path: root/drivers/ide/it8172.c
2010-01-19ide: change ->set_dma_mode method parametersBartlomiej Zolnierkiewicz
Change ->set_dma_mode method parameters to match ->set_dmamode method used in struct ata_port_operations. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2010-01-19ide: change ->set_pio_mode method parametersBartlomiej Zolnierkiewicz
Change ->set_pio_mode method parameters to match ->set_piomode method used in struct ata_port_operations. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-15ide: IORDY handling fixesBartlomiej Zolnierkiewicz
Add ide_pio_need_iordy() helper and convert host drivers to use it. This fixes it8172, it8213, pdc202xx_old, piix, slc90e66 and siimage host drivers to handle IORDY correctly. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-01-06Resurrect IT8172 IDE controller driverShane McDonald
Support for the IT8172 IDE controller was removed from the kernel sometime after 2.6.18. Support for the only boards that used the IT8172 was removed from the kernel after 2.6.18, as they had never compiled since 2.6.0. However, there are a couple of platforms that use this chip: the PMC-Sierra Xiao Hu thin-client computer, which is no longer in production, and the Linksys NSS4000 Network Attached Storage box, which is based on the Xiao Hu board. I am attempting to add support for the Xiao Hu to the kernel, and this IT8172 IDE controller is the first bit of code in this effort. This patch resurrects the IT8172 IDE controller code. I began with the 2.6.18 version of the it8172.c file, and have moved it forward so that it works with the latest version of the kernel. I have run this driver on a PMC-Sierra Xiao Hu board with the 2.6.28 kernel, and I have had no problems with it in my configuration. The attached patch applies cleanly against 2.6.28. Signed-off-by: Shane McDonald <mcdonald.shane@gmail.com> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: alan@lxorguk.ukuu.org.uk [bart: s/HWIF(drive)/drive->hwif/] Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
