path: root/drivers/ide/ide-tape.c
2009-03-05ide: NULL noise: drivers/ide/ide-*.cHannes Eder
Fix this sparse warnings: drivers/ide/ide-disk_proc.c:130:11: warning: Using plain integer as NULL pointer drivers/ide/ide-floppy_proc.c:32:11: warning: Using plain integer as NULL pointer drivers/ide/ide-proc.c:234:11: warning: Using plain integer as NULL pointer drivers/ide/ide-tape.c:2141:11: warning: Using plain integer as NULL pointer Signed-off-by: Hannes Eder <hannes@hanneseder.net> Cc: trivial@kernel.org Cc: kernel-janitors@vger.kernel.org Cc: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-02-25ide: fix refcounting in device driversBartlomiej Zolnierkiewicz
During host driver module removal del_gendisk() results in a final put on drive->gendev and freeing the drive by drive_release_dev(). Convert device drivers from using struct kref to use struct device so device driver's object holds reference on ->gendev and prevents drive from prematurely going away. Also fix ->remove methods to not erroneously drop reference on a host driver by using only put_device() instead of ide*_put(). Reported-by: Stanislaw Gruszka <stf_xl@wp.pl> Tested-by: Stanislaw Gruszka <stf_xl@wp.pl> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-01-06ide: remove ->error method from struct ide_driverBartlomiej Zolnierkiewicz
* Remove (now superfluous) ->error method from struct ide_driver. * Unexport __ide_error() and make it static. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-01-06ide: remove ide_driver_t typedefBartlomiej Zolnierkiewicz
While at it: - s/struct ide_driver_s/struct ide_driver/ - use to_ide_driver() macro in ide-proc.c Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-01-06ide: merge ide_hwgroup_t with ide_hwif_t (v2)Bartlomiej Zolnierkiewicz
* Merge ide_hwgroup_t with ide_hwif_t. * Cleanup init_irq() accordingly, then remove no longer needed ide_remove_port_from_hwgroup() and ide_ports[]. * Remove now unused HWGROUP() macro. While at it: * ide_dump_ata_error() fixups v2: * Fix ->quirk_list check in do_ide_request() (s/hwif->cur_dev/prev_port->cur_dev). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-01-02ide-atapi: remove timeout arg to ide_issue_pcBorislav Petkov
There should be no functionality change resulting from this patch. Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-01-02ide-cd: move cdrom_timer_expiry to ide-atapi.cBorislav Petkov
- cdrom_timer_expiry -> ide_cd_expiry - remove expiry-arg to ide_issue_pc as it is redundant now - ide_debug_log -> debug_log Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-21[PATCH] switch ide-tapeAl Viro
2008-10-21[PATCH] beginning of methods conversionAl Viro
To keep the size of changesets sane we split the switch by drivers; to keep the damn thing bisectable we do the following: 1) rename the affected methods, add ones with correct prototypes, make (few) callers handle both. That's this changeset. 2) for each driver convert to new methods. *ALL* drivers are converted in this series. 3) kill the old (renamed) methods. Note that it _is_ a flagday; all in-tree drivers are converted and by the end of this series no trace of old methods remain. The only reason why we do that this way is to keep the damn thing bisectable and allow per-driver debugging if anything goes wrong. New methods: open(bdev, mode) release(disk, mode) ioctl(bdev, mode, cmd, arg) /* Called without BKL */ compat_ioctl(bdev, mode, cmd, arg) locked_ioctl(bdev, mode, cmd, arg) /* Called with BKL, legacy */ Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-21[PATCH] lose the unused file argument in generic_ide_ioctl()Al Viro
2008-10-17ide: allow device drivers to specify per-device type /proc settingsBartlomiej Zolnierkiewicz
Turn ide_driver_t's 'proc' field into ->proc_entries method (and also 'settings' field into ->proc_devsets method). Then update all device drivers accordingly. There should be no functional changes caused by this patch. Acked-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-17ide: remove IDE_AFLAG_NO_DOORLOCKINGBartlomiej Zolnierkiewicz
Just use IDE_DFLAG_DOORLOCKING instead. There should be no functional changes caused by this patch. Acked-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-16device create: ide: convert device_create_drvdata to device_createGreg Kroah-Hartman
Now that device_create() has been audited, rename things back to the original call to be sane. Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-13ide: set IDE_AFLAG_DRQ_INTERRUPT in do_identify()Bartlomiej Zolnierkiewicz
Set IDE_AFLAG_DRQ_INTERRUPT in do_identify() instead of ATAPI device drivers *_setup() methods. While at it: - use ata_id_cdb_intr() There should be no functional changes caused by this patch. Cc: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: remove superfluous ->media field from ide_driver_tBartlomiej Zolnierkiewicz
Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: add device flagsBartlomiej Zolnierkiewicz
Add 'unsigned long dev_flags' to ide_drive_t and convert bitfields to IDE_DFLAG_* flags. While at it: - IDE_DFLAG_ADDRESSING -> IDE_DFLAG_LBA48 - fixup some comments - remove needless g->flags zeroing from ide*_probe() There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: unify conversion macrosBorislav Petkov
Introduce to_ide_drv() and ide_drv_g() macros and replace the respective definitions of similar ones in each driver. There should be no functionality change resulting from this patch. Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: make ide_transfer_pc() staticBartlomiej Zolnierkiewicz
* Move ->ticks field from struct ide_floppy_obj to ide_drive_t. * Move idefloppy_transfer_pc() to ide-atapi.c and make ide_transfer_pc() use it. * Always use ide_transfer_pc as a handler in ide_issue_pc(). * Remove no longer used idefloppy_start_pc_transfer(), ide*_transfer_pc() and 'handler' argument from ide_issue_pc(). * Make ide_transfer_pc() static. While at it: * idefloppy_transfer_pc() -> ide_delayed_transfer_pc() * IDEFLOPPY_TICKS_DELAY -> IDEFLOPPY_PC_DELAY * ->ticks -> ->pc_delay There should be no functional changes caused by this patch. Cc: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: make ide_pc_intr() staticBartlomiej Zolnierkiewicz
* Always use ide_pc_intr as a handler in ide_pc_intr(). * Remove no longer used ide*_pc_intr() and 'handler' argument from ide_{transfer_pc,pc_intr}(). * Make ide_pc_intr() static. There should be no functional changes caused by this patch. Cc: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: add ->pc_{update,io}_buffers methodsBartlomiej Zolnierkiewicz
Add ->pc_{update,io}_buffers methods to ide_drive_t and use them instead of {update,io}_buffers ide_pc_intr() arguments. There should be no functional changes caused by this patch. Cc: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: add ide_retry_pc() helperBartlomiej Zolnierkiewicz
* Add ide_create_request_sense_cmd() and ide_retry_pc() helpers and convert ide-{atapi,floppy,tape}.c to use them. * Remove no longer used ide*_create_request_sense_cmd(), ide*_retry_pc() and 'retry_pc' argument from ide_pc_intr(). * Make ide_queue_pc_head() static. There should be no functional changes caused by this patch. Cc: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: add request_sense_{pc,rq} to ide_drive_tBartlomiej Zolnierkiewicz
Add 'struct ide_atapi_pc request_sense_pc' and 'request request_sense_rq' to ide_drive_t and use them instead of fields in struct ide_{floppy,tape}_obj. There should be no functional changes caused by this patch. Cc: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: drop 'timeout' and 'expiry' arguments from ide_pc_intr()Bartlomiej Zolnierkiewicz
* Move idescsi_expiry() to ide-atapi.c. * Move get_timeout() to <linux/ide.h>. * Drop 'timeout' and 'expiry' arguments from ide_pc_intr(). While at it: * idescsi_expiry() -> ide_scsi_expiry() * get_timeout() -> ide_scsi_get_timeout() There should be no functional changes caused by this patch. Cc: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: add pointer to the current packet command to ide_drive_tBartlomiej Zolnierkiewicz
* Add pointer to the current packet command (struct ide_atapi_pc *pc) to ide_drive_t and use it instead of the pointer in struct ide_*_obj. * Use drive->pc in ide_{issue,transfer}_pc() and ide_pc_intr() instead of 'pc' argument. There should be no functional changes caused by this patch. Cc: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: drop dsc_handle argument from ide_pc_intr()Bartlomiej Zolnierkiewicz
* Add 'int dsc' argument to ->pc_callback method. * Call ide_tape_handle_dsc() internally in ide_tape_callback() if dsc argument is set and update ide_pc_intr() accordingly. There should be no functional changes caused by this patch. Cc: Borislav Petkov <petkovbb@gmail.com> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: Remove ide_spin_wait_hwgroup() and use special requests insteadElias Oltmanns
Use a special request for serialisation purposes and get rid of the awkward ide_spin_wait_hwgroup(). This also involves converting the ide_devset structure so it can be shared by the /proc and the ioctl code. Signed-off-by: Elias Oltmanns <eo@nebensachen.de> [bart: use rq->cmd[] directly] Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: move IDE{FLOPPY,TAPE}_WAIT_CMD defines to <linux/ide.h>Bartlomiej Zolnierkiewicz
While at it: * IDE{FLOPPY,TAPE}_WAIT_CMD -> WAIT_{FLOPPY,TAPE}_CMD * Use enum for WAIT_* defines. There should be no functional changes caused by this patch. Acked-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: add ide_do_test_unit_ready() helperBartlomiej Zolnierkiewicz
* Add ide_do_test_unit_ready() helper and convert ide-{floppy,tape}.c to use it. * Remove no longer used idetape_create_test_unit_ready_cmd(). There should be no functional changes caused by this patch. Acked-by: Borislav Petkov <petkovbb@gmail.com> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: add ide_do_start_stop() helperBartlomiej Zolnierkiewicz
* Add ide_do_start_stop() helper and convert ide-{floppy,tape}.c to use it. * Remove no longer used idefloppy_create_start_stop_cmd() and idetape_create_load_unload_cmd(). There should be no functional changes caused by this patch. Acked-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: add ide_set_media_lock() helperBartlomiej Zolnierkiewicz
* Set IDE_AFLAG_NO_DOORLOCK in idetape_get_mode_sense_result(), check it in ide_tape_set_media_lock() and cleanup idetape_create_prevent_cmd(). * Set IDE_AFLAG_NO_DOORLOCK in ide_floppy_create_read_capacity_cmd() and check it instead of IDE_AFLAG_CLIK_DRIVE in ide_floppy_set_media_lock(). * Add ide_set_media_lock() helper and convert ide-{floppy,tape}.c to use it. * Remove no longer used ide*_create_prevent_cmd()/ide*_set_media_lock(). * Update comment in <linux/ide.h> accordingly. Acked-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: add ide_queue_pc_tail() helperBartlomiej Zolnierkiewicz
* Add ide_queue_pc_tail() and convert ide-{floppy,tape}.c to use it instead of ide*_queue_pc_tail(). * Remove no longer used ide*_queue_pc_tail(). There should be no functional changes caused by this patch. Acked-by: Borislav Petkov <petkovbb@gmail.com> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: add ide_queue_pc_head() helperBartlomiej Zolnierkiewicz
* Move REQ_IDETAPE_* enums to <linux/ide.h>. * Add ide_queue_pc_head() and convert ide-{floppy,tape}.c to use it instead of ide*_queue_pc_head(). * Remove no longer used ide*_queue_pc_head(). There should be no functional changes caused by this patch. Acked-by: Borislav Petkov <petkovbb@gmail.com> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: add ide_init_pc() helperBartlomiej Zolnierkiewicz
* Add IDE_PC_BUFFER_SIZE define. * Add ide_init_pc() and convert ide-{floppy,tape}.c to use it instead of ide*_init_pc(). * Remove no longer used IDE*_PC_BUFFER_SIZE and ide*_init_pc(). There should be no functional changes caused by this patch. Acked-by: Borislav Petkov <petkovbb@gmail.com> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide-tape: add ide_tape_set_media_lock() helperBartlomiej Zolnierkiewicz
Add ide_tape_set_media_lock() helper and convert idetape_mtioctop(), idetape_chrdev_open() and idetape_chrdev_release() to use it. There should be no functional changes caused by this patch (it is OK to modify ->door_locked if idetape_create_prevent_cmd() fails). Acked-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: add ide_io_buffers() helperBartlomiej Zolnierkiewicz
* Make ->io_buffers method return number of bytes transferred. * Use ide_end_request() instead of idefloppy_end_request() in ide_floppy_io_buffers() and then move the call out to ide_pc_intr(). * Add ide_io_buffers() helper and convert ide-{floppy,scsi}.c to use it instead of ide*_io_buffers(). There should be no functional changes caused by this patch. Acked-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide-{floppy,tape}: remove packet command stackBartlomiej Zolnierkiewicz
* Add 'struct ide_atapi_pc queued_pc' to struct ide_{floppy,tape}_obj and switch ide*_do_request() to use it (there can be only one active request for a given device). * Add 'struct ide_atapi_pc request_sense_pc' to struct ide_*_obj and switch ide*_retry_pc() to use it. * Remove needless {floppy,tape}->pc assignment from ide*_setup(). * Remove no longer needed ide*_next_pc_storage(), pc_stack[], rq_stack_index, IDE*_PC_STACK and DBG_PC_STACK. There should be no functional changes caused by this patch. Cc: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide-{floppy,tape}: remove request stackBartlomiej Zolnierkiewicz
* Add 'struct request request_sense_rq' to struct ide_{floppy,tape}_obj and switch ide*_retry_pc() to use it (there can be only one REQUEST SENSE request active for a given device). * Remove no longer needed ide*_next_rq_storage(), rq_stack[] and rq_stack_index. * DBG_PCRQ_STACK -> DBG_PC_STACK * Update comments for IDE*_PC_STACK and idetape_queue_pc_{head,tail}(). There should be no functional changes caused by this patch. Cc: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide-tape: remove idetape_init_rq()Bartlomiej Zolnierkiewicz
idetape_init_rq() is only used in idetape_queue_pc_head() so inline it there. Cc: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: add ide_check_atapi_device() helperBartlomiej Zolnierkiewicz
* Add ide_check_atapi_device() to ide-atapi.c and convert ide-{floppy,tape}.c to use it instead of ide*_identify_device(). While at it: * Add DRV_NAME defines to ide-{floppy,tape}.c. Cc: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: remove ->supports_dsc_overlap field from ide_driver_tBartlomiej Zolnierkiewicz
* Use drive->media and drive->scsi to check if ->dsc_overlap can be set by HDIO_SET_NICE ioctl in generic_ide_ioctl(). * Remove unused ->supports_dsc_overlap field from ide_driver_t. There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: /proc/ide/hd*/settings reworkBartlomiej Zolnierkiewicz
* Add struct ide_devset, S_* flags, *DEVSET() & ide*_devset_*() macros. * Add 'const struct ide_devset **settings' to ide_driver_t. * Use 'const struct ide_devset **settings' in ide_drive_t instead of 'struct ide_settings_s *settings'. Then convert core code and device drivers to use struct ide_devset and co.: - device settings are no longer allocated dynamically for each device but instead there is an unique struct ide_devset instance per setting - device driver keeps the pointer to the table of pointers to its settings in ide_driver_t.settings - generic settings are kept in ide_generic_setting[] - ide_proc_[un]register_driver(), ide_find_setting_by_name(), ide_{read,write}_setting() and proc_ide_{read,write}_settings() are updated accordingly - ide*_add_settings() are removed * Remove no longer used __ide_add_setting(), ide_add_setting(), __ide_remove_setting() and auto_remove_settings(). * Remove no longer used TYPE_*, SETTING_*, ide_procset_t and ide_settings_t. * ->keep_settings, ->using_dma, ->unmask, ->noflush, ->dsc_overlap, ->nice1, ->addressing, ->wcache and ->nowerr ide_drive_t fields can now be bitfield flags. While at it: * Rename ide_find_setting_by_name() to ide_find_setting(). * Rename write_wcache() to set_wcache(). There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: call ide_proc_register_driver() laterBartlomiej Zolnierkiewicz
Call ide_proc_register_driver() in ide*_setup() (just before ide*_add_settings() call) instead of in ->probe method. Despite being basically a preparation for /proc/ide/hd*/settings rework this is a nice cleanup in itself. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: remove needless drive->present checks from device driversBartlomiej Zolnierkiewicz
Remove needless drive->present checks from ->probe methods (device model takes care of that). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: use ATA_* defines instead of *_STAT and *_ERR onesBartlomiej Zolnierkiewicz
* ERR_STAT -> ATA_ERR * INDEX_STAT -> ATA_IDX * ECC_STAT -> ATA_CORR * DRQ_STAT -> ATA_DRQ * SEEK_STAT -> ATA_DSC * WRERR_STAT -> ATA_DF * READY_STAT -> ATA_DRDY * BUSY_STAT -> ATA_BUSY * MARK_ERR -> ATA_AMNF * TRK0_ERR -> ATA_TRK0NF * ABRT_ERR -> ATA_ABORTED * MCR_ERR -> ATA_MCR * ID_ERR -> ATA_IDNF * MC_ERR -> ATA_MC * ECC_ERR -> ATA_UNC * ICRC_ERR -> ATA_ICRC * BBD_ERR -> ATA_BBK Also: * ILI_ERR -> ATAPI_ILI * EOM_ERR -> ATAPI_EOM * LFS_ERR -> ATAPI_LFS * CD -> ATAPI_COD * IO -> ATAPI_IO Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: make drive->id an union (take 2)Bartlomiej Zolnierkiewicz
Make drive->id an unnamed union so id can be accessed either by using 'u16 *id' or 'struct hd_driveid *driveid'. Then convert all existing drive->id users accordingly (using 'u16 *id' when possible). This is an intermediate step to make ide 'struct hd_driveid'-free. While at it: - Add missing KERN_CONTs in it821x.c. - Use ATA_ID_WORDS and ATA_ID_*_LEN defines. - Remove unnecessary checks for drive->id. - s/drive_table/table/ in ide_in_drive_list(). - Cleanup ide_config_drive_speed() a bit. - s/drive1/dev1/ & s/drive0/dev0/ in ide_undecoded_slave(). v2: Fix typo in drivers/ide/ppc/pmac.c. (From Stephen Rothwell) There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide-tape: Buildfix when IDETAPE_DEBUG_LOG is set to 1.Mark de Wever
The format specifier for rq->sector didn't specify the proper size and signedness. Borislav Petkov discovered that the signedness for rq->nr_sectors and rq->current_nr_sectors also were incorrect. Signed-off-by: Mark de Wever <koraq@xs4all.nl> Acked-by: Borislav Petkov <petkovbb@gmail.com> [bart: remove trailing whitespace] Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-09-27ide-tape: fix vendor stringsBorislav Petkov
Remove superfluous two bytes from each string buffer and add proper length format specifiers. Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Tested-by: Mark de Wever <koraq@xs4all.nl> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-08-05ide: fix regression caused by ide_device_{get,put}() addition (take 2)Bartlomiej Zolnierkiewicz
On Monday 28 July 2008, Benjamin Herrenschmidt wrote: [...] > Vector: 300 (Data Access) at [c58b7b80] > pc: c014f264: elv_may_queue+0x10/0x44 > lr: c0152750: get_request+0x2c/0x2c0 > sp: c58b7c30 > msr: 1032 > dar: c > dsisr: 40000000 > current = 0xc58aaae0 > pid = 854, comm = media-bay > enter ? for help > mon> t > [c58b7c40] c0152750 get_request+0x2c/0x2c0 > [c58b7c70] c0152a08 get_request_wait+0x24/0xec > [c58b7cc0] c0225674 ide_cd_queue_pc+0x58/0x1a0 > [c58b7d40] c022672c ide_cdrom_packet+0x9c/0xdc > [c58b7d70] c0261810 cdrom_get_disc_info+0x60/0xd0 > [c58b7dc0] c026208c cdrom_mrw_exit+0x1c/0x11c > [c58b7e30] c0260f7c unregister_cdrom+0x84/0xe8 > [c58b7e50] c022395c ide_cd_release+0x80/0x84 > [c58b7e70] c0163650 kref_put+0x54/0x6c > [c58b7e80] c0223884 ide_cd_put+0x40/0x5c > [c58b7ea0] c0211100 generic_ide_remove+0x28/0x3c > [c58b7eb0] c01e9d34 __device_release_driver+0x78/0xb4 > [c58b7ec0] c01e9e44 device_release_driver+0x28/0x44 > [c58b7ee0] c01e8f7c bus_remove_device+0xac/0xd8 > [c58b7f00] c01e7424 device_del+0x104/0x198 > [c58b7f20] c01e74d0 device_unregister+0x18/0x30 > [c58b7f40] c02121c4 __ide_port_unregister_devices+0x6c/0x88 > [c58b7f60] c0212398 ide_port_unregister_devices+0x38/0x80 > [c58b7f80] c0208ca4 media_bay_step+0x1cc/0x5c0 > [c58b7fb0] c0209124 media_bay_task+0x8c/0xcc > [c58b7fd0] c00485c0 kthread+0x48/0x84 > [c58b7ff0] c0011b20 kernel_thread+0x44/0x60 The guilty commit turned out to be 08da591e14cf87247ec09b17c350235157a92fc3 ("ide: add ide_device_{get,put}() helpers"). ide_device_put() is called before kref_put() in ide_cd_put() so IDE device is already gone by the time ide_cd_release() is reached. Fix it by calling ide_device_get() before kref_get() and ide_device_put() after kref_put() in all affected device drivers. v2: Brown paper bag time. In v1 cd->drive was referenced after dropping last reference on cd object (which could result in OOPS in ide_device_put() as reported/debugged by Mariusz Kozlowski). Fix it by caching cd->drive in the local variable (fix other device drivers too). Reported-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Reported-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Borislav Petkov <petkovbb@gmail.com> Tested-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Tested-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-24ide: ide-tape.c sparse annotations and unaligned access removalHarvey Harrison
If this is actually unaligned the access of speed/max_speed above is already broken and needs a get_unaligned. Otherwise it is aligned and they can be removed. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Borislav Petkov <petkovbb@googlemail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-24ide: add ide_device_{get,put}() helpersBartlomiej Zolnierkiewicz
* Add 'struct ide_host *host' field to ide_hwif_t and set it in ide_host_alloc_all(). * Add ide_device_{get,put}() helpers loosely based on SCSI's scsi_device_{get,put}() ones. * Convert IDE device drivers to use ide_device_{get,put}(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
