path: root/drivers/idle/i7300_idle.c
2009-09-08ioat: switch watchdog and reset handler from workqueue to timerDan Williams
In order to support dynamic resizing of the descriptor ring or polling for a descriptor in the presence of a hung channel the reset handler needs to make progress while in a non-preemptible context. The current workqueue implementation precludes polling channel reset completion under spin_lock(). This conversion also allows us to return to opportunistic cleanup in the ioat2 case as the timer implementation guarantees at least one cleanup after every descriptor is submitted. This means the worst case completion latency becomes the timer frequency (for exceptional circumstances), but with the benefit of avoiding busy waiting when the lock is contended. Signed-off-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-07-28ioat: move to drivers/dma/ioat/Dan Williams
When first created the ioat driver was the only inhabitant of drivers/dma/. Now, it is the only multi-file (more than a .c and a .h) driver in the directory. Moving it to an ioat/ subdirectory allows the naming convention to be cleaned up, and allows for future splitting of the source files by hardware version (v1, v2, and v3). Signed-off-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-05-28i7300_idle: allow testing on i5000-series hardware w/o re-compileLen Brown
Testing the i7300_idle driver on i5000-series hardware required an edit to i7300_idle.h to "#define SUPPORT_I5000 1" and a re-build of both i7300_idle and ioat_dma. Replace that build-time scheme with a load-time module parameter: "7300_idle.forceload=1" to make it easier to test the driver on hardware that while not officially validated, works fine and is much more commonly available. By default (no modparam) the driver will continue to load only on the i7300. Note that ioat_dma runs a copy of i7300_idle's probe routine to know to reserve an IOAT channel for i7300_idle. This change makes ioat_dma do that always on the i5000, just like it does on the i7300. Signed-off-by: Len Brown <len.brown@intel.com> Acked-by: Andrew Henroid <andrew.d.henroid@intel.com>
2009-04-07dma-mapping: replace all DMA_64BIT_MASK macro with DMA_BIT_MASK(64)Yang Hongyang
Replace all DMA_64BIT_MASK macro with DMA_BIT_MASK(64) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06i7300_idle: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
CC: Andy Henroid <andrew.d.henroid@intel.com> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-24i7300_idle: Cleanup based review commentsVenki Pallipadi
Cleanup of i7300 idle driver based on review comments from Randy Dunlap, Andi Kleen and Len Brown. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-24i7300_idle: Disable ioat channel only on platforms where ile driver can loadVenki Pallipadi
Based on input from Andi Kleen: share the platform detection code with ioat_dma and disable the channel in dma engine only for specific platforms. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-21i7300_idle driver v1.55Andy Henroid
The Intel 7300 Memory Controller supports dynamic throttling of memory which can be used to save power when system is idle. This driver does the memory throttling when all CPUs are idle on such a system. Refer to "Intel 7300 Memory Controller Hub (MCH)" datasheet for the config space description. Signed-off-by: Andy Henroid <andrew.d.henroid@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
