path: root/drivers/ide/cs5536.c
2010-01-19cs5536: use ->pio_mode value to determine pair device speedBartlomiej Zolnierkiewicz
Use the current PIO mode value instead of the physical maximum one of the pair device on the port to determine PIO commmand timings used for both devices on the port. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-19ide: change ->set_dma_mode method parametersBartlomiej Zolnierkiewicz
Change ->set_dma_mode method parameters to match ->set_dmamode method used in struct ata_port_operations. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2010-01-19ide: change ->set_pio_mode method parametersBartlomiej Zolnierkiewicz
Change ->set_pio_mode method parameters to match ->set_piomode method used in struct ata_port_operations. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-15ide: do not access ide_drive_t 'drive_data' field directlyJoao Ramos
Change ide_drive_t 'drive_data' field from 'unsigned int' type to 'void *' type, allowing a wider range of values/types to be stored in this field. Added 'ide_get_drivedata' and 'ide_set_drivedata' helpers to get and set the 'drive_data' field. Fixed all host drivers to maintain coherency with the change in the 'drive_data' field type. Signed-off-by: Joao Ramos <joao.ramos@inov.pt> [bart: fix qd65xx build, cast to 'unsigned long', minor Coding Style fixups] Acked-by: Sergei Shtylyov <sshtylyov@ru.montavista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-04-18cs5536: define dma_sff_read_status() methodSergei Shtylyov
The driver somehow got merged with the initializer for the dma_sff_read_status() method missing which caused kernel panic on bootup. This should fix the kernel.org bug #13026... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Reported-by: Arnd Hannemann <hannemann@nets.rwth-aachen.de> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide: add ->dma_clear method and remove ->dma_timeout oneBartlomiej Zolnierkiewicz
All custom ->dma_timeout implementations call the generic one thus it is possible to have only an optional method for resetting DMA engine instead: * Add ->dma_clear method and convert hpt366, pdc202xx_old and sl82c105 host drivers to use it. * Always use ide_dma_timeout() in ide_dma_timeout_retry() and remove ->dma_timeout method. * Make ide_dma_timeout() static. There should be no functional changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-27ide: add ->dma_timer_expiry method and remove ->dma_exec_cmd one (v2)Bartlomiej Zolnierkiewicz
* Rename dma_timer_expiry() to ide_dma_sff_timer_expiry() and export it. * Add ->dma_timer_expiry method and use it to set hwif->expiry for ATA_PROT_DMA protocol in do_rw_taskfile(). * Initialize ->dma_timer_expiry to ide_dma_sff_timer_expiry() for SFF hosts. * Move setting hwif->expiry from ide_execute_command() to its users and drop 'expiry' argument. * Use ide_execute_command() instead of ->dma_exec_cmd in do_rw_taskfile(). * Remove ->dma_exec_cmd method and its implementations. * Unexport ide_execute_command() and ide_dma_intr(). v2: * Fix CONFIG_BLK_DEV_IDEDMA=n build (noticed by Randy Dunlap). * Fix *dma_expiry naming (suggested by Sergei Shtylyov). There should be no functional changes caused by this patch. Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-02-02ide: add CS5536 host driver (v3)Bartlomiej Zolnierkiewicz
This is a port of libata's pata_cs5536.c (written by Martin K. Petersen) to IDE subsystem. Changes done while at it: * Reprogram PIO/MWDMA timings if needed before and after DMA transfer (chipset uses shared PIO/MWDMA timings). * Fix cable detection to report 80-wires cable if BIOS set it for any device on a port (IDE core will do drive-side cable detection later). * Don't disable UDMA while programming PIO timings. * Simplify PCI/MSR support. Pros of having IDE host driver in addition to libata's one: * IDE is much lighter than SCSI+libata, the host driver itself is also a bit smaller: text data bss dec hex filename 1261 496 4 1761 6e1 drivers/ata/pata_cs5536.o 1242 128 4 1374 55e drivers/ide/cs5536.o * This allows use of IDE features which are unavailable under libata. v2: * Fixes per review from Sergei: - simplify dependency check in Kconfig - use IDE_DRV_MASK also for ->drive_data - disable UDMA when programming MWDMA - program new DTC timings only when necessary - fix printk() level in cs5536_init_one() * Fix patch description according to comments from Alan and Sergei. v3: * Smarter masking of UDMA bits per Sergei's suggestion. Cc: Martin K. Petersen <mkp@mkp.net> Cc: Karl Auerbach <karl@iwl.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
