path: root/drivers/ide/cs5535.c
2010-01-19cs5535: use ->pio_mode value to determine pair device speedBartlomiej Zolnierkiewicz
Use the current PIO mode value instead of the physical maximum one of the pair device on the port to determine PIO commmand timings used for both devices on the port. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-19ide: change ->set_dma_mode method parametersBartlomiej Zolnierkiewicz
Change ->set_dma_mode method parameters to match ->set_dmamode method used in struct ata_port_operations. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2010-01-19ide: change ->set_pio_mode method parametersBartlomiej Zolnierkiewicz
Change ->set_pio_mode method parameters to match ->set_piomode method used in struct ata_port_operations. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-02cs5535: add pci id for AMD based CS5535 controllersBartlomiej Zolnierkiewicz
Based on commit 02cb009 for pata_cs5530. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-21ide: remove useless subdirs from drivers/ide/Bartlomiej Zolnierkiewicz
Suggested-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
