path: root/drivers/ide/pdc202xx_new.c
2010-01-19ide: change ->set_dma_mode method parametersBartlomiej Zolnierkiewicz
Change ->set_dma_mode method parameters to match ->set_dmamode method used in struct ata_port_operations. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2010-01-19ide: change ->set_pio_mode method parametersBartlomiej Zolnierkiewicz
Change ->set_pio_mode method parameters to match ->set_piomode method used in struct ata_port_operations. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-07ide: respect quirk_drives[] list on all controllersBartlomiej Zolnierkiewicz
* Add ide_check_nien_quirk_list() helper to the core code and then use it in ide_port_tune_devices(). * Remove no longer needed ->quirkproc methods from hpt366.c and pdc202xx_{new,old}.c. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-24ide: fix ->init_chipset method to return 'int' valueBartlomiej Zolnierkiewicz
* Return 0 instead of dev->irq in ->init_chipset implementations. * Fix ->init_chipset method to return 'int' value instead of 'unsigned int' one. This fixes ->init_chipset handling for host drivers (cs5530, hpt366 and pdc202xx_new) for which it is possible for this method to fail. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-01-06ide: remove HWIF() macroBartlomiej Zolnierkiewicz
2008-10-21ide: remove useless subdirs from drivers/ide/Bartlomiej Zolnierkiewicz
Suggested-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
