path: root/drivers/ide/delkin_cb.c
2009-05-17ide: remove hw_regs_t typedefBartlomiej Zolnierkiewicz
Remove hw_regs_t typedef and rename struct hw_regs_s to struct ide_hw. There should be no functional changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-05-17ide: pass number of ports to ide_host_{alloc,add}() (v2)Bartlomiej Zolnierkiewicz
Pass number of ports to ide_host_{alloc,add}() and then update all users accordingly. v2: - drop no longer needed NULL initializers in buddha.c, cmd640.c and gayle.c (noticed by Sergei) There should be no functional changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-05-17ide: remove chipset field from hw_regs_tBartlomiej Zolnierkiewicz
* Convert host drivers that still use hw_regs_t's chipset field to use the one in struct ide_port_info instead. * Move special handling of ide_pci chipset type from ide_hw_configure() to ide_init_port(). * Remove chipset field from hw_regs_t. While at it: - remove stale comment in delkin_cb.c There should be no functional changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-27ide: allow host drivers to specify IRQ flagsBartlomiej Zolnierkiewicz
* Add ->irq_flags field to struct ide_port_info and struct ide_host. * Update host drivers and IDE PCI code to use ->irq_flags field. * Convert init_irq() and ide_intr() to use host->irq_flags. This fixes handling of shared IRQs for non-PCI hosts and removes ugly ifdeffery from core IDE code. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-24ide: fix ->init_chipset method to return 'int' valueBartlomiej Zolnierkiewicz
* Return 0 instead of dev->irq in ->init_chipset implementations. * Fix ->init_chipset method to return 'int' value instead of 'unsigned int' one. This fixes ->init_chipset handling for host drivers (cs5530, hpt366 and pdc202xx_new) for which it is possible for this method to fail. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-21ide: remove useless subdirs from drivers/ide/Bartlomiej Zolnierkiewicz
Suggested-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
