path: root/drivers/ide/qd65xx.c
2010-01-19ide: change ->set_pio_mode method parametersBartlomiej Zolnierkiewicz
Change ->set_pio_mode method parameters to match ->set_piomode method used in struct ata_port_operations. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-15ide: do not access ide_drive_t 'drive_data' field directlyJoao Ramos
Change ide_drive_t 'drive_data' field from 'unsigned int' type to 'void *' type, allowing a wider range of values/types to be stored in this field. Added 'ide_get_drivedata' and 'ide_set_drivedata' helpers to get and set the 'drive_data' field. Fixed all host drivers to maintain coherency with the change in the 'drive_data' field type. Signed-off-by: Joao Ramos <joao.ramos@inov.pt> [bart: fix qd65xx build, cast to 'unsigned long', minor Coding Style fixups] Acked-by: Sergei Shtylyov <sshtylyov@ru.montavista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-31ide: turn selectproc() method into dev_select() method (take 5)Sergei Shtylyov
Turn selectproc() method into dev_select() method by teaching it to write to the device register and moving it from 'struct ide_port_ops' to 'struct ide_tp_ops'. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: benh@kernel.crashing.org Cc: petkovbb@gmail.com [bart: add ->dev_select to at91_ide.c and tx4939.c (__BIG_ENDIAN case)] Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-02-03Fix my email address in qd65xx.[ch]/pata_qdi.cSamuel Thibault
The @fnac.net will be shut down within a couple of months, so fix my email address. Signed-off-by: Samuel Thibault <samuel.thibault@ens-lyon.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06ide: remove HWIF() macroBartlomiej Zolnierkiewicz
2008-10-21ide: remove useless subdirs from drivers/ide/Bartlomiej Zolnierkiewicz
Suggested-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
