path: root/drivers/ieee802154
2011-06-30IEEE 802.15.4: do not enable driver debugging by defaultWerner Almesberger
The IEEE 802.15.4 drivers were compiled by default with debugging, which caused them to be rather chatty and slow. This patch silences them. People debugging drivers can still add a #define DEBUG in the beginning of the respective file or use dynamic debug This patch also removes the now unused option CONFIG_FFD. Signed-off-by: Werner Almesberger <werner@almesberger.net> Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
2011-06-30fakehard: stop setting platform_data as it's unused anymoreDmitry Eremin-Solenikov
Previously dev.platform_data was used to store a pointer to net device. Now this code was gone. Drop it. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
2011-05-05net: call dev_alloc_name from register_netdeviceJiri Pirko
Force dev_alloc_name() to be called from register_netdevice() by dev_get_valid_name(). That allows to remove multiple explicit dev_alloc_name() calls. The possibility to call dev_alloc_name in advance remains. This also fixes veth creation regresion caused by 84c49d8c3e4abefb0a41a77b25aa37ebe8d6b743 Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-17ieee802154: change to new flag variablematt mooney
Replace EXTRA_CFLAGS with ccflags-y. Signed-off-by: matt mooney <mfm@muteddisk.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Acked-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-12-02ieee802154: merge cleanupEric Dumazet
A small cleanup after last net-2.6 merge into net-next-2.6 As we are going to free skb, no need to set skb->skb_iif or skb->dev Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-29Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/ieee802154/fakehard.c drivers/net/e1000e/ich8lan.c drivers/net/e1000e/phy.c drivers/net/netxen/netxen_nic_init.c drivers/net/wireless/ath/ath9k/main.c
2009-11-20net: rename skb->iif to skb->skb_iifEric Dumazet
To help grep games, rename iif to skb_iif Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-19ieee802154: dont leak skbs in ieee802154_fake_xmit()Eric Dumazet
ieee802154_fake_xmit() should free skbs since it returns NETDEV_TX_OK Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-06fakehard: mlme_ops->get_phy implementationDmitry Eremin-Solenikov
2009-11-06fakehard: claim all 2.4 Ghz channels as supportedDmitry Eremin-Solenikov
Make fakehard device claim all 2.4 Ghz channels from 802.15.4-2006, 802.15.4a-2007 as supported by the hw. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
2009-11-06fakehard: no need to export net_to_phy, make it staticDmitry Eremin-Solenikov
2009-11-06ieee802154: constify struct net_device in some operationsDmitry Eremin-Solenikov
Some of ieee802154 operations really shouldn't change passed net_device. Constify passed argument. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
2009-11-06wpan-phy: follow usual patter of devices registrationDmitry Eremin-Solenikov
Follow the usual pattern of devices registration by adding new function (wpan_phy_set_dev) that sets child->parent relationship and removing parent argument from wpan_phy_register call. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
2009-11-06wpan-phy: allow specifying a per-page channel maskDmitry Eremin-Solenikov
IEEE 802.15.4-2006 defines channel pages that hold channels (max 32 pages, 27 channels per page). Allow the driver to specify supported channels on pages, other than the first one. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
2009-09-01netdev: convert bulk of drivers to netdev_tx_tStephen Hemminger
In a couple of cases collapse some extra code like: int retval = NETDEV_TX_OK; ... return retval; into return NETDEV_TX_OK; Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-19ieee802154: add support for channel pages from IEEE 802.15.4-2006Dmitry Eremin-Solenikov
IEEE 802.15.4-2006 adds new concept: channel pages, which can contain several channels. Add support for channel pages in the API and in the fakehard driver. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
2009-08-19fakehard: add binding to wpan-phy deviceDmitry Eremin-Solenikov
Make fakehard create and maintain wpan-phy node, thus representing it's phy in the sysfs. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
2009-08-12fakehard: use START-CONFIRM primitive to report START failureDmitry Baryshkov
Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-27Merge branch 'for-linus' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/lowpan/lowpan
2009-07-23ieee802154: move headers out of extra directoryDmitry Eremin-Solenikov
include/net/ieee802154/af_ieee802154.h (and others) naming seems to be too long and redundant. Drop one level of subdirectories. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
2009-07-23IEEE80154: Add documentation to the IEEE80154 netlink and fakehard driverDaniel Silverstone
This adds some perfunctory documentation comments to the IEEE 802.15.4 fakehard.c driver (Fake hard MAC) and the nl802154.h (outgoing netlink messages) header. These comments are not necessarily complete, but they do reference the IEEE 802.15.4-2006 document where possible. Signed-off-by: Daniel Silverstone <dsilvers@simtec.co.uk>
2009-07-05net: use NETDEV_TX_OK instead of 0 in ndo_start_xmit() functionsPatrick McHardy
This patch is the result of an automatic spatch transformation to convert all ndo_start_xmit() return values of 0 to NETDEV_TX_OK. Some occurences are missed by the automatic conversion, those will be handled in a seperate patch. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-13ieee802154: fix kconfig bool/tristate muckupRandy Dunlap
menuconfig IEEE802154_DRIVERS is a bool that depends on tristate IEEE802154. If the IEEE802154 symbol is 'm', the bool becomes 'y'. This allows tristate symbols under IEEE802154_DRIVERS to be configured as 'y' and cause build problems. Changing the menuconfig bool to a tristate fixes this. drivers/built-in.o: In function `fake_scan_req': fakehard.c:(.text+0x46d625): undefined reference to `ieee802154_nl_scan_confirm' drivers/built-in.o: In function `fake_disassoc_req': fakehard.c:(.text+0x46d66f): undefined reference to `ieee802154_nl_disassoc_confirm' drivers/built-in.o: In function `fake_assoc_req': fakehard.c:(.text+0x46d6be): undefined reference to `ieee802154_nl_assoc_confirm' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Sergey Lapin <slapin@ossfans.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-09ieee802154: add simple HardMAC driver sampleSergey Lapin
fakehard is a really simple driver implementing only necessary callbacks and serves the role of an example of driver for HardMAC IEEE 802.15.4 device. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Sergey Lapin <slapin@ossfans.org> Signed-off-by: David S. Miller <davem@davemloft.net>
