path: root/drivers/ide/ide-h8300.c
2009-05-17ide: remove hw_regs_t typedefBartlomiej Zolnierkiewicz
Remove hw_regs_t typedef and rename struct hw_regs_s to struct ide_hw. There should be no functional changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-05-17ide: pass number of ports to ide_host_{alloc,add}() (v2)Bartlomiej Zolnierkiewicz
Pass number of ports to ide_host_{alloc,add}() and then update all users accordingly. v2: - drop no longer needed NULL initializers in buddha.c, cmd640.c and gayle.c (noticed by Sergei) There should be no functional changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-05-17ide: remove chipset field from hw_regs_tBartlomiej Zolnierkiewicz
* Convert host drivers that still use hw_regs_t's chipset field to use the one in struct ide_port_info instead. * Move special handling of ide_pci chipset type from ide_hw_configure() to ide_init_port(). * Remove chipset field from hw_regs_t. While at it: - remove stale comment in delkin_cb.c There should be no functional changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-04-08ide-h8300: remove custom tf_{read|load}() methodsSergei Shtylyov
Since tf_{read|load}() methods of this driver have now become identical to their standard counterparts using I/O port accesses, there's no need to override those anymore... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-04-08ide-h8300: remove mm_{inw|outw}()Sergei Shtylyov
Remove two no longer used functions that I've overlooked... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide: turn selectproc() method into dev_select() method (take 5)Sergei Shtylyov
Turn selectproc() method into dev_select() method by teaching it to write to the device register and moving it from 'struct ide_port_ops' to 'struct ide_tp_ops'. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: benh@kernel.crashing.org Cc: petkovbb@gmail.com [bart: add ->dev_select to at91_ide.c and tx4939.c (__BIG_ENDIAN case)] Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide: move data register access out of tf_{read|load}() methods (take 2)Sergei Shtylyov
Move IDE_FTFLAG_{IN|OUT}_DATA flag handling out of tf_{read|load}() methods into the only two functions where these flags actually need to be handled: do_rw_taskfile() and ide_complete_cmd()... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide: call {in|out}put_data() methods from tf_{read|load}() methods (take 2)Sergei Shtylyov
Handle IDE_FTFLAG_{IN|OUT}_DATA flags in tf_{read|load}() methods by calling {in|out}put_data() methods to transfer 2 bytes -- this will allow us to move that handling out of those methods altogether... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide: rename IDE_TFLAG_IN_[HOB_]FEATURESergei Shtylyov
The feature register has never been readable -- when its location is read, one gets the error register value; hence rename IDE_TFLAG_IN_[HOB_]FEATURE into IDE_TFLAG_IN_[HOB_]ERROR and introduce the 'hob_error' field into the 'struct ide_taskfile' (despite the error register not really depending on the HOB bit). Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide: turn set_irq() method into write_devctl() methodSergei Shtylyov
Turn set_irq() method with its software reset hack into write_devctl() method (for just writing a value into the device control register) at last... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide: use ATA_HOBSergei Shtylyov
Make use of ATA_HOB instead of hard-coded value in the tf_read() method. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-27ide: pass command instead of request to ide_pio_datablock()Bartlomiej Zolnierkiewicz
* Add IDE_TFLAG_FS taskfile flag and set it for REQ_TYPE_FS requests. * Convert ->{in,out}put_data methods to take command instead of request as an argument. Then convert pre_task_out_intr(), task_end_request(), task_error(), task_in_unexpected(), ide_pio_sector(), ide_pio_multi() and ide_pio_datablock() in similar way. * Rename task_end_request() to ide_finish_cmd(). There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-27ide: remove ide_task_t typedefBartlomiej Zolnierkiewicz
While at it: - rename struct ide_task_s to struct ide_cmd - remove stale comments from idedisk_{read_native,set}_max_address() - drop unused 'cmd' argument from ide_{cmd,task}_ioctl() - drop unused 'task' argument from tx4939ide_tf_load_fixup() - rename ide_complete_task() to ide_complete_cmd() - use consistent naming for struct ide_cmd variables There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-27ide: add "flagged" taskfile flags to struct ide_taskfile (v2)Bartlomiej Zolnierkiewicz
* Add ->ftf_flags field to struct ide_taskfile and convert flags for TASKFILE ioctl to use it. * Rename "flagged" taskfile flags: - IDE_TFLAG_FLAGGED -> IDE_FTFLAG_FLAGGED - IDE_TFLAG_FLAGGED_SET_IN_FLAGS -> IDE_FTFLAG_SET_IN_FLAGS - IDE_TFLAG_{OUT,IN}_DATA -> IDE_FTFLAG_{OUT,IN}_DATA v2: * Remember to fully update ide-h8300.c, scc_pata.c and tx493{8,9}ide.c (thanks to Stephen Rothwell for noticing). There should be no functional changes caused by this patch. Cc: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-01-06ide: move read_sff_dma_status() method to 'struct ide_dma_ops'Sergei Shtylyov
Move apparently misplaced read_sff_dma_status() method from 'struct ide_tp_ops' to 'struct ide_dma_ops', renaming it to dma_sff_read_status() and making only required for SFF-8038i compatible IDE controller drivers (greatly cutting down the number of initializers) as its only user (outside ide-dma-sff.c and such drivers) appears to be ide_pci_check_simplex() which is only called for such controllers... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-21ide: remove useless subdirs from drivers/ide/Bartlomiej Zolnierkiewicz
Suggested-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
