path: root/drivers/ide/ide-scan-pci.c
2008-04-26ide: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ [bart: fix checkpatch.pl errors in ide-lib.c and ppc/mpc8xx.c while at it] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18IDE: remove ide=reverse IDE coreGreg Kroah-Hartman
This option is obsolete and can be removed safely. It allows us to remove the pci_get_device_reverse() function from the PCI core. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide: small ide-scan-pci.c cleanupAdrian Bunk
- ide_scan_pcibus() can become static - instead of ide_scan_pci() we can use ide_scan_pcibus() directly in module_init() Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-26ide: move CONFIG_IDEPCI_PCIBUS_ORDER code to ide-scan-pci.cBartlomiej Zolnierkiewicz
2008-01-26ide: make remaining built-in only IDE host drivers modular (take 2)Bartlomiej Zolnierkiewicz
* Make remaining built-in only IDE host drivers modular, add ide-scan-pci.c file for probing PCI host drivers registered with IDE core (special case for built-in IDE and CONFIG_IDEPCI_PCIBUS_ORDER=y) and then take care of the ordering in which all IDE host drivers are probed when IDE is built-in during link time. * Move probing of gayle, falconide, macide, q40ide and buddha (m68k arch specific) host drivers, before PCI ones (no PCI on m68k), ide-cris (cris arch specific), cmd640 (x86 arch specific) and pmac (ppc arch specific). * Move probing of ide-cris (cris arch specific) host driver before cmd640 (x86 arch specific). * Move probing of mpc8xx (ppc specific) host driver before ide-pnp (depends on ISA and none of ppc platform that use mpc8xx supports ISA) and ide-h8300 (h8300 arch specific). * Add "probe_vlb" kernel parameter to cmd640 host driver and update Documentation/ide.txt accordingly. * Make IDE_ARM config option visible so it can also be disabled if needed. * Remove bogus comment from ide.c while at it. v2: * Fix two issues spotted by Sergei: - replace ENOMEM error value by ENOENT in ide-h8300 host driver - fix MODULE_PARM_DESC() in cmd640 host driver Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
