path: root/drivers/ide/amd74xx.c
2010-01-19amd74xx: use ->pio_mode value to determine pair device speedBartlomiej Zolnierkiewicz
Use the current PIO mode value instead of the current transfer speed of the pair device on the port to determine PIO commmand timings used for both devices on the port. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-19ide: change ->set_dma_mode method parametersBartlomiej Zolnierkiewicz
Change ->set_dma_mode method parameters to match ->set_dmamode method used in struct ata_port_operations. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2010-01-19ide: change ->set_pio_mode method parametersBartlomiej Zolnierkiewicz
Change ->set_pio_mode method parameters to match ->set_piomode method used in struct ata_port_operations. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-19amd74xx: don't change UDMA settings when programming PIO timingsBartlomiej Zolnierkiewicz
Based on libata pata_amd host driver. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-24ide: fix ->init_chipset method to return 'int' valueBartlomiej Zolnierkiewicz
* Return 0 instead of dev->irq in ->init_chipset implementations. * Fix ->init_chipset method to return 'int' value instead of 'unsigned int' one. This fixes ->init_chipset handling for host drivers (cs5530, hpt366 and pdc202xx_new) for which it is possible for this method to fail. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-24amd74xx: remove no longer needed ->init_hwif methodBartlomiej Zolnierkiewicz
This is now handled by core IDE PCI code. There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-24amd74xx: use ide_pci_is_in_compatibility_mode()Bartlomiej Zolnierkiewicz
Fix ->init_hwif to check if IDE PCI controller is in compatibility mode instead of checking for hwif->irq == 0. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-02-25amd74xx: device/vendor confusionRoel Kluin
Device and vendor ids were confused Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-01-06amd74xx: use ide_get_pair_dev() helperBartlomiej Zolnierkiewicz
There should be no functional changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-12-02amd74xx: workaround unreliable AltStatus register for nVidia controllersBartlomiej Zolnierkiewicz
It seems that on some nVidia controllers using AltStatus register can be unreliable so default to Status register if the PCI device is in Compatibility Mode. In order to achieve this: * Add ide_pci_is_in_compatibility_mode() inline helper to <linux/ide.h>. * Add IDE_HFLAG_BROKEN_ALTSTATUS host flag and set it in amd74xx host driver for nVidia controllers in Compatibility Mode. * Teach actual_try_to_identify() and drive_is_ready() about the new flag. This fixes the regression caused by removal of CONFIG_IDEPCI_SHARE_IRQ config option in 2.6.25 and using AltStatus register unconditionally when available (kernel.org bugs #11659 and #10216). [ Moreover for CONFIG_IDEPCI_SHARE_IRQ=y (which is what most people and distributions use) it never worked correctly. ] Thanks to Remy LABENE and Lars Winterfeld for help with debugging the problem. More info at: http://bugzilla.kernel.org/show_bug.cgi?id=11659 http://bugzilla.kernel.org/show_bug.cgi?id=10216 Reported-by: Remy LABENE <remy.labene@free.fr> Tested-by: Remy LABENE <remy.labene@free.fr> Tested-by: Lars Winterfeld <lars.winterfeld@tu-ilmenau.de> Acked-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-21ide: remove useless subdirs from drivers/ide/Bartlomiej Zolnierkiewicz
Suggested-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
