path: root/drivers/ide/ide-timing.h
2008-02-03Spelling fixes: lenght->lengthPaulius Zaleckas
Signed-off-by: Paulius Zaleckas <pauliusz@yahoo.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2008-02-01ide: delete filenames/versions from commentsBartlomiej Zolnierkiewicz
Delete filenames/versions from comments. I'm leaving decisions about adding DRV_VERSION defines and MODULE_VERSION()-s to maintainers of the respective drivers. While at it: * Remove unused VERSION define from ide.c. * Remove unused/stale DRV_VERSION define from au1xxx-ide.c. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-07-20ide: remove ide_find_best_pio_mode()Bartlomiej Zolnierkiewicz
* Add ->host_flags to ide_hwif_t to store ide_pci_device_t.host_flags, assign it in setup-pci.c:ide_pci_setup_ports(). * Add IDE_HFLAG_PIO_NO_{BLACKLIST,DOWNGRADE} to ide_pci_device_t.host_flags and teach ide_get_best_pio_mode() about them. Also remove needless !drive->id check while at it (drive->id is always present). * Convert amd74xx, via82cxxx and ide-timing.h to use ide_get_best_pio_mode() and then remove no longer needed ide_find_best_pio_mode(). There should be no functionality changes caused by this patch. Acked-by: Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-07-20ide: ide_find_best_pio_mode() fixes (take 2)Bartlomiej Zolnierkiewicz
* Check IORDY bit for PIO modes > 2. * Some devices claim maximum PIO mode > 2 in id->tPIO, they were punished too severly for this by being limited to PIO_SLOW. Limit them to PIO2 instead. v2: * Fix PIO number being returned incorrectly instead of PIO mode (Noticed by Sergei). Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-07-09ide: convert ide_find_best_mode() users to use ide_max_dma_mode()Bartlomiej Zolnierkiewicz
ide-timing.h: * remove handling of DMA modes from ide_find_best_mode() and rename it to ide_find_best_pio_mode() * drop no longer needed "map" argument from ide_find_best_pio_mode() and delete needless ->id check * remove no longer needed XFER_SWDMA and XFER_UDMA* defines au1xxx-ide.c: * use ide_max_dma_mode() instead of ide_find_best_mode() * remove needless CONFIG_BLK_DEV_IDE_AU1XXX_MDMA2_DBDMA #ifdef amd74xx.c: * store UDMA masks in amd_ide_chip[] and while at it make "base" field to be u8 instead of unsigned long * convert the driver to use UDMA masks from amd_ide_chip[] * use ide_max_dma_mode() and ide_find_best_pio_mode() instead of ide_find_best_mode() * delete stale comment from amd74xx_ide_dma_check() * remove no longer needed AMD_UDMA* defines via82cxxx.c: * remove unused DISPLAY_VIA_TIMINGS define * store UDMA masks in via_isa_bridges[] and while at it make "flags" field to be u8 instead of u16 * convert the driver to use UDMA masks from via_isa_bridges[] * use ide_max_dma_mode() and ide_find_best_pio_mode() instead of ide_find_best_mode() * remove no longer needed VIA_UDMA* defines pmac.c: * use ide_max_dma_mode() instead of ide_find_best_mode() There should be no functionality changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Reviewed-by: Sergei Shtylyov <sshtylyov@ru.mvista.com>
2006-06-26[PATCH] ide: actually honor drive's minimum PIO/DMA cycle timesSergei Shtylyov
The function ide_timing_compute() fails to *actually* take drive's specified minimum PIO/DMA cycle times into account -- when doing this, it calls ide_timing_merge() on the 'struct ide_timing' argument which contains garbage at the moment, and then ultimately destroys the read cycle time by quantizing the ide_timing[] entry, instead of copying from that entry to the argument structure, and only then doing a merge/quantize. Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-10[PATCH] janitor: ide: min/max macros in ide-timing.hClemens Buchacher
I replaced the custom MIN/MAX macros with the type safe min/max macros from linux/kernel.h. Signed-off-by: Maximilian Attems <janitor@sternwelten.at> Signed-off-by: Domen Puncer <domen@coderock.org> Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
