path: root/drivers/ide/ide.c
2010-08-11ide: use module_param_named rather than module_param_callRusty Russell
It has the additional benefit of typechecking (in this case, an unsigned int). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Reviewed-by: Takashi Iwai <tiwai@suse.de>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-06-07ide: preserve Host Protected Area by default (v2)Bartlomiej Zolnierkiewicz
From the perspective of most users of recent systems, disabling Host Protected Area (HPA) can break vendor RAID formats, GPT partitions and risks corrupting firmware or overwriting vendor system recovery tools. Unfortunately the original (kernels < 2.6.30) behavior (unconditionally disabling HPA and using full disk capacity) was introduced at the time when the main use of HPA was to make the drive look small enough for the BIOS to allow the system to boot with large capacity drives. Thus to allow the maximum compatibility with the existing setups (using HPA and partitioned with HPA disabled) we automically disable HPA if any partitions overlapping HPA are detected. Additionally HPA can also be disabled using the "nohpa" module parameter (i.e. "ide_core.nohpa=0.0" to disable HPA on /dev/hda). v2: Fix ->resume HPA support. While at it: - remove stale "idebus=" entry from Documentation/kernel-parameters.txt Cc: Robert Hancock <hancockrwd@gmail.com> Cc: Frans Pop <elendil@planet.nl> Cc: "Andries E. Brouwer" <Andries.Brouwer@cwi.nl> Cc: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> [patch description was based on input from Alan Cox and Frans Pop] Emphatically-Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-24ide: move device settings code to ide-devsets.cBartlomiej Zolnierkiewicz
Remove stale comment from ide.c while at it. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-24ide: sanitize ACPI initializationBartlomiej Zolnierkiewicz
* ide_acpi_init() -> ide_acpi_init_port() * ide_acpi_blacklist() -> ide_acpi_init() * Call ide_acpi_init() only once (do it during IDE core initialization) and cleanup the function accordingly. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-02-25ide: ide.c 'clear' fix, update "ide=nodma" documentationDavid Fries
Documentation/kernel-parameters.txt - ide=nodma is no longer valid. drivers/ide/Kconfig - The module is ide-core.ko not ide. drivers/ide/ide.c - It took me a while to figure out what the arguments %d.%d:%d to nodma module parameter ment, so I added a comment to each. - Added a comment to each of the sscanf lines. - There is a bug, if j is 0 it would previously clear all the other bits except the current device, changed in three different places. mask &= (1 << i) should be mask &= ~(1 << i). Signed-off-by: David Fries <david@fries.net> [bart: s/disk/device/ in ide.c, beautify patch description] Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-01-06ide: add port and host iteratorsBartlomiej Zolnierkiewicz
Add ide_port_for_each_dev() / ide_host_for_each_port() iterators and update IDE code to use them. While at it: - s/unit/i/ variable in ide_port_wait_ready(), ide_probe_port(), ide_port_tune_devices(), ide_port_init_devices_data(), do_reset1(), ide_acpi_set_state() and scc_dma_end() - s/d/i/ variable in ide_proc_port_register_devices() There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-01-06ide: dynamic allocation of device structuresBartlomiej Zolnierkiewicz
Allocate device structures dynamically instead of having them embedded in ide_hwif_t: * Remove needless zeroing of port structure from ide_init_port_data(). * Add ide_hwif_t.devices[MAX_DRIVES] (table of pointers to the devices). * Add ide_port_{alloc,free}_devices() helpers and use them respectively in ide_{host,free}_alloc(). * Convert all users of ->drives[] to use ->devices[] instead. While at it: * Use drive->dn for the slave device check in scc_pata.c. As a nice side-effect this patch cuts ~1kB (x86-32) from the resulting code size: text data bss dec hex filename 53963 1244 237 55444 d894 drivers/ide/ide-core.o.before 52981 1244 237 54462 d4be drivers/ide/ide-core.o.after Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-01-06ide: remove ide_driver_t typedefBartlomiej Zolnierkiewicz
While at it: - s/struct ide_driver_s/struct ide_driver/ - use to_ide_driver() macro in ide-proc.c Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-01-06ide: move ide_init_port_data() and friends to ide-probe.cBartlomiej Zolnierkiewicz
* Move IDE_DEFAULT_MAX_FAILURES to <linux/ide.h>. * Move ide_cfg_mtx, ide_hwif_to_major[], ide_port_init_devices_data(), ide_init_port_data(), ide_init_port_hw() and ide_unregister() to ide-probe.c from ide.c. * Make ide_unregister(), ide_init_port_data(), ide_init_port_hw() and ide_cfg_mtx static. While at it: * Remove stale ide_init_port_data() documentation and ide_lock extern. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-01-06ide: update ide_unregister() documentationBartlomiej Zolnierkiewicz
2009-01-06ide: merge ide_hwgroup_t with ide_hwif_t (v2)Bartlomiej Zolnierkiewicz
* Merge ide_hwgroup_t with ide_hwif_t. * Cleanup init_irq() accordingly, then remove no longer needed ide_remove_port_from_hwgroup() and ide_ports[]. * Remove now unused HWGROUP() macro. While at it: * ide_dump_ata_error() fixups v2: * Fix ->quirk_list check in do_ide_request() (s/hwif->cur_dev/prev_port->cur_dev). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-01-06ide: use per-port IRQ handlersBartlomiej Zolnierkiewicz
Use hwif instead of hwgroup as {request,free}_irq()'s cookie, teach ide_intr() to return early for non-active serialized ports, modify unexpected_intr() accordingly and then use per-port IRQ handlers instead of per-hwgroup ones. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-01-02ide: move sysfs support to ide-sysfs.cBartlomiej Zolnierkiewicz
While at it: - media_string() -> ide_media_string() There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-12-29ide: move Power Management support to ide-pm.cBartlomiej Zolnierkiewicz
2008-12-29ide: replace the global ide_lock spinlock by per-hwgroup spinlocks (v2)Bartlomiej Zolnierkiewicz
Now that (almost) all host drivers have been fixed not to abuse ide_lock and core code usage of ide_lock has been sanitized we may safely replace ide_lock by per-hwgroup locks. This patch is partially based on earlier patch from Ravikiran G Thirumalai. While at it: - don't use deprecated HWIF() and HWGROUP() macros - update locking documentation in ide.h v2: Add missing spin_lock_init(&hwgroup->lock). (Noticed by Elias Oltmanns) Cc: Vaibhav V. Nivargi <vaibhav.nivargi@gmail.com> Cc: Alok N. Kataria <alokk@calsoftinc.com> Cc: Shai Fultheim <shai@scalex86.org> Signed-off-by: Ravikiran Thirumalai <kiran@scalex86.org> Cc: Elias Oltmanns <eo@nebensachen.de> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-12-29ide: __ide_port_unregister_devices() doesn't need an ide_lock heldBartlomiej Zolnierkiewicz
[ and ide_cfg_mtx mutex provides a sufficient protection for callers ] Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: Implement disk shock protection support (v4)Elias Oltmanns
On user request (through sysfs), the IDLE IMMEDIATE command with UNLOAD FEATURE as specified in ATA-7 is issued to the device and processing of the request queue is stopped thereafter until the specified timeout expires or user space asks to resume normal operation. This is supposed to prevent the heads of a hard drive from accidentally crashing onto the platter when a heavy shock is anticipated (like a falling laptop expected to hit the floor). Port resets are deferred whenever a device on that port is in the parked state. v3: Elias Oltmanns <eo@nebensachen.de> wrote: [...] > >> 1. Make sure that no negative value is being passed to > >> jiffies_to_msecs() in ide_park_show(). > >> 2. Drop the superfluous variable hwif in ide_special_rq(). > >> 3. Skip initialisation of task and tf in ide_special_rq() if we are not > >> handling a (un)park request. > > > > Well, #3 should have been done differently because we donn't want to > > check for REQ_(UN)?PARK_HEADS more often than is necessary. > > While preparing the backport to 2.6.27, it has just occurred to me that > we need to clear the IDE_DFLAG_PARKED flag in ide_disk_pre_reset() > because this flag must not be set after *any* sort of access to the > device. v4: Fix a memory leak due to a missing blk_put_request() in issue_park_cmd(). Additionally, we should plug the queue when enqueueing the unpark request because there is no guarantee that the park timeout has not expired by then. Even though the chance for that to happen is very slim, the request might end up hanging in the queue until the next I/O operation is queued up. While at it, clean up the code a little: - make issue_park_cmd() a function of type void since nobody cares for the return value anyway; - use blk_start_queueing() instead of __blk_run_queue() since we don't have to worry about recursion; - remove a superfluous pointer deference in task_no_data_intr(). Signed-off-by: Elias Oltmanns <eo@nebensachen.de> Cc: Jeff Garzik <jeff@garzik.org>, Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Tejun Heo <htejun@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: switch to DMA-mapping API part #2Bartlomiej Zolnierkiewicz
Follow-up to commit 5c05ff68b9a9b40a9be949497e0aa980185565cf ("ide: switch to DMA-mapping API"): * pci_{alloc,free}_consistent() -> dma_{alloc,free}_coherent() in ide_{allocate,release}_dma_engine(). * Add ->prd_max_nents and ->prd_ent_size fields to ide_hwif_t (+ set default values in ide_allocate_dma_engine()). * Make ide_{allocate,release}_dma_engine() available also for CONFIG_BLK_DEV_IDEDMA_SFF=n. Then convert au1xxx-ide.c, scc_pata.c and sgiioc4.c to use them. * Add missing ->init_dma method to scc_pata. This patch also fixes: - ->dmatable_cpu leak for au1xxx-ide - too early realease of ->dmatable_cpu for scc_pata - wrong amount of ->dmatable_cpu memory being freed for sgiioc4 While at it: - remove superfluous ->dma_base check from ide_unregister() - return -ENOMEM on error in ide_release_dma_engine() - beautify error message in ide_release_dma_engine() Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide-disk: move all ioctl handling to ide-disk_ioctl.cBartlomiej Zolnierkiewicz
While at it: - idedisk_ioctl() -> ide_disk_ioctl() Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: convert 'pio_mode' device setting to use DS_SYNC flagBartlomiej Zolnierkiewicz
* Convert 'pio_mode' device setting to use DS_SYNC flag. * Remove unused special_t.b.{set_tune,serviced} and ide_drive_t.tune_req. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: remove [ata_]select_tBartlomiej Zolnierkiewicz
* Use 'drive->dn & 1' in ide_init_disk(). * remove [ata_]select_t. While at it: * Use ATA_DEVICE_OBS define in ide_port_init_devices_data(). Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: use 'drive->dn & 1' instead of drive->select.b.unitBartlomiej Zolnierkiewicz
* Call ide_port_init_devices() in ide_host_register() also if 'struct ide_port_info *d' is not available. * Init drive->dn in ide_port_init_devices() instead of ide_probe_port() so it is valid also in ->init_dev. * Pass device number to ide_dev_apply_params(). * Use 'drive->dn & 1' instead of drive->select.b.unit. There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: sanitize ide*_pm_* enumsBartlomiej Zolnierkiewicz
* Move ide*_pm_* enums from ide-io.c to <linux/ide.h>. * idedisk_pm_* -> ide_pm_* * ide_pm_state_* -> ide_pm_* * No need to set ide_pm_* enums to the fixed values. * Uppercase ide_pm_* enums. * Fix/update comments. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: add device flagsBartlomiej Zolnierkiewicz
Add 'unsigned long dev_flags' to ide_drive_t and convert bitfields to IDE_DFLAG_* flags. While at it: - IDE_DFLAG_ADDRESSING -> IDE_DFLAG_LBA48 - fixup some comments - remove needless g->flags zeroing from ide*_probe() There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: fix IDE ACPI for slave device-only configurationsBartlomiej Zolnierkiewicz
ACPI _GTM / _PS0 / _STM were not called if only slave device was present. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: Remove ide_spin_wait_hwgroup() and use special requests insteadElias Oltmanns
Use a special request for serialisation purposes and get rid of the awkward ide_spin_wait_hwgroup(). This also involves converting the ide_devset structure so it can be shared by the /proc and the ioctl code. Signed-off-by: Elias Oltmanns <eo@nebensachen.de> [bart: use rq->cmd[] directly] Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: move ioctls handling to ide-ioctls.cBartlomiej Zolnierkiewicz
* Move ioctls handling to ide-ioctls.c (except HDIO_DRIVE_TASKFILE for now). * Make ide_{cmd,task}() static. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: cleanup generic_ide_ioctl()Bartlomiej Zolnierkiewicz
* Fix intendation for the main 'switch ()'. * 'switch ()' -> 'if ()' for HDIO_DRIVE_TASKFILE case. * Move HDIO_SET_NICE case under HDIO_GET_NICE one. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: add ide_setting_ioctl() helperBartlomiej Zolnierkiewicz
* Add struct ide_ioctl_devset representing ioctl device setting. * Add ide_setting_ioctl() helper for matching given ioctl and its parameters against table of ioctl device settings. * Convert ide_setting_ioctl() and idedisk_ioctl() to use ide_setting_ioctl(). * Un-export ide_setting_mtx. While at it: * {get,set}_lba_addressing() -> {get,set}_addressing() There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: remove ->bus_state field from ide_hwif_tBartlomiej Zolnierkiewicz
It is always set to BUSSTATE_ON. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: ide_id_to_hd_driveid() -> ata_id_to_hd_driveid()Bartlomiej Zolnierkiewicz
Rename ide_id_to_hd_driveid() to ata_id_to_hd_driveid() and move it to <linux/ata.h>. Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: factor out HDIO_*_NICE ioctl handling to ide_*_nice_ioctl()Bartlomiej Zolnierkiewicz
Factor out HDIO_{GET,SET}_NICE ioctl handling from generic_ide_ioctl() to ide_{get,set}_nice_ioctl(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: remove ->supports_dsc_overlap field from ide_driver_tBartlomiej Zolnierkiewicz
* Use drive->media and drive->scsi to check if ->dsc_overlap can be set by HDIO_SET_NICE ioctl in generic_ide_ioctl(). * Remove unused ->supports_dsc_overlap field from ide_driver_t. There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: remove read-only ->atapi_overlap field from ide_drive_tBartlomiej Zolnierkiewicz
2008-10-10ide: /proc/ide/hd*/settings reworkBartlomiej Zolnierkiewicz
* Add struct ide_devset, S_* flags, *DEVSET() & ide*_devset_*() macros. * Add 'const struct ide_devset **settings' to ide_driver_t. * Use 'const struct ide_devset **settings' in ide_drive_t instead of 'struct ide_settings_s *settings'. Then convert core code and device drivers to use struct ide_devset and co.: - device settings are no longer allocated dynamically for each device but instead there is an unique struct ide_devset instance per setting - device driver keeps the pointer to the table of pointers to its settings in ide_driver_t.settings - generic settings are kept in ide_generic_setting[] - ide_proc_[un]register_driver(), ide_find_setting_by_name(), ide_{read,write}_setting() and proc_ide_{read,write}_settings() are updated accordingly - ide*_add_settings() are removed * Remove no longer used __ide_add_setting(), ide_add_setting(), __ide_remove_setting() and auto_remove_settings(). * Remove no longer used TYPE_*, SETTING_*, ide_procset_t and ide_settings_t. * ->keep_settings, ->using_dma, ->unmask, ->noflush, ->dsc_overlap, ->nice1, ->addressing, ->wcache and ->nowerr ide_drive_t fields can now be bitfield flags. While at it: * Rename ide_find_setting_by_name() to ide_find_setting(). * Rename write_wcache() to set_wcache(). There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: preparations for /proc/ide/hd*/settings reworkBartlomiej Zolnierkiewicz
After rework settings will be no longer created dynamically for each device so we need to make some fixups first. * Use set_[ksettings,unmaskirq]() as a set function for ["keepsettings","unmaskirq"] setting. * Allow writes to ["io_32bit","unmaskirq"] settings also when drive->no_[io_32bit,unmask] is set (this is checked later inside set_[io_32bit,unmaskirq]() anywyay and keeps consistency with the corresponding HDIO_SET_[32BIT,UNMASKINTR] ioctls). * Use max possible multi sectors value (16) as an allowed max for "multcount" setting. set_multcount() set function checks against device's max possbile value anyway and it makes the proc setting consistent with the corresponding HDIO_SET_MULTCOUNT ioctl. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: include <linux/hdreg.h> only when neededBartlomiej Zolnierkiewicz
* Include <linux/ata.h> directly in <linux/ide.h> instead of through <linux/hdreg.h>. * Include <linux/hdreg.h> only when needed. Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: remove unused _IDE_C and _IDE_DISK definesBartlomiej Zolnierkiewicz
2008-10-10ide: use ATA_* defines instead of *_STAT and *_ERR onesBartlomiej Zolnierkiewicz
* ERR_STAT -> ATA_ERR * INDEX_STAT -> ATA_IDX * ECC_STAT -> ATA_CORR * DRQ_STAT -> ATA_DRQ * SEEK_STAT -> ATA_DSC * WRERR_STAT -> ATA_DF * READY_STAT -> ATA_DRDY * BUSY_STAT -> ATA_BUSY * MARK_ERR -> ATA_AMNF * TRK0_ERR -> ATA_TRK0NF * ABRT_ERR -> ATA_ABORTED * MCR_ERR -> ATA_MCR * ID_ERR -> ATA_IDNF * MC_ERR -> ATA_MC * ECC_ERR -> ATA_UNC * ICRC_ERR -> ATA_ICRC * BBD_ERR -> ATA_BBK Also: * ILI_ERR -> ATAPI_ILI * EOM_ERR -> ATAPI_EOM * LFS_ERR -> ATAPI_LFS * CD -> ATAPI_COD * IO -> ATAPI_IO Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: remove drive->driveidBartlomiej Zolnierkiewicz
* Factor out HDIO_[OBSOLETE,GET]_IDENTITY ioctls handling to ide_get_identity_ioctl(). * Use temporary buffer in ide_get_identity_ioctl() instead of accessing drive->id directly. * Add ide_id_to_hd_driveid() inline to convert raw id into struct hd_driveid format (needed on big-endian). * Use ide_id_to_hd_driveid() in ide_get_identity_ioctl(), cleanup ide_fix_driveid() and switch ide to use use raw id. * Remove no longer needed drive->driveid. This leaves us with 3 users of struct hd_driveid in tree: - arch/um/drivers/ubd_kern.c - drivers/block/xsysace.c - drivers/usb/storage/isd200.c While at it: * Use ata_id_u{32,64}() and ata_id_has_{dma,lba,iordy}() macros. There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: make drive->id an union (take 2)Bartlomiej Zolnierkiewicz
Make drive->id an unnamed union so id can be accessed either by using 'u16 *id' or 'struct hd_driveid *driveid'. Then convert all existing drive->id users accordingly (using 'u16 *id' when possible). This is an intermediate step to make ide 'struct hd_driveid'-free. While at it: - Add missing KERN_CONTs in it821x.c. - Use ATA_ID_WORDS and ATA_ID_*_LEN defines. - Remove unnecessary checks for drive->id. - s/drive_table/table/ in ide_in_drive_list(). - Cleanup ide_config_drive_speed() a bit. - s/drive1/dev1/ & s/drive0/dev0/ in ide_undecoded_slave(). v2: Fix typo in drivers/ide/ppc/pmac.c. (From Stephen Rothwell) There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-24ide: add ide_device_{get,put}() helpersBartlomiej Zolnierkiewicz
* Add 'struct ide_host *host' field to ide_hwif_t and set it in ide_host_alloc_all(). * Add ide_device_{get,put}() helpers loosely based on SCSI's scsi_device_{get,put}() ones. * Convert IDE device drivers to use ide_device_{get,put}(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-23ide: small whitespace fixesPavel Machek
Small whitespace fixes for drivers/ide. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-23ide: allocate ide_hwif_t instances dynamicallyBartlomiej Zolnierkiewicz
* Allocate ide_hwif_t instances dynamically and remove ide_hwifs[]. This cuts almost ~14kB from ide-probe.o (x86-32, MAX_HWIFS == 10): text data bss dec hex filename 9140 40 14084 23264 5ae0 drivers/ide/ide-probe.o.before 9169 40 44 9253 2425 drivers/ide/ide-probe.o.after * Remove no longer needed ide_init_port_data() call from ide_unregister(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-23ide: move ide_remove_port_from_hwgroup() to ide-probe.cBartlomiej Zolnierkiewicz
2008-07-23ide: add struct ide_host (take 3)Bartlomiej Zolnierkiewicz
* Add struct ide_host which keeps pointers to host's ports. * Add ide_host_alloc[_all]() and ide_host_remove() helpers. * Pass 'struct ide_host *host' instead of 'u8 *idx' to ide_device_add[_all]() and rename it to ide_host_register[_all](). * Convert host drivers and core code to use struct ide_host. * Remove no longer needed ide_find_port(). * Make ide_find_port_slot() static. * Unexport ide_unregister(). v2: * Add missing 'struct ide_host *host' to macide.c. v3: * Fix build problem in pmac.c (s/ide_alloc_host/ide_host_alloc/) (Noticed by Stephen Rothwell). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-23ide: add struct ide_tp_ops (take 2)Bartlomiej Zolnierkiewicz
* Add struct ide_tp_ops for transport methods. * Add 'const struct ide_tp_ops *tp_ops' to struct ide_port_info and ide_hwif_t. * Set the default hwif->tp_ops in ide_init_port_data(). * Set host driver specific hwif->tp_ops in ide_init_port(). * Export ide_exec_command(), ide_read_status(), ide_read_altstatus(), ide_read_sff_dma_status(), ide_set_irq(), ide_tf_{load,read}() and ata_{in,out}put_data(). * Convert host drivers and core code to use struct ide_tp_ops. * Remove no longer needed default_hwif_transport(). * Cleanup ide_hwif_t from methods that are now in struct ide_tp_ops. While at it: * Use struct ide_port_info in falconide.c and q40ide.c. * Rename ata_{in,out}put_data() to ide_{in,out}put_data(). v2: * Fix missing convertion in ns87415.c. There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-23ide: add 'config' field to hw_regs_tBartlomiej Zolnierkiewicz
Add 'config' field to hw_regs_t and use it to set hwif->config_data in ide_init_port_hw(), then convert ide_legacy_init_one() to use hw->config. There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-23ide: remove ->INB, ->OUTB and ->OUTBSYNC methodsBartlomiej Zolnierkiewicz
* Remove no longer needed ->INB, ->OUTB and ->OUTBSYNC methods. Then: * Remove no longer used default_hwif_[mm]iops() and ide_[mm_]outbsync(). * Cleanup SuperIO handling in ns87415.c. There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
