path: root/drivers/ide
2007-09-17ide: remove unused variables from drivers/ide/ppc/pmac.cStephen Rothwell
Removes these warnings: /home/sfr/kernels/linus/drivers/ide/ppc/pmac.c: In function 'pmac_ide_dma_check': /home/sfr/kernels/linus/drivers/ide/ppc/pmac.c:1807: warning: unused variable 'map' /home/sfr/kernels/linus/drivers/ide/ppc/pmac.c:1805: warning: unused variable 'pmif' Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: paulus@samba.org Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-09-17ide: ST320413A has the same problem as ST340823AJorge Juan Chico
ST320413A has the same problem as ST340823A. Please see https://bugs.launchpad.net/ubuntu/+source/linux-source-2.6.15/+bug/26119 From: "Jorge Juan Chico" <jjchico@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-09-11pdc202xx_new: PLL detection fixMikael Pettersson
Fix a bitmask typo in the pdc202xx_new PLL frequency detection code which causes it to truncate an intermediate difference to 26 bits instead of the correct 30 bits (the PLL's bitwidth). Signed-off-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-09-11via82cxxx: add Arima W730-K8 and other rebadgings to short cables listBartlomiej Zolnierkiewicz
Port of Alan's patch for pata_via.c. Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-09-11pmac: build fixTony Breeds
Ensure that BLK_DEV_IDE is built-in before allowing BLK_DEV_IDE_PMAC to be selected. Signed-off-by: Tony Breeds <tony@bakeyournoodle.com> Cc: Bret Towe <magnade@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-09-11pata_ali/alim15x3: override 80-wire cable detection for Toshiba S1800-814Daniel Exner
Add Toshiba S1800-814 to whitelist for both pata_ali and alim15x3, as it is correctly detected as 40-wire connected but this cable is short enough to still use transfer modes higher than UDMA33. Signed-off-by: Daniel Exner <dex@dragonslave.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-09-11hpt366: UltraDMA filter for SATA cards (take 2)Sergei Shtylyov
The Marvell bridge chips used on HighPoint SATA cards do not seem to support the UltraDMA modes 1, 2, and 3 as well as any MWDMA modes, so the driver needs to account for this in the udma_filter() method. In order to achieve that, do the following changes: - install the method for all chips, not only HPT36x/370 and improve the code formatting by killing the extra tabs while at it; - add to the end of the 'switch' statement in the method cases for HPT372[AN] and HPT374 chips upon which the known SATA cards are based; - use hwif->ultra_mask as a default mask for the ide_dma_filter() method to behave correctly; - move the HPT370[A] cases below the HPT36x case for consistency. While at it, replace the explicit UltraDMA mode masks with ATA_UDMA* constants all over the driver... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Bob Ham <rah@bash.sh> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-09-11ide: add ide_dev_is_sata() helper (take 2)Sergei Shtylyov
Make the SATA drive detection code from eighty_ninty_three() into inline ide_dev_is_sata() helper fixing it along the way to be more strict while checking word 80 for the reserved values... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-09-11hpt366: fix PCI clock detection for HPT374 (take 4)Sergei Shtylyov
HPT374 BIOS seems to only save f_CNT register value for the function #0 before re-tuning DPLL (that causes the driver to report obviously distorted f_CNT for the function #1) -- fix this by always reading the saved f_CNT register value from the function #0 in the driver's init_chipset() method. While at it, introduce 'chip_type' for holding the 'struct hpt_info' field of the same name and replace the structure assignment with memcpy()... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-09-11pdc202xx_new: fix PCI refcountingSergei Shtylyov
The driver erroneously "lets go" the mate IDE chip in init_setup_pdc20270() when ide_setup_pci_devices() call succeeds -- fix this, and drop a couple of useless assignments in this function while at it... Bart: keep "findev" variable initialization to silence gcc Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-09-11ide: fix PCI refcountingSergei Shtylyov
The IDE core never marked the PCI IDE devices as being in use after succesfull driver probe call (the devices were marked in use only while being probed), and so was susceptible to issues caused by unsolicited PCI hotplug device removal. So, add pci_dev_get() call to ide_scan_pcidev() and convert this function to the kernel style, also dropping a bunch of useless curly braces from its caller, ide_scan_pcibus() and somewhat beautifying printk() call there, while at it... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-09-11mpc8xx: Only build mpc8xx on arch/ppcKumar Gala
Currently the mpc8xx ide driver will only work on arch/ppc so only allow it to be built there. Also, killed a minor include that isn't actually used by the driver. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-09-10[libata, IDE] add new VIA bridge to VIA PATA driversJoseph Chan
Signed-off-by: Joseph Chan <josephchan@via.com.tw> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-08-20ide-disk: workaround for buggy HPA support on ST340823A (take 3)Bartlomiej Zolnierkiewicz
This disk reports total number of sectors instead of maximum sector address in response to READ_NATIVE_MAX_ADDRESS command and also happily accepts SET_MAX_ADDRESS command with the bogus value. This results in +1 sector capacity being used and errors on attempts to use the last sector. ... hdd: Host Protected Area detected.         current capacity is 78165360 sectors (40020 MB)         native  capacity is 78165361 sectors (40020 MB) hdd: Host Protected Area disabled. ... hdd: reading: block=78165360, sectors=1, buffer=0xc1e63000 hdd: dma_intr: status=0x51 { DriveReady SeekComplete Error } hdd: dma_intr: error=0x10 { SectorIdNotFound }, LBAsect=78165360, sector=78165360 ... Add hpa_list[] table and workaround the issue in idedisk_check_hpa(). v2: * Add missing export and improve patch description a bit. v3: * Add list termination. (From Mikko) Fixes kernel bugzilla bug #8816. Thanks to Mikko for investigating the issue and helping with this patch. Cc: Mikko Rapeli <mikko.rapeli@iki.fi> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-08-20hpt34x: fix CONFIG_HPT34X_AUTODMA=n handlingBartlomiej Zolnierkiewicz
Programming DMA mode may destroy current PIO mode setting so if CONFIG_HPT34X_AUTODMA=n (the default case) make ide_tune_dma() fail early by disabling all host DMA masks and re-tune PIO mode. This fix doesn't help with the driver being broken but is needed for some other changes. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-08-20triflex: add missing ->dma_base checkBartlomiej Zolnierkiewicz
If ->dma_base is not set (== PCI BAR4 cannot be reserved) then DMA hooks shouldn't be initialized or bad things will happen. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-08-20pdc202xx_old: add missing ->dma_base checkBartlomiej Zolnierkiewicz
2007-08-20pdc202xx_new: add missing ->dma_base checkBartlomiej Zolnierkiewicz
If ->dma_base is not set (== PCI BAR4 cannot be reserved) then DMA hooks shouldn't be initialized or bad things will happen. Also this host driver requires valid PCI BAR4 for normal operation so check it in ->init_chipset and fail initialization if not set. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-08-20cs5530: add missing ->dma_base checkBartlomiej Zolnierkiewicz
2007-08-20ide: ide_config_drive_speed() bugfixesBartlomiej Zolnierkiewicz
* Use ->OUTBSYNC instead of ->OUTB when writing command register (needed for scc_pata and pmac host drivers). * Don't check DRDY bit of the status register on ATAPI devices (ATAPI devices are free to ignore DRDY bit). Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Kou Ishizaki <kou.ishizaki@toshiba.co.jp> Cc: Akira Iguchi <akira2.iguchi@toshiba.co.jp> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-08-20ide: add cable detection for early UDMA66 devices (take 3)Bartlomiej Zolnierkiewicz
* Move ide_in_drive_list() from ide-dma.c to ide-iops.c. * Add ivb_list[] table for listening early UDMA66 devices which don't conform to ATA4 standard wrt cable detection (bit14 is zero, only bit13 is valid) and use only device side cable detection for them since host side cable detection may be unreliable. * Add model "QUANTUM FIREBALLlct10 05" with firwmare "A03.0900" to the list (from Craig's bugreport). v2: * Improve kernel message basing on suggestion from Sergei. v3: * Don't print kernel message when no device side cable detection is done, plus some minor fixes. (Noticed by Sergei) Thanks to Craig for testing this patch. Cc: Craig Block <chblock3@yahoo.com> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-08-20ide-pmac: fix drive->init_speed reportingBartlomiej Zolnierkiewicz
pmac_ide_tune_chipset() don't set drive->init_speed. Fix it by setting drive->{current,init}_speed in pmac_ide_do_setfeature() and clean up pmac_ide_{tune_chipset,mdma_enable,udma_enable}(). Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-08-20ide: config_drive_for_dma() fixesBartlomiej Zolnierkiewicz
* Add DMA blacklist checking (->ide_dma_on check probably can go now). * Add ->atapi_dma flag checking and remove no longer needed ns87415_ide_dma_check() from ns87415 host driver. * Remove now needless __ide_dma_check() wrapper and symbol export. * Check drive->autodma instead of hwif->autodma (there should be no changes in behavior as all users of config_drive_for_dma() set both ->autodma flags). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-08-20ide-cris: fix ->set_pio_mode method to set transfer mode on the deviceBartlomiej Zolnierkiewicz
2007-08-20ide: fix hidden dependencies on CONFIG_IDE_GENERICBartlomiej Zolnierkiewicz
Some host drivers depend on CONFIG_IDE_GENERIC to do the probing but their config options lack explicit dependencies on IDE_GENERIC. In the long-term these host drivers should be fixed to do the probing themselves but for now fix them by making their config options select CONFIG_IDE_GENERIC. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-08-20ide: make CONFIG_IDE_GENERIC default to NTejun Heo
These days, CONFIG_IDE_GENERIC causes more confusion and misconfiguration than it helps. Especially so because libata is linked after the generic driver. Default to N. Signed-off-by: Tejun Heo <htejun@gmail.com> Acked-by: Jeff Garzik <jeff@garzik.org> Cc: "P.C.Chan" <pc.chan@alcatel-lucent.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-08-01scc_pata: PIO fixesBartlomiej Zolnierkiewicz
* Use pio == 255 == "auto-tune" in scc_config_drive_for_dma() instead of forcing PIO4 on PIO fallback. Fix comment while at it. * Rename scc_tuneproc() to scc_tune_pio() and add scc_tuneproc() wrapper. Move finding of the best PIO mode and setting of transfer mode on the device to the new wrapper. * Fix scc_tune_chipset() to tune PIO modes. Do a small cleanup while at it. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-08-01piix/slc90e66: fix PIO1 handling in ->speedproc method (take 2)Bartlomiej Zolnierkiewicz
* Don't call {piix,slc90e66}_dma_2_pio() for PIO modes in {piix,slc90e66}_tune_chipset(). * Add PIO1 handling to {piix,slc90e66}_tune_chipset(). * Bump driver version. v2: * Remove PIO modes from {piix,slc90e66}_dma_2_pio(), they are no longer needed there (Noticed by Sergei) Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-08-01jmicron: PIO fixesBartlomiej Zolnierkiewicz
* Set transfer mode on the device in jmicron_tuneproc(), also add pio == 255 == "auto-tune" handling. * Use jmicron_tuneproc() in jmicron_config_drive_for_dma(). * Remove no longer needed config_jmicron_chipset_for_pio(). Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-08-01it8213: PIO fixes (take 2)Bartlomiej Zolnierkiewicz
* Rename it8213_tuneproc() to it8213_tune_pio() and add it8213_tuneproc() wrapper. Move finding of the best PIO mode to the new wrapper. * Add setting of transfer mode on the device to it8213_tuneproc(). * Don't call it8213_dma_2_pio() for PIO modes in it8213_tune_chipset(). * Use it8213_tuneproc() in it8213_config_drive_for_dma(). v2: * Remove PIO modes from it8213_dma_2_pio(), they are no longer needed there (Noticed by Sergei) Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-08-01cs5535: PIO fixesBartlomiej Zolnierkiewicz
* Fix cs5535_tuneproc() to pass PIO transfer mode value instead of PIO mode number to cs5535_set_speed() (fixes random PIO timings being programmed and a possible OOPS). Do a little cleanup while at it. * Fix cs5535_set_speed() to check if the mate device is present (fixes PIO0 taskfile timings being used if there is no other device on the cable). * Use cs5535_tuneproc() in cs5535_dma_check(). The old code had the same issue as cs5535_tuneproc() and add additionally caused 0x00-0x04 transfer mode values (== default PIO, default PIO w/ IORDY + two invalid values) being set on the device instead of values 0x08-0x0c (XFER_PIO_[0,4]). Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-08-01cs5520: fix PIO auto-tuning in ->ide_dma_check methodBartlomiej Zolnierkiewicz
2007-08-01drivers/ide/arm/icside.c: kmalloc + memset conversion to kzallocMariusz Kozlowski
Is this a bug? In original verison memset cleared sizeof(state) bytes instead of sizeof(*state). If it was intentional then this patch is invalid. If not intentional -> valid :) Please review. Bart: Yes, it is a bug so this patch is a valid bugfix. :-) drivers/ide/arm/icside.c | 18883 -> 18849 (-34 bytes) Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-08-01ide: eliminate warnings in ide-tape.cStephen Rothwell
drivers/ide/ide-tape.c: In function '__idetape_kmalloc_stage': drivers/ide/ide-tape.c:2588: warning: large integer implicitly truncated to unsigned type drivers/ide/ide-tape.c:2616: warning: large integer implicitly truncated to unsigned type b_size in struct idetape_bh is an unsigned short. We sometimes assigne PAGE_SIZE to it and PAGE_SIZE can be 64K or larger, so make it a u32. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-08-01ide: fix runtogether printk's in cmd64x IDE driverMeelis Roos
Fix a couple of runtogether printks in cmd64x.c IDE driver by adding proper newlines. Signed-off-by: Meelis Roos <mroos@linux.ee> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-08-01sis5513: Add FSC Amilo A1630 PCI subvendor/dev to laptopsDavid Lamparter
Recognise the FSC Amilo A1630's incarnation of a SiS5513 chip as laptop to get UDMA100 support. Signed-off-by: David Lamparter <equinox@diac24.net> Cc: Lionel Bouton <Lionel.Bouton@inet6.fr> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-08-01alim15x3: Correct HP detectBartlomiej Zolnierkiewicz
Direct port of Alan's fix for pata_ali. Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-08-01ide: Fix an overrun found in the CS5535 IDE driverJordan Crouse
As found by the Coverity checker, and reported by Adrian Bunk, this fixes a overrun error in the CS5535 IDE driver. Somebody got a little excited with the if() statement - the CS5535 only supports UDMA 0-4. Bart: Not a bug per se since the upper layer will never feed this function with speed > XFER_UDMA_4 (thanks to ->ultra_mask being set to 0x1f). Worth fixing anyway. Signed-off-by: Jordan Crouse <jordan.crouse@amd.com> Cc: Adrian Bunk <bunk@stusta.de> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-07-31Remove the arm26 portAdrian Bunk
The arm26 port has been in a state where it was far from even compiling for quite some time. Ian Molton agreed with the removal. Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Ian Molton <spyro@f2s.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-26drivers/ misc __iomem annotationsAl Viro
2007-07-24[BLOCK] Get rid of request_queue_t typedefJens Axboe
Some of the code has been gradually transitioned to using the proper struct request_queue, but there's lots left. So do a full sweet of the kernel and get rid of this typedef and replace its uses with the proper type. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-20m68k: missing exportsAl Viro
2007-07-20ide: add support for SCSI ioctls to ide-floppyBartlomiej Zolnierkiewicz
Now that ide-floppy supports SG_IO we can add support for SCSI ioctls (except deprecated SCSI_IOCTL_SEND_COMMAND and legacy CDROM_SEND_PACKET ones - we can add them later iff really needed). While at it remove handling of CDROMEJECT and CDROMCLOSETRAY ioctls from generic_ide_ioctl(): - This prevents ide-{disk,tape,scsi} device drivers from obtaining REQ_TYPE_BLOCK_PC type requests which are currently unsupported by these drivers and which are potentially harmful (as reported by Andrew). - There is no functionality loss since aforementioned ioctls will now be handled by idefloppy_ioctl()->scsi_cmd_ioctl() (for devices using ide-floppy driver) and by idecd_ioctl->cdrom_ioctl()->scsi_cmd_ioctl() (for devices using ide-cd driver). Cc: Jens Axboe <jens.axboe@oracle.com> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Jeff Garzik <jeff@garzik.org> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-07-20ide: remove stale changelog from setup-pci.cBartlomiej Zolnierkiewicz
2007-07-20ide: remove stale changelog/comments/TODO from ide.cBartlomiej Zolnierkiewicz
2007-07-20ide-cris: handle PIO auto-tuning in tune_cris_ide()Bartlomiej Zolnierkiewicz
2007-07-20ide: add PIO masksBartlomiej Zolnierkiewicz
* Add ATA_PIO[0-6] defines to <linux/ata.h>. * Add ->pio_mask field to ide_pci_device_t and ide_hwif_t. * Add PIO masks to host drivers. <linux/ata.h> change ACK-ed by Jeff Garzik <jeff@garzik.org>. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-07-20ide: remove ide_find_best_pio_mode()Bartlomiej Zolnierkiewicz
* Add ->host_flags to ide_hwif_t to store ide_pci_device_t.host_flags, assign it in setup-pci.c:ide_pci_setup_ports(). * Add IDE_HFLAG_PIO_NO_{BLACKLIST,DOWNGRADE} to ide_pci_device_t.host_flags and teach ide_get_best_pio_mode() about them. Also remove needless !drive->id check while at it (drive->id is always present). * Convert amd74xx, via82cxxx and ide-timing.h to use ide_get_best_pio_mode() and then remove no longer needed ide_find_best_pio_mode(). There should be no functionality changes caused by this patch. Acked-by: Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-07-20ide: drop "PIO data" argument from ide_get_best_pio_mode()Bartlomiej Zolnierkiewicz
* Drop no longer needed "PIO data" argument from ide_get_best_pio_mode() and convert all users accordingly. * Remove no longer needed ide_pio_data_t. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-07-20ide: ide_find_best_pio_mode() fixes (take 2)Bartlomiej Zolnierkiewicz
* Check IORDY bit for PIO modes > 2. * Some devices claim maximum PIO mode > 2 in id->tPIO, they were punished too severly for this by being limited to PIO_SLOW. Limit them to PIO2 instead. v2: * Fix PIO number being returned incorrectly instead of PIO mode (Noticed by Sergei). Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
