path: root/drivers/ide/at91_ide.c
2010-01-19ide: change ->set_pio_mode method parametersBartlomiej Zolnierkiewicz
Change ->set_pio_mode method parameters to match ->set_piomode method used in struct ata_port_operations. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-15at91_ide: remove headers specific for at91sam9263Sergey Matyukevich
This driver requires only static memory controller definitions and macroses contained in generic header at91sam9_smc.h. Those extra headers are misleading since this driver also works fine for at91sam9260 SoC: tests were performed on afeb9260 board. Signed-off-by: Sergey Matyukevich <geomatsi@gmail.com> Acked-by: Stanislaw Gruszka <stf_xl@wp.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-15ide: IORDY handling fixesBartlomiej Zolnierkiewicz
Add ide_pio_need_iordy() helper and convert host drivers to use it. This fixes it8172, it8213, pdc202xx_old, piix, slc90e66 and siimage host drivers to handle IORDY correctly. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-05-17ide: remove hw_regs_t typedefBartlomiej Zolnierkiewicz
Remove hw_regs_t typedef and rename struct hw_regs_s to struct ide_hw. There should be no functional changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-05-17ide: pass number of ports to ide_host_{alloc,add}() (v2)Bartlomiej Zolnierkiewicz
Pass number of ports to ide_host_{alloc,add}() and then update all users accordingly. v2: - drop no longer needed NULL initializers in buddha.c, cmd640.c and gayle.c (noticed by Sergei) There should be no functional changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-05-17ide: remove chipset field from hw_regs_tBartlomiej Zolnierkiewicz
* Convert host drivers that still use hw_regs_t's chipset field to use the one in struct ide_port_info instead. * Move special handling of ide_pci chipset type from ide_hw_configure() to ide_init_port(). * Remove chipset field from hw_regs_t. While at it: - remove stale comment in delkin_cb.c There should be no functional changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-04-08at91_ide: turn on PIO 6 supportStanislaw Gruszka
As we have already PIO 6 transfer mode supported in IDE layer, we can turn it on in the driver. Signed-off-by: Stanislaw Gruszka <stf_xl@wp.pl> Tested-by: "Steve Wootton" <swootton@esi-estech.com> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-04-08at91_ide: remove unused ide_mm_{outb,inb}Stanislaw Gruszka
Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Stanislaw Gruszka <stf_xl@wp.pl>
2009-04-08ide: remove unused #include <linux/version.h>Huang Weiyi
Remove unused #include <linux/version.h> in drivers/ide/at91_ide.c. Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-04-08at91_ide: remove custom tf_{read|load}() methodsSergei Shtylyov
Since tf_{read|load}() methods of this driver have now become identical to their standard counterparts using MMIO accesses, there's no need to override those anymore... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide: turn selectproc() method into dev_select() method (take 5)Sergei Shtylyov
Turn selectproc() method into dev_select() method by teaching it to write to the device register and moving it from 'struct ide_port_ops' to 'struct ide_tp_ops'. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: benh@kernel.crashing.org Cc: petkovbb@gmail.com [bart: add ->dev_select to at91_ide.c and tx4939.c (__BIG_ENDIAN case)] Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide: move data register access out of tf_{read|load}() methods (take 2)Sergei Shtylyov
Move IDE_FTFLAG_{IN|OUT}_DATA flag handling out of tf_{read|load}() methods into the only two functions where these flags actually need to be handled: do_rw_taskfile() and ide_complete_cmd()... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide: call {in|out}put_data() methods from tf_{read|load}() methods (take 2)Sergei Shtylyov
Handle IDE_FTFLAG_{IN|OUT}_DATA flags in tf_{read|load}() methods by calling {in|out}put_data() methods to transfer 2 bytes -- this will allow us to move that handling out of those methods altogether... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide: rename IDE_TFLAG_IN_[HOB_]FEATURESergei Shtylyov
The feature register has never been readable -- when its location is read, one gets the error register value; hence rename IDE_TFLAG_IN_[HOB_]FEATURE into IDE_TFLAG_IN_[HOB_]ERROR and introduce the 'hob_error' field into the 'struct ide_taskfile' (despite the error register not really depending on the HOB bit). Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide: turn set_irq() method into write_devctl() methodSergei Shtylyov
Turn set_irq() method with its software reset hack into write_devctl() method (for just writing a value into the device control register) at last... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide: use ATA_HOBSergei Shtylyov
Make use of ATA_HOB instead of hard-coded value in the tf_read() method. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31at91_ide: fix ->ftf_flags handlingBartlomiej Zolnierkiewicz
Fix some incorrect IDE_FTFLAG_* changes which slipped in commit "ide: add "flagged" taskfile flags to struct ide_taskfile (v2)" (commit 19710d25d50ae0be05eebe4231ed8918b1092d82) few days ago. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-27ide: pass command instead of request to ide_pio_datablock()Bartlomiej Zolnierkiewicz
* Add IDE_TFLAG_FS taskfile flag and set it for REQ_TYPE_FS requests. * Convert ->{in,out}put_data methods to take command instead of request as an argument. Then convert pre_task_out_intr(), task_end_request(), task_error(), task_in_unexpected(), ide_pio_sector(), ide_pio_multi() and ide_pio_datablock() in similar way. * Rename task_end_request() to ide_finish_cmd(). There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-27ide: remove ide_task_t typedefBartlomiej Zolnierkiewicz
While at it: - rename struct ide_task_s to struct ide_cmd - remove stale comments from idedisk_{read_native,set}_max_address() - drop unused 'cmd' argument from ide_{cmd,task}_ioctl() - drop unused 'task' argument from tx4939ide_tf_load_fixup() - rename ide_complete_task() to ide_complete_cmd() - use consistent naming for struct ide_cmd variables There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-27ide: add "flagged" taskfile flags to struct ide_taskfile (v2)Bartlomiej Zolnierkiewicz
* Add ->ftf_flags field to struct ide_taskfile and convert flags for TASKFILE ioctl to use it. * Rename "flagged" taskfile flags: - IDE_TFLAG_FLAGGED -> IDE_FTFLAG_FLAGGED - IDE_TFLAG_FLAGGED_SET_IN_FLAGS -> IDE_FTFLAG_SET_IN_FLAGS - IDE_TFLAG_{OUT,IN}_DATA -> IDE_FTFLAG_{OUT,IN}_DATA v2: * Remember to fully update ide-h8300.c, scc_pata.c and tx493{8,9}ide.c (thanks to Stephen Rothwell for noticing). There should be no functional changes caused by this patch. Cc: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-27at91_ide: use readsw()/writesw() directlyBartlomiej Zolnierkiewicz
Use readsw()/writesw() directly intead of __ide_mm_{in,out}sw() macros. Cc: Stanislaw Gruszka <stf_xl@wp.pl> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-05ide: add at91_ide driverStanislaw Gruszka
This is IDE host driver for AT91 (SAM9, CAP9, AT572D940HF) Static Memory Controller with Compact Flash True IDE Mode logic. Driver have to switch 8/16 bit bus width when accessing Task Tile or Data Register. Moreover some extra things need to be done when setting PIO mode. Only PIO mode is used, hardware have no DMA support. If interrupt line is connected through GPIO extra quirk is needed to cope with fake interrupts. Signed-off-by: Stanislaw Gruszka <stf_xl@wp.pl> Cc: Andrew Victor <avictor.za@gmail.com> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
