path: root/drivers/ide/ide-proc.c
2013-04-09procfs: new helper - PDE_DATA(inode)Al Viro
The only part of proc_dir_entry the code outside of fs/proc really cares about is PDE(inode)->data. Provide a helper for that; static inline for now, eventually will be moved to fs/proc, along with the knowledge of struct proc_dir_entry layout. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-22new helper: file_inode(file)Al Viro
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-09-22ide: use printk_onceMarcin Slusarz
Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01ide: convert to ->proc_fopsAlexey Dobriyan
->read_proc, ->write_proc are going away, ->proc_fops should be used instead. The only tricky place is IDENTIFY handling: if for some reason taskfile_lib_get_identify() fails, buffer _is_ changed and at least first byte is overwritten. Emulate old behaviour with returning that first byte to userspace and reporting length=1 despite overall -E. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-07ide: fix races in handling of user-space SET XFER commandsBartlomiej Zolnierkiewicz
* Make cmd->tf_flags field 'u16' and add IDE_TFLAG_SET_XFER taskfile flag. * Update ide_finish_cmd() to set xfer / re-read id if the new flag is set. * Convert set_xfer_rate() (write handler for /proc/ide/hd?/current_speed) and ide_cmd_ioctl() (HDIO_DRIVE_CMD ioctl handler) to use the new flag. * Remove no longer needed disable_irq_nosync() + enable_irq() from ide_config_drive_speed(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-08ide: replace IDE_TFLAG_* flags by IDE_VALID_*Sergei Shtylyov
Replace IDE_TFLAG_{IN|OUT}_* flags meaning to the taskfile register validity on input/output by the IDE_VALID_* flags and introduce 4 symmetric 8-bit register validity indicator subfields, 'valid.{input/output}.{tf|hob}', into the 'struct ide_cmd' instead of using the 'tf_flags' field for that purpose (this field can then be turned from 32-bit into 8-bit one). Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-27ide: remove ide_task_t typedefBartlomiej Zolnierkiewicz
While at it: - rename struct ide_task_s to struct ide_cmd - remove stale comments from idedisk_{read_native,set}_max_address() - drop unused 'cmd' argument from ide_{cmd,task}_ioctl() - drop unused 'task' argument from tx4939ide_tf_load_fixup() - rename ide_complete_task() to ide_complete_cmd() - use consistent naming for struct ide_cmd variables There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-24ide: remove superfluous check from ide_proc_port_register_devices()Bartlomiej Zolnierkiewicz
2009-03-05ide: NULL noise: drivers/ide/ide-*.cHannes Eder
Fix this sparse warnings: drivers/ide/ide-disk_proc.c:130:11: warning: Using plain integer as NULL pointer drivers/ide/ide-floppy_proc.c:32:11: warning: Using plain integer as NULL pointer drivers/ide/ide-proc.c:234:11: warning: Using plain integer as NULL pointer drivers/ide/ide-tape.c:2141:11: warning: Using plain integer as NULL pointer Signed-off-by: Hannes Eder <hannes@hanneseder.net> Cc: trivial@kernel.org Cc: kernel-janitors@vger.kernel.org Cc: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-01-06ide: add port and host iteratorsBartlomiej Zolnierkiewicz
Add ide_port_for_each_dev() / ide_host_for_each_port() iterators and update IDE code to use them. While at it: - s/unit/i/ variable in ide_port_wait_ready(), ide_probe_port(), ide_port_tune_devices(), ide_port_init_devices_data(), do_reset1(), ide_acpi_set_state() and scc_dma_end() - s/d/i/ variable in ide_proc_port_register_devices() There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-01-06ide: dynamic allocation of device structuresBartlomiej Zolnierkiewicz
Allocate device structures dynamically instead of having them embedded in ide_hwif_t: * Remove needless zeroing of port structure from ide_init_port_data(). * Add ide_hwif_t.devices[MAX_DRIVES] (table of pointers to the devices). * Add ide_port_{alloc,free}_devices() helpers and use them respectively in ide_{host,free}_alloc(). * Convert all users of ->drives[] to use ->devices[] instead. While at it: * Use drive->dn for the slave device check in scc_pata.c. As a nice side-effect this patch cuts ~1kB (x86-32) from the resulting code size: text data bss dec hex filename 53963 1244 237 55444 d894 drivers/ide/ide-core.o.before 52981 1244 237 54462 d4be drivers/ide/ide-core.o.after Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-01-06ide: remove ide_driver_t typedefBartlomiej Zolnierkiewicz
While at it: - s/struct ide_driver_s/struct ide_driver/ - use to_ide_driver() macro in ide-proc.c Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-12-29cy82c693: remove superfluous ide_cy82c693 chipset typeBartlomiej Zolnierkiewicz
Since CY82C693 doesn't require serialization we may as well use the default ide_pci chipset type. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-12-29trm290: add IDE_HFLAG_TRM290 host flagBartlomiej Zolnierkiewicz
* Add IDE_HFLAG_TRM290 host flag and use it in ide_build_dmatable(). * Remove no longer needed ide_trm290 chipset type. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-12-29rz1000: apply chipset quirks early (v2)Bartlomiej Zolnierkiewicz
* Use pci_name(dev) instead of hwif->name in init_hwif_rz1000(). * init_hwif_rz1000() -> rz1000_init_chipset(). Update rz1000_init_one() to use rz1000_init_chipset() and add now required rz1000_remove(). * Remove superfluous ide_rz1000 chipset type. v2: * unsigned int rz1000_init_chipset() -> int rz1000_disable_readahead() per Sergei's suggestion. Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-12-29cmd64x: set IDE_HFLAG_SERIALIZE explictly for CMD646Bartlomiej Zolnierkiewicz
* Set IDE_HFLAG_SERIALIZE explictly for CMD646. * Remove no longer needed ide_cmd646 chipset type (which has a nice side-effect of fixing handling of unexpected IRQs). Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-12-29ide: IDE settings don't need an ide_lock heldBartlomiej Zolnierkiewicz
IDE settings are protected by ide_setting_mtx mutex so there is no need to hold ide_lock in ide_setting_ioctl(), ide_read_setting() and ide_proc_unregister_driver(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-11-02ide: Switch to a common addressAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-17ide: allow device drivers to specify per-device type /proc settingsBartlomiej Zolnierkiewicz
Turn ide_driver_t's 'proc' field into ->proc_entries method (and also 'settings' field into ->proc_devsets method). Then update all device drivers accordingly. There should be no functional changes caused by this patch. Acked-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: add device flagsBartlomiej Zolnierkiewicz
Add 'unsigned long dev_flags' to ide_drive_t and convert bitfields to IDE_DFLAG_* flags. While at it: - IDE_DFLAG_ADDRESSING -> IDE_DFLAG_LBA48 - fixup some comments - remove needless g->flags zeroing from ide*_probe() There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: Remove ide_spin_wait_hwgroup() and use special requests insteadElias Oltmanns
Use a special request for serialisation purposes and get rid of the awkward ide_spin_wait_hwgroup(). This also involves converting the ide_devset structure so it can be shared by the /proc and the ioctl code. Signed-off-by: Elias Oltmanns <eo@nebensachen.de> [bart: use rq->cmd[] directly] Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: remove SECTOR_WORDS defineBartlomiej Zolnierkiewicz
Just use SECTOR_SIZE instead. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: /proc/ide/hd*/settings reworkBartlomiej Zolnierkiewicz
* Add struct ide_devset, S_* flags, *DEVSET() & ide*_devset_*() macros. * Add 'const struct ide_devset **settings' to ide_driver_t. * Use 'const struct ide_devset **settings' in ide_drive_t instead of 'struct ide_settings_s *settings'. Then convert core code and device drivers to use struct ide_devset and co.: - device settings are no longer allocated dynamically for each device but instead there is an unique struct ide_devset instance per setting - device driver keeps the pointer to the table of pointers to its settings in ide_driver_t.settings - generic settings are kept in ide_generic_setting[] - ide_proc_[un]register_driver(), ide_find_setting_by_name(), ide_{read,write}_setting() and proc_ide_{read,write}_settings() are updated accordingly - ide*_add_settings() are removed * Remove no longer used __ide_add_setting(), ide_add_setting(), __ide_remove_setting() and auto_remove_settings(). * Remove no longer used TYPE_*, SETTING_*, ide_procset_t and ide_settings_t. * ->keep_settings, ->using_dma, ->unmask, ->noflush, ->dsc_overlap, ->nice1, ->addressing, ->wcache and ->nowerr ide_drive_t fields can now be bitfield flags. While at it: * Rename ide_find_setting_by_name() to ide_find_setting(). * Rename write_wcache() to set_wcache(). There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: preparations for /proc/ide/hd*/settings reworkBartlomiej Zolnierkiewicz
After rework settings will be no longer created dynamically for each device so we need to make some fixups first. * Use set_[ksettings,unmaskirq]() as a set function for ["keepsettings","unmaskirq"] setting. * Allow writes to ["io_32bit","unmaskirq"] settings also when drive->no_[io_32bit,unmask] is set (this is checked later inside set_[io_32bit,unmaskirq]() anywyay and keeps consistency with the corresponding HDIO_SET_[32BIT,UNMASKINTR] ioctls). * Use max possible multi sectors value (16) as an allowed max for "multcount" setting. set_multcount() set function checks against device's max possbile value anyway and it makes the proc setting consistent with the corresponding HDIO_SET_MULTCOUNT ioctl. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: include <linux/hdreg.h> only when neededBartlomiej Zolnierkiewicz
* Include <linux/ata.h> directly in <linux/ide.h> instead of through <linux/hdreg.h>. * Include <linux/hdreg.h> only when needed. Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: WIN_* -> ATA_CMD_*Bartlomiej Zolnierkiewicz
* Use ATA_CMD_* defines instead of WIN_* ones. While at it: * EXABYTE_ENABLE_NEXT -> ATA_EXABYTE_ENABLE_NEST * SETFEATURES_{EN,DIS}_WCACHE -> SETFEATURES_WC_{ON,OFF} * SETFEATURES_{EN,DIS}_AAM -> SETFEATURES_AAM_{ON,OFF} * SMART_* -> ATA_SMART_* * Remove stale comment from ide-proc.c. Partially based on earlier work by Chris Wedgwood. Acked-by: Chris Wedgwood <cw@f00f.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: make drive->id an union (take 2)Bartlomiej Zolnierkiewicz
Make drive->id an unnamed union so id can be accessed either by using 'u16 *id' or 'struct hd_driveid *driveid'. Then convert all existing drive->id users accordingly (using 'u16 *id' when possible). This is an intermediate step to make ide 'struct hd_driveid'-free. While at it: - Add missing KERN_CONTs in it821x.c. - Use ATA_ID_WORDS and ATA_ID_*_LEN defines. - Remove unnecessary checks for drive->id. - s/drive_table/table/ in ide_in_drive_list(). - Cleanup ide_config_drive_speed() a bit. - s/drive1/dev1/ & s/drive0/dev0/ in ide_undecoded_slave(). v2: Fix typo in drivers/ide/ppc/pmac.c. (From Stephen Rothwell) There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-24ide: trivial sparse annotationsHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-23ide: filter out "default" transfer mode values in set_xfer_rate()Bartlomiej Zolnierkiewicz
* Filter out "default" transfer mode values (0x00 - default PIO mode, 0x01 - default PIO mode w/ IORDY disabled) in write handler for obsoleted /proc/ide/hd?/settings:current_speed setting. Allowing "default" transfer mode values is a dangerous thing to do as we don't support programming controller to the "default" transfer mode and devices often use different values for the default and maximum PIO mode (i.e. PIO2 default and PIO4 maximum) so the controller will stay programmed for higher PIO mode while device will use the lower PIO mode. There is no functionality loss as by using special IOCTLs device can still be programmed to "default" transfer modes (it is only useful for debugging/testing purposes anyway). * Remove no longer needed IDE_HFLAG_ABUSE_SET_DMA_MODE host flag, it was previously used by few host drivers to program the controller to PIO0 timings for "default" transfer mode == 0x01 (although some host drivers would program invalid PIO timings instead). * Cleanup ide_set_xfer_rate() and add BUG_ON(). Suggested-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-23ide: filter out invalid transfer mode values in set_xfer_rate()Bartlomiej Zolnierkiewicz
Filter out invalid transfer mode values (0x02-0x07) in write handler for obsoleted /proc/ide/hd?/settings:current_speed setting. While at it: * Use XFER_UDMA_6 define. Suggested-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-06-30ide: fix /proc/ide/ide?/mate reportingBartlomiej Zolnierkiewicz
Now that we support warm-plug mate port will be registered even if there are no devices attached to it. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-06-10ide: remove the ide_etrax100 chipset typeAdrian Bunk
I forgot to remove the ide_etrax100 chipset type when removing the ETRAX_IDE driver. Reported-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-29drivers: use non-racy method for proc entries creation (2)Denis V. Lunev
Use proc_create()/proc_create_data() to make sure that ->proc_fops and ->data be setup before gluing PDE to main tree. Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Peter Osterlund <petero2@telia.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Neil Brown <neilb@suse.de> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-27ide: remove now unused ide_pci_create_host_proc()Alexey Dobriyan
It creates files in proc with obsoleted ->get_info interface. Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org> Cc: Andrew Morton <akpm@osdl.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ [bart: fix checkpatch.pl errors in ide-lib.c and ppc/mpc8xx.c while at it] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26IDE: Coding Style fixes to drivers/ide/ide-proc.cPaolo Ciarrocchi
Lot of errors and warnings removed. Compile tested. [bart: minor fixes, md5sum checked] Signed-off-by: Paolo Ciarrocchi <paolo.ciarrocchi@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ide: remove obsoleted "idex=base[,ctl[,irq]]" kernel parameters (take 2)Bartlomiej Zolnierkiewicz
* Remove obsoleted "idex=base[,ctl[,irq]]" kernel parameters and update Documentation/ide/ide.txt. * Remove no longer needed ide_forced chipset type. v2: * is_chipset_set[] -> is_chipset_set in ide.c. * Documentation/ide/ide.txt fix. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ide: remove IDE devices from /proc/ide/ before unregistering themBartlomiej Zolnierkiewicz
IDE devices need to be removed from /proc/ide/ _before_ being unregistered: * Drop 'ide_hwif_t *hwif' argument from destroy_proc_ide_device() and use drive->hwif instead. * Rename destroy_proc_ide_device() to ide_proc_unregister_device(). * Call ide_proc_unregister_device() in drive_release_dev(). * Remove no longer needed destroy_proc_ide_drives(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-06Palmchip BK3710 IDE driverAnton Salnikov
This is Palmchip BK3710 IDE controller support. The IDE controller logic supports PIO, MultiWord-DMA and Ultra-DMA modes. Supports interface to Compact Flash (CF) configured in True-IDE mode. Bart: - remove dead code - fix ide_hwif_setup_dma() build problem Signed-off-by: Anton Salnikov <asalnikov@ru.mvista.com> Reviewed-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Reviewed-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-02ide: move create_proc_ide_drives() call to ide_device_add_all()Bartlomiej Zolnierkiewicz
* Un-static create_proc_ide_drives() and call it from ide_device_add_all(). While at it: * Rename create_proc_ide_drives() to ide_proc_port_register_devices(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-02ide: move hwif->present check out from ide_proc_register_port()Bartlomiej Zolnierkiewicz
Move hwif->present check out from ide_proc_register_port() to ide_device_add_all(). There should be no functionality changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide: delete filenames/versions from commentsBartlomiej Zolnierkiewicz
Delete filenames/versions from comments. I'm leaving decisions about adding DRV_VERSION defines and MODULE_VERSION()-s to maintainers of the respective drivers. While at it: * Remove unused VERSION define from ide.c. * Remove unused/stale DRV_VERSION define from au1xxx-ide.c. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-26ide: switch set_xfer_rate() to use REQ_TYPE_ATA_TASKFILE requestsBartlomiej Zolnierkiewicz
Based on the earlier work by Tejun Heo. Switch set_xfer_rate() to use REQ_TYPE_ATA_TASKFILE requests and make ide_wait_cmd() static. There should be no functionality changes caused by this patch. Cc: Tejun Heo <htejun@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-20ide: add ide_device_add()Bartlomiej Zolnierkiewicz
* Add ide_device_add() helper and convert host drivers to use it instead of open-coded variants. * Make ide_pci_setup_ports() and do_ide_setup_pci_device() take 'u8 *idx' argument instead of 'ata_index_t *index'. * Remove no longer needed ata_index_t. * Unexport probe_hwif_init() and make it static. * Unexport ide_proc_register_port(). There should be no functionality changes caused by this patch (sgiioc4.c: ide_proc_register_port() requires hwif->present to be set and it won't be set if probe_hwif_init() fails). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-07-09ide: use mutex instead of ide_setting_sem semaphore in IDE driverMatthias Kaehlcke
The IDE driver uses a semaphore as mutex. Use the mutex API instead of the (binary) semaphore. Signed-off-by: Matthias Kaehlcke <matthias.kaehlcke@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> --
2007-05-24Add two missing chipsets to drivers/ide/ide-proc.cMika Kukkonen
Compiling with '-Wswitch-enum' I noticed following: CC drivers/ide/ide-proc.o drivers/ide/ide-proc.c: In function ‘proc_ide_read_imodel’: drivers/ide/ide-proc.c:54: warning: enumeration value ‘ide_etrax100’ not handled in switch drivers/ide/ide-proc.c:54: warning: enumeration value ‘ide_acorn’ not handled in switch How about the following patch? Signed-off-by: Mika Kukkonen <mikukkon@iki.fi> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-05-10ide: add ide_proc_register_port()Bartlomiej Zolnierkiewicz
* create_proc_ide_interfaces() tries to add /proc entries for every probed and initialized IDE port, replace it by ide_proc_register_port() which does it only for the given port (also rename destroy_proc_ide_interface() to ide_proc_unregister_port() for consistency) * convert {create,destroy}_proc_ide_interface[s]() users to use new functions * pmac driver depended on proc_ide_create() to add /proc port entries, fix it * au1xxx-ide, swarm and cs5520 drivers depended indirectly on ide-generic driver (CONFIG_IDE_GENERIC=y) to add port /proc entries, fix them * there is now no need to add /proc entries for IDE ports in proc_ide_create() so don't do it * proc_ide_create() needs now to be called before drivers are probed - fix it, while at it make proc_ide_create() create /proc "ide" directory Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-05-10ide: move IDE settings handling to ide-proc.cBartlomiej Zolnierkiewicz
* move __ide_add_setting() ide_add_setting() __ide_remove_setting() auto_remove_settings() ide_find_setting_by_name() ide_read_setting() ide_write_setting() set_xfer_rate() ide_add_generic_settings() ide_register_subdriver() ide_unregister_subdriver() from ide.c to ide-proc.c * set_{io_32bit,pio_mode,using_dma}() cannot be marked static now, fix it * rename ide_[un]register_subdriver() to ide_proc_[un]register_driver(), update device drivers to use new names * add CONFIG_IDE_PROC_FS=n versions of ide_proc_[un]register_driver() and ide_add_generic_settings() * make ide_find_setting_by_name(), ide_{read,write}_setting() and ide_{add,remove}_proc_entries() static * cover IDE settings code in device drivers with CONFIG_IDE_PROC_FS #ifdef, also while at it cover with CONFIG_IDE_PROC_FS #ifdef ide_driver_t.proc * remove bogus comment from ide.h * cover with CONFIG_IDE_PROC_FS #ifdef .proc and .settings in ide_drive_t Besides saner code this patch results in the IDE core smaller by ~2 kB (on x86-32) and IDE disk driver by ~1 kB (ditto) when CONFIG_IDE_PROC_FS=n. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-04-27IDE: remove rwsem use from ide-proc coreGreg Kroah-Hartman
The subsystem rwsem is not used by the driver core at all, so the use of it in the ide-proc code of it doesn't make any sense. Perhaps a local lock might be needed, but I do not really think so. Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: linux ide <linux-ide@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
