable if BIOS set it for any device on a port (IDE core will do drive-side cable detection later). * Don't disable UDMA while programming PIO timings. * Simplify PCI/MSR support. Pros of having IDE host driver in addition to libata's one: * IDE is much lighter than SCSI+libata, the host driver itself is also a bit smaller: text data bss dec hex filename 1261 496 4 1761 6e1 drivers/ata/pata_cs5536.o 1242 128 4 1374 55e drivers/ide/cs5536.o * This allows use of IDE features which are unavailable under libata. v2: * Fixes per review from Sergei: - simplify dependency check in Kconfig - use IDE_DRV_MASK also for ->drive_data - disable UDMA when programming MWDMA - program new DTC timings only when necessary - fix printk() level in cs5536_init_one() * Fix patch description according to comments from Alan and Sergei. v3: * Smarter masking of UDMA bits per Sergei's suggestion. Cc: Martin K. Petersen <mkp@mkp.net> Cc: Karl Auerbach <karl@iwl.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-01-14ide: remove unused CONFIG_BLK_DEV_IDE_AU1XXX_SEQTS_PER_RQBartlomiej Zolnierkiewicz
2009-01-06Resurrect IT8172 IDE controller driverShane McDonald
Support for the IT8172 IDE controller was removed from the kernel sometime after 2.6.18. Support for the only boards that used the IT8172 was removed from the kernel after 2.6.18, as they had never compiled since 2.6.0. However, there are a couple of platforms that use this chip: the PMC-Sierra Xiao Hu thin-client computer, which is no longer in production, and the Linksys NSS4000 Network Attached Storage box, which is based on the Xiao Hu board. I am attempting to add support for the Xiao Hu to the kernel, and this IT8172 IDE controller is the first bit of code in this effort. This patch resurrects the IT8172 IDE controller code. I began with the 2.6.18 version of the it8172.c file, and have moved it forward so that it works with the latest version of the kernel. I have run this driver on a PMC-Sierra Xiao Hu board with the 2.6.28 kernel, and I have had no problems with it in my configuration. The attached patch applies cleanly against 2.6.28. Signed-off-by: Shane McDonald <mcdonald.shane@gmail.com> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: alan@lxorguk.ukuu.org.uk [bart: s/HWIF(drive)/drive->hwif/] Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-01-02ide-atapi: accomodate transfer length calculation for ide-cdBorislav Petkov
... by factoring it out of ide_cd_do_request() into a helper, as suggested by Bart. There should be no functionality change resulting from this patch. Signed-off-by: Borislav Petkov <petkovbb@gmail.com> [bart: BLK_DEV_IDECD needs to select IDE_ATAPI now] Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-01-02remove ide-scsiFUJITA Tomonori
As planed, this removes ide-scsi. The 2.6 kernel supports direct writing to ide CD drives, which eliminates the need for ide-scsi. ide-scsi has been unmaintained and marked as deprecated. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: James.Bottomley@HansenPartnership.com Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-12-30Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (407 commits) [ARM] pxafb: add support for overlay1 and overlay2 as framebuffer devices [ARM] pxafb: cleanup of the timing checking code [ARM] pxafb: cleanup of the color format manipulation code [ARM] pxafb: add palette format support for LCCR4_PAL_FOR_3 [ARM] pxafb: add support for FBIOPAN_DISPLAY by dma braching [ARM] pxafb: allow pxafb_set_par() to start from arbitrary yoffset [ARM] pxafb: allow video memory size to be configurable [ARM] pxa: add document on the MFP design and how to use it [ARM] sa1100_wdt: don't assume CLOCK_TICK_RATE to be a constant [ARM] rtc-sa1100: don't assume CLOCK_TICK_RATE to be a constant [ARM] pxa/tavorevb: update board support (smartpanel LCD + keypad) [ARM] pxa: Update eseries defconfig [ARM] 5352/1: add w90p910-plat config file [ARM] s3c: S3C options should depend on PLAT_S3C [ARM] mv78xx0: implement GPIO and GPIO interrupt support [ARM] Kirkwood: implement GPIO and GPIO interrupt support [ARM] Orion: share GPIO IRQ handling code [ARM] Orion: share GPIO handling code [ARM] s3c: define __io using the typesafe version [ARM] S3C64XX: Ensure CPU_V6 is selected ...
2008-12-29ide: move legacy ISA/VLB ports handling to ide-legacy.c (v2)Bartlomiej Zolnierkiewicz
* Move legacy ISA/VLB ports handling from ide-probe.c to ide-legacy.c. * Add CONFIG_IDE_LEGACY config option to be selected by host drivers needing ide-legacy.c. v2: Fix CONFIG_IDE_LEGACY not being defined in Kconfig. (from Takashi Iwai <tiwai@suse.de>) There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-12-15Merge branch 'omap3-upstream' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 into devel
2008-12-08ide: build-fix for CONFIG_BLK_DEV_IDEDMA_PMAC=nBartlomiej Zolnierkiewicz
IDE pmac host driver build fails with CONFIG_BLK_DEV_IDEDMA_PMAC=n as reported by Kamalesh: > drivers/ide/pmac.c: In function 'pmac_ide_set_pio_mode': > drivers/ide/pmac.c:527: error: implicit declaration of function 'kauai_lookup_timing' > drivers/ide/pmac.c:527: error: 'shasta_pio_timings' undeclared (first use in this function) > drivers/ide/pmac.c:527: error: (Each undeclared identifier is reported only once > drivers/ide/pmac.c:527: error: for each function it appears in.) > drivers/ide/pmac.c:534: error: 'kauai_pio_timings' undeclared (first use in this function) > drivers/ide/pmac.c: In function 'pmac_ide_do_resume': > drivers/ide/pmac.c:914: error: 'IDE_WAKEUP_DELAY' undeclared (first use in this function) > drivers/ide/pmac.c: At top level: > drivers/ide/pmac.c:1007: error: 'pmac_ide_init_dma' undeclared here (not in a function) > drivers/ide/pmac.c: In function 'pmac_ide_setup_device': > drivers/ide/pmac.c:1107: error: 'IDE_WAKEUP_DELAY' undeclared (first use in this function) > drivers/ide/pmac.c: In function 'pmac_ide_macio_attach': > drivers/ide/pmac.c:1209: error: 'pmac_ide_hwif_t' has no member named 'dma_regs' > drivers/ide/pmac.c:1210: error: 'pmac_ide_hwif_t' has no member named 'dma_regs' > make[2]: *** [drivers/ide/pmac.o] Error 1 Fix it by removing the superfluous config option. Reported-and-tested-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-11-27[ARM] clps7500: remove supportRussell King
The CLPS7500 platform has not built since 2.6.22-git7 and there seems to be no interest in fixing it. So, remove the platform support. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-23ide: Add tx4938ide driver (v2)Atsushi Nemoto
This is the driver for the Toshiba TX4938 SoC EBUS controller ATA mode. It has custom set_pio_mode and some hacks for big endian. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: ralf@linux-mips.org Cc: sshtylyov@ru.mvista.com Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-23ide: Add tx4939ide driver (v6)Atsushi Nemoto
This is the driver for the Toshiba TX4939 SoC ATA controller. This controller has standard ATA taskfile registers and DMA command/status registers, but the register layout is swapped on big endian. There are some other endian issue and some special registers which requires many custom dma_ops/tp_ops routines and build_dmatable. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: ralf@linux-mips.org Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-17ide: remove broken hpt34x driverBartlomiej Zolnierkiewicz
No big loss since HPT343/363 controllers are properly supported by pata_hpt3x3 driver from Alan Cox. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-17ide: add generic ATA/ATAPI disk driverBartlomiej Zolnierkiewicz
* Add struct ide_disk_ops containing protocol specific methods. * Add 'struct ide_disk_ops *' to ide_drive_t. * Convert ide-{disk,floppy} drivers to use struct ide_disk_ops. * Merge ide-{disk,floppy} drivers into generic ide-gd driver. While at it: - ide_disk_init_capacity() -> ide_disk_get_capacity() Acked-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-16Kconfig: eliminate "def_bool n" constructsJan Beulich
Using "def_bool n" is pointless, simply using bool here appears more appropriate. Further, retaining such options that don't have a prompt and aren't selected by anything seems also at least questionable. Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Tony Luck <tony.luck@intel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13ide: remove CONFIG_BLK_DEV_IDE config option (take 2)Bartlomiej Zolnierkiewicz
Because hd.c was moved to drivers/block/ this config option is superfluous now and may be removed. v2: Fix drivers/ide/Makefile (noticed by Adrian Bunk). Cc: Adrian Bunk <bunk@kernel.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: remove CONFIG_IDEDISK_MULTI_MODEBartlomiej Zolnierkiewicz
Use multi PIO by default when available and remove no longer needed CONFIG_IDEDISK_MULTI_MODE (it should be safe nowadays, despite to what help entry has been saying). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-05IDE: Fix platform device registration in Swarm IDE driver (v2)Ralf Baechle
The Swarm IDE driver uses a release method which is defined in the driver itself thus potentially oopsable. The simple fix would be to just leak the device but this patch goes the full length and moves the entire handling of the platform device in the platform code and retains only the platform driver code in drivers/ide/mips/swarm.c. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: "Maciej W. Rozycki" <macro@linux-mips.org> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> [bart: remove no longer needed BLK_DEV_IDE_SWARM from ide/Kconfig] Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-09-27ide: note that IDE generic may prevent other drivers from attachingTejun Heo
Enabling IDE generic may prevent ATA controllers located on legacy ports from being attached to more proper driver or can prevent other controllers which share the IRQ from working. Note it in the help message. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: xerces8 <xerces8@butn.net> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: stein@hermes.si [bart: s/will grab/may grab/ since Borislav has fixed PCI-case for .28] Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-09-02ide/Kconfig: mark ide-scsi as deprecatedBartlomiej Zolnierkiewicz
Mark ide-scsi as deprecated and remove stale/bogus documentation. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-08-05ide: remove CONFIG_IDE_MAX_HWIFSAdrian Bunk
The benefits of a user settable CONFIG_IDE_MAX_HWIFS have become pretty tiny and are no longer considered worth the trouble of an own option. Simply always #define MAX_HWIFS to 10. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-24ide-generic: is no longer needed on ppc32Bartlomiej Zolnierkiewicz
Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-23ide: mark hpt34x host driver as BROKENBartlomiej Zolnierkiewicz
Alan Cox has noticed some time ago that hpt34x is broken (http://lkml.org/lkml/2007/7/3/257): "No the old driver doesn't even do that. It starts up. It spuriously adjusts some non writable PCI BAR registers, prints a message about resources being in use already then exits." Reported-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-23ide: limit cy82c693 host driver to ALPHABartlomiej Zolnierkiewicz
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-16move ide/legacy/hd.c to drivers/block/Adrian Bunk
This patch moves hd.c to drivers/block/ Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: rmk@arm.linux.org.uk Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-16remove BLK_DEV_HD_ONLYAdrian Bunk
After commit 80aa31cb460d12c1e02327b43eceb3eebc6e7090 (ide: remove CONFIG_BLK_DEV_HD_IDE config option (take 2)) the indirection through BLK_DEV_HD_ONLY is no longer required. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: rmk@arm.linux.org.uk Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-16powerpc/ide: remove mpc8xx-ide driverArnd Bergmann
This driver was only used by arch/ppc code and is obsolete now with the move to common arch/powerpc code. [bart: port it over IDE tree, remove leftover 'choice' from Kconfig] Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Kumar Gala <galak@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-16sl82c105: convert to use ide_timing_find_mode()Bartlomiej Zolnierkiewicz
There should be no functional changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-16cy82c693: convert to use ide_timing_find_mode()Bartlomiej Zolnierkiewicz
2008-07-16cmd64x: convert to use ide_timing_find_mode()Bartlomiej Zolnierkiewicz
2008-07-16cmd640: convert to use ide_timing_find_mode()Bartlomiej Zolnierkiewicz
2008-07-16alim15x3: convert to use ide_timing_find_mode()Bartlomiej Zolnierkiewicz
2008-07-16qd65xx: convert to use ide_timing_find_mode()Bartlomiej Zolnierkiewicz
2008-07-16ht6560b: convert to use ide_timing_find_mode()Bartlomiej Zolnierkiewicz
2008-07-16ali14xx: convert to use ide_timing_find_mode()Bartlomiej Zolnierkiewicz
2008-07-16ide: convert ide-timing.h to ide-timings.c library (take 2)Bartlomiej Zolnierkiewicz
* Don't include ide-timing.h in cs5535 and sis5513 host drivers (they don't need it currently). * Convert ide-timing.h to ide-timings.c library and add CONFIG_IDE_TIMINGS config option to be selected by host drivers using the library. While at it: - fix ide_timing_find_mode() placement v2: * Add missing EXPORT_SYMBOLs. (Stephen Rothwell <sfr@canb.auug.org.au>) There should be no functional changes caused by this patch. Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-16BAST: Remove old IDE driverBen Dooks
Remove the old BAST IDE driver, as we are now using the platform-pata support. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-15ide: add ide_transfer_pc() helperBartlomiej Zolnierkiewicz
* Add ide-atapi.c file for generic ATAPI support together with CONFIG_IDE_ATAPI config option. * Add generic ide_transfer_pc() helper to ide-atapi.c and then convert ide-{floppy,tape,scsi} device drivers to use it. There should be no functional changes caused by this patch. Cc: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-06-30Revert "BAST: Remove old IDE driver"Bartlomiej Zolnierkiewicz
This reverts commit ac1623625c5818bbdf5c68973098ba386ba7a004. It was premature to remove it now, we will do it post-2.6.26. Thanks to Russell King for noticing the issue. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-06-20BAST: Remove old IDE driverBen Dooks
